1 |
/* Copyright (c) 1999 Silicon Graphics, Inc. */ |
2 |
3 |
#ifndef lint |
4 |
static char SCCSid[] = "$SunId$ SGI"; |
5 |
#endif |
6 |
7 |
8 |
* Rendering routines for rhpict. |
9 |
10 |
11 |
#include "holo.h" |
12 |
#include "view.h" |
13 |
14 |
#ifndef DEPS |
15 |
#define DEPS 0.02 /* depth epsilon */ |
16 |
#endif |
17 |
#ifndef PEPS |
18 |
#define PEPS 0.04 /* pixel value epsilon */ |
19 |
#endif |
20 |
#ifndef MAXRAD |
21 |
#define MAXRAD 64 /* maximum kernel radius */ |
22 |
#endif |
23 |
#ifndef NNEIGH |
24 |
#define NNEIGH 7 /* find this many neighbors */ |
25 |
#endif |
26 |
27 |
#define NINF 16382 |
28 |
29 |
#define MAXRAD2 (MAXRAD*MAXRAD+1) |
30 |
31 |
#define G0NORM 0.286 /* ground zero normalization (1/x integral) */ |
32 |
33 |
#ifndef FL4OP |
34 |
#define FL4OP(f,i,op) ((f)[(i)>>5] op (1L<<((i)&0x1f))) |
35 |
#define CHK4(f,i) FL4OP(f,i,&) |
36 |
#define SET4(f,i) FL4OP(f,i,|=) |
37 |
#define CLR4(f,i) FL4OP(f,i,&=~) |
38 |
#define TGL4(f,i) FL4OP(f,i,^=) |
39 |
#define FL4NELS(n) (((n)+0x1f)>>5) |
40 |
#define CLR4ALL(f,n) bzero((char *)(f),FL4NELS(n)*sizeof(int4)) |
41 |
#endif |
42 |
43 |
static int4 *pixFlags; /* pixel occupancy flags */ |
44 |
static float pixWeight[MAXRAD2]; /* pixel weighting function */ |
45 |
static short isqrttab[MAXRAD2]; /* integer square root table */ |
46 |
47 |
#define isqrt(i2) ((int)isqrttab[(int)(i2)]) |
48 |
49 |
extern VIEW myview; /* current output view */ |
50 |
extern COLOR *mypixel; /* pixels being rendered */ |
51 |
extern float *myweight; /* weights (used to compute final pixels) */ |
52 |
extern float *mydepth; /* depth values (visibility culling) */ |
53 |
extern int hres, vres; /* current horizontal and vertical res. */ |
54 |
55 |
56 |
pixBeam(bp, hb) /* render a particular beam */ |
57 |
BEAM *bp; |
58 |
register HDBEAMI *hb; |
59 |
60 |
GCOORD gc[2]; |
61 |
register RAYVAL *rv; |
62 |
FVECT rorg, rdir, wp, ip; |
63 |
double d, prox; |
64 |
COLOR col; |
65 |
int n; |
66 |
register int4 p; |
67 |
68 |
if (!hdbcoord(gc, hb->h, hb->b)) |
69 |
error(CONSISTENCY, "bad beam in render_beam"); |
70 |
for (n = bp->nrm, rv = hdbray(bp); n--; rv++) { |
71 |
/* reproject each sample */ |
72 |
hdray(rorg, rdir, hb->h, gc, rv->r); |
73 |
if (rv->d < DCINF) { |
74 |
d = hddepth(hb->h, rv->d); |
75 |
VSUM(wp, rorg, rdir, d); |
76 |
VSUB(ip, wp, myview.vp); |
77 |
d = DOT(ip,rdir); |
78 |
prox = d*d/DOT(ip,ip); /* cos(diff_angle)^32 */ |
79 |
prox *= prox; prox *= prox; prox *= prox; prox *= prox; |
80 |
} else { |
81 |
if (myview.type == VT_PAR || myview.vaft > FTINY) |
82 |
continue; /* inf. off view */ |
83 |
VSUM(wp, myview.vp, rdir, FHUGE); |
84 |
prox = 1.; |
85 |
86 |
viewloc(ip, &myview, wp); /* frustum clipping */ |
87 |
if (ip[2] < 0.) |
88 |
continue; |
89 |
if (ip[0] < 0. || ip[0] >= 1.) |
90 |
continue; |
91 |
if (ip[1] < 0. || ip[1] >= 1.) |
92 |
continue; |
93 |
if (myview.vaft > FTINY && ip[2] > myview.vaft - myview.vfore) |
94 |
continue; /* not exact for VT_PER */ |
95 |
p = (int)(ip[1]*vres)*hres + (int)(ip[0]*hres); |
96 |
if (mydepth[p] > FTINY) { /* check depth */ |
97 |
if (ip[2] > mydepth[p]*(1.+DEPS)) |
98 |
continue; |
99 |
if (ip[2] < mydepth[p]*(1.-DEPS)) { |
100 |
setcolor(mypixel[p], 0., 0., 0.); |
101 |
myweight[p] = 0.; |
