root/Development/ray/src/hd/rhpict2.c
Revision: 3.15
Committed: Thu Jan 1 11:21:55 2004 UTC (22 years ago) by schorsch
CVS Tags: rad5R1, rad5R0, rad4R2P2, rad4R2P1, rad4R2, rad4R1, rad4R0, rad3R9, rad3R8, rad3R7P2, rad3R7P1, rad3R6P1, rad3R6
Changes since 3.14: +69 -38 lines
Ansification and prototypes.
2 static const char RCSid[] = "$Id: rhpict2.c,v 3.14 2003/07/27 22:12:02 schorsch Exp $";
5 * Rendering routines for rhpict.
6 */
7
8 #include <string.h>
9
10 #include "holo.h"
11 #include "view.h"
12 #include "random.h"
13
14 #ifndef DEPS
15 #define DEPS 0.02 /* depth epsilon */
16 #endif
17 #ifndef PEPS
18 #define PEPS 0.04 /* pixel value epsilon */
19 #endif
20 #ifndef MAXRAD
21 #define MAXRAD 64 /* maximum kernel radius */
22 #endif
23 #ifndef NNEIGH
24 #define NNEIGH 5 /* find this many neighbors */
25 #endif
26
27 #define NINF 16382
28
29 #define MAXRAD2 (MAXRAD*MAXRAD+1)
30
31 #define G0NORM 0.286 /* ground zero normalization (1/x integral) */
32
33 #ifndef FL4OP
34 #define FL4OP(f,i,op) ((f)[(i)>>5] op (1L<<((i)&0x1f)))
35 #define CHK4(f,i) FL4OP(f,i,&)
36 #define SET4(f,i) FL4OP(f,i,|=)
37 #define CLR4(f,i) FL4OP(f,i,&=~)
38 #define TGL4(f,i) FL4OP(f,i,^=)
39 #define FL4NELS(n) (((n)+0x1f)>>5)
40 #define CLR4ALL(f,n) memset((char *)(f),'\0',FL4NELS(n)*sizeof(int32))
41 #endif
42
43 static int32 *pixFlags; /* pixel occupancy flags */
44 static float pixWeight[MAXRAD2]; /* pixel weighting function */
45 static short isqrttab[MAXRAD2]; /* integer square root table */
46
47 #define isqrt(i2) (isqrttab[i2])
48
49 extern VIEW myview; /* current output view */
50 extern COLOR *mypixel; /* pixels being rendered */
51 extern float *myweight; /* weights (used to compute final pixels) */
52 extern float *mydepth; /* depth values (visibility culling) */
53 extern int hres, vres; /* current horizontal and vertical res. */
54
55 extern void pixFinish(double ransamp);
56 extern void pixBeam(BEAM *bp, HDBEAMI *hb);
57
58 typedef int (sampfunc)(int h, int v, short nl[NNEIGH][2], int nd[NNEIGH],
59 int n, double *rf);
60 static sampfunc kill_occl;
61 static sampfunc smooth_samp;
62 static sampfunc random_samp;
63 static void meet_neighbors(int occ, sampfunc *nf, double *dp);
64 static void reset_flags(void);
65 static void init_wfunc(void);
66 static int findneigh(short nl[NNEIGH][2], int nd[NNEIGH], int h, int v,
67 register short (*rnl)[NNEIGH]);
68
69
70 extern void
71 pixBeam( /* render a particular beam */
72 BEAM *bp,
73 register HDBEAMI *hb
74 )
75 {
76 GCOORD gc[2];
77 register RAYVAL *rv;
78 FVECT rorg, rdir, wp, ip;
79 double d, prox;
80 COLOR col;
81 int n;
82 register int32 p;
83
84 if (!hdbcoord(gc, hb->h, hb->b))
85 error(CONSISTENCY, "bad beam in render_beam");
86 for (n = bp->nrm, rv = hdbray(bp); n--; rv++) {
87 /* reproject each sample */
88 hdray(rorg, rdir, hb->h, gc, rv->r);
89 if (rv->d < DCINF) {
90 d = hddepth(hb->h, rv->d);
91 VSUM(wp, rorg, rdir, d);
92 VSUB(ip, wp, myview.vp);
93 d = DOT(ip,rdir);
94 prox = d*d/DOT(ip,ip); /* cos(diff_angle)^32 */
95 prox *= prox; prox *= prox; prox *= prox; prox *= prox;
96 } else {
97 if (myview.type == VT_PAR || myview.vaft > FTINY)
98 continue; /* inf. off view */
99 VSUM(wp, myview.vp, rdir, FHUGE);
100 prox = 1.;
101 }
102 viewloc(ip, &myview, wp); /* frustum clipping */
103 if (ip[2] < 0.)
