--- ray/src/hd/rhoptimize.c 1998/11/04 16:37:19 3.1 +++ ray/src/hd/rhoptimize.c 1998/11/06 16:54:23 3.3 @@ -12,13 +12,22 @@ static char SCCSid[] = "$SunId$ SGI"; #include "holo.h" +#include + #ifndef BKBSIZE -#define BKBSIZE 64 /* beam clump size (kilobytes) */ +#define BKBSIZE 256 /* beam clump size (kilobytes) */ #endif +#define flgop(p,i,op) ((p)[(i)>>5] op (1L<<((i)&0x1f))) +#define isset(p,i) flgop(p,i,&) +#define setfl(p,i) flgop(p,i,|=) +#define clrfl(p,i) flgop(p,i,&=~) char *progname; +char tempfile[128]; +extern char *rindex(); +extern int quit(); extern long rhinitcopy(); @@ -26,7 +35,6 @@ main(argc, argv) int argc; char *argv[]; { - char nambuf[128]; char *inpname, *outname; int hdfd[2]; long nextipos, lastopos, thisopos; @@ -39,14 +47,18 @@ char *argv[]; inpname = argv[1]; if (argc == 3) /* use given output file */ outname = argv[2]; - else { /* else create temporary file */ - strcpy(nambuf, inpname); - if ((outname = strrchr(nambuf, '/')) != NULL) + else { /* else use temporary file */ + if (access(inpname, R_OK|W_OK) < 0) { /* check permissions */ + sprintf(errmsg, "cannot access \"%s\"", inpname); + error(SYSTEM, errmsg); + } + strcpy(tempfile, inpname); + if ((outname = rindex(tempfile, '/')) != NULL) outname++; else - outname = nambuf; + outname = tempfile; sprintf(outname, "rho%d.hdk", getpid()); - outname = nambuf; + outname = tempfile; } /* copy holodeck file header */ nextipos = rhinitcopy(hdfd, inpname, outname); @@ -71,7 +83,7 @@ char *argv[]; /* clean up */ close(hdfd[0]); close(hdfd[1]); - if (argc == 2 && rename(outname, inpname) < 0) { + if (outname == tempfile && rename(outname, inpname) < 0) { sprintf(errmsg, "cannot rename \"%s\" to \"%s\"", outname, inpname); error(SYSTEM, errmsg); @@ -96,9 +108,16 @@ char *infn, *outfn; sprintf(errmsg, "cannot open \"%s\" for writing", outfn); error(SYSTEM, errmsg); } + /* set up signal handling */ + if (signal(SIGINT, quit) == SIG_IGN) signal(SIGINT, SIG_IGN); + if (signal(SIGHUP, quit) == SIG_IGN) signal(SIGHUP, SIG_IGN); + if (signal(SIGTERM, quit) == SIG_IGN) signal(SIGTERM, SIG_IGN); +#ifdef SIGXCPU + if (signal(SIGXCPU, quit) == SIG_IGN) signal(SIGXCPU, SIG_IGN); + if (signal(SIGXFSZ, quit) == SIG_IGN) signal(SIGXFSZ, SIG_IGN); +#endif /* copy and verify header */ - if (checkheader(infp, HOLOFMT, outfp) < 0 || - getw(infp) != HOLOMAGIC) + if (checkheader(infp, HOLOFMT, outfp) < 0 || getw(infp) != HOLOMAGIC) error(USER, "input not in holodeck format"); fputformat(HOLOFMT, outfp); fputc('\n', outfp); @@ -111,7 +130,7 @@ char *infn, *outfn; fclose(infp); if (fclose(outfp) == EOF) error(SYSTEM, "file flushing error in rhinitcopy"); - /* we flush everything manually */ + /* flush everything manually hence */ hdcachesize = 0; /* return input position */ return(ifpos); @@ -149,14 +168,14 @@ HOLO *hp; GCOORD *gc; { GCOORD gci0; - int i, j; + register int i, j; for (i = 3; i--; ) { copystruct(&gci0, gc); gcshifti(&gci0, 0, i-1, hp); for (j = 3; j--; ) { copystruct(ng+(3*i+j), &gci0); - gcshifti(ng+(3*i+j), 1, j-1, hp); + gcshifti(ng+(3*i+j), gci0.w==gc->w, j-1, hp); } } } @@ -181,35 +200,63 @@ int b; bneighrem = 0; for (i = 9; i--; ) for (j = 9; j--; ) { - if (i == 4 & j == 4) + if (i == 4 & j == 4) /* don't copy starting beam */ continue; + if (wg0[i].w == wg1[j].w) + continue; copystruct(bgc, wg0+i); copystruct(bgc+1, wg1+j); bneighlist[bneighrem++] = hdbindex(hp, bgc); +#ifdef DEBUG + if (bneighlist[bneighrem-1] <= 0) + error(CONSISTENCY, "bad