102 |
103 |
104 |
colr_color(col, rv->v); |
105 |
scalecolor(col, prox); |
106 |
addcolor(mypixel[p], col); |
107 |
myweight[p] += prox; |
108 |
mydepth[p] = ip[2]; |
109 |
110 |
111 |
112 |
113 |
int |
114 |
kill_occl(h, v, nl, n) /* check for occlusion errors */ |
115 |
int h, v; |
116 |
register short nl[NNEIGH][2]; |
117 |
int n; |
118 |
119 |
short forequad[2][2]; |
120 |
int d; |
121 |
register int4 i, p; |
122 |
123 |
if (n <= 0) |
124 |
return(1); |
125 |
p = v*hres + h; |
126 |
forequad[0][0] = forequad[0][1] = forequad[1][0] = forequad[1][1] = 0; |
127 |
for (i = n; i--; ) { |
128 |
d = (h-nl[i][0])*(h-nl[i][0]) + (v-nl[i][1])*(v-nl[i][1]); |
129 |
d = isqrt(d); |
130 |
if (mydepth[nl[i][1]*hres+nl[i][0]]*(1.+DEPS*d) < mydepth[p]) |
131 |
forequad[nl[i][0]<h][nl[i][1]<v] = 1; |
132 |
133 |
if (forequad[0][0]+forequad[0][1]+forequad[1][0]+forequad[1][1] > 2) { |
134 |
135 |
myweight[p] = 0.; /* occupancy reset afterwards */ |
136 |
137 |
return(1); |
138 |
139 |
140 |
141 |
int |
142 |
grow_samp(h, v, nl, n) /* grow sample point appropriately */ |
143 |
int h, v; |
144 |
145 |
int n; |
146 |
147 |
int dis[NNEIGH], ndis; |
148 |
COLOR mykern[MAXRAD2]; |
149 |
int4 maxr2; |
150 |
double w, d; |
151 |
register int4 p, r2; |
152 |
int i, r, maxr, h2, v2; |
153 |
154 |
if (n <= 0) |
155 |
return(1); |
156 |
p = v*hres + h; /* build kernel values */ |
157 |
maxr2 = (h-nl[n-1][0])*(h-nl[n-1][0]) + (v-nl[n-1][1])*(v-nl[n-1][1]); |
158 |
DCHECK(maxr2>=MAXRAD2, CONSISTENCY, "out of range neighbor"); |
159 |
maxr = isqrt(maxr2); |
160 |
for (v2 = 1; v2 <= maxr; v2++) |
161 |
for (h2 = 0; h2 <= v2; h2++) { |
162 |
r2 = h2*h2 + v2*v2; |
163 |
if (r2 > maxr2) break; |
164 |
copycolor(mykern[r2], mypixel[p]); |
165 |
scalecolor(mykern[r2], pixWeight[r2]); |
166 |
167 |
ndis = 0; /* find discontinuities */ |
168 |
169 |
r2 = (h-nl[i][0])*(h-nl[i][0]) + (v-nl[i][1])*(v-nl[i][1]); |
170 |
r = isqrt(r2); |
171 |
d = mydepth[nl[i][1]*hres+nl[i][0]] / mydepth[p]; |
172 |
d = d>=1. ? d-1. : 1.-d; |
173 |
if (d > r*DEPS || bigdiff(mypixel[p], |
174 |
mypixel[nl[i][1]*hres+nl[i][0]], r*PEPS)) |
175 |
dis[ndis++] = i; |
176 |
177 |
/* stamp out that kernel */ |
178 |
for (v2 = v-maxr; v2 <= v+maxr; v2++) { |
179 |
if (v2 < 0) v2 = 0; |
180 |
else if (v2 >= vres) break; |
181 |
for (h2 = h-maxr; h2 <= h+maxr; h2++) { |
182 |
if (h2 < 0) h2 = 0; |
183 |
else if (h2 >= hres) break; |
184 |
r2 = (h2-h)*(h2-h) + (v2-v)*(v2-v); |
185 |
if (r2 > maxr2) continue; |
186 |
if (CHK4(pixFlags, v2*hres+h2)) |
187 |
continue; /* occupied */ |
188 |
for (i = ndis; i--; ) { |
189 |
r = (h2-nl[dis[i]][0])*(h2-nl[dis[i]][0]) + |
190 |
(v2-nl[dis[i]][1])*(v2-nl[dis[i]][1]); |
191 |
if (r < r2) break; |
192 |
193 |
if (i >= 0) continue; /* outside edge */ |
194 |
addcolor(mypixel[v2*hres+h2], mykern[r2]); |
195 |
myweight[v2*hres+h2] += pixWeight[r2] * |
196 |
myweight[v*hres+h]; |
197 |
198 |
199 |
return(1); |
200 |
201 |
202 |
203 |
pixFlush() /* done with beams -- flush pixel values */ |
204 |
205 |
reset_flags(); /* set occupancy flags */ |
206 |
meet_neighbors(kill_occl); /* eliminate occlusion errors */ |
207 |
reset_flags(); /* reset occupancy flags */ |
208 |
if (pixWeight[0] <= FTINY) { /* initialize weighting function */ |
