root/radiance/ray/src/hd/rhpict2.c
Revision: 3.11
Committed: Fri Jun 20 00:25:49 2003 UTC (21 years ago) by greg
Changes since 3.10: +9 -9 lines
2 static const char RCSid[] = "$Id: rhpict2.c,v 3.10 2003/02/22 02:07:25 greg Exp $";
5 * Rendering routines for rhpict.
6 */
7
8 #include "holo.h"
9 #include "view.h"
10 #include "random.h"
11
12 #ifndef DEPS
13 #define DEPS 0.02 /* depth epsilon */
14 #endif
15 #ifndef PEPS
16 #define PEPS 0.04 /* pixel value epsilon */
17 #endif
18 #ifndef MAXRAD
19 #define MAXRAD 64 /* maximum kernel radius */
20 #endif
21 #ifndef NNEIGH
22 #define NNEIGH 5 /* find this many neighbors */
23 #endif
24
25 #define NINF 16382
26
27 #define MAXRAD2 (MAXRAD*MAXRAD+1)
28
29 #define G0NORM 0.286 /* ground zero normalization (1/x integral) */
30
31 #ifndef FL4OP
32 #define FL4OP(f,i,op) ((f)[(i)>>5] op (1L<<((i)&0x1f)))
33 #define CHK4(f,i) FL4OP(f,i,&)
34 #define SET4(f,i) FL4OP(f,i,|=)
35 #define CLR4(f,i) FL4OP(f,i,&=~)
36 #define TGL4(f,i) FL4OP(f,i,^=)
37 #define FL4NELS(n) (((n)+0x1f)>>5)
38 #define CLR4ALL(f,n) bzero((char *)(f),FL4NELS(n)*sizeof(int32))
39 #endif
40
41 static int32 *pixFlags; /* pixel occupancy flags */
42 static float pixWeight[MAXRAD2]; /* pixel weighting function */
43 static short isqrttab[MAXRAD2]; /* integer square root table */
44
45 #define isqrt(i2) (isqrttab[i2])
46
47 extern VIEW myview; /* current output view */
48 extern COLOR *mypixel; /* pixels being rendered */
49 extern float *myweight; /* weights (used to compute final pixels) */
50 extern float *mydepth; /* depth values (visibility culling) */
51 extern int hres, vres; /* current horizontal and vertical res. */
52
53
54 pixBeam(bp, hb) /* render a particular beam */
55 BEAM *bp;
56 register HDBEAMI *hb;
57 {
58 GCOORD gc[2];
59 register RAYVAL *rv;
60 FVECT rorg, rdir, wp, ip;
61 double d, prox;
62 COLOR col;
63 int n;
64 register int32 p;
65
66 if (!hdbcoord(gc, hb->h, hb->b))
67 error(CONSISTENCY, "bad beam in render_beam");
68 for (n = bp->nrm, rv = hdbray(bp); n--; rv++) {
69 /* reproject each sample */
70 hdray(rorg, rdir, hb->h, gc, rv->r);
71 if (rv->d < DCINF) {
72 d = hddepth(hb->h, rv->d);
73 VSUM(wp, rorg, rdir, d);
74 VSUB(ip, wp, myview.vp);
75 d = DOT(ip,rdir);
76 prox = d*d/DOT(ip,ip); /* cos(diff_angle)^32 */
77 prox *= prox; prox *= prox; prox *= prox; prox *= prox;
78 } else {
79 if (myview.type == VT_PAR || myview.vaft > FTINY)
80 continue; /* inf. off view */
81 VSUM(wp, myview.vp, rdir, FHUGE);
82 prox = 1.;
83 }
84 viewloc(ip, &myview, wp); /* frustum clipping */
85 if (ip[2] < 0.)
86 continue;
87 if (ip[0] < 0. || ip[0] >= 1.)
88 continue;
89 if (ip[1] < 0. || ip[1] >= 1.)