beam in firstneigh"); +#endif } return(nextneigh()); } +BEAMI *beamdir; + +int +bpcmp(b1p, b2p) /* compare beam positions on disk */ +int *b1p, *b2p; +{ + register long pdif = beamdir[*b1p].fo - beamdir[*b2p].fo; + + if (pdif > 0L) return(1); + if (pdif < 0L) return(-1); + return(0); +} + + copysect(ifd, ofd) /* copy holodeck section from ifd to ofd */ int ifd, ofd; { -#define beamdone(b) (!hinp->bi[b].nrd || bnrays(hout,b)) static short primes[] = {9431,6803,4177,2659,1609,887,587,251,47,1}; - register HOLO *hinp, *hout; + register HOLO *hinp; + HOLO *hout; register BEAM *bp; + unsigned int4 *bflags; int *bqueue; int bqlen; int4 bqtotal; - int bc, bci, bqc, bnc, myprime; + int bc, bci, bqc, myprime; register int i; /* load input section directory */ hinp = hdinit(ifd, NULL); /* create output section directory */ hout = hdinit(ofd, (HDGRID *)hinp); /* allocate beam queue */ - if ((bqueue = (int *)malloc(nbeams(hinp)*sizeof(int))) == NULL) + bqueue = (int *)malloc(nbeams(hinp)*sizeof(int)); + bflags = (unsigned int4 *)calloc((nbeams(hinp)>>5)+1, + sizeof(unsigned int4)); + if (bqueue == NULL | bflags == NULL) error(SYSTEM, "out of memory in copysect"); + /* mark empty beams as done */ + for (i = nbeams(hinp); i > 0; i--) + if (!hinp->bi[i].nrd) + setfl(bflags, i); /* pick a good prime step size */ for (i = 0; primes[i]<<5 >= nbeams(hinp); i++) ; @@ -219,44 +266,48 @@ int ifd, ofd; /* add each input beam and neighbors */ for (bc = bci = nbeams(hinp); bc > 0; bc--, bci += bci>myprime ? -myprime : nbeams(hinp)-myprime) { - if (beamdone(bci)) + if (isset(bflags, bci)) continue; bqueue[0] = bci; /* initialize queue */ bqlen = 1; - bqtotal = bnrays(hinp, bci); + bqtotal = hinp->bi[bci].nrd; + setfl(bflags, bci); /* run through growing queue */ for (bqc = 0; bqc < bqlen; bqc++) { - /* transfer the beam */ - bp = hdgetbeam(hinp, bqueue[bqc]); - bcopy((char *)hdbray(bp), - (char *)hdnewrays(hout,bqueue[bqc],bp->nrm), - bp->nrm*sizeof(RAYVAL)); - hdfreebeam(hinp, bqueue[bqc]); - /* check queue size */ - if (bqtotal >= BKBSIZE*1024/sizeof(RAYVAL)) - continue; - /* add neighbors to queue */ - for (bnc = firstneigh(hinp,bqueue[bqc]); bnc > 0; - bnc = nextneigh()) { - if (beamdone(bnc)) /* see if valid */ + /* add neighbors until full */ + for (i = firstneigh(hinp,bqueue[bqc]); i > 0; + i = nextneigh()) { + if (isset(bflags, i)) /* done already? */ continue; - for (i = bqlen; i--; ) - if (bqueue[i] == bnc) break; - if (i >= 0) - continue; - bqueue[bqlen++] = bnc; /* add it */ - bqtotal += bnrays(hinp, bnc); + bqueue[bqlen++] = i; /* add it */ + bqtotal += hinp->bi[i].nrd; + setfl(bflags, i); if (bqtotal >= BKBSIZE*1024/sizeof(RAYVAL)) break; /* queue full */ } + if (i > 0) + break; } + beamdir = hinp->bi; /* sort queue */ + qsort((char *)bqueue, bqlen, sizeof(*bqueue), bpcmp); + /* transfer each beam */ + for (i = 0; i < bqlen; i++) { + bp = hdgetbeam(hinp, bqueue[i]); + bcopy((char *)hdbray(bp), + (char *)hdnewrays(hout,bqueue[i],bp->nrm), + bp->nrm*sizeof(RAYVAL)); + hdfreebeam(hinp, bqueue[i]); + } hdfreebeam(hout, 0); /* flush output block */ +#ifdef DEBUG + hdsync(hout, 0); +#endif } /* we're done -- clean up */ free((char *)bqueue); + free((char *)bflags); hddone(hinp); hddone(hout); -#undef beamdone } @@ -282,6 +333,7 @@ register char *s; quit(code) /* exit the program gracefully */ int code; { - hdsync(NULL, 1); /* write out any buffered data */ + if (tempfile[0]) + unlink(tempfile); exit(code); }
