root/radiance/ray/src/hd/rhpict.c
Tue Jun 8 19:48:30 2004 UTC (19 years, 11 months ago) by greg
Changes since 3.17: +1 -2 lines
Diff to previous 3.17 , to selected 3.10
Changes since 3.16: +34 -15 lines
Diff to previous 3.16 , to selected 3.10
Ansification and prototypes.
Diff to previous 3.15 , to selected 3.10
Changes since 3.14: +3 -2 lines
Diff to previous 3.14 , to selected 3.10
Sun Jul 27 22:12:02 2003 UTC (20 years, 9 months ago) by schorsch
Changes since 3.13: +5 -5 lines
Diff to previous 3.13 , to selected 3.10
Changes since 3.12: +3 -2 lines
Diff to previous 3.12 , to selected 3.10
Mon Jul 7 17:21:51 2003 UTC (20 years, 10 months ago) by greg
Diff to previous 3.11 , to selected 3.10
Changes since 3.10: +6 -4 lines
Diff to previous 3.10
Revision 3.10 - (view) (download) (annotate) - [selected]
Changes since 3.9: +4 -4 lines
Diff to previous 3.9
Thu May 29 16:26:22 2003 UTC (20 years, 11 months ago) by greg
Changes since 3.8: +0 -1 lines
Diff to previous 3.8 , to selected 3.10
Sat Feb 22 02:07:25 2003 UTC (21 years, 2 months ago) by greg
Changes since 3.7: +5 -8 lines
Diff to previous 3.7 , to selected 3.10
Tue Mar 9 15:10:26 1999 UTC (25 years, 2 months ago) by gwlarson
Changes since 3.6: +4 -1 lines
Diff to previous 3.6 , to selected 3.10
added printing of command arguments in header
Tue Mar 9 14:55:53 1999 UTC (25 years, 2 months ago) by gwlarson
Changes since 3.5: +7 -5 lines
Diff to previous 3.5 , to selected 3.10
second cut at random sampling -- variable randomness
Tue Mar 9 14:23:51 1999 UTC (25 years, 2 months ago) by gwlarson
Changes since 3.4: +9 -2 lines
Diff to previous 3.4 , to selected 3.10
first cut at random resampling algorithm
Tue Mar 9 10:55:24 1999 UTC (25 years, 2 months ago) by gwlarson
Changes since 3.3: +13 -6 lines
Diff to previous 3.3 , to selected 3.10
added brain-dead pixel filling for unrendered pixels
Mon Mar 8 14:09:11 1999 UTC (25 years, 2 months ago) by gwlarson
Changes since 3.2: +8 -6 lines
Diff to previous 3.2 , to selected 3.10
finished discontinuity implementation and fixed various bugs
Fri Mar 5 17:02:41 1999 UTC (25 years, 2 months ago) by gwlarson
Changes since 3.1: +7 -3 lines
Diff to previous 3.1 , to selected 3.10
added kernel and occlusion culling
Thu Mar 4 10:30:04 1999 UTC (25 years, 2 months ago) by gwlarson
Diff to selected 3.10