104 continue;
105 if (ip[0] < 0. || ip[0] >= 1.)
106 continue;
107 if (ip[1] < 0. || ip[1] >= 1.)
108 continue;
109 if (myview.vaft > FTINY && ip[2] > myview.vaft - myview.vfore)
110 continue; /* not exact for VT_PER */
111 p = (int)(ip[1]*vres)*hres + (int)(ip[0]*hres);
112 if (mydepth[p] > FTINY) { /* check depth */
113 if (ip[2] > mydepth[p]*(1.+DEPS))
114 continue;
115 if (ip[2] < mydepth[p]*(1.-DEPS)) {
116 setcolor(mypixel[p], 0., 0., 0.);
117 myweight[p] = 0.;
118 }
119 }
120 colr_color(col, rv->v);
121 scalecolor(col, prox);
122 addcolor(mypixel[p], col);
123 myweight[p] += prox;
124 mydepth[p] = ip[2];
125 }
126 }
127
128
129 static int
130 kill_occl( /* check for occlusion errors */
131 int h,
132 int v,
133 register short nl[NNEIGH][2],
134 int nd[NNEIGH],
135 int n,
136 double *rf
137 )
138 {
139 short forequad[2][2];
140 int d;
141 register int i;
142 register int32 p;
143
144 if (n <= 0) {
145 #ifdef DEBUG
146 error(WARNING, "neighborless sample in kill_occl");
147 #endif
148 return(1);
149 }
150 p = v*hres + h;
151 forequad[0][0] = forequad[0][1] = forequad[1][0] = forequad[1][1] = 0;
152 for (i = n; i--; ) {
153 d = isqrt(nd[i]);
154 if (mydepth[nl[i][1]*hres+nl[i][0]]*(1.+DEPS*d) < mydepth[p])
155 forequad[nl[i][0]<h][nl[i][1]<v] = 1;
156 }
157 if (forequad[0][0]+forequad[0][1]+forequad[1][0]+forequad[1][1] > 2) {
158 setcolor(mypixel[p], 0., 0., 0.);
159 myweight[p] = 0.; /* occupancy reset afterwards */
160 }
161 return(1);
162 }
163
164
165 static int
166 smooth_samp( /* grow sample point smoothly */
167 int h,
168 int v,
169 register short nl[NNEIGH][2],
170 int nd[NNEIGH],
171 int n,
172 double *rf
173 )
174 {
175 int dis[NNEIGH], ndis;
176 COLOR mykern[MAXRAD2];
177 int maxr2;
178 double d;
179 register int32 p;
180 register int r2;
181 int i, r, maxr, h2, v2;
182
183 if (n <= 0)
184 return(1);
185 p = v*hres + h; /* build kernel values */
186 maxr2 = nd[n-1];
187 DCHECK(maxr2>=MAXRAD2, CONSISTENCY, "out of range neighbor");
188 maxr = isqrt(maxr2);
189 for (v2 = 1; v2 <= maxr; v2++)
190 for (h2 = 0; h2 <= v2; h2++) {
191 r2 = h2*h2 + v2*v2;
192 if (r2 > maxr2) break;
193 copycolor(mykern[r2], mypixel[p]);
194 scalecolor(mykern[r2], pixWeight[r2]);
195 }
196 ndis = 0; /* find discontinuities */
197 for (i = n; i--; ) {
198 r = isqrt(nd[i]);
199 d = mydepth[nl[i][1]*hres+nl[i][0]] / mydepth[p];
200 d = d>=1. ? d-1. : 1.-d;
201 if (d > r*DEPS || bigdiff(mypixel[p],
202 mypixel[nl[i][1]*hres+nl[i][0]], r*PEPS))
203 dis[ndis++] = i;
204 }
205 /* stamp out that kernel */
