1 |
/* Copyright (c) 1998 Silicon Graphics, Inc. */ |
2 |
3 |
#ifndef lint |
4 |
static char SCCSid[] = "$SunId$ SGI"; |
5 |
#endif |
6 |
7 |
8 |
* Optimize holodeck for quick access. |
9 |
10 |
* 11/4/98 Greg Ward Larson |
11 |
12 |
13 |
#include "holo.h" |
14 |
15 |
#include <signal.h> |
16 |
17 |
#ifndef BKBSIZE |
18 |
#define BKBSIZE 256 /* beam clump size (kilobytes) */ |
19 |
#endif |
20 |
21 |
char *progname; |
22 |
char tempfile[128]; |
23 |
24 |
extern char *rindex(); |
25 |
extern int quit(); |
26 |
extern long rhinitcopy(); |
27 |
28 |
29 |
main(argc, argv) |
30 |
int argc; |
31 |
char *argv[]; |
32 |
33 |
char *inpname, *outname; |
34 |
int hdfd[2]; |
35 |
long nextipos, lastopos, thisopos; |
36 |
37 |
progname = argv[0]; |
38 |
if (argc < 2 | argc > 3) { |
39 |
fprintf(stderr, "Usage: %s input.hdk [output.hdk]\n", progname); |
40 |
exit(1); |
41 |
42 |
inpname = argv[1]; |
43 |
if (argc == 3) /* use given output file */ |
44 |
outname = argv[2]; |
45 |
else { /* else use temporary file */ |
46 |
if (access(inpname, R_OK|W_OK) < 0) { /* check permissions */ |
47 |
sprintf(errmsg, "cannot access \"%s\"", inpname); |
48 |
error(SYSTEM, errmsg); |
49 |
50 |
strcpy(tempfile, inpname); |
51 |
if ((outname = rindex(tempfile, '/')) != NULL) |
52 |
outname++; |
53 |
else |
54 |
outname = tempfile; |
55 |
sprintf(outname, "rho%d.hdk", getpid()); |
56 |
57 |
58 |
/* copy holodeck file header */ |
59 |
nextipos = rhinitcopy(hdfd, inpname, outname); |
60 |
lastopos = 0L; /* copy sections one by one */ |
61 |
while (nextipos != 0L) { |
62 |
/* set input position; get next */ |
63 |
lseek(hdfd[0], nextipos, 0); |
64 |
read(hdfd[0], (char *)&nextipos, sizeof(nextipos)); |
65 |
/* get output position; set last */ |
66 |
thisopos = lseek(hdfd[1], 0L, 2); |
67 |
if (lastopos > 0L) { |
68 |
lseek(hdfd[1], lastopos, 0); |
69 |
write(hdfd[1], (char *)&thisopos, sizeof(thisopos)); |
70 |
71 |
72 |
lastopos = thisopos; |
73 |
thisopos = 0L; /* write place holder */ |
74 |
75 |
/* copy holodeck section */ |
76 |
copysect(hdfd[0], hdfd[1]); |
77 |
78 |
/* clean up */ |
79 |
close(hdfd[0]); |
80 |
close(hdfd[1]); |
81 |
if (outname == tempfile && rename(outname, inpname) < 0) { |
82 |
sprintf(errmsg, "cannot rename \"%s\" to \"%s\"", |
83 |
outname, inpname); |
84 |
85 |
86 |
exit(0); |
87 |
88 |
89 |
90 |
long |
91 |
rhinitcopy(hfd, infn, outfn) /* open files and copy header */ |
92 |
int hfd[2]; /* returned file descriptors */ |
93 |
char *infn, *outfn; |
94 |
95 |
FILE *infp, *outfp; |
96 |
long ifpos; |
97 |
/* open files for i/o */ |
98 |
if ((infp = fopen(infn, "r")) == NULL) { |
99 |
sprintf(errmsg, "cannot open \"%s\" for reading", infn); |
100 |
101 |
102 |
if ((outfp = fopen(outfn, "w+")) == NULL) { |
103 |
sprintf(errmsg, "cannot open \"%s\" for writing", outfn); |
104 |
105 |
106 |
/* set up signal handling */ |
107 |
if (signal(SIGINT, quit) == SIG_IGN) signal(SIGINT, SIG_IGN); |
108 |
if (signal(SIGHUP, quit) == SIG_IGN) signal(SIGHUP, SIG_IGN); |
109 |
