root/Development/ray/src/hd/rhpict.c
Revision: 3.8
Committed: Sat Feb 22 02:07:25 2003 UTC (22 years, 10 months ago) by greg
Changes since 3.7: +5 -8 lines
# User Rev Content
1 gwlarson 3.1 #ifndef lint
2 greg 3.8 static const char RCSid[] = "$Id$";
3 gwlarson 3.1 #endif
4     /*
5     * Radiance holodeck picture generator
6     */
7
8     #include "rholo.h"
9     #include "view.h"
10
11     char *progname; /* our program name */
12     char *hdkfile; /* holodeck file name */
13 gwlarson 3.7 char gargc; /* global argc */
14     char **gargv; /* global argv */
15 gwlarson 3.1
16     VIEW myview = STDVIEW; /* current output view */
17     int xres = 512, yres = 512; /* max. horizontal and vertical resolution */
18     char *outspec = NULL; /* output file specification */
19 gwlarson 3.6 double randfrac = -1.; /* random resampling fraction */
20 gwlarson 3.1 double pixaspect = 1.; /* pixel aspect ratio */
21     int seqstart = 0; /* sequence start frame */
22     double expval = 1.; /* exposure value */
23
24     COLOR *mypixel; /* pixels being rendered */
25     float *myweight; /* weights (used to compute final pixels) */
26 gwlarson 3.2 float *mydepth; /* depth values (visibility culling) */
27 gwlarson 3.1 int hres, vres; /* current horizontal and vertical res. */
28
29     extern int nowarn; /* turn warnings off? */
30
31
32     main(argc, argv)
33     int argc;
34     char *argv[];
35     {
36     int i, rval;
37
38 gwlarson 3.7 gargc = argc; gargv = argv;
39 gwlarson 3.1 progname = argv[0]; /* get arguments */
40     for (i = 1; i < argc && argv[i][0] == '-'; i++) {
41     rval = getviewopt(&myview, argc-i, argv+i);
42     if (rval >= 0) { /* view option */
43     i += rval;
44     continue;
45     }
46     switch (argv[i][1]) {
47     case 'w': /* turn off warnings */
48     nowarn++;
49     break;
50     case 'p': /* pixel aspect/exposure */
51     if (badarg(argc-i-1,argv+i+1,"f"))
52     goto userr;
53 gwlarson 3.3 if (argv[i][2] == 'a')
54 gwlarson 3.1 pixaspect = atof(argv[++i]);
55 gwlarson 3.3 else if (argv[i][2] == 'e') {
56 gwlarson 3.1 expval = atof(argv[++i]);
57     if (argv[i][0] == '-' | argv[i][0] == '+')
58     expval = pow(2., expval);
59     } else
60     goto userr;
61     break;
62     case 'x': /* horizontal resolution */
63     if (badarg(argc-i-1,argv+i+1,"i"))
64     goto userr;
65     xres = atoi(argv[++i]);
66     break;
67     case 'y': /* vertical resolution */
68     if (badarg(argc-i-1,argv+i+1,"i"))
69     goto userr;
70     yres = atoi(argv[++i]);
71     break;
72     case 'o': /* output file specificaiton */
73     if (badarg(argc-i-1,argv+i+1,"s"))
74     goto userr;
75     outspec = argv[++i];
76     break;
77 gwlarson 3.5 case 'r': /* random sampling */
78 gwlarson 3.6 if (badarg(argc-i-1,argv+i+1,"f"))
79     goto userr;
80     randfrac = atof(argv[++i]);
81 gwlarson 3.5 break;
82     case 's': /* smooth sampling */
83 gwlarson 3.6 randfrac = -1.;
84 gwlarson 3.5 break;
85 gwlarson 3.1 case 'S': /* sequence start */
86     if (badarg(argc-i-1,argv+i+1,"i"))
87     goto userr;
88     seqstart = atoi(argv[++i]);
89     break;
90     case 'v': /* view file */
91 gwlarson 3.4 if (argv[i][2]!='f' || badarg(argc-i-1,argv+i+1,"s"))
92 gwlarson 3.1 goto userr;
93     rval = viewfile(argv[++i], &myview, NULL);
94     if (rval < 0) {
95     sprintf(errmsg, "cannot open view file \"%s\"",
96     argv[i]);
97     error(SYSTEM, errmsg);
