1 |
#ifndef lint |
2 |
static const char RCSid[] = "$Id$"; |
3 |
#endif |
4 |
5 |
* Optimize holodeck for quick access. |
6 |
7 |
* 11/4/98 Greg Ward Larson |
8 |
9 |
10 |
#include "holo.h" |
11 |
12 |
#include <signal.h> |
13 |
14 |
#ifndef BKBSIZE |
15 |
#define BKBSIZE 256 /* beam clump size (kilobytes) */ |
16 |
#endif |
17 |
18 |
char *progname; |
19 |
char tempfile[128]; |
20 |
int dupchecking = 0; |
21 |
22 |
extern char *rindex(); |
23 |
extern long rhinitcopy(); |
24 |
25 |
26 |
main(argc, argv) |
27 |
int argc; |
28 |
char *argv[]; |
29 |
30 |
char *inpname, *outname; |
31 |
int hdfd[2]; |
32 |
long nextipos, lastopos, thisopos; |
33 |
34 |
progname = argv[0]; |
35 |
argv++; argc--; /* duplicate checking flag? */ |
36 |
if (argc > 1 && !strcmp(argv[0], "-u")) { |
37 |
dupchecking++; |
38 |
argv++; argc--; |
39 |
40 |
if (argc < 1 | argc > 2) { |
41 |
fprintf(stderr, "Usage: %s [-u] input.hdk [output.hdk]\n", |
42 |
progname); |
43 |
exit(1); |
44 |
45 |
inpname = argv[0]; /* get input file */ |
46 |
argv++; argc--; |
47 |
if (argc == 1) /* use given output file */ |
48 |
outname = argv[0]; |
49 |
else { /* else use temporary file */ |
50 |
if (access(inpname, R_OK|W_OK) < 0) { /* check permissions */ |
51 |
sprintf(errmsg, "cannot access \"%s\"", inpname); |
52 |
error(SYSTEM, errmsg); |
53 |
54 |
strcpy(tempfile, inpname); |
55 |
if ((outname = rindex(tempfile, '/')) != NULL) |
56 |
outname++; |
57 |
else |
58 |
outname = tempfile; |
59 |
sprintf(outname, "rho%d.hdk", getpid()); |
60 |
61 |
62 |
/* copy holodeck file header */ |
63 |
nextipos = rhinitcopy(hdfd, inpname, outname); |
64 |
lastopos = 0L; /* copy sections one by one */ |
65 |
while (nextipos != 0L) { |
66 |
/* set input position; get next */ |
67 |
lseek(hdfd[0], (off_t)nextipos, 0); |
68 |
read(hdfd[0], (char *)&nextipos, sizeof(nextipos)); |
69 |
/* get output position; set last */ |
70 |
thisopos = lseek(hdfd[1], (off_t)0L, 2); |
71 |
if (lastopos > 0L) { |
72 |
lseek(hdfd[1], (off_t)lastopos, 0); |
73 |
write(hdfd[1], (char *)&thisopos, sizeof(thisopos)); |
74 |
75 |
76 |
lastopos = thisopos; |
77 |
thisopos = 0L; /* write place holder */ |
78 |
79 |
/* copy holodeck section */ |
80 |
copysect(hdfd[0], hdfd[1]); |
81 |
82 |
/* clean up */ |
83 |
close(hdfd[0]); |
84 |
close(hdfd[1]); |
85 |
if (outname == tempfile && rename(outname, inpname) < 0) { |
86 |
sprintf(errmsg, "cannot rename \"%s\" to \"%s\"", |
87 |
outname, inpname); |
88 |
89 |
90 |
exit(0); |
91 |
92 |
93 |
94 |
long |
95 |
rhinitcopy(hfd, infn, outfn) /* open files and copy header */ |
96 |
int hfd[2]; /* returned file descriptors */ |
97 |
char *infn, *outfn; |
98 |
99 |
FILE *infp, *outfp; |
100 |
long ifpos; |
101 |
/* open files for i/o */ |
102 |
if ((infp = fopen(infn, "r")) == NULL) { |
103 |
sprintf(errmsg, "cannot open \"%s\" for reading", infn); |
104 |
105 |
106 |
if (access(outfn, F_OK) == 0) { |
107 |
sprintf(errmsg, "output file \"%s\" already exists!", outfn); |
108 |
error(USER, errmsg); |
109 |
110 |
if ((outfp = fopen(outfn, "w+")) == NULL) { |
111 |
sprintf(errmsg, "cannot open \"%s\" for writing", outfn); |
112 |
113 |
114 |
/* set up signal handling */ |
115 |
if (signal(SIGINT, quit) == SIG_IGN) signal(SIGINT, SIG_IGN); |
116 |
if (signal(SIGHUP, quit) == SIG_IGN) signal(SIGHUP, SIG_IGN); |
117 |
if (signal(SIGTERM, quit) == SIG_IGN) signal(SIGTERM, SIG_IGN); |
118 |
#ifdef SIGXCPU |
119 |
if (signal(SIGXCPU, quit) == SIG_IGN) signal(SIGXCPU, SIG_IGN); |
120 |
if (signal(SIGXFSZ, quit) == SIG_IGN) signal(SIGXFSZ, SIG_IGN); |
121 |
#endif |
122 |
/* copy and verify header */ |
