| 1 |
#ifndef lint
| 2 |
static const char RCSid[] = "$Id: rhpict2.c,v 3.17 2018/10/05 19:19:16 greg Exp $";
| 3 |
#endif
| 4 |
| 5 |
* Rendering routines for rhpict.
| 6 |
| 7 |
| 8 |
#include <string.h>
| 9 |
| 10 |
#include "holo.h"
| 11 |
#include "view.h"
| 12 |
#include "random.h"
| 13 |
| 14 |
#ifndef DEPS
| 15 |
#define DEPS 0.02 /* depth epsilon */
| 16 |
#endif
| 17 |
#ifndef PEPS
| 18 |
#define PEPS 0.04 /* pixel value epsilon */
| 19 |
#endif
| 20 |
#ifndef MAXRAD
| 21 |
#define MAXRAD 64 /* maximum kernel radius */
| 22 |
#endif
| 23 |
#ifndef NNEIGH
| 24 |
#define NNEIGH 5 /* find this many neighbors */
| 25 |
#endif
| 26 |
| 27 |
#define NINF 16382
| 28 |
| 29 |
#define MAXRAD2 (MAXRAD*MAXRAD+1)
| 30 |
| 31 |
#define G0NORM 0.286 /* ground zero normalization (1/x integral) */
| 32 |
| 33 |
#ifndef FL4OP
| 34 |
#define FL4OP(f,i,op) ((f)[(i)>>5] op (1L<<((i)&0x1f)))
| 35 |
#define CHK4(f,i) FL4OP(f,i,&)
| 36 |
#define SET4(f,i) FL4OP(f,i,|=)
| 37 |
#define CLR4(f,i) FL4OP(f,i,&=~)
| 38 |
#define TGL4(f,i) FL4OP(f,i,^=)
| 39 |
#define FL4NELS(n) (((n)+0x1f)>>5)
| 40 |
#define CLR4ALL(f,n) memset((char *)(f),'\0',FL4NELS(n)*sizeof(int32))
| 41 |
#endif
| 42 |
| 43 |
static int32 *pixFlags; /* pixel occupancy flags */
| 44 |
static float pixWeight[MAXRAD2]; /* pixel weighting function */
| 45 |
static short isqrttab[MAXRAD2]; /* integer square root table */
| 46 |
| 47 |
#define isqrt(i2) (isqrttab[i2])
| 48 |
| 49 |
extern VIEW myview; /* current output view */
| 50 |
extern COLOR *mypixel; /* pixels being rendered */
| 51 |
extern float *myweight; /* weights (used to compute final pixels) */
| 52 |
extern float *mydepth; /* depth values (visibility culling) */
| 53 |
extern int hres, vres; /* current horizontal and vertical res. */
| 54 |
| 55 |
extern void pixFinish(double ransamp);
| 56 |
extern void pixBeam(BEAM *bp, HDBEAMI *hb);
| 57 |
| 58 |
typedef int (sampfunc)(int h, int v, short nl[NNEIGH][2], int nd[NNEIGH],
| 59 |
int n, double *rf);
| 60 |
static sampfunc kill_occl;
| 61 |
static sampfunc smooth_samp;
| 62 |
static sampfunc random_samp;
| 63 |
static void meet_neighbors(int occ, sampfunc *nf, double *dp);
| 64 |
static void reset_flags(void);
| 65 |
static void init_wfunc(void);
| 66 |
static int findneigh(short nl[NNEIGH][2], int nd[NNEIGH], int h, int v,
| 67 |
short (*rnl)[NNEIGH]);
| 68 |
| 69 |
| 70 |
void
| 71 |
pixBeam( /* render a particular beam */
| 72 |
BEAM *bp,
| 73 |
HDBEAMI *hb
| 74 |
| 75 |
| 76 |
GCOORD gc[2];
| 77 |
RAYVAL *rv;
| 78 |
FVECT rorg, rdir, wp, ip;
| 79 |
double d, prox;
| 80 |
COLOR col;
| 81 |
int n;
| 82 |
int32 p;
| 83 |
| 84 |
if (!hdbcoord(gc, hb->h, hb->b))
| 85 |
error(CONSISTENCY, "bad beam in render_beam");
| 86 |
for (n = bp->nrm, rv = hdbray(bp); n--; rv++) {
| 87 |
/* reproject each sample */
| 88 |
hdray(rorg, rdir, hb->h, gc, rv->r);
| 89 |
if (rv->d < DCINF) {
| 90 |
d = hddepth(hb->h, rv->d);