206 for (v2 = v-maxr; v2 <= v+maxr; v2++) {
207 if (v2 < 0) v2 = 0;
208 else if (v2 >= vres) break;
209 for (h2 = h-maxr; h2 <= h+maxr; h2++) {
210 if (h2 < 0) h2 = 0;
211 else if (h2 >= hres) break;
212 r2 = (h2-h)*(h2-h) + (v2-v)*(v2-v);
213 if (r2 > maxr2) continue;
214 if (CHK4(pixFlags, v2*hres+h2))
215 continue; /* occupied */
216 for (i = ndis; i--; ) {
217 r = (h2-nl[dis[i]][0])*(h2-nl[dis[i]][0]) +
218 (v2-nl[dis[i]][1])*(v2-nl[dis[i]][1]);
219 if (r < r2) break;
220 }
221 if (i >= 0) continue; /* outside edge */
222 addcolor(mypixel[v2*hres+h2], mykern[r2]);
223 myweight[v2*hres+h2] += pixWeight[r2] * myweight[p];
224 }
225 }
226 return(1);
227 }
228
229
230 static int
231 random_samp( /* gather samples randomly */
232 int h,
233 int v,
234 register short nl[NNEIGH][2],
235 int nd[NNEIGH],
236 int n,
237 double *rf
238 )
239 {
240 float rnt[NNEIGH];
241 double rvar;
242 register int32 p, pn;
243 register int ni;
244
245 if (n <= 0)
246 return(1);
247 p = v*hres + h;
248 if (*rf <= FTINY) /* straight Voronoi regions */
249 ni = 0;
250 else { /* weighted choice */
251 DCHECK(nd[n-1]>=MAXRAD2, CONSISTENCY, "out of range neighbor");
252 rnt[0] = pixWeight[nd[0]];
253 for (ni = 1; ni < n; ni++)
254 rnt[ni] = rnt[ni-1] + pixWeight[nd[ni]];
255 rvar = rnt[n-1]*pow(frandom(), 1. / *rf);
256 for (ni = 0; rvar > rnt[ni]+FTINY; ni++)
257 ;
258 }
259 pn = nl[ni][1]*hres + nl[ni][0];
260 addcolor(mypixel[p], mypixel[pn]);
261 myweight[p] += myweight[pn];
262 return(1);
263 }
264
265
266 extern void
267 pixFinish( /* done with beams -- compute pixel values */
268 double ransamp
269 )
270 {
271 if (pixWeight[0] <= FTINY)
272 init_wfunc(); /* initialize weighting function */
273 reset_flags(); /* set occupancy flags */
274 meet_neighbors(1,kill_occl,NULL); /* identify occlusion errors */
275 reset_flags(); /* reset occupancy flags */
276 if (ransamp >= 0.) /* spread samples over image */
277 meet_neighbors(0,random_samp,&ransamp);
278 else
279 meet_neighbors(1,smooth_samp,NULL);
280 free((void *)pixFlags); /* free pixel flags */
281 pixFlags = NULL;
282 }
283
284
285 static void
286 reset_flags(void) /* allocate/set/reset occupancy flags */
287 {
288 register int32 p;
289
290 if (pixFlags == NULL) {
291 pixFlags = (int32 *)calloc(FL4NELS(hres*vres), sizeof(int32));
292 CHECK(pixFlags==NULL, SYSTEM, "out of memory in reset_flags");
293 } else
294 CLR4ALL(pixFlags, hres*vres);
295 for (p = hres*vres; p--; )
296 if (myweight[p] > FTINY)
297 SET4(pixFlags, p);
298 }
299
300
301 static void
