1 |
#ifndef lint |
2 |
static const char RCSid[] = "$Id: rhpict.c,v 3.25 2025/07/01 19:40:35 greg Exp $"; |
3 |
#endif |
4 |
5 |
* Radiance holodeck picture generator |
6 |
7 |
8 |
#include <string.h> |
9 |
#include "platform.h" |
10 |
#include "rterror.h" |
11 |
#include "rholo.h" |
12 |
13 |
char *hdkfile; /* holodeck file name */ |
14 |
char gargc; /* global argc */ |
15 |
char **gargv; /* global argv */ |
16 |
17 |
VIEW myview = STDVIEW; /* current output view */ |
18 |
int xres = 512, yres = 512; /* max. horizontal and vertical resolution */ |
19 |
char *outspec = NULL; /* output file specification */ |
20 |
double randfrac = -1.; /* random resampling fraction */ |
21 |
double pixaspect = 1.; /* pixel aspect ratio */ |
22 |
int seqstart = 0; /* sequence start frame */ |
23 |
double expval = 1.; /* exposure value */ |
24 |
25 |
COLOR *mypixel; /* pixels being rendered */ |
26 |
float *myweight; /* weights (used to compute final pixels) */ |
27 |
float *mydepth; /* depth values (visibility culling) */ |
28 |
int hres, vres; /* current horizontal and vertical res. */ |
29 |
30 |
extern int nowarn; /* turn warnings off? */ |
31 |
32 |
static void dopicture(int fn); |
33 |
static void render_frame(PACKHEAD *bl, int nb); |
34 |
static void startpicture(int fn); |
35 |
static int endpicture(void); |
36 |
static void initialize(void); |
37 |
/* from rhpict2.c */ |
38 |
extern void pixFinish(double ransamp); |
39 |
extern void pixBeam(BEAM *bp, HDBEAMI *hb); |
40 |
41 |
42 |
int |
43 |
main( |
44 |
int argc, |
45 |
char *argv[] |
46 |
47 |
48 |
int i, rval; |
49 |
50 |
gargc = argc; gargv = argv; |
51 |
fixargv0(argv[0]); /* get arguments */ |
52 |
for (i = 1; i < argc && argv[i][0] == '-'; i++) { |
53 |
rval = getviewopt(&myview, argc-i, argv+i); |
54 |
if (rval >= 0) { /* view option */ |
55 |
i += rval; |
56 |
continue; |
57 |
58 |
switch (argv[i][1]) { |
59 |
case 'w': /* turn off warnings */ |
60 |
nowarn++; |
61 |
break; |
62 |
case 'p': /* pixel aspect/exposure */ |
63 |
if (badarg(argc-i-1,argv+i+1,"f")) |
64 |
goto userr; |
65 |
if (argv[i][2] == 'a') |
66 |
pixaspect = atof(argv[++i]); |
67 |
else if (argv[i][2] == 'e') { |
68 |
expval = atof(argv[++i]); |
69 |
if ((argv[i][0] == '-') | (argv[i][0] == '+')) |
70 |
expval = pow(2., expval); |
71 |
} else |
72 |
goto userr; |
73 |
break; |
74 |
case 'x': /* horizontal resolution */ |
75 |
if (badarg(argc-i-1,argv+i+1,"i")) |
76 |
goto userr; |
77 |
xres = atoi(argv[++i]); |
78 |
break; |
79 |
case 'y': /* vertical resolution */ |
80 |
81 |
goto userr; |
82 |
yres = atoi(argv[++i]); |
83 |
break; |
84 |
case 'o': /* output file specificaiton */ |
85 |
if (badarg(argc-i-1,argv+i+1,"s")) |
86 |
goto userr; |
87 |
outspec = argv[++i]; |
88 |
break; |
89 |
case 'r': /* random sampling */ |
90 |
91 |
goto userr; |
92 |
randfrac = atof(argv[++i]); |
93 |
break; |
94 |
case 's': /* smooth sampling */ |
95 |
randfrac = -1.; |
96 |
break; |
97 |
case 'S': /* sequence start */ |
98 |
99 |
goto userr; |
100 |
seqstart = atoi(argv[++i]); |
101 |
break; |
102 |
case 'v': /* view file */ |
103 |
if (argv[i][2]!='f' || badarg(argc-i-1,argv+i+1,"s")) |
104 |
goto userr; |
105 |
rval = viewfile(argv[++i], &myview, NULL); |
