| 1 |
#ifndef lint
| 2 |
static const char RCSid[] = "$Id: rhpict.c,v 3.19 2017/03/29 01:10:23 greg Exp $";
| 3 |
#endif
| 4 |
| 5 |
* Radiance holodeck picture generator
| 6 |
| 7 |
| 8 |
#include <string.h>
| 9 |
| 10 |
#include "platform.h"
| 11 |
#include "rterror.h"
| 12 |
#include "rholo.h"
| 13 |
| 14 |
char *progname; /* our program name */
| 15 |
char *hdkfile; /* holodeck file name */
| 16 |
char gargc; /* global argc */
| 17 |
char **gargv; /* global argv */
| 18 |
| 19 |
VIEW myview = STDVIEW; /* current output view */
| 20 |
int xres = 512, yres = 512; /* max. horizontal and vertical resolution */
| 21 |
char *outspec = NULL; /* output file specification */
| 22 |
double randfrac = -1.; /* random resampling fraction */
| 23 |
double pixaspect = 1.; /* pixel aspect ratio */
| 24 |
int seqstart = 0; /* sequence start frame */
| 25 |
double expval = 1.; /* exposure value */
| 26 |
| 27 |
COLOR *mypixel; /* pixels being rendered */
| 28 |
float *myweight; /* weights (used to compute final pixels) */
| 29 |
float *mydepth; /* depth values (visibility culling) */
| 30 |
int hres, vres; /* current horizontal and vertical res. */
| 31 |
| 32 |
extern int nowarn; /* turn warnings off? */
| 33 |
| 34 |
static void dopicture(int fn);
| 35 |
static void render_frame(PACKHEAD *bl, int nb);
| 36 |
static void startpicture(int fn);
| 37 |
static int endpicture(void);
| 38 |
static void initialize(void);
| 39 |
/* from rhpict2.c */
| 40 |
extern void pixFinish(double ransamp);
| 41 |
extern void pixBeam(BEAM *bp, HDBEAMI *hb);
| 42 |
| 43 |
| 44 |
int
| 45 |
main(
| 46 |
int argc,
| 47 |
char *argv[]
| 48 |
| 49 |
| 50 |
int i, rval;
| 51 |
| 52 |
gargc = argc; gargv = argv;
| 53 |
progname = argv[0]; /* get arguments */
| 54 |
for (i = 1; i < argc && argv[i][0] == '-'; i++) {
| 55 |
rval = getviewopt(&myview, argc-i, argv+i);
| 56 |
if (rval >= 0) { /* view option */
| 57 |
i += rval;
| 58 |
continue;
| 59 |
| 60 |
switch (argv[i][1]) {
| 61 |
case 'w': /* turn off warnings */
| 62 |
nowarn++;
| 63 |
break;
| 64 |
case 'p': /* pixel aspect/exposure */
| 65 |
if (badarg(argc-i-1,argv+i+1,"f"))
| 66 |
goto userr;
| 67 |
if (argv[i][2] == 'a')
| 68 |
pixaspect = atof(argv[++i]);
| 69 |
else if (argv[i][2] == 'e') {
| 70 |
expval = atof(argv[++i]);
| 71 |
if ((argv[i][0] == '-') | (argv[i][0] == '+'))
| 72 |
expval = pow(2., expval);
| 73 |
} else
| 74 |
goto userr;
| 75 |
break;
| 76 |
case 'x': /* horizontal resolution */
| 77 |
if (badarg(argc-i-1,argv+i+1,"i"))
| 78 |
goto userr;
| 79 |
xres = atoi(argv[++i]);
| 80 |
break;
| 81 |
case 'y': /* vertical resolution */
| 82 |
| 83 |
goto userr;
| 84 |
yres = atoi(argv[++i]);
| 85 |
break;
| 86 |
case 'o': /* output file specificaiton */
| 87 |
if (badarg(argc-i-1,argv+i+1,"s"))
| 88 |
goto userr;
| 89 |
outspec = argv[++i];
| 90 |
break;
| 91 |
case 'r': /* random sampling */
| 92 |
| 93 |
goto userr;
| 94 |
randfrac = atof(argv[++i]);
| 95 |
break;
| 96 |
case 's': /* smooth sampling */
| 97 |
randfrac = -1.;
| 98 |
break;
| 99 |
case 'S': /* sequence start */
| 100 |
| 101 |
goto userr;
| 102 |
seqstart = atoi(argv[++i]);
| 103 |
break;
| 104 |
case 'v': /* view file */
| 105 |
if (argv[i][2]!='f' || badarg(argc-i-1,argv+i+1,"s"))
| 106 |
goto userr;
| 107 |