if (signal(SIGTERM, quit) == SIG_IGN) signal(SIGTERM, SIG_IGN); |
110 |
#ifdef SIGXCPU |
111 |
if (signal(SIGXCPU, quit) == SIG_IGN) signal(SIGXCPU, SIG_IGN); |
112 |
if (signal(SIGXFSZ, quit) == SIG_IGN) signal(SIGXFSZ, SIG_IGN); |
113 |
#endif |
114 |
/* copy and verify header */ |
115 |
if (checkheader(infp, HOLOFMT, outfp) < 0 || getw(infp) != HOLOMAGIC) |
116 |
error(USER, "input not in holodeck format"); |
117 |
fputformat(HOLOFMT, outfp); |
118 |
fputc('\n', outfp); |
119 |
putw(HOLOMAGIC, outfp); |
120 |
/* get descriptors and free stdio */ |
121 |
if ((hfd[0] = dup(fileno(infp))) < 0 || |
122 |
(hfd[1] = dup(fileno(outfp))) < 0) |
123 |
error(SYSTEM, "dup call failed in rhinitcopy"); |
124 |
ifpos = ftell(infp); |
125 |
fclose(infp); |
126 |
if (fclose(outfp) == EOF) |
127 |
error(SYSTEM, "file flushing error in rhinitcopy"); |
128 |
/* check cache size */ |
129 |
if (BKBSIZE*1024*1.5 > hdcachesize) |
130 |
hdcachesize = BKBSIZE*1024*1.5; |
131 |
/* return input position */ |
132 |
return(ifpos); |
133 |
134 |
135 |
136 |
static BEAMI *beamdir; |
137 |
138 |
static int |
139 |
bpcmp(b1p, b2p) /* compare beam positions on disk */ |
140 |
int *b1p, *b2p; |
141 |
142 |
register long pdif = beamdir[*b1p].fo - beamdir[*b2p].fo; |
143 |
144 |
if (pdif > 0L) return(1); |
145 |
if (pdif < 0L) return(-1); |
146 |
return(0); |
147 |
148 |
149 |
static HOLO *hout; |
150 |
151 |
static int |
152 |
xferclump(hp, bq, nb) /* transfer the given clump to hout and free */ |
153 |
HOLO *hp; |
154 |
int *bq, nb; |
155 |
156 |
register int i; |
157 |
register BEAM *bp; |
158 |
159 |
beamdir = hp->bi; /* sort based on file position */ |
160 |
qsort((char *)bq, nb, sizeof(*bq), bpcmp); |
161 |
/* transfer and free each beam */ |
162 |
for (i = 0; i < nb; i++) { |
163 |
bp = hdgetbeam(hp, bq[i]); |
164 |
bcopy((char *)hdbray(bp), (char *)hdnewrays(hout,bq[i],bp->nrm), |
165 |
bp->nrm*sizeof(RAYVAL)); |
166 |
hdfreebeam(hp, bq[i]); |
167 |
168 |
hdflush(hout); /* write & free clump */ |
169 |
return(0); |
170 |
171 |
172 |
copysect(ifd, ofd) /* copy holodeck section from ifd to ofd */ |
173 |
int ifd, ofd; |
174 |
175 |
HOLO *hinp; |
176 |
/* load input section directory */ |
177 |
hinp = hdinit(ifd, NULL); |
178 |
/* create output section directory */ |
179 |
hout = hdinit(ofd, (HDGRID *)hinp); |
180 |
/* clump the beams */ |
181 |
clumpbeams(hinp, 0, BKBSIZE*1024, xferclump); |
182 |
/* clean up */ |
183 |
hddone(hinp); |
184 |
hddone(hout); |
185 |
186 |
187 |
188 |
eputs(s) /* put error message to stderr */ |
189 |
register char *s; |
190 |
191 |
static int midline = 0; |
192 |
193 |
if (!*s) |
194 |
return; |
195 |
if (!midline++) { /* prepend line with program name */ |
196 |
fputs(progname, stderr); |
197 |
fputs(": ", stderr); |
198 |
199 |
fputs(s, stderr); |
200 |
if (s[strlen(s)-1] == '\n') { |
201 |
fflush(stderr); |
202 |
midline = 0; |
203 |
204 |
205 |
206 |
207 |
quit(code) /* exit the program gracefully */ |
208 |
int code; |
209 |
210 |
if (tempfile[0]) |
211 |
unlink(tempfile); |
212 |
exit(code); |
213 |
