root/radiance/ray/src/hd/rhoptimize.c
Mon Feb 6 22:40:21 2023 UTC (2 years, 6 months ago) by greg
Changes since 3.23: +2 -3 lines
Diff to previous 3.23 , to selected 3.1
Mon Oct 21 18:19:32 2019 UTC (5 years, 9 months ago) by greg
Changes since 3.22: +3 -3 lines
Diff to previous 3.22 , to selected 3.1
Added binary option for Windows
Fri Oct 5 19:19:16 2018 UTC (6 years, 10 months ago) by greg
Changes since 3.21: +8 -8 lines
Diff to previous 3.21 , to selected 3.1
Mon Mar 7 01:15:01 2016 UTC (9 years, 5 months ago) by schorsch
Changes since 3.20: +7 -1 lines
Diff to previous 3.20 , to selected 3.1
Enable SCons windows build
Thu Sep 30 15:43:30 2010 UTC (14 years, 10 months ago) by greg
Changes since 3.19: +7 -7 lines
Diff to previous 3.19 , to selected 3.1
Changed holodeck section pointers to off_t to avoid issues with rhcopy
Sun Sep 26 15:39:10 2010 UTC (14 years, 10 months ago) by greg
Changes since 3.18: +2 -2 lines
Diff to previous 3.18 , to selected 3.1
Fixed 64-bit bug in rhcopy and rhoptimize
Thu Jan 1 11:21:55 2004 UTC (21 years, 7 months ago) by schorsch
Changes since 3.17: +41 -22 lines
Diff to previous 3.17 , to selected 3.1
Ansification and prototypes.
Wed Oct 22 02:06:34 2003 UTC (21 years, 9 months ago) by greg
Changes since 3.16: +2 -2 lines
Diff to previous 3.16 , to selected 3.1
Mon Oct 20 16:01:55 2003 UTC (21 years, 9 months ago) by greg
Changes since 3.15: +6 -5 lines
Diff to previous 3.15 , to selected 3.1
Sun Jul 27 22:12:02 2003 UTC (22 years ago) by schorsch
Diff to previous 3.14 , to selected 3.1
Mon Jul 21 22:30:18 2003 UTC (22 years ago) by schorsch
Changes since 3.13: +4 -4 lines
Diff to previous 3.13 , to selected 3.1
Mon Jul 14 20:02:29 2003 UTC (22 years, 1 month ago) by schorsch
Changes since 3.12: +2 -4 lines
Diff to previous 3.12 , to selected 3.1
Mon Jun 30 14:59:12 2003 UTC (22 years, 1 month ago) by schorsch
Changes since 3.11: +9 -6 lines
Diff to previous 3.11 , to selected 3.1
Fri Jun 13 15:27:04 2003 UTC (22 years, 2 months ago) by greg
Changes since 3.10: +3 -3 lines
Diff to previous 3.10 , to selected 3.1
Type fixing to lseek() call
Thu May 29 16:26:22 2003 UTC (22 years, 2 months ago) by greg
Diff to previous 3.9 , to selected 3.1
Tue May 13 17:58:33 2003 UTC (22 years, 3 months ago) by greg
Changes since 3.8: +2 -2 lines
Diff to previous 3.8 , to selected 3.1
Sat Feb 22 02:07:25 2003 UTC (22 years, 5 months ago) by greg
Changes since 3.7: +11 -9 lines
Diff to previous 3.7 , to selected 3.1
Mon Feb 1 09:56:18 1999 UTC (26 years, 6 months ago) by gwlarson
Changes since 3.6: +1 -1 lines
Diff to previous 3.6 , to selected 3.1
made caching code slightly more efficient
Sat Jan 9 09:23:49 1999 UTC (26 years, 7 months ago) by gwlarson
Changes since 3.5: +45 -10 lines
Diff to previous 3.5 , to selected 3.1
added duplicate ray checking option (-u)
Thu Nov 12 15:07:49 1998 UTC (26 years, 9 months ago) by gwlarson
Changes since 3.4: +31 -8 lines
Diff to previous 3.4 , to selected 3.1
change clumpbeams() callback function to take clump's queue
Mon Nov 9 17:11:40 1998 UTC (26 years, 9 months ago) by gwlarson
Changes since 3.3: +15 -164 lines
Diff to previous 3.3 , to selected 3.1
moved routines to clumpbeams.c and made rhcopy clump beams
Fri Nov 6 16:54:23 1998 UTC (26 years, 9 months ago) by gwlarson
Changes since 3.2: +35 -18 lines
Diff to previous 3.2 , to selected 3.1
added check to see if single argument is writeable
fixed bug in copysect() due to a wrong index
added automatic temporary file removal on interrupt or error
Thu Nov 5 14:43:14 1998 UTC (26 years, 9 months ago) by gwlarson
Changes since 3.1: +63 -28 lines
build queue then read
bug fixes in neighbor algorithm
Revision 3.1 - (view) (download) (annotate) - [selected]
Wed Nov 4 16:37:19 1998 UTC (26 years, 9 months ago) by gwlarson
