root/radiance/ray/src/hd/rhpict.c
Revision: 3.20
Committed: Fri Oct 5 19:19:16 2018 UTC (6 years, 6 months ago) by greg
Changes since 3.19: +7 -7 lines
# User Rev Content
1 gwlarson 3.1 #ifndef lint
2 greg 3.20 static const char RCSid[] = "$Id: rhpict.c,v 3.19 2017/03/29 01:10:23 greg Exp $";
3 gwlarson 3.1 #endif
4     /*
5     * Radiance holodeck picture generator
6     */
7
8 schorsch 3.11 #include <string.h>
9
10 greg 3.16 #include "platform.h"
11 schorsch 3.17 #include "rterror.h"
12 gwlarson 3.1 #include "rholo.h"
13
14     char *progname; /* our program name */
15     char *hdkfile; /* holodeck file name */
16 gwlarson 3.7 char gargc; /* global argc */
17     char **gargv; /* global argv */
18 gwlarson 3.1
19     VIEW myview = STDVIEW; /* current output view */
20     int xres = 512, yres = 512; /* max. horizontal and vertical resolution */
21     char *outspec = NULL; /* output file specification */
22 gwlarson 3.6 double randfrac = -1.; /* random resampling fraction */
23 gwlarson 3.1 double pixaspect = 1.; /* pixel aspect ratio */
24     int seqstart = 0; /* sequence start frame */
25     double expval = 1.; /* exposure value */
26
27     COLOR *mypixel; /* pixels being rendered */
28     float *myweight; /* weights (used to compute final pixels) */
29 gwlarson 3.2 float *mydepth; /* depth values (visibility culling) */
30 gwlarson 3.1 int hres, vres; /* current horizontal and vertical res. */
31
32     extern int nowarn; /* turn warnings off? */
33
34 schorsch 3.17 static void dopicture(int fn);
35     static void render_frame(PACKHEAD *bl, int nb);
36     static void startpicture(int fn);
37     static int endpicture(void);
38     static void initialize(void);
39     /* from rhpict2.c */
40     extern void pixFinish(double ransamp);
41     extern void pixBeam(BEAM *bp, HDBEAMI *hb);
42 gwlarson 3.1
43 schorsch 3.17
44     int
45     main(
46     int argc,
47     char *argv[]
48     )
49 gwlarson 3.1 {
50     int i, rval;
51
52 gwlarson 3.7 gargc = argc; gargv = argv;
53 gwlarson 3.1 progname = argv[0]; /* get arguments */
54     for (i = 1; i < argc && argv[i][0] == '-'; i++) {
55     rval = getviewopt(&myview, argc-i, argv+i);
56     if (rval >= 0) { /* view option */
57     i += rval;
58     continue;
59     }
60     switch (argv[i][1]) {
61     case 'w': /* turn off warnings */
62     nowarn++;
63     break;
64     case 'p': /* pixel aspect/exposure */
65     if (badarg(argc-i-1,argv+i+1,"f"))
66     goto userr;
67 gwlarson 3.3 if (argv[i][2] == 'a')
68 gwlarson 3.1 pixaspect = atof(argv[++i]);
69 gwlarson 3.3 else if (argv[i][2] == 'e') {
70 gwlarson 3.1 expval = atof(argv[++i]);
71 schorsch 3.14 if ((argv[i][0] == '-') | (argv[i][0] == '+'))
72 gwlarson 3.1 expval = pow(2., expval);
73     } else
74     goto userr;
75     break;
76     case 'x': /* horizontal resolution */
77     if (badarg(argc-i-1,argv+i+1,"i"))
78     goto userr;
79     xres = atoi(argv[++i]);
80     break;
81     case 'y': /* vertical resolution */
82     if (badarg(argc-i-1,argv+i+1,"i"))
83     goto userr;
84     yres = atoi(argv[++i]);
85     break;
86     case 'o': /* output file specificaiton */
87     if (badarg(argc-i-1,argv+i+1,"s"))
88     goto userr;
89     outspec = argv[++i];
90     break;
91 gwlarson 3.5 case 'r': /* random sampling */
92 gwlarson 3.6 if (badarg(argc-i-1,argv+i+1,"f"))
93     goto userr;
94     randfrac = atof(argv[++i]);
95 gwlarson 3.5 break;
96     case 's': /* smooth sampling */
97 gwlarson 3.6 randfrac = -1.;
98 gwlarson 3.5 break;
99 gwlarson 3.1 case 'S': /* sequence start */
100     if (badarg(argc-i-1,argv+i+1,"i"))
101     goto userr;
102     seqstart = atoi(argv[++i]);
103     break;
104     case 'v': /* view file */