90 continue;
91 if (myview.vaft > FTINY && ip[2] > myview.vaft - myview.vfore)
92 continue; /* not exact for VT_PER */
93 p = (int)(ip[1]*vres)*hres + (int)(ip[0]*hres);
94 if (mydepth[p] > FTINY) { /* check depth */
95 if (ip[2] > mydepth[p]*(1.+DEPS))
96 continue;
97 if (ip[2] < mydepth[p]*(1.-DEPS)) {
98 setcolor(mypixel[p], 0., 0., 0.);
99 myweight[p] = 0.;
100 }
101 }
102 colr_color(col, rv->v);
103 scalecolor(col, prox);
104 addcolor(mypixel[p], col);
105 myweight[p] += prox;
106 mydepth[p] = ip[2];
107 }
108 }
109
110
111 int
112 kill_occl(h, v, nl, nd, n) /* check for occlusion errors */
113 int h, v;
114 register short nl[NNEIGH][2];
115 int nd[NNEIGH];
116 int n;
117 {
118 short forequad[2][2];
119 int d;
120 register int i;
121 register int32 p;
122
123 if (n <= 0) {
124 #ifdef DEBUG
125 error(WARNING, "neighborless sample in kill_occl");
126 #endif
127 return(1);
128 }
129 p = v*hres + h;
130 forequad[0][0] = forequad[0][1] = forequad[1][0] = forequad[1][1] = 0;
131 for (i = n; i--; ) {
132 d = isqrt(nd[i]);
133 if (mydepth[nl[i][1]*hres+nl[i][0]]*(1.+DEPS*d) < mydepth[p])
134 forequad[nl[i][0]<h][nl[i][1]<v] = 1;
135 }
136 if (forequad[0][0]+forequad[0][1]+forequad[1][0]+forequad[1][1] > 2) {
137 setcolor(mypixel[p], 0., 0., 0.);
138 myweight[p] = 0.; /* occupancy reset afterwards */
139 }
140 return(1);
141 }
142
143
144 int
145 smooth_samp(h, v, nl, nd, n) /* grow sample point smoothly */
146 int h, v;
147 register short nl[NNEIGH][2];
148 int nd[NNEIGH];
149 int n;
150 {
151 int dis[NNEIGH], ndis;
152 COLOR mykern[MAXRAD2];
153 int maxr2;
154 double d;
155 register int32 p;
156 register int r2;
157 int i, r, maxr, h2, v2;
158
159 if (n <= 0)
160 return(1);
161 p = v*hres + h; /* build kernel values */
162 maxr2 = nd[n-1];
163 DCHECK(maxr2>=MAXRAD2, CONSISTENCY, "out of range neighbor");
164 maxr = isqrt(maxr2);
165 for (v2 = 1; v2 <= maxr; v2++)
166 for (h2 = 0; h2 <= v2; h2++) {
167 r2 = h2*h2 + v2*v2;
168 if (r2 > maxr2) break;
169 copycolor(mykern[r2], mypixel[p]);
170 scalecolor(mykern[r2], pixWeight[r2]);
171 }
172 ndis = 0; /* find discontinuities */
173 for (i = n; i--; ) {
174 r = isqrt(nd[i]);
175 d = mydepth[nl[i][1]*hres+nl[i][0]] / mydepth[p];
176 d = d>=1. ? d-1. : 1.-d;
177 if (d > r*DEPS || bigdiff(mypixel[p],
178 mypixel[nl[i][1]*hres+nl[i][0]], r*PEPS))
179 dis[ndis++] = i;
180 }
181 /* stamp out that kernel */
182 for (v2 = v-maxr; v2 <= v+maxr; v2++) {
183 if (v2 < 0) v2 = 0;
184 else if (v2 >= vres) break;
185 for (h2 = h-maxr; h2 <= h+maxr; h2++) {
186 if (h2 < 0) h2 = 0;
187 else if (h2 >= hres) break;
188 r2 = (h2-h)*(h2-h) + (v2-v)*(v2-v);
189 if (r2 > maxr2) continue;
190 if (CHK4(pixFlags, v2*hres+h2))
191 continue; /* occupied */
192 for (i = ndis; i--; ) {
193 r = (h2-nl[dis[i]][0])*(h2-nl[dis[i]][0]) +
194 (v2-nl[dis[i]][1])*(v2-nl[dis[i]][1]);
195 if (r < r2) break;
196 }
197 if (i >= 0) continue; /* outside edge */
198 addcolor(mypixel[v2*hres+h2], mykern[r2]);
199 myweight[v2*hres+h2] += pixWeight[r2] * myweight[p];
200 }
201 }
202 return(1);
203 }
204
205
206 int
207 random_samp(h, v, nl, nd, n, rf) /* gather samples randomly */
208 int h, v;
209 register short nl[NNEIGH][2];
210 int nd[NNEIGH];
211 int n;
212 double *rf;
213 {
214 float rnt[NNEIGH];
215 double rvar;
216 register int32 p, pn;
217 register int ni;
218
219 if (n <= 0)
220 return(1);
221 p = v*hres + h;
222 if (*rf <= FTINY) /* straight Voronoi regions */
223 ni = 0;
224 else { /* weighted choice */
225 DCHECK(nd[n-1]>=MAXRAD2, CONSISTENCY, "out of range neighbor");
226 rnt[0] = pixWeight[nd[0]];
227 for (ni = 1; ni < n; ni++)
228 rnt[ni] = rnt[ni-1] + pixWeight[nd[ni]];
229 rvar = rnt[n-1]*pow(frandom(), 1. / *rf);