123 |
if (checkheader(infp, HOLOFMT, outfp) < 0 || getw(infp) != HOLOMAGIC) |
124 |
error(USER, "input not in holodeck format"); |
125 |
fputformat(HOLOFMT, outfp); |
126 |
fputc('\n', outfp); |
127 |
putw(HOLOMAGIC, outfp); |
128 |
/* get descriptors and free stdio */ |
129 |
if ((hfd[0] = dup(fileno(infp))) < 0 || |
130 |
(hfd[1] = dup(fileno(outfp))) < 0) |
131 |
error(SYSTEM, "dup call failed in rhinitcopy"); |
132 |
ifpos = ftell(infp); |
133 |
fclose(infp); |
134 |
if (fclose(outfp) == EOF) |
135 |
error(SYSTEM, "file flushing error in rhinitcopy"); |
136 |
/* check cache size */ |
137 |
if (BKBSIZE*1024*1.5 > hdcachesize) |
138 |
hdcachesize = BKBSIZE*1024*1.5; |
139 |
/* return input position */ |
140 |
return(ifpos); |
141 |
142 |
143 |
144 |
int |
145 |
nuniq(rva, n) /* sort unique rays to front of beam list */ |
146 |
register RAYVAL *rva; |
147 |
int n; |
148 |
149 |
register int i, j; |
150 |
RAYVAL rtmp; |
151 |
152 |
for (j = 0; j < n; j++) |
153 |
for (i = j+1; i < n; i++) |
154 |
if ( rva[i].d == rva[j].d && |
155 |
rva[i].r[0][0]==rva[j].r[0][0] && |
156 |
rva[i].r[0][1]==rva[j].r[0][1] && |
157 |
rva[i].r[1][0]==rva[j].r[1][0] && |
158 |
rva[i].r[1][1]==rva[j].r[1][1] ) { |
159 |
n--; /* swap duplicate with end */ |
160 |
copystruct(&rtmp, rva+n); |
161 |
copystruct(rva+n, rva+i); |
162 |
copystruct(rva+i, &rtmp); |
163 |
i--; /* recheck one we swapped */ |
164 |
165 |
return(n); |
166 |
167 |
168 |
169 |
static BEAMI *beamdir; |
170 |
171 |
static int |
172 |
bpcmp(b1p, b2p) /* compare beam positions on disk */ |
173 |
int *b1p, *b2p; |
174 |
175 |
register off_t pdif = beamdir[*b1p].fo - beamdir[*b2p].fo; |
176 |
177 |
if (pdif < 0L) return(-1); |
178 |
return(pdif > 0L); |
179 |
180 |
181 |
static HOLO *hout; |
182 |
183 |
static int |
184 |
xferclump(hp, bq, nb) /* transfer the given clump to hout and free */ |
185 |
HOLO *hp; |
186 |
int *bq, nb; |
187 |
188 |
register int i; |
189 |
register BEAM *bp; |
190 |
int n; |
191 |
192 |
beamdir = hp->bi; /* sort based on file position */ |
193 |
qsort((void *)bq, nb, sizeof(*bq), bpcmp); |
194 |
/* transfer and free each beam */ |
195 |
for (i = 0; i < nb; i++) { |
196 |
bp = hdgetbeam(hp, bq[i]); |
197 |
DCHECK(bp==NULL, CONSISTENCY, "empty beam in xferclump"); |
198 |
n = dupchecking ? nuniq(hdbray(bp),bp->nrm) : bp->nrm; |
199 |
bcopy((void *)hdbray(bp), (void *)hdnewrays(hout,bq[i],n), |
200 |
n*sizeof(RAYVAL)); |
201 |
hdfreebeam(hp, bq[i]); |
202 |
203 |
hdfreebeam(hout, 0); /* write & free clump */ |
204 |
return(0); |
205 |
206 |
207 |
copysect(ifd, ofd) /* copy holodeck section from ifd to ofd */ |
208 |
int ifd, ofd; |
209 |
210 |
HOLO *hinp; |
211 |
/* load input section directory */ |
212 |
hinp = hdinit(ifd, NULL); |
213 |
/* create output section directory */ |
214 |
hout = hdinit(ofd, (HDGRID *)hinp); |
215 |
/* clump the beams */ |
216 |
clumpbeams(hinp, 0, BKBSIZE*1024, xferclump); |
217 |
/* clean up */ |
218 |
hddone(hinp); |
219 |
hddone(hout); |
220 |
221 |
222 |
223 |
void |
224 |
eputs(s) /* put error message to stderr */ |
225 |
register char *s; |
226 |
227 |
static int midline = 0; |
228 |
229 |
if (!*s) |
230 |
return; |
231 |
if (!midline++) { /* prepend line with program name */ |
232 |
fputs(progname, stderr); |
233 |
fputs(": ", stderr); |
234 |
235 |
fputs(s, stderr); |
236 |
if (s[strlen(s)-1] == '\n') { |
237 |
fflush(stderr); |
238 |
midline = 0; |
239 |
240 |
241 |
242 |
243 |
void |
244 |
quit(code) /* exit the program gracefully */ |
245 |
int code; |
246 |
247 |
if (tempfile[0]) |
248 |
unlink(tempfile); |
249 |
exit(code); |
250 |