105 gwlarson 3.4 if (argv[i][2]!='f' || badarg(argc-i-1,argv+i+1,"s"))
106 gwlarson 3.1 goto userr;
107     rval = viewfile(argv[++i], &myview, NULL);
108     if (rval < 0) {
109     sprintf(errmsg, "cannot open view file \"%s\"",
110     argv[i]);
111     error(SYSTEM, errmsg);
112     } else if (rval == 0) {
113     sprintf(errmsg, "bad view file \"%s\"",
114     argv[i]);
115     error(USER, errmsg);
116     }
117     break;
118     default:
119     goto userr;
120     }
121     }
122     /* open holodeck file */
123 gwlarson 3.3 if (i != argc-1)
124 gwlarson 3.1 goto userr;
125 gwlarson 3.3 hdkfile = argv[i];
126 gwlarson 3.1 initialize();
127     /* render picture(s) */
128     if (seqstart <= 0)
129     dopicture(0);
130     else
131     while (nextview(&myview, stdin) != EOF)
132     dopicture(seqstart++);
133     quit(0); /* all done! */
134     userr:
135     fprintf(stderr,
136 gwlarson 3.6 "Usage: %s [-w][-r rf][-pa pa][-pe ex][-x hr][-y vr][-S stfn][-o outp][view] input.hdk\n",
137 gwlarson 3.1 progname);
138     quit(1);
139 schorsch 3.17 return 1; /* pro forma return */
140 gwlarson 3.1 }
141
142
143 schorsch 3.17 static void
144     dopicture( /* render view from holodeck */
145     int fn
146     )
147 gwlarson 3.1 {
148     char *err;
149     int rval;
150     BEAMLIST blist;
151
152     if ((err = setview(&myview)) != NULL) {
153     sprintf(errmsg, "%s -- skipping frame %d", err, fn);
154     error(WARNING, errmsg);
155     return;
156     }
157     startpicture(fn); /* open output picture */
158     /* determine relevant beams */
159     viewbeams(&myview, hres, vres, &blist);
160     /* render image */
161     if (blist.nb > 0) {
162     render_frame(blist.bl, blist.nb);
163 greg 3.8 free((void *)blist.bl);
164 gwlarson 3.1 } else {
165     sprintf(errmsg, "no section visible in frame %d", fn);
166     error(WARNING, errmsg);
167     }
168     rval = endpicture(); /* write pixel values */
169     if (rval < 0) {
170     sprintf(errmsg, "error writing frame %d", fn);
171     error(SYSTEM, errmsg);
172     }
173 gwlarson 3.3 #ifdef DEBUG
174 gwlarson 3.1 if (blist.nb > 0 & rval > 0) {
175 gwlarson 3.3 sprintf(errmsg, "%d unrendered pixels in frame %d (%.1f%%)",
176     rval, fn, 100.*rval/(hres*vres));
177 gwlarson 3.1 error(WARNING, errmsg);
178     }
179 gwlarson 3.3 #endif
180 gwlarson 3.1 }
181
182
183 schorsch 3.17 static void
184     render_frame( /* render frame from beam values */
185 greg 3.20 PACKHEAD *bl,
186 schorsch 3.17 int nb
187     )
188 gwlarson 3.1 {
189 greg 3.20 HDBEAMI *bil;
190     int i;
191 gwlarson 3.1
192     if (nb <= 0) return;
193     if ((bil = (HDBEAMI *)malloc(nb*sizeof(HDBEAMI))) == NULL)
194     error(SYSTEM, "out of memory in render_frame");
195     for (i = nb; i--; ) {
196     bil[i].h = hdlist[bl[i].hd];
197     bil[i].b = bl[i].bi;
198     }
199 gwlarson 3.2 hdloadbeams(bil, nb, pixBeam);
200 gwlarson 3.6 pixFinish(randfrac);
201 greg 3.8 free((void *)bil);
202 gwlarson 3.1 }
203
204
205 schorsch 3.17 static void
206     startpicture( /* initialize picture for rendering & output */
207     int fn
208     )
209 gwlarson 3.1 {
210     extern char VersionID[];
211     double pa = pixaspect;
212     char fname[256];
213     /* compute picture resolution */
214     hres = xres; vres = yres;
215     normaspect(viewaspect(&myview), &pa, &hres, &vres);
216     /* prepare output */
217     if (outspec != NULL) {
218     sprintf(fname, outspec, fn);
219     if (freopen(fname, "w", stdout) == NULL) {
220     sprintf(errmsg, "cannot open output \"%s\"", fname);
221     error(SYSTEM, errmsg);
222     }
223     }
224     /* write header */
225     newheader("RADIANCE", stdout);
226     printf("SOFTWARE= %s\n", VersionID);
