root/radiance/ray/src/hd/rhoptimize.c
Revision: 3.17
Committed: Wed Oct 22 02:06:34 2003 UTC (21 years, 6 months ago) by greg
Changes since 3.16: +2 -2 lines
2 static const char RCSid[] = "$Id: rhoptimize.c,v 3.16 2003/10/20 16:01:55 greg Exp $";
5 * Optimize holodeck for quick access.
6 *
7 * 11/4/98 Greg Ward Larson
8 */
9
10 #include <signal.h>
11 #include <string.h>
12
13 #include "platform.h"
14 #include "rtprocess.h" /* getpid() */
15 #include "holo.h"
16
17 #ifndef BKBSIZE
18 #define BKBSIZE 256 /* beam clump size (kilobytes) */
19 #endif
20
21 char *progname;
22 char tempfile[128];
23 int dupchecking = 0;
24
25 extern long rhinitcopy();
26
27
28 main(argc, argv)
29 int argc;
30 char *argv[];
31 {
32 char *inpname, *outname;
33 int hdfd[2];
34 long nextipos, lastopos, thisopos;
35
36 progname = argv[0];
37 argv++; argc--; /* duplicate checking flag? */
38 if (argc > 1 && !strcmp(argv[0], "-u")) {
39 dupchecking++;
40 argv++; argc--;
41 }
42 if ((argc < 1) | (argc > 2)) {
43 fprintf(stderr, "Usage: %s [-u] input.hdk [output.hdk]\n",
44 progname);
45 exit(1);
46 }
47 inpname = argv[0]; /* get input file */
48 argv++; argc--;
49 if (argc == 1) /* use given output file */
50 outname = argv[0];
51 else { /* else use temporary file */
52 if (access(inpname, R_OK|W_OK) < 0) { /* check permissions */
53 sprintf(errmsg, "cannot access \"%s\"", inpname);
54 error(SYSTEM, errmsg);
55 }
56 strcpy(tempfile, inpname);
57 if ((outname = strrchr(tempfile, '/')) != NULL)
58 outname++;
59 else
60 outname = tempfile;
61 sprintf(outname, "rho%d.hdk", getpid());
62 outname = tempfile;
63 }
64 /* copy holodeck file header */
65 nextipos = rhinitcopy(hdfd, inpname, outname);
66 lastopos = 0L; /* copy sections one by one */
67 while (nextipos != 0L) {
68 /* set input position; get next */
69 lseek(hdfd[0], (off_t)nextipos, SEEK_SET);
70 read(hdfd[0], (char *)&nextipos, sizeof(nextipos));
71 /* get output position; set last */
72 thisopos = lseek(hdfd[1], (off_t)0, SEEK_END);
73 if (lastopos > 0L) {
74 lseek(hdfd[1], (off_t)lastopos, SEEK_SET);
75 write(hdfd[1], (char *)&thisopos, sizeof(thisopos));
76 lseek(hdfd[1], (off_t)0, SEEK_END);
77 }
78 lastopos = thisopos;
79 thisopos = 0L; /* write place holder */
80 write(hdfd[1], (char *)&thisopos, sizeof(thisopos));
81 /* copy holodeck section */
82 copysect(hdfd[0], hdfd[1]);
83 }
84 /* clean up */
85 close(hdfd[0]);
86 close(hdfd[1]);
87 if (outname == tempfile && rename(outname, inpname) < 0) {
88 sprintf(errmsg, "cannot rename \"%s\" to \"%s\"",
89 outname, inpname);
90 error(SYSTEM, errmsg);
91 }
92 exit(0);
93 }
94
95
96 long
97 rhinitcopy(hfd, infn, outfn) /* open files and copy header */
98 int hfd[2]; /* returned file descriptors */
99 char *infn, *outfn;
100 {
101 FILE *infp, *outfp;
102 long ifpos;
103 /* open files for i/o */
104 if ((infp = fopen(infn, "r")) == NULL) {
105 sprintf(errmsg, "cannot open \"%s\" for reading", infn);
106 error(SYSTEM, errmsg);
107 }
108 if (access(outfn, F_OK) == 0) {
109 sprintf(errmsg, "output file \"%s\" already exists!", outfn);
110 error(USER, errmsg);
111 }
112 if ((outfp = fopen(outfn, "w+")) == NULL) {
113 sprintf(errmsg, "cannot open \"%s\" for writing", outfn);
114 error(SYSTEM, errmsg);
115 }
116 /* set up signal handling */
117 if (signal(SIGINT, quit) == SIG_IGN) signal(SIGINT, SIG_IGN);