| 91 |
VSUM(wp, rorg, rdir, d);
| 92 |
VSUB(ip, wp, myview.vp);
| 93 |
d = DOT(ip,rdir);
| 94 |
prox = d*d/DOT(ip,ip); /* cos(diff_angle)^32 */
| 95 |
prox *= prox; prox *= prox; prox *= prox; prox *= prox;
| 96 |
} else {
| 97 |
if (myview.type == VT_PAR || myview.vaft > FTINY)
| 98 |
continue; /* inf. off view */
| 99 |
VSUM(wp, myview.vp, rdir, FHUGE);
| 100 |
prox = 1.;
| 101 |
| 102 |
if (viewloc(ip, &myview, wp) != VL_GOOD)
| 103 |
continue; /* frustum clipping */
| 104 |
if (myview.vaft > FTINY && ip[2] > myview.vaft - myview.vfore)
| 105 |
continue; /* not exact for VT_PER */
| 106 |
p = (int)(ip[1]*vres)*hres + (int)(ip[0]*hres);
| 107 |
if (mydepth[p] > FTINY) { /* check depth */
| 108 |
if (ip[2] > mydepth[p]*(1.+DEPS))
| 109 |
continue;
| 110 |
if (ip[2] < mydepth[p]*(1.-DEPS)) {
| 111 |
setcolor(mypixel[p], 0., 0., 0.);
| 112 |
myweight[p] = 0.;
| 113 |
| 114 |
| 115 |
colr_color(col, rv->v);
| 116 |
scalecolor(col, prox);
| 117 |
addcolor(mypixel[p], col);
| 118 |
myweight[p] += prox;
| 119 |
mydepth[p] = ip[2];
| 120 |
| 121 |
| 122 |
| 123 |
| 124 |
static int
| 125 |
kill_occl( /* check for occlusion errors */
| 126 |
int h,
| 127 |
int v,
| 128 |
| 129 |
int nd[NNEIGH],
| 130 |
int n,
| 131 |
double *rf
| 132 |
| 133 |
| 134 |
short forequad[2][2];
| 135 |
int d;
| 136 |
int i;
| 137 |
int32 p;
| 138 |
| 139 |
if (n <= 0) {
| 140 |
#ifdef DEBUG
| 141 |
error(WARNING, "neighborless sample in kill_occl");
| 142 |
#endif
| 143 |
return(1);
| 144 |
| 145 |
p = v*hres + h;
| 146 |
forequad[0][0] = forequad[0][1] = forequad[1][0] = forequad[1][1] = 0;
| 147 |
for (i = n; i--; ) {
| 148 |
d = isqrt(nd[i]);
| 149 |
if (mydepth[nl[i][1]*hres+nl[i][0]]*(1.+DEPS*d) < mydepth[p])
| 150 |
forequad[nl[i][0]<h][nl[i][1]<v] = 1;
| 151 |
| 152 |
if (forequad[0][0]+forequad[0][1]+forequad[1][0]+forequad[1][1] > 2) {
| 153 |
| 154 |
myweight[p] = 0.; /* occupancy reset afterwards */
| 155 |
| 156 |
return(1);
| 157 |
| 158 |
| 159 |
| 160 |
static int
| 161 |
smooth_samp( /* grow sample point smoothly */
| 162 |
int h,
| 163 |
int v,
| 164 |
| 165 |
int nd[NNEIGH],
| 166 |
int n,
| 167 |
double *rf
| 168 |
| 169 |
| 170 |
int dis[NNEIGH], ndis;
| 171 |
COLOR mykern[MAXRAD2];
| 172 |
int maxr2;
| 173 |
double d;
| 174 |
int32 p;
| 175 |
int r2;
| 176 |
int i, r, maxr, h2, v2;
| 177 |
| 178 |
if (n <= 0)
| 179 |
return(1);
| 180 |
p = v*hres + h; /* build kernel values */
| 181 |
maxr2 = nd[n-1];
| 182 |
DCHECK(maxr2>=MAXRAD2, CONSISTENCY, "out of range neighbor");
| 183 |
maxr = isqrt(maxr2);
| 184 |
for (v2 = 1; v2 <= maxr; v2++)
| 185 |
for (h2 = 0; h2 <= v2; h2++) {
| 186 |
r2 = h2*h2 + v2*v2;
| 187 |
if (r2 > maxr2) break;
| 188 |
copycolor(mykern[r2], mypixel[p]);
| 189 |
scalecolor(mykern[r2], pixWeight[r2]);
| 190 |
| 191 |
ndis = 0; /* find discontinuities */
| 192 |
| 193 |
r = isqrt(nd[i]);
| 194 |
d = mydepth[nl[i][1]*hres+nl[i][0]] / mydepth[p];