rval = viewfile(argv[++i], &myview, NULL);
| 108 |
if (rval < 0) {
| 109 |
sprintf(errmsg, "cannot open view file \"%s\"",
| 110 |
argv[i]);
| 111 |
error(SYSTEM, errmsg);
| 112 |
} else if (rval == 0) {
| 113 |
sprintf(errmsg, "bad view file \"%s\"",
| 114 |
argv[i]);
| 115 |
error(USER, errmsg);
| 116 |
| 117 |
break;
| 118 |
default:
| 119 |
goto userr;
| 120 |
| 121 |
| 122 |
/* open holodeck file */
| 123 |
if (i != argc-1)
| 124 |
goto userr;
| 125 |
hdkfile = argv[i];
| 126 |
initialize();
| 127 |
/* render picture(s) */
| 128 |
if (seqstart <= 0)
| 129 |
dopicture(0);
| 130 |
else
| 131 |
while (nextview(&myview, stdin) != EOF)
| 132 |
dopicture(seqstart++);
| 133 |
quit(0); /* all done! */
| 134 |
userr:
| 135 |
fprintf(stderr,
| 136 |
"Usage: %s [-w][-r rf][-pa pa][-pe ex][-x hr][-y vr][-S stfn][-o outp][view] input.hdk\n",
| 137 |
progname);
| 138 |
quit(1);
| 139 |
return 1; /* pro forma return */
| 140 |
| 141 |
| 142 |
| 143 |
static void
| 144 |
dopicture( /* render view from holodeck */
| 145 |
int fn
| 146 |
| 147 |
| 148 |
char *err;
| 149 |
int rval;
| 150 |
BEAMLIST blist;
| 151 |
| 152 |
if ((err = setview(&myview)) != NULL) {
| 153 |
sprintf(errmsg, "%s -- skipping frame %d", err, fn);
| 154 |
error(WARNING, errmsg);
| 155 |
return;
| 156 |
| 157 |
startpicture(fn); /* open output picture */
| 158 |
/* determine relevant beams */
| 159 |
viewbeams(&myview, hres, vres, &blist);
| 160 |
/* render image */
| 161 |
if (blist.nb > 0) {
| 162 |
render_frame(blist.bl, blist.nb);
| 163 |
free((void *)blist.bl);
| 164 |
} else {
| 165 |
sprintf(errmsg, "no section visible in frame %d", fn);
| 166 |
| 167 |
| 168 |
rval = endpicture(); /* write pixel values */
| 169 |
if (rval < 0) {
| 170 |
sprintf(errmsg, "error writing frame %d", fn);
| 171 |
| 172 |
| 173 |
#ifdef DEBUG
| 174 |
if (blist.nb > 0 & rval > 0) {
| 175 |
sprintf(errmsg, "%d unrendered pixels in frame %d (%.1f%%)",
| 176 |
rval, fn, 100.*rval/(hres*vres));
| 177 |
| 178 |
| 179 |
#endif
| 180 |
| 181 |
| 182 |
| 183 |
static void
| 184 |
render_frame( /* render frame from beam values */
| 185 |
PACKHEAD *bl,
| 186 |
int nb
| 187 |
| 188 |
| 189 |
HDBEAMI *bil;
| 190 |
int i;
| 191 |
| 192 |
if (nb <= 0) return;
| 193 |
if ((bil = (HDBEAMI *)malloc(nb*sizeof(HDBEAMI))) == NULL)
| 194 |
error(SYSTEM, "out of memory in render_frame");
| 195 |
for (i = nb; i--; ) {
| 196 |
bil[i].h = hdlist[bl[i].hd];
| 197 |
bil[i].b = bl[i].bi;
| 198 |
| 199 |
hdloadbeams(bil, nb, pixBeam);
| 200 |
pixFinish(randfrac);
| 201 |
free((void *)bil);
| 202 |
| 203 |
| 204 |
| 205 |
static void
| 206 |
startpicture( /* initialize picture for rendering & output */
| 207 |
int fn
| 208 |
| 209 |
| 210 |
extern char VersionID[];
| 211 |
double pa = pixaspect;
| 212 |
char fname[256];
| 213 |
/* compute picture resolution */
| 214 |
hres = xres; vres = yres;
| 215 |
normaspect(viewaspect(&myview), &pa, &hres, &vres);
| 216 |
/* prepare output */
| 217 |
if (outspec != NULL) {
| 218 |
sprintf(fname, outspec, fn);
| 219 |
if (freopen(fname, "w", stdout) == NULL) {
| 220 |
sprintf(errmsg, "cannot open output \"%s\"", fname);
| 221 |
| 222 |
| 223 |
| 224 |
/* write header */
| 225 |
newheader("RADIANCE", stdout);
| 226 |
printf("SOFTWARE= %s\n", VersionID);
| 227 |
printargs(gargc, gargv, stdout);
| 228 |