302 init_wfunc(void) /* initialize weighting function */
303 {
304 register int r2;
305 register double d;
306
307 for (r2 = MAXRAD2; --r2; ) {
308 d = sqrt((double)r2);
309 pixWeight[r2] = G0NORM/d;
310 isqrttab[r2] = d + 0.99;
311 }
312 pixWeight[0] = 1.;
313 isqrttab[0] = 0;
314 }
315
316
317 static int
318 findneigh( /* find NNEIGH neighbors for pixel */
319 short nl[NNEIGH][2],
320 int nd[NNEIGH],
321 int h,
322 int v,
323 register short (*rnl)[NNEIGH]
324 )
325 {
326 int nn = 0;
327 int d, n, hoff;
328 register int h2, n2;
329
330 nd[NNEIGH-1] = MAXRAD2;
331 for (hoff = 0; hoff < hres; hoff = (hoff<=0) - hoff) {
332 h2 = h + hoff;
333 if ((h2 < 0) | (h2 >= hres))
334 continue;
335 if ((h2-h)*(h2-h) >= nd[NNEIGH-1])
336 break;
337 for (n = 0; n < NNEIGH && rnl[h2][n] < NINF; n++) {
338 d = (h2-h)*(h2-h) + (v-rnl[h2][n])*(v-rnl[h2][n]);
339 if ((d == 0) | (d >= nd[NNEIGH-1]))
340 continue;
341 if (nn < NNEIGH) /* insert neighbor */
342 nn++;
343 for (n2 = nn; n2--; ) {
344 if (!n2 || d >= nd[n2-1]) {
345 nd[n2] = d;
346 nl[n2][0] = h2;
347 nl[n2][1] = rnl[h2][n];
348 break;
349 }
350 nd[n2] = nd[n2-1];
351 nl[n2][0] = nl[n2-1][0];
352 nl[n2][1] = nl[n2-1][1];
353 }
354 }
355 }
356 return(nn);
357 }
358
359
360 static void
361 meet_neighbors( /* run through samples and their neighbors */
362 int occ,
363 sampfunc *nf,
364 double *dp
365 )
366 {
367 short ln[NNEIGH][2];
368 int nd[NNEIGH];
369 int h, v, n, v2;
370 register short (*rnl)[NNEIGH];
371 /* initialize bottom row list */
372 rnl = (short (*)[NNEIGH])malloc(NNEIGH*sizeof(short)*hres);
373 CHECK(rnl==NULL, SYSTEM, "out of memory in meet_neighbors");
374 for (h = 0; h < hres; h++) {
375 for (n = v = 0; v < vres; v++)
376 if (CHK4(pixFlags, v*hres+h)) {
377 rnl[h][n++] = v;
378 if (n >= NNEIGH)
379 break;
380 }
381 while (n < NNEIGH)
382 rnl[h][n++] = NINF;
383 }
384 v = 0; /* do each row */
385 for ( ; ; ) {
386 for (h = 0; h < hres; h++) {
387 if (!CHK4(pixFlags, v*hres+h) != !occ)
388 continue; /* occupancy mismatch */
389 /* find neighbors */
390 n = findneigh(ln, nd, h, v, rnl);
391 /* call on neighbors */
392 (*nf)(h, v, ln, nd, n, dp);
393 }
394 if (++v >= vres) /* reinitialize row list */
395 break;
396 for (h = 0; h < hres; h++)
397 for (v2 = rnl[h][NNEIGH-1]+1; v2 < vres; v2++) {
398 if (v2 - v > v - rnl[h][0])
399 break; /* not close enough */
400 if (CHK4(pixFlags, v2*hres+h)) {
401 for (n = 0; n < NNEIGH-1; n++)
402 rnl[h][n] = rnl[h][n+1];
403 rnl[h][NNEIGH-1] = v2;
404 }
405 }
406 }
407 free((void *)rnl); /* free row list */
408 }