| 195 |
d = d>=1. ? d-1. : 1.-d;
| 196 |
if (d > r*DEPS || bigdiff(mypixel[p],
| 197 |
mypixel[nl[i][1]*hres+nl[i][0]], r*PEPS))
| 198 |
dis[ndis++] = i;
| 199 |
| 200 |
/* stamp out that kernel */
| 201 |
for (v2 = v-maxr; v2 <= v+maxr; v2++) {
| 202 |
if (v2 < 0) v2 = 0;
| 203 |
else if (v2 >= vres) break;
| 204 |
for (h2 = h-maxr; h2 <= h+maxr; h2++) {
| 205 |
if (h2 < 0) h2 = 0;
| 206 |
else if (h2 >= hres) break;
| 207 |
r2 = (h2-h)*(h2-h) + (v2-v)*(v2-v);
| 208 |
if (r2 > maxr2) continue;
| 209 |
if (CHK4(pixFlags, v2*hres+h2))
| 210 |
continue; /* occupied */
| 211 |
for (i = ndis; i--; ) {
| 212 |
r = (h2-nl[dis[i]][0])*(h2-nl[dis[i]][0]) +
| 213 |
(v2-nl[dis[i]][1])*(v2-nl[dis[i]][1]);
| 214 |
if (r < r2) break;
| 215 |
| 216 |
if (i >= 0) continue; /* outside edge */
| 217 |
addcolor(mypixel[v2*hres+h2], mykern[r2]);
| 218 |
myweight[v2*hres+h2] += pixWeight[r2] * myweight[p];
| 219 |
| 220 |
| 221 |
return(1);
| 222 |
| 223 |
| 224 |
| 225 |
static int
| 226 |
random_samp( /* gather samples randomly */
| 227 |
int h,
| 228 |
int v,
| 229 |
| 230 |
int nd[NNEIGH],
| 231 |
int n,
| 232 |
double *rf
| 233 |
| 234 |
| 235 |
float rnt[NNEIGH];
| 236 |
double rvar;
| 237 |
int32 p, pn;
| 238 |
int ni;
| 239 |
| 240 |
if (n <= 0)
| 241 |
return(1);
| 242 |
p = v*hres + h;
| 243 |
if (*rf <= FTINY) /* straight Voronoi regions */
| 244 |
ni = 0;
| 245 |
else { /* weighted choice */
| 246 |
DCHECK(nd[n-1]>=MAXRAD2, CONSISTENCY, "out of range neighbor");
| 247 |
rnt[0] = pixWeight[nd[0]];
| 248 |
for (ni = 1; ni < n; ni++)
| 249 |
rnt[ni] = rnt[ni-1] + pixWeight[nd[ni]];
| 250 |
rvar = rnt[n-1]*pow(frandom(), 1. / *rf);
| 251 |
for (ni = 0; rvar > rnt[ni]+FTINY; ni++)
| 252 |
| 253 |
| 254 |
pn = nl[ni][1]*hres + nl[ni][0];
| 255 |
addcolor(mypixel[p], mypixel[pn]);
| 256 |
myweight[p] += myweight[pn];
| 257 |
return(1);
| 258 |
| 259 |
| 260 |
| 261 |
void
| 262 |
pixFinish( /* done with beams -- compute pixel values */
| 263 |
double ransamp
| 264 |
| 265 |
| 266 |
if (pixWeight[0] <= FTINY)
| 267 |
init_wfunc(); /* initialize weighting function */
| 268 |
reset_flags(); /* set occupancy flags */
| 269 |
meet_neighbors(1,kill_occl,NULL); /* identify occlusion errors */
| 270 |
reset_flags(); /* reset occupancy flags */
| 271 |
if (ransamp >= 0.) /* spread samples over image */
| 272 |
meet_neighbors(0,random_samp,&ransamp);
| 273 |
else
| 274 |
meet_neighbors(1,smooth_samp,NULL);
| 275 |
free((void *)pixFlags); /* free pixel flags */
| 276 |
pixFlags = NULL;
| 277 |
| 278 |
| 279 |
| 280 |
static void
| 281 |
reset_flags(void) /* allocate/set/reset occupancy flags */
| 282 |
| 283 |
int32 p;
| 284 |
| 285 |
if (pixFlags == NULL) {
| 286 |
pixFlags = (int32 *)calloc(FL4NELS(hres*vres), sizeof(int32));
| 287 |
CHECK(pixFlags==NULL, SYSTEM, "out of memory in reset_flags");
| 288 |
} else
| 289 |
CLR4ALL(pixFlags, hres*vres);
| 290 |
for (p = hres*vres; p--; )