if (fn)
| 229 |
printf("FRAME=%d\n", fn);
| 230 |
fputs(VIEWSTR, stdout);
| 231 |
fprintview(&myview, stdout);
| 232 |
fputc('\n', stdout);
| 233 |
if ((pa < 0.99) | (pa > 1.01))
| 234 |
fputaspect(pa, stdout);
| 235 |
if ((expval < 0.99) | (expval > 1.01))
| 236 |
fputexpos(expval, stdout);
| 237 |
fputformat(COLRFMT, stdout);
| 238 |
| 239 |
/* write resolution (standard order) */
| 240 |
fprtresolu(hres, vres, stdout);
| 241 |
/* prepare image buffers */
| 242 |
memset((char *)mypixel, '\0', hres*vres*sizeof(COLOR));
| 243 |
memset((char *)myweight, '\0', hres*vres*sizeof(float));
| 244 |
memset((char *)mydepth, '\0', hres*vres*sizeof(float));
| 245 |
| 246 |
| 247 |
| 248 |
static int
| 249 |
endpicture(void) /* finish and write out pixels */
| 250 |
| 251 |
int lastr = -1, nunrend = 0;
| 252 |
int32 lastp, lastrp;
| 253 |
int32 p;
| 254 |
double d;
| 255 |
/* compute final pixel values */
| 256 |
for (p = hres*vres; p--; ) {
| 257 |
if (myweight[p] <= FTINY) {
| 258 |
if (lastr >= 0) {
| 259 |
if (p/hres == lastp/hres)
| 260 |
copycolor(mypixel[p], mypixel[lastp]);
| 261 |
else
| 262 |
copycolor(mypixel[p], mypixel[lastrp]);
| 263 |
| 264 |
nunrend++;
| 265 |
continue;
| 266 |
| 267 |
d = expval/myweight[p];
| 268 |
scalecolor(mypixel[p], d);
| 269 |
if ((lastp=p)/hres != lastr)
| 270 |
lastr = (lastrp=p)/hres;
| 271 |
| 272 |
/* write each scanline */
| 273 |
for (p = vres; p--; )
| 274 |
if (fwritescan(mypixel+p*hres, hres, stdout) < 0)
| 275 |
return(-1);
| 276 |
if (fflush(stdout) == EOF)
| 277 |
return(-1);
| 278 |
return(nunrend);
| 279 |
| 280 |
| 281 |
| 282 |
static void
| 283 |
initialize(void) /* initialize holodeck and buffers */
| 284 |
| 285 |
int fd;
| 286 |
FILE *fp;
| 287 |
int n;
| 288 |
off_t nextloc;
| 289 |
| 290 |
if ((fp = fopen(hdkfile, "r")) == NULL) {
| 291 |
sprintf(errmsg, "cannot open \"%s\" for reading", hdkfile);
| 292 |
| 293 |
| 294 |
/* check header format */
| 295 |
checkheader(fp, HOLOFMT, NULL);
| 296 |
/* check magic number */
| 297 |
if (getw(fp) != HOLOMAGIC) {
| 298 |
sprintf(errmsg, "bad magic number in holodeck file \"%s\"",
| 299 |
hdkfile);
| 300 |
| 301 |
| 302 |
nextloc = ftell(fp); /* get stdio position */
| 303 |
fd = dup(fileno(fp)); /* dup file descriptor */
| 304 |
fclose(fp); /* done with stdio */
| 305 |
for (n = 0; nextloc > 0L; n++) { /* initialize each section */
| 306 |
lseek(fd, nextloc, SEEK_SET);
| 307 |
read(fd, (char *)&nextloc, sizeof(nextloc));
| 308 |
hdinit(fd, NULL);
| 309 |
| 310 |
/* allocate picture buffer */
| 311 |
mypixel = (COLOR *)bmalloc(xres*yres*sizeof(COLOR));
| 312 |
myweight = (float *)bmalloc(xres*yres*sizeof(float));
| 313 |
mydepth = (float *)bmalloc(xres*yres*sizeof(float));
| 314 |
if ((mypixel == NULL) | (myweight == NULL) | (mydepth == NULL))
| 315 |
error(SYSTEM, "out of memory in initialize");
| 316 |
| 317 |
| 318 |
| 319 |
void
| 320 |
eputs(s) /* put error message to stderr */
| 321 |
char *s;
| 322 |
| 323 |
static int midline = 0;
| 324 |
| 325 |
if (!*s)
| 326 |
return;
| 327 |
if (!midline++) { /* prepend line with program name */
| 328 |
fputs(progname, stderr);
| 329 |
fputs(": ", stderr);
| 330 |
| 331 |
fputs(s, stderr);
| 332 |
if (s[strlen(s)-1] == '\n') {
| 333 |
fflush(stderr);
| 334 |
midline = 0;
| 335 |
| 336 |