98     } else if (rval == 0) {
99     sprintf(errmsg, "bad view file \"%s\"",
100     argv[i]);
101     error(USER, errmsg);
102     }
103     break;
104     default:
105     goto userr;
106     }
107     }
108     /* open holodeck file */
109 gwlarson 3.3 if (i != argc-1)
110 gwlarson 3.1 goto userr;
111 gwlarson 3.3 hdkfile = argv[i];
112 gwlarson 3.1 initialize();
113     /* render picture(s) */
114     if (seqstart <= 0)
115     dopicture(0);
116     else
117     while (nextview(&myview, stdin) != EOF)
118     dopicture(seqstart++);
119     quit(0); /* all done! */
120     userr:
121     fprintf(stderr,
122 gwlarson 3.6 "Usage: %s [-w][-r rf][-pa pa][-pe ex][-x hr][-y vr][-S stfn][-o outp][view] input.hdk\n",
123 gwlarson 3.1 progname);
124     quit(1);
125     }
126
127
128     dopicture(fn) /* render view from holodeck */
129     int fn;
130     {
131     char *err;
132     int rval;
133     BEAMLIST blist;
134
135     if ((err = setview(&myview)) != NULL) {
136     sprintf(errmsg, "%s -- skipping frame %d", err, fn);
137     error(WARNING, errmsg);
138     return;
139     }
140     startpicture(fn); /* open output picture */
141     /* determine relevant beams */
142     viewbeams(&myview, hres, vres, &blist);
143     /* render image */
144     if (blist.nb > 0) {
145     render_frame(blist.bl, blist.nb);
146 greg 3.8 free((void *)blist.bl);
147 gwlarson 3.1 } else {
148     sprintf(errmsg, "no section visible in frame %d", fn);
149     error(WARNING, errmsg);
150     }
151     rval = endpicture(); /* write pixel values */
152     if (rval < 0) {
153     sprintf(errmsg, "error writing frame %d", fn);
154     error(SYSTEM, errmsg);
155     }
156 gwlarson 3.3 #ifdef DEBUG
157 gwlarson 3.1 if (blist.nb > 0 & rval > 0) {
158 gwlarson 3.3 sprintf(errmsg, "%d unrendered pixels in frame %d (%.1f%%)",
159     rval, fn, 100.*rval/(hres*vres));
160 gwlarson 3.1 error(WARNING, errmsg);
161     }
162 gwlarson 3.3 #endif
163 gwlarson 3.1 }
164
165
166     render_frame(bl, nb) /* render frame from beam values */
167     register PACKHEAD *bl;
168     int nb;
169     {
170 gwlarson 3.2 extern int pixBeam();
171 gwlarson 3.1 register HDBEAMI *bil;
172     register int i;
173
174     if (nb <= 0) return;
175     if ((bil = (HDBEAMI *)malloc(nb*sizeof(HDBEAMI))) == NULL)
176     error(SYSTEM, "out of memory in render_frame");
177     for (i = nb; i--; ) {
178     bil[i].h = hdlist[bl[i].hd];
179     bil[i].b = bl[i].bi;
180     }
181 gwlarson 3.2 hdloadbeams(bil, nb, pixBeam);
182 gwlarson 3.6 pixFinish(randfrac);
183 greg 3.8 free((void *)bil);
184 gwlarson 3.1 }
185
186
187     startpicture(fn) /* initialize picture for rendering & output */
188     int fn;
189     {
190     extern char VersionID[];
191     double pa = pixaspect;
192     char fname[256];
193     /* compute picture resolution */
194     hres = xres; vres = yres;
195     normaspect(viewaspect(&myview), &pa, &hres, &vres);
196     /* prepare output */
197     if (outspec != NULL) {
198     sprintf(fname, outspec, fn);
199     if (freopen(fname, "w", stdout) == NULL) {
200     sprintf(errmsg, "cannot open output \"%s\"", fname);
201     error(SYSTEM, errmsg);
202     }
203     }
204     /* write header */
205     newheader("RADIANCE", stdout);
206     printf("SOFTWARE= %s\n", VersionID);
207 gwlarson 3.7 printargs(gargc, gargv, stdout);
208 gwlarson 3.1 if (fn)
209     printf("FRAME=%d\n", fn);