106 |
if (rval < 0) { |
107 |
sprintf(errmsg, "cannot open view file \"%s\"", |
108 |
argv[i]); |
109 |
error(SYSTEM, errmsg); |
110 |
} else if (rval == 0) { |
111 |
sprintf(errmsg, "bad view file \"%s\"", |
112 |
argv[i]); |
113 |
error(USER, errmsg); |
114 |
115 |
break; |
116 |
default: |
117 |
goto userr; |
118 |
119 |
120 |
/* open holodeck file */ |
121 |
if (i != argc-1) |
122 |
goto userr; |
123 |
hdkfile = argv[i]; |
124 |
initialize(); |
125 |
/* render picture(s) */ |
126 |
if (seqstart <= 0) |
127 |
dopicture(0); |
128 |
else |
129 |
while (nextview(&myview, stdin) != EOF) |
130 |
dopicture(seqstart++); |
131 |
quit(0); /* all done! */ |
132 |
userr: |
133 |
fprintf(stderr, |
134 |
"Usage: %s [-w][-r rf][-pa pa][-pe ex][-x hr][-y vr][-S stfn][-o outp][view] input.hdk\n", |
135 |
progname); |
136 |
quit(1); |
137 |
return 1; /* pro forma return */ |
138 |
139 |
140 |
141 |
static void |
142 |
dopicture( /* render view from holodeck */ |
143 |
int fn |
144 |
145 |
146 |
char *err; |
147 |
int rval; |
148 |
BEAMLIST blist; |
149 |
150 |
if ((err = setview(&myview)) != NULL) { |
151 |
sprintf(errmsg, "%s -- skipping frame %d", err, fn); |
152 |
error(WARNING, errmsg); |
153 |
return; |
154 |
155 |
startpicture(fn); /* open output picture */ |
156 |
/* determine relevant beams */ |
157 |
viewbeams(&myview, hres, vres, &blist); |
158 |
/* render image */ |
159 |
if (blist.nb > 0) { |
160 |
render_frame(blist.bl, blist.nb); |
161 |
free((void *)blist.bl); |
162 |
} else { |
163 |
sprintf(errmsg, "no section visible in frame %d", fn); |
164 |
165 |
166 |
rval = endpicture(); /* write pixel values */ |
167 |
if (rval < 0) { |
168 |
sprintf(errmsg, "error writing frame %d", fn); |
169 |
170 |
171 |
#ifdef DEBUG |
172 |
if (blist.nb > 0 & rval > 0) { |
173 |
sprintf(errmsg, "%d unrendered pixels in frame %d (%.1f%%)", |
174 |
rval, fn, 100.*rval/(hres*vres)); |
175 |
176 |
177 |
#endif |
178 |
179 |
180 |
181 |
static void |
182 |
render_frame( /* render frame from beam values */ |
183 |
PACKHEAD *bl, |
184 |
int nb |
185 |
186 |
187 |
HDBEAMI *bil; |
188 |
int i; |
189 |
190 |
if (nb <= 0) return; |
191 |
if ((bil = (HDBEAMI *)malloc(nb*sizeof(HDBEAMI))) == NULL) |
192 |
error(SYSTEM, "out of memory in render_frame"); |
193 |
for (i = nb; i--; ) { |
194 |
bil[i].h = hdlist[bl[i].hd]; |
195 |
bil[i].b = bl[i].bi; |
196 |
197 |
hdloadbeams(bil, nb, pixBeam); |
198 |
pixFinish(randfrac); |
199 |
free((void *)bil); |
200 |
201 |
202 |
203 |
static void |
204 |
startpicture( /* initialize picture for rendering & output */ |
205 |
int fn |
206 |
207 |
208 |
extern char VersionID[]; |
209 |
double pa = pixaspect; |
210 |
char fname[256]; |
211 |
/* compute picture resolution */ |
212 |
hres = xres; vres = yres; |
213 |
normaspect(viewaspect(&myview), &pa, &hres, &vres); |
214 |
/* prepare output */ |
215 |
if (outspec != NULL) { |
216 |
sprintf(fname, outspec, fn); |
217 |
if (freopen(fname, "wb", stdout) == NULL) { |
218 |
sprintf(errmsg, "cannot open output \"%s\"", fname); |
219 |
220 |
221 |
222 |
/* write header */ |
223 |
newheader("RADIANCE", stdout); |
224 |
printf("SOFTWARE= %s\n", VersionID); |
225 |
printargs(gargc, gargv, stdout); |
226 |
if (fn) |
