root/radiance/ray/src/hd/rhoptimize.c
Revision: 3.4
Committed: Mon Nov 9 17:11:40 1998 UTC (25 years, 6 months ago) by gwlarson
Changes since 3.3: +15 -164 lines
moved routines to clumpbeams.c and made rhcopy clump beams
1 /* Copyright (c) 1998 Silicon Graphics, Inc. */
2
3 #ifndef lint
4 static char SCCSid[] = "$SunId$ SGI";
5 #endif
6
7 /*
8 * Optimize holodeck for quick access.
9 *
10 * 11/4/98 Greg Ward Larson
11 */
12
13 #include "holo.h"
14
15 #include <signal.h>
16
17 #ifndef BKBSIZE
18 #define BKBSIZE 256 /* beam clump size (kilobytes) */
19 #endif
20
21 char *progname;
22 char tempfile[128];
23
24 extern char *rindex();
25 extern int quit();
26 extern long rhinitcopy();
27
28
29 main(argc, argv)
30 int argc;
31 char *argv[];
32 {
33 char *inpname, *outname;
34 int hdfd[2];
35 long nextipos, lastopos, thisopos;
36
37 progname = argv[0];
38 if (argc < 2 | argc > 3) {
39 fprintf(stderr, "Usage: %s input.hdk [output.hdk]\n", progname);
40 exit(1);
41 }
42 inpname = argv[1];
43 if (argc == 3) /* use given output file */
44 outname = argv[2];
45 else { /* else use temporary file */
46 if (access(inpname, R_OK|W_OK) < 0) { /* check permissions */
47 sprintf(errmsg, "cannot access \"%s\"", inpname);
48 error(SYSTEM, errmsg);
49 }
50 strcpy(tempfile, inpname);
51 if ((outname = rindex(tempfile, '/')) != NULL)
52 outname++;
53 else
54 outname = tempfile;
55 sprintf(outname, "rho%d.hdk", getpid());
56 outname = tempfile;
57 }
58 /* copy holodeck file header */
59 nextipos = rhinitcopy(hdfd, inpname, outname);
60 lastopos = 0L; /* copy sections one by one */
61 while (nextipos != 0L) {
62 /* set input position; get next */
63 lseek(hdfd[0], nextipos, 0);
64 read(hdfd[0], (char *)&nextipos, sizeof(nextipos));
65 /* get output position; set last */
66 thisopos = lseek(hdfd[1], 0L, 2);
67 if (lastopos > 0L) {
68 lseek(hdfd[1], lastopos, 0);
69 write(hdfd[1], (char *)&thisopos, sizeof(thisopos));
70 lseek(hdfd[1], 0L, 2);
71 }
72 lastopos = thisopos;
73 thisopos = 0L; /* write place holder */
74 write(hdfd[1], (char *)&thisopos, sizeof(thisopos));
75 /* copy holodeck section */
76 copysect(hdfd[0], hdfd[1]);
77 }
78 /* clean up */
79 close(hdfd[0]);
80 close(hdfd[1]);
81 if (outname == tempfile && rename(outname, inpname) < 0) {
82 sprintf(errmsg, "cannot rename \"%s\" to \"%s\"",
83 outname, inpname);
84 error(SYSTEM, errmsg);
85 }
86 exit(0);
87 }
88
89
90 long
91 rhinitcopy(hfd, infn, outfn) /* open files and copy header */
92 int hfd[2]; /* returned file descriptors */
93 char *infn, *outfn;
94 {
95 FILE *infp, *outfp;
96 long ifpos;
97 /* open files for i/o */
98 if ((infp = fopen(infn, "r")) == NULL) {
99 sprintf(errmsg, "cannot open \"%s\" for reading", infn);
100 error(SYSTEM, errmsg);
101 }
102 if ((outfp = fopen(outfn, "w+")) == NULL) {
103 sprintf(errmsg, "cannot open \"%s\" for writing", outfn);
104 error(SYSTEM, errmsg);
105 }
106 /* set up signal handling */
107 if (signal(SIGINT, quit) == SIG_IGN) signal(SIGINT, SIG_IGN);
108 if (signal(SIGHUP, quit) == SIG_IGN) signal(SIGHUP, SIG_IGN);
109 if (signal(SIGTERM, quit) == SIG_IGN) signal(SIGTERM, SIG_IGN);
110 #ifdef SIGXCPU
111 if (signal(SIGXCPU, quit) == SIG_IGN) signal(SIGXCPU, SIG_IGN);
112 if (signal(SIGXFSZ, quit) == SIG_IGN) signal(SIGXFSZ, SIG_IGN);
113 #endif
114 /* copy and verify header */
115 if (checkheader(infp, HOLOFMT, outfp) < 0 || getw(infp) != HOLOMAGIC)
116 error(USER, "input not in holodeck format");
117 fputformat(HOLOFMT, outfp);
118 fputc('\n', outfp);
119 putw(HOLOMAGIC, outfp);
120 /* get descriptors and free stdio */
121 if ((hfd[0] = dup(fileno(infp))) < 0 ||
122 (hfd[1] = dup(fileno(outfp))) < 0)
123 error(SYSTEM, "dup call failed in rhinitcopy");
124 ifpos = ftell(infp);
125 fclose(infp);
126 if (fclose(outfp) == EOF)
127 error(SYSTEM, "file flushing error in rhinitcopy");
128 /* check cache size */
129 if (BKBSIZE*1024*1.5 > hdcachesize)
130 hdcachesize = BKBSIZE*1024*1.5;
131 /* return input position */
132 return(ifpos);
133 }
134
135
136 static HOLO *hout; /* output holodeck section */
137
138 static int
139 xferbeam(bp, hb) /* transfer the given beam to hout and free */
140 register BEAM *bp;
141 HDBEAMI *hb;
142 {
143 bcopy((char *)hdbray(bp), (char *)hdnewrays(hout,hb->b,bp->nrm),
144 bp->nrm*sizeof(RAYVAL));
145 hdfreebeam(hb->h, hb->b);
146 return(0);
147 }
148
149 copysect(ifd, ofd) /* copy holodeck section from ifd to ofd */
150 int ifd, ofd;
151 {
152 HOLO *hinp;
153 /* load input section directory */
154 hinp = hdinit(ifd, NULL);
155 /* create output section directory */
156 hout = hdinit(ofd, (HDGRID *)hinp);
157 /* clump the beams */
158 clumpbeams(hinp, 0, BKBSIZE*1024, xferbeam);
159 /* clean up */
160 hddone(hinp);
161 hddone(hout);
162 }
163
164
165 eputs(s) /* put error message to stderr */
166 register char *s;
167 {
168 static int midline = 0;
169
170 if (!*s)
171 return;
172 if (!midline++) { /* prepend line with program name */
173 fputs(progname, stderr);
174 fputs(": ", stderr);
175 }
176 fputs(s, stderr);
177 if (s[strlen(s)-1] == '\n') {
178 fflush(stderr);
179 midline = 0;
180 }
181 }
182
183
184 quit(code) /* exit the program gracefully */
185 int code;
186 {
187 if (tempfile[0])
188 unlink(tempfile);
189 exit(code);
190 }