210     fputs(VIEWSTR, stdout);
211     fprintview(&myview, stdout);
212     fputc('\n', stdout);
213     if (pa < 0.99 | pa > 1.01)
214     fputaspect(pa, stdout);
215     if (expval < 0.99 | expval > 1.01)
216     fputexpos(expval, stdout);
217     fputformat(COLRFMT, stdout);
218     fputc('\n', stdout);
219     /* write resolution (standard order) */
220     fprtresolu(hres, vres, stdout);
221     /* prepare image buffers */
222     bzero((char *)mypixel, hres*vres*sizeof(COLOR));
223     bzero((char *)myweight, hres*vres*sizeof(float));
224 gwlarson 3.2 bzero((char *)mydepth, hres*vres*sizeof(float));
225 gwlarson 3.1 }
226
227
228     int
229     endpicture() /* finish and write out pixels */
230     {
231 gwlarson 3.4 int lastr = -1, nunrend = 0;
232     int4 lastp, lastrp;
233     register int4 p;
234 gwlarson 3.1 register double d;
235     /* compute final pixel values */
236     for (p = hres*vres; p--; ) {
237     if (myweight[p] <= FTINY) {
238 gwlarson 3.4 if (lastr >= 0)
239     if (p/hres == lastp/hres)
240     copycolor(mypixel[p], mypixel[lastp]);
241     else
242     copycolor(mypixel[p], mypixel[lastrp]);
243 gwlarson 3.1 nunrend++;
244     continue;
245     }
246     d = expval/myweight[p];
247     scalecolor(mypixel[p], d);
248 gwlarson 3.4 if ((lastp=p)/hres != lastr)
249     lastr = (lastrp=p)/hres;
250 gwlarson 3.1 }
251     /* write each scanline */
252 gwlarson 3.4 for (p = vres; p--; )
253     if (fwritescan(mypixel+p*hres, hres, stdout) < 0)
254 gwlarson 3.1 return(-1);
255     if (fflush(stdout) == EOF)
256     return(-1);
257     return(nunrend);
258     }
259
260
261     initialize() /* initialize holodeck and buffers */
262     {
263     extern long ftell();
264     int fd;
265     FILE *fp;
266     int n;
267     int4 nextloc;
268     /* open holodeck file */
269     if ((fp = fopen(hdkfile, "r")) == NULL) {
270     sprintf(errmsg, "cannot open \"%s\" for reading", hdkfile);
271     error(SYSTEM, errmsg);
272     }
273     /* check header format */
274     checkheader(fp, HOLOFMT, NULL);
275     /* check magic number */
276     if (getw(fp) != HOLOMAGIC) {
277     sprintf(errmsg, "bad magic number in holodeck file \"%s\"",
278     hdkfile);
279     error(USER, errmsg);
280     }
281     nextloc = ftell(fp); /* get stdio position */
282     fd = dup(fileno(fp)); /* dup file descriptor */
283     fclose(fp); /* done with stdio */
284     for (n = 0; nextloc > 0L; n++) { /* initialize each section */
285 greg 3.8 lseek(fd, (off_t)nextloc, 0);
286 gwlarson 3.1 read(fd, (char *)&nextloc, sizeof(nextloc));
287     hdinit(fd, NULL);
288     }
289     /* allocate picture buffer */
290     mypixel = (COLOR *)bmalloc(xres*yres*sizeof(COLOR));
291     myweight = (float *)bmalloc(xres*yres*sizeof(float));
292 gwlarson 3.2 mydepth = (float *)bmalloc(xres*yres*sizeof(float));
293     if (mypixel == NULL | myweight == NULL | mydepth == NULL)
294 gwlarson 3.1 error(SYSTEM, "out of memory in initialize");
295     }
296
297
298 greg 3.8 void
299 gwlarson 3.1 eputs(s) /* put error message to stderr */
300     register char *s;
301     {
302     static int midline = 0;
303
304     if (!*s)
305     return;
306     if (!midline++) { /* prepend line with program name */
307     fputs(progname, stderr);
308     fputs(": ", stderr);
309     }
310     fputs(s, stderr);
311     if (s[strlen(s)-1] == '\n') {
312     fflush(stderr);
313     midline = 0;
314     }
315     }