227 |
printf("FRAME=%d\n", fn); |
228 |
fputs(VIEWSTR, stdout); |
229 |
fprintview(&myview, stdout); |
230 |
fputc('\n', stdout); |
231 |
if ((pa < 0.995) | (pa > 1.005)) |
232 |
fputaspect(pa, stdout); |
233 |
if ((expval < 0.99) | (expval > 1.01)) |
234 |
fputexpos(expval, stdout); |
235 |
fputformat(COLRFMT, stdout); |
236 |
237 |
/* write resolution (standard order) */ |
238 |
fprtresolu(hres, vres, stdout); |
239 |
/* prepare image buffers */ |
240 |
memset((char *)mypixel, '\0', hres*vres*sizeof(COLOR)); |
241 |
memset((char *)myweight, '\0', hres*vres*sizeof(float)); |
242 |
memset((char *)mydepth, '\0', hres*vres*sizeof(float)); |
243 |
244 |
245 |
246 |
static int |
247 |
endpicture(void) /* finish and write out pixels */ |
248 |
249 |
int lastr = -1, nunrend = 0; |
250 |
int32 lastp, lastrp; |
251 |
int32 p; |
252 |
double d; |
253 |
/* compute final pixel values */ |
254 |
for (p = hres*vres; p--; ) { |
255 |
if (myweight[p] <= FTINY) { |
256 |
if (lastr >= 0) { |
257 |
if (p/hres == lastp/hres) |
258 |
copycolor(mypixel[p], mypixel[lastp]); |
259 |
else |
260 |
copycolor(mypixel[p], mypixel[lastrp]); |
261 |
262 |
nunrend++; |
263 |
continue; |
264 |
265 |
d = expval/myweight[p]; |
266 |
scalecolor(mypixel[p], d); |
267 |
if ((lastp=p)/hres != lastr) |
268 |
lastr = (lastrp=p)/hres; |
269 |
270 |
/* write each scanline */ |
271 |
for (p = vres; p--; ) |
272 |
if (fwritescan(mypixel+p*hres, hres, stdout) < 0) |
273 |
return(-1); |
274 |
if (fflush(stdout) == EOF) |
275 |
return(-1); |
276 |
return(nunrend); |
277 |
278 |
279 |
280 |
static void |
281 |
initialize(void) /* initialize holodeck and buffers */ |
282 |
283 |
int fd; |
284 |
FILE *fp; |
285 |
int n; |
286 |
off_t nextloc; |
287 |
288 |
if ((fp = fopen(hdkfile, "rb")) == NULL) { |
289 |
sprintf(errmsg, "cannot open \"%s\" for reading", hdkfile); |
290 |
291 |
292 |
/* check header format */ |
293 |
checkheader(fp, HOLOFMT, NULL); |
294 |
/* check magic number */ |
295 |
if (getw(fp) != HOLOMAGIC) { |
296 |
sprintf(errmsg, "bad magic number in holodeck file \"%s\"", |
297 |
hdkfile); |
298 |
299 |
300 |
nextloc = ftell(fp); /* get stdio position */ |
301 |
fd = dup(fileno(fp)); /* dup file descriptor */ |
302 |
fclose(fp); /* done with stdio */ |
303 |
for (n = 0; nextloc > 0L; n++) { /* initialize each section */ |
304 |
lseek(fd, nextloc, SEEK_SET); |
305 |
read(fd, (char *)&nextloc, sizeof(nextloc)); |
306 |
hdinit(fd, NULL); |
307 |
308 |
/* allocate picture buffer */ |
309 |
mypixel = (COLOR *)bmalloc(xres*yres*sizeof(COLOR)); |
310 |
myweight = (float *)bmalloc(xres*yres*sizeof(float)); |
311 |
mydepth = (float *)bmalloc(xres*yres*sizeof(float)); |
312 |
if ((mypixel == NULL) | (myweight == NULL) | (mydepth == NULL)) |
313 |
error(SYSTEM, "out of memory in initialize"); |
314 |
315 |
316 |
317 |
void |
318 |
eputs(const char *s) /* put error message to stderr */ |
319 |
320 |
static int midline = 0; |
321 |
322 |
if (!*s) |
323 |
return; |
324 |
if (!midline++) { /* prepend line with program name */ |
325 |
fputs(progname, stderr); |
326 |
fputs(": ", stderr); |
327 |
328 |
fputs(s, stderr); |
329 |
if (s[strlen(s)-1] == '\n') { |
330 |
fflush(stderr); |
331 |
midline = 0; |
332 |
333 |