| 291 |
if (myweight[p] > FTINY)
| 292 |
SET4(pixFlags, p);
| 293 |
| 294 |
| 295 |
| 296 |
static void
| 297 |
init_wfunc(void) /* initialize weighting function */
| 298 |
| 299 |
int r2;
| 300 |
double d;
| 301 |
| 302 |
for (r2 = MAXRAD2; --r2; ) {
| 303 |
d = sqrt((double)r2);
| 304 |
pixWeight[r2] = G0NORM/d;
| 305 |
isqrttab[r2] = d + 0.99;
| 306 |
| 307 |
pixWeight[0] = 1.;
| 308 |
isqrttab[0] = 0;
| 309 |
| 310 |
| 311 |
| 312 |
static int
| 313 |
findneigh( /* find NNEIGH neighbors for pixel */
| 314 |
| 315 |
int nd[NNEIGH],
| 316 |
int h,
| 317 |
int v,
| 318 |
| 319 |
| 320 |
| 321 |
int nn = 0;
| 322 |
int d, n, hoff;
| 323 |
int h2, n2;
| 324 |
| 325 |
nd[NNEIGH-1] = MAXRAD2;
| 326 |
for (hoff = 0; hoff < hres; hoff = (hoff<=0) - hoff) {
| 327 |
h2 = h + hoff;
| 328 |
if ((h2 < 0) | (h2 >= hres))
| 329 |
continue;
| 330 |
if ((h2-h)*(h2-h) >= nd[NNEIGH-1])
| 331 |
break;
| 332 |
for (n = 0; n < NNEIGH && rnl[h2][n] < NINF; n++) {
| 333 |
d = (h2-h)*(h2-h) + (v-rnl[h2][n])*(v-rnl[h2][n]);
| 334 |
if ((d == 0) | (d >= nd[NNEIGH-1]))
| 335 |
continue;
| 336 |
if (nn < NNEIGH) /* insert neighbor */
| 337 |
nn++;
| 338 |
for (n2 = nn; n2--; ) {
| 339 |
if (!n2 || d >= nd[n2-1]) {
| 340 |
nd[n2] = d;
| 341 |
nl[n2][0] = h2;
| 342 |
nl[n2][1] = rnl[h2][n];
| 343 |
break;
| 344 |
| 345 |
nd[n2] = nd[n2-1];
| 346 |
nl[n2][0] = nl[n2-1][0];
| 347 |
nl[n2][1] = nl[n2-1][1];
| 348 |
| 349 |
| 350 |
| 351 |
return(nn);
| 352 |
| 353 |
| 354 |
| 355 |
static void
| 356 |
meet_neighbors( /* run through samples and their neighbors */
| 357 |
int occ,
| 358 |
sampfunc *nf,
| 359 |
double *dp
| 360 |
| 361 |
| 362 |
short ln[NNEIGH][2];
| 363 |
int nd[NNEIGH];
| 364 |
int h, v, n, v2;
| 365 |
short (*rnl)[NNEIGH];
| 366 |
/* initialize bottom row list */
| 367 |
rnl = (short (*)[NNEIGH])malloc(NNEIGH*sizeof(short)*hres);
| 368 |
CHECK(rnl==NULL, SYSTEM, "out of memory in meet_neighbors");
| 369 |
for (h = 0; h < hres; h++) {
| 370 |
for (n = v = 0; v < vres; v++)
| 371 |
if (CHK4(pixFlags, v*hres+h)) {
| 372 |
rnl[h][n++] = v;
| 373 |
if (n >= NNEIGH)
| 374 |
break;
| 375 |
| 376 |
while (n < NNEIGH)
| 377 |
rnl[h][n++] = NINF;
| 378 |
| 379 |
v = 0; /* do each row */
| 380 |
for ( ; ; ) {
| 381 |
| 382 |
if (!CHK4(pixFlags, v*hres+h) != !occ)
| 383 |
continue; /* occupancy mismatch */
| 384 |
/* find neighbors */
| 385 |
n = findneigh(ln, nd, h, v, rnl);
| 386 |
/* call on neighbors */
| 387 |
(*nf)(h, v, ln, nd, n, dp);
| 388 |
| 389 |
if (++v >= vres) /* reinitialize row list */
| 390 |
break;
| 391 |
| 392 |
for (v2 = rnl[h][NNEIGH-1]+1; v2 < vres; v2++) {
| 393 |
if (v2 - v > v - rnl[h][0])
| 394 |
break; /* not close enough */
| 395 |
if (CHK4(pixFlags, v2*hres+h)) {
| 396 |
for (n = 0; n < NNEIGH-1; n++)
| 397 |
rnl[h][n] = rnl[h][n+1];
| 398 |
rnl[h][NNEIGH-1] = v2;
| 399 |
| 400 |
| 401 |
| 402 |
free((void *)rnl); /* free row list */
| 403 |
