--- ray/src/hd/rhoptimize.c 1998/11/12 15:07:49 3.5 +++ ray/src/hd/rhoptimize.c 2003/07/14 20:02:29 3.13 @@ -1,28 +1,26 @@ -/* Copyright (c) 1998 Silicon Graphics, Inc. */ - #ifndef lint -static char SCCSid[] = "$SunId$ SGI"; +static const char RCSid[] = "$Id: rhoptimize.c,v 3.13 2003/07/14 20:02:29 schorsch Exp $"; #endif - /* * Optimize holodeck for quick access. * * 11/4/98 Greg Ward Larson */ -#include "holo.h" - #include +#include +#include "rtprocess.h" /* getpid() */ +#include "holo.h" + #ifndef BKBSIZE #define BKBSIZE 256 /* beam clump size (kilobytes) */ #endif char *progname; char tempfile[128]; +int dupchecking = 0; -extern char *rindex(); -extern int quit(); extern long rhinitcopy(); @@ -35,20 +33,27 @@ char *argv[]; long nextipos, lastopos, thisopos; progname = argv[0]; - if (argc < 2 | argc > 3) { - fprintf(stderr, "Usage: %s input.hdk [output.hdk]\n", progname); + argv++; argc--; /* duplicate checking flag? */ + if (argc > 1 && !strcmp(argv[0], "-u")) { + dupchecking++; + argv++; argc--; + } + if (argc < 1 | argc > 2) { + fprintf(stderr, "Usage: %s [-u] input.hdk [output.hdk]\n", + progname); exit(1); } - inpname = argv[1]; - if (argc == 3) /* use given output file */ - outname = argv[2]; + inpname = argv[0]; /* get input file */ + argv++; argc--; + if (argc == 1) /* use given output file */ + outname = argv[0]; else { /* else use temporary file */ if (access(inpname, R_OK|W_OK) < 0) { /* check permissions */ sprintf(errmsg, "cannot access \"%s\"", inpname); error(SYSTEM, errmsg); } strcpy(tempfile, inpname); - if ((outname = rindex(tempfile, '/')) != NULL) + if ((outname = strrchr(tempfile, '/')) != NULL) outname++; else outname = tempfile; @@ -60,14 +65,14 @@ char *argv[]; lastopos = 0L; /* copy sections one by one */ while (nextipos != 0L) { /* set input position; get next */ - lseek(hdfd[0], nextipos, 0); + lseek(hdfd[0], (off_t)nextipos, 0); read(hdfd[0], (char *)&nextipos, sizeof(nextipos)); /* get output position; set last */ - thisopos = lseek(hdfd[1], 0L, 2); + thisopos = lseek(hdfd[1], (off_t)0, 2); if (lastopos > 0L) { - lseek(hdfd[1], lastopos, 0); + lseek(hdfd[1], (off_t)lastopos, 0); write(hdfd[1], (char *)&thisopos, sizeof(thisopos)); - lseek(hdfd[1], 0L, 2); + lseek(hdfd[1], (off_t)0, 2); } lastopos = thisopos; thisopos = 0L; /* write place holder */ @@ -99,6 +104,10 @@ char *infn, *outfn; sprintf(errmsg, "cannot open \"%s\" for reading", infn); error(SYSTEM, errmsg); } + if (access(outfn, F_OK) == 0) { + sprintf(errmsg, "output file \"%s\" already exists!", outfn); + error(USER, errmsg); + } if ((outfp = fopen(outfn, "w+")) == NULL) { sprintf(errmsg, "cannot open \"%s\" for writing", outfn); error(SYSTEM, errmsg); @@ -133,17 +142,41 @@ char *infn, *outfn; } +int +nuniq(rva, n) /* sort unique rays to front of beam list */ +register RAYVAL *rva; +int n; +{ + register int i, j; + RAYVAL rtmp; + + for (j = 0; j < n; j++) + for (i = j+1; i < n; i++) + if ( rva[i].d == rva[j].d && + rva[i].r[0][0]==rva[j].r[0][0] && + rva[i].r[0][1]==rva[j].r[0][1] && + rva[i].r[1][0]==rva[j].r[1][0] && + rva[i].r[1][1]==rva[j].r[1][1] ) { + n--; /* swap duplicate with end */ + copystruct(&rtmp, rva+n); + copystruct(rva+n, rva+i); + copystruct(rva+i, &rtmp); + i--; /* recheck one we swapped */ + } + return(n); +} + + static BEAMI *beamdir; static int bpcmp(b1p, b2p) /* compare beam positions on disk */ int *b1p, *b2p; { - register long pdif = beamdir[*b1p].fo - beamdir[*b2p].fo; + register off_t pdif = beamdir[*b1p].fo - beamdir[*b2p].fo; - if (pdif > 0L) return(1); if (pdif < 0L) return(-1); - return(0); + return(pdif > 0L); } static HOLO *hout; @@ -155,17 +188,20 @@ int *bq, nb; { register int i; register BEAM *bp; + int n; beamdir = hp->bi; /* sort based on file position */ - qsort((char *)bq, nb, sizeof(*bq), bpcmp); + qsort((void *)bq, nb, sizeof(*bq), bpcmp); /* transfer and free each beam */ for (i = 0; i < nb; i++) { bp = hdgetbeam(hp, bq[i]); - bcopy((char *)hdbray(bp), (char *)hdnewrays(hout,bq[i],bp->nrm), - bp->nrm*sizeof(RAYVAL)); + DCHECK(bp==NULL, CONSISTENCY, "empty beam in xferclump"); + n = dupchecking ? nuniq(hdbray(bp),bp->nrm) : bp->nrm; + memcpy((void *)hdnewrays(hout,bq[i],n),(void *)hdbray(bp), + n*sizeof(RAYVAL)); hdfreebeam(hp, bq[i]); } - hdflush(hout); /* write & free clump */ + hdfreebeam(hout, 0); /* write & free clump */ return(0); } @@ -185,6 +221,7 @@ int ifd, ofd; } +void eputs(s) /* put error message to stderr */ register char *s; { @@ -204,6 +241,7 @@ register char *s; } +void quit(code) /* exit the program gracefully */ int code; {