227 gwlarson 3.7 printargs(gargc, gargv, stdout);
228 gwlarson 3.1 if (fn)
229     printf("FRAME=%d\n", fn);
230     fputs(VIEWSTR, stdout);
231     fprintview(&myview, stdout);
232     fputc('\n', stdout);
233 schorsch 3.14 if ((pa < 0.99) | (pa > 1.01))
234 gwlarson 3.1 fputaspect(pa, stdout);
235 schorsch 3.14 if ((expval < 0.99) | (expval > 1.01))
236 gwlarson 3.1 fputexpos(expval, stdout);
237     fputformat(COLRFMT, stdout);
238     fputc('\n', stdout);
239     /* write resolution (standard order) */
240     fprtresolu(hres, vres, stdout);
241     /* prepare image buffers */
242 schorsch 3.11 memset((char *)mypixel, '\0', hres*vres*sizeof(COLOR));
243     memset((char *)myweight, '\0', hres*vres*sizeof(float));
244     memset((char *)mydepth, '\0', hres*vres*sizeof(float));
245 gwlarson 3.1 }
246
247
248 schorsch 3.17 static int
249     endpicture(void) /* finish and write out pixels */
250 gwlarson 3.1 {
251 gwlarson 3.4 int lastr = -1, nunrend = 0;
252 greg 3.10 int32 lastp, lastrp;
253 greg 3.20 int32 p;
254     double d;
255 gwlarson 3.1 /* compute final pixel values */
256     for (p = hres*vres; p--; ) {
257     if (myweight[p] <= FTINY) {
258 schorsch 3.13 if (lastr >= 0) {
259 gwlarson 3.4 if (p/hres == lastp/hres)
260     copycolor(mypixel[p], mypixel[lastp]);
261     else
262     copycolor(mypixel[p], mypixel[lastrp]);
263 schorsch 3.13 }
264 gwlarson 3.1 nunrend++;
265     continue;
266     }
267     d = expval/myweight[p];
268     scalecolor(mypixel[p], d);
269 gwlarson 3.4 if ((lastp=p)/hres != lastr)
270     lastr = (lastrp=p)/hres;
271 gwlarson 3.1 }
272     /* write each scanline */
273 gwlarson 3.4 for (p = vres; p--; )
274     if (fwritescan(mypixel+p*hres, hres, stdout) < 0)
275 gwlarson 3.1 return(-1);
276     if (fflush(stdout) == EOF)
277     return(-1);
278     return(nunrend);
279     }
280
281
282 schorsch 3.17 static void
283     initialize(void) /* initialize holodeck and buffers */
284 gwlarson 3.1 {
285     int fd;
286     FILE *fp;
287     int n;
288 greg 3.19 off_t nextloc;
289 gwlarson 3.1 /* open holodeck file */
290     if ((fp = fopen(hdkfile, "r")) == NULL) {
291     sprintf(errmsg, "cannot open \"%s\" for reading", hdkfile);
292     error(SYSTEM, errmsg);
293     }
294     /* check header format */
295     checkheader(fp, HOLOFMT, NULL);
296     /* check magic number */
297     if (getw(fp) != HOLOMAGIC) {
298     sprintf(errmsg, "bad magic number in holodeck file \"%s\"",
299     hdkfile);
300     error(USER, errmsg);
301     }
302     nextloc = ftell(fp); /* get stdio position */
303     fd = dup(fileno(fp)); /* dup file descriptor */
304     fclose(fp); /* done with stdio */
305     for (n = 0; nextloc > 0L; n++) { /* initialize each section */
306 greg 3.19 lseek(fd, nextloc, SEEK_SET);
307 gwlarson 3.1 read(fd, (char *)&nextloc, sizeof(nextloc));
308     hdinit(fd, NULL);
309     }
310     /* allocate picture buffer */
311     mypixel = (COLOR *)bmalloc(xres*yres*sizeof(COLOR));
312     myweight = (float *)bmalloc(xres*yres*sizeof(float));
313 gwlarson 3.2 mydepth = (float *)bmalloc(xres*yres*sizeof(float));
314 schorsch 3.14 if ((mypixel == NULL) | (myweight == NULL) | (mydepth == NULL))
315 gwlarson 3.1 error(SYSTEM, "out of memory in initialize");
316     }
317
318
319 greg 3.8 void
320 gwlarson 3.1 eputs(s) /* put error message to stderr */
321 greg 3.20 char *s;
322 gwlarson 3.1 {
323     static int midline = 0;
324
325     if (!*s)
326     return;
327     if (!midline++) { /* prepend line with program name */
328     fputs(progname, stderr);
329     fputs(": ", stderr);
330     }
331     fputs(s, stderr);
332     if (s[strlen(s)-1] == '\n') {
333     fflush(stderr);
334     midline = 0;
335     }
336     }