230 for (ni = 0; rvar > rnt[ni]+FTINY; ni++)
231 ;
232 }
233 pn = nl[ni][1]*hres + nl[ni][0];
234 addcolor(mypixel[p], mypixel[pn]);
235 myweight[p] += myweight[pn];
236 return(1);
237 }
238
239
240 pixFinish(ransamp) /* done with beams -- compute pixel values */
241 double ransamp;
242 {
243 if (pixWeight[0] <= FTINY)
244 init_wfunc(); /* initialize weighting function */
245 reset_flags(); /* set occupancy flags */
246 meet_neighbors(1,kill_occl,NULL); /* identify occlusion errors */
247 reset_flags(); /* reset occupancy flags */
248 if (ransamp >= 0.) /* spread samples over image */
249 meet_neighbors(0,random_samp,&ransamp);
250 else
251 meet_neighbors(1,smooth_samp,NULL);
252 free((void *)pixFlags); /* free pixel flags */
253 pixFlags = NULL;
254 }
255
256
257 reset_flags() /* allocate/set/reset occupancy flags */
258 {
259 register int32 p;
260
261 if (pixFlags == NULL) {
262 pixFlags = (int32 *)calloc(FL4NELS(hres*vres), sizeof(int32));
263 CHECK(pixFlags==NULL, SYSTEM, "out of memory in reset_flags");
264 } else
265 CLR4ALL(pixFlags, hres*vres);
266 for (p = hres*vres; p--; )
267 if (myweight[p] > FTINY)
268 SET4(pixFlags, p);
269 }
270
271
272 init_wfunc() /* initialize weighting function */
273 {
274 register int r2;
275 register double d;
276
277 for (r2 = MAXRAD2; --r2; ) {
278 d = sqrt((double)r2);
279 pixWeight[r2] = G0NORM/d;
280 isqrttab[r2] = d + 0.99;
281 }
282 pixWeight[0] = 1.;
283 isqrttab[0] = 0;
284 }
285
286
287 int
288 findneigh(nl, nd, h, v, rnl) /* find NNEIGH neighbors for pixel */
289 short nl[NNEIGH][2];
290 int nd[NNEIGH];
291 int h, v;
292 register short (*rnl)[NNEIGH];
293 {
294 int nn = 0;
295 int d, n, hoff;
296 register int h2, n2;
297
298 nd[NNEIGH-1] = MAXRAD2;
299 for (hoff = 0; hoff < hres; hoff = (hoff<=0) - hoff) {
300 h2 = h + hoff;
301 if (h2 < 0 | h2 >= hres)
302 continue;
303 if ((h2-h)*(h2-h) >= nd[NNEIGH-1])
304 break;
305 for (n = 0; n < NNEIGH && rnl[h2][n] < NINF; n++) {
306 d = (h2-h)*(h2-h) + (v-rnl[h2][n])*(v-rnl[h2][n]);
307 if (d == 0 | d >= nd[NNEIGH-1])
308 continue;
309 if (nn < NNEIGH) /* insert neighbor */
310 nn++;
311 for (n2 = nn; n2--; ) {
312 if (!n2 || d >= nd[n2-1]) {
313 nd[n2] = d;
314 nl[n2][0] = h2;
315 nl[n2][1] = rnl[h2][n];
316 break;
317 }
318 nd[n2] = nd[n2-1];
319 nl[n2][0] = nl[n2-1][0];
320 nl[n2][1] = nl[n2-1][1];
321 }
322 }
323 }
324 return(nn);
325 }
326
327
328 meet_neighbors(occ, nf, dp) /* run through samples and their neighbors */
329 int occ;
330 int (*nf)();
331 char *dp;
332 {
333 short ln[NNEIGH][2];
334 int nd[NNEIGH];
335 int h, v, n, v2;
336 register short (*rnl)[NNEIGH];
337 /* initialize bottom row list */
338 rnl = (short (*)[NNEIGH])malloc(NNEIGH*sizeof(short)*hres);
339 CHECK(rnl==NULL, SYSTEM, "out of memory in meet_neighbors");
340 for (h = 0; h < hres; h++) {
341 for (n = v = 0; v < vres; v++)
342 if (CHK4(pixFlags, v*hres+h)) {
343 rnl[h][n++] = v;
344 if (n >= NNEIGH)
345 break;
346 }
347 while (n < NNEIGH)
348 rnl[h][n++] = NINF;
349 }
350 v = 0; /* do each row */
351 for ( ; ; ) {
352 for (h = 0; h < hres; h++) {
353 if (!CHK4(pixFlags, v*hres+h) != !occ)
354 continue; /* occupancy mismatch */
355 /* find neighbors */
356 n = findneigh(ln, nd, h, v, rnl);
357 /* call on neighbors */
358 (*nf)(h, v, ln, nd, n, dp);
359 }
360 if (++v >= vres) /* reinitialize row list */
361 break;
362 for (h = 0; h < hres; h++)
363 for (v2 = rnl[h][NNEIGH-1]+1; v2 < vres; v2++) {
364 if (v2 - v > v - rnl[h][0])
365 break; /* not close enough */
366 if (CHK4(pixFlags, v2*hres+h)) {
367 for (n = 0; n < NNEIGH-1; n++)
368 rnl[h][n] = rnl[h][n+1];
369 rnl[h][NNEIGH-1] = v2;
370 }
371 }
372 }
373 free((void *)rnl); /* free row list */
374 }
