root/radiance/ray/src/hd/rhpict.c
Tue Jun 8 19:48:30 2004 UTC (21 years ago) by greg
Changes since 3.17: +1 -2 lines
Diff to previous 3.17
Thu Jan 1 11:21:55 2004 UTC (21 years, 5 months ago) by schorsch
Changes since 3.16: +34 -15 lines
Diff to previous 3.16
Ansification and prototypes.
Wed Oct 22 02:06:34 2003 UTC (21 years, 8 months ago) by greg
Diff to previous 3.15
Mon Oct 20 16:01:55 2003 UTC (21 years, 8 months ago) by greg
Changes since 3.14: +3 -2 lines
Diff to previous 3.14
Sun Jul 27 22:12:02 2003 UTC (21 years, 10 months ago) by schorsch
Changes since 3.13: +5 -5 lines
Diff to previous 3.13
Mon Jul 21 22:30:18 2003 UTC (21 years, 11 months ago) by schorsch
Changes since 3.12: +3 -2 lines
Diff to previous 3.12
Mon Jul 7 17:21:51 2003 UTC (21 years, 11 months ago) by greg
Diff to previous 3.11
Mon Jun 30 14:59:12 2003 UTC (21 years, 11 months ago) by schorsch
Changes since 3.10: +6 -4 lines
Diff to previous 3.10
Fri Jun 20 00:25:49 2003 UTC (22 years ago) by greg
Changes since 3.9: +4 -4 lines
Diff to previous 3.9
Thu May 29 16:26:22 2003 UTC (22 years ago) by greg
Changes since 3.8: +0 -1 lines
Diff to previous 3.8
Sat Feb 22 02:07:25 2003 UTC (22 years, 3 months ago) by greg
Changes since 3.7: +5 -8 lines
Diff to previous 3.7
Tue Mar 9 15:10:26 1999 UTC (26 years, 3 months ago) by gwlarson
Changes since 3.6: +4 -1 lines
Diff to previous 3.6
added printing of command arguments in header
Tue Mar 9 14:55:53 1999 UTC (26 years, 3 months ago) by gwlarson
Changes since 3.5: +7 -5 lines
Diff to previous 3.5
second cut at random sampling -- variable randomness
Tue Mar 9 14:23:51 1999 UTC (26 years, 3 months ago) by gwlarson
Changes since 3.4: +9 -2 lines
Diff to previous 3.4
first cut at random resampling algorithm
Tue Mar 9 10:55:24 1999 UTC (26 years, 3 months ago) by gwlarson
Changes since 3.3: +13 -6 lines
Diff to previous 3.3
added brain-dead pixel filling for unrendered pixels
Mon Mar 8 14:09:11 1999 UTC (26 years, 3 months ago) by gwlarson
Changes since 3.2: +8 -6 lines
Diff to previous 3.2
finished discontinuity implementation and fixed various bugs
Fri Mar 5 17:02:41 1999 UTC (26 years, 3 months ago) by gwlarson
Changes since 3.1: +7 -3 lines
added kernel and occlusion culling
Thu Mar 4 10:30:04 1999 UTC (26 years, 3 months ago) by gwlarson