209 |
register int i, j, r2; |
210 |
double d; |
211 |
for (i = 1; i <= MAXRAD; i++) |
212 |
for (j = 0; j <= i; j++) { |
213 |
r2 = i*i + j*j; |
214 |
if (r2 >= MAXRAD2) break; |
215 |
d = sqrt((double)r2); |
216 |
pixWeight[r2] = G0NORM/d; |
217 |
isqrttab[r2] = d + 0.99; |
218 |
219 |
pixWeight[0] = 1.; |
220 |
isqrttab[0] = 0; |
221 |
222 |
meet_neighbors(grow_samp); /* grow valid samples over image */ |
223 |
free((char *)pixFlags); /* free pixel flags */ |
224 |
pixFlags = NULL; |
225 |
226 |
227 |
228 |
reset_flags() /* allocate/set/reset occupancy flags */ |
229 |
230 |
register int p; |
231 |
232 |
if (pixFlags == NULL) { |
233 |
pixFlags = (int4 *)calloc(FL4NELS(hres*vres), sizeof(int4)); |
234 |
CHECK(pixFlags==NULL, SYSTEM, "out of memory in reset_flags"); |
235 |
} else |
236 |
CLR4ALL(pixFlags, hres*vres); |
237 |
for (p = hres*vres; p--; ) |
238 |
if (myweight[p] > FTINY) |
239 |
SET4(pixFlags, p); |
240 |
241 |
242 |
243 |
int |
244 |
findneigh(nl, h, v, rnl) /* find NNEIGH neighbors for pixel */ |
245 |
246 |
int h, v; |
247 |
register short (*rnl)[NNEIGH]; |
248 |
249 |
int nn = 0; |
250 |
int4 d, nd[NNEIGH]; |
251 |
int n, hoff; |
252 |
register int h2, n2; |
253 |
254 |
nd[NNEIGH-1] = MAXRAD2; |
255 |
for (hoff = 1; hoff < hres; hoff = (hoff<0) - hoff) { |
256 |
h2 = h + hoff; |
257 |
if (h2 < 0 | h2 >= hres) |
258 |
continue; |
259 |
if ((h2-h)*(h2-h) >= nd[NNEIGH-1]) |
260 |
break; |
261 |
for (n = 0; n < NNEIGH && rnl[h2][n] < NINF; n++) { |
262 |
d = (h2-h)*(h2-h) + (v-rnl[h2][n])*(v-rnl[h2][n]); |
263 |
if (d >= nd[NNEIGH-1]) |
264 |
continue; |
265 |
if (nn < NNEIGH) /* insert neighbor */ |
266 |
nn++; |
267 |
for (n2 = nn; n2--; ) { |
268 |
if (!n2 || d >= nd[n2-1]) { |
269 |
nd[n2] = d; |
270 |
nl[n2][0] = h2; |
271 |
nl[n2][1] = rnl[h2][n]; |
272 |
break; |
273 |
274 |
nd[n2] = nd[n2-1]; |
275 |
nl[n2][0] = nl[n2-1][0]; |
276 |
nl[n2][1] = nl[n2-1][1]; |
277 |
278 |
279 |
280 |
return(nn); |
281 |
282 |
283 |
284 |
meet_neighbors(nf) /* run through samples and their neighbors */ |
285 |
int (*nf)(); |
286 |
287 |
short ln[NNEIGH][2]; |
288 |
int h, v, n, v2; |
289 |
290 |
/* initialize bottom row list */ |
291 |
rnl = (short (*)[NNEIGH])malloc(NNEIGH*sizeof(short)*hres); |
292 |
CHECK(rnl==NULL, SYSTEM, "out of memory in meet_neighbors"); |
293 |
for (h = 0; h < hres; h++) { |
294 |
for (n = v = 0; v < vres; v++) |
295 |
if (CHK4(pixFlags, v*hres+h)) { |
296 |
rnl[h][n++] = v; |
297 |
if (n >= NNEIGH) |
298 |
break; |
299 |
300 |
while (n < NNEIGH) |
301 |
rnl[h][n++] = NINF; |
302 |
303 |
v = 0; /* do each row */ |
304 |
for ( ; ; ) { |
305 |
306 |
if (!CHK4(pixFlags, v*hres+h)) |
307 |
continue; /* no one home */ |
308 |
n = findneigh(ln, h, v, rnl); |
309 |
(*nf)(h, v, ln, n); /* call on neighbors */ |
310 |
311 |
if (++v >= vres) /* reinitialize row list */ |
312 |
break; |
313 |
for (h = 0; h < hres; h++) |
314 |
for (v2 = rnl[h][NNEIGH-1]+1; v2 < vres; v2++) { |
315 |
if (v2 - v > v - rnl[h][0]) |
316 |
break; /* not close enough */ |
317 |
if (CHK4(pixFlags, v2*hres+h)) { |
318 |
for (n = 0; n < NNEIGH-1; n++) |
319 |
rnl[h][n] = rnl[h][n+1]; |
320 |
rnl[h][NNEIGH-1] = v2; |
321 |
322 |
323 |
324 |
free((char *)rnl); /* free row list */ |
325 |
