root/radiance/ray/src/hd/rhpict2.c
Changes since 3.14: +69 -38 lines
Diff to previous 3.14 , to selected 3.6
Ansification and prototypes.
Sun Jul 27 22:12:02 2003 UTC (20 years, 9 months ago) by schorsch
Diff to previous 3.13 , to selected 3.6
Mon Jul 7 17:21:51 2003 UTC (20 years, 10 months ago) by greg
Changes since 3.12: +2 -1 lines
Diff to previous 3.12 , to selected 3.6
Changes since 3.11: +4 -2 lines
Diff to previous 3.11 , to selected 3.6
Changes since 3.10: +9 -9 lines
Diff to previous 3.10 , to selected 3.6
Sat Feb 22 02:07:25 2003 UTC (21 years, 2 months ago) by greg
Changes since 3.9: +3 -6 lines
Diff to previous 3.9 , to selected 3.6
Wed Mar 10 16:15:19 1999 UTC (25 years, 1 month ago) by gwlarson
Changes since 3.8: +52 -68 lines
Diff to previous 3.8 , to selected 3.6
reduced NNEIGH default from 7 to 5
changed random sampling function to use sampled Voronoi regions
Tue Mar 9 15:08:22 1999 UTC (25 years, 1 month ago) by gwlarson
Changes since 3.7: +12 -11 lines
Diff to previous 3.7 , to selected 3.6
final cut on random resampling algorithm -- fairer choice algorithm
Tue Mar 9 14:48:06 1999 UTC (25 years, 1 month ago) by gwlarson
Changes since 3.6: +15 -12 lines
Diff to previous 3.6
second cut at random sampling -- variable randomness
Revision 3.6 - (view) (download) (annotate) - [selected]
Tue Mar 9 14:23:51 1999 UTC (25 years, 1 month ago) by gwlarson
Changes since 3.5: +66 -12 lines
Diff to previous 3.5
first cut at random resampling algorithm
Tue Mar 9 11:41:29 1999 UTC (25 years, 1 month ago) by gwlarson
Changes since 3.4: +9 -6 lines
Diff to previous 3.4 , to selected 3.6
bug fix in occlusion culling
Mon Mar 8 17:34:24 1999 UTC (25 years, 2 months ago) by gwlarson
Changes since 3.3: +22 -15 lines
Diff to previous 3.3 , to selected 3.6
put weighting function initialization into separate routine
Mon Mar 8 14:09:11 1999 UTC (25 years, 2 months ago) by gwlarson
Changes since 3.2: +67 -37 lines
Diff to previous 3.2 , to selected 3.6
finished discontinuity implementation and fixed various bugs
Fri Mar 5 17:03:38 1999 UTC (25 years, 2 months ago) by gwlarson
Changes since 3.1: +239 -7 lines
Diff to previous 3.1 , to selected 3.6
added kernel and occlusion culling
Thu Mar 4 10:30:04 1999 UTC (25 years, 2 months ago) by gwlarson
Diff to selected 3.6