118 if (signal(SIGHUP, quit) == SIG_IGN) signal(SIGHUP, SIG_IGN);
119 if (signal(SIGTERM, quit) == SIG_IGN) signal(SIGTERM, SIG_IGN);
120 #ifdef SIGXCPU
121 if (signal(SIGXCPU, quit) == SIG_IGN) signal(SIGXCPU, SIG_IGN);
122 if (signal(SIGXFSZ, quit) == SIG_IGN) signal(SIGXFSZ, SIG_IGN);
123 #endif
124 /* copy and verify header */
125 if (checkheader(infp, HOLOFMT, outfp) < 0 || getw(infp) != HOLOMAGIC)
126 error(USER, "input not in holodeck format");
127 fputformat(HOLOFMT, outfp);
128 fputc('\n', outfp);
129 putw(HOLOMAGIC, outfp);
130 /* get descriptors and free stdio */
131 if ((hfd[0] = dup(fileno(infp))) < 0 ||
132 (hfd[1] = dup(fileno(outfp))) < 0)
133 error(SYSTEM, "dup call failed in rhinitcopy");
134 ifpos = ftell(infp);
135 fclose(infp);
136 if (fclose(outfp) == EOF)
137 error(SYSTEM, "file flushing error in rhinitcopy");
138 /* check cache size */
139 if (BKBSIZE*1024*1.5 > hdcachesize)
140 hdcachesize = BKBSIZE*1024*1.5;
141 /* return input position */
142 return(ifpos);
143 }
144
145
146 int
147 nuniq(rva, n) /* sort unique rays to front of beam list */
148 register RAYVAL *rva;
149 int n;
150 {
151 register int i, j;
152 RAYVAL rtmp;
153
154 for (j = 0; j < n; j++)
155 for (i = j+1; i < n; i++)
156 if ( rva[i].d == rva[j].d &&
157 rva[i].r[0][0]==rva[j].r[0][0] &&
158 rva[i].r[0][1]==rva[j].r[0][1] &&
159 rva[i].r[1][0]==rva[j].r[1][0] &&
160 rva[i].r[1][1]==rva[j].r[1][1] ) {
161 n--; /* swap duplicate with end */
162 rtmp = *(rva+n);
163 *(rva+n) = *(rva+i);
164 *(rva+i) = rtmp;
165 i--; /* recheck one we swapped */
166 }
167 return(n);
168 }
169
170
171 static BEAMI *beamdir;
172
173 static int
174 bpcmp(b1p, b2p) /* compare beam positions on disk */
175 int *b1p, *b2p;
176 {
177 register off_t pdif = beamdir[*b1p].fo - beamdir[*b2p].fo;
178
179 if (pdif < 0L) return(-1);
180 return(pdif > 0L);
181 }
182
183 static HOLO *hout;
184
185 static int
186 xferclump(hp, bq, nb) /* transfer the given clump to hout and free */
187 HOLO *hp;
188 int *bq, nb;
189 {
190 register int i;
191 register BEAM *bp;
192 int n;
193
194 beamdir = hp->bi; /* sort based on file position */
195 qsort((void *)bq, nb, sizeof(*bq), bpcmp);
196 /* transfer and free each beam */
197 for (i = 0; i < nb; i++) {
198 bp = hdgetbeam(hp, bq[i]);
199 DCHECK(bp==NULL, CONSISTENCY, "empty beam in xferclump");
200 n = dupchecking ? nuniq(hdbray(bp),bp->nrm) : bp->nrm;
201 memcpy((void *)hdnewrays(hout,bq[i],n),(void *)hdbray(bp),
202 n*sizeof(RAYVAL));
203 hdfreebeam(hp, bq[i]);
204 }
205 hdfreebeam(hout, 0); /* write & free clump */
206 return(0);
207 }
208
209 copysect(ifd, ofd) /* copy holodeck section from ifd to ofd */
210 int ifd, ofd;
211 {
212 HOLO *hinp;
213 /* load input section directory */
214 hinp = hdinit(ifd, NULL);
215 /* create output section directory */
216 hout = hdinit(ofd, (HDGRID *)hinp);
217 /* clump the beams */
218 clumpbeams(hinp, 0, BKBSIZE*1024, xferclump);
219 /* clean up */
220 hddone(hinp);
221 hddone(hout);
222 }
223
224
225 void
226 eputs(s) /* put error message to stderr */
227 register char *s;
228 {
229 static int midline = 0;
230
231 if (!*s)
232 return;
233 if (!midline++) { /* prepend line with program name */
234 fputs(progname, stderr);
235 fputs(": ", stderr);
236 }
237 fputs(s, stderr);
238 if (s[strlen(s)-1] == '\n') {
239 fflush(stderr);
240 midline = 0;
241 }
242 }
243
244
245 void
246 quit(code) /* exit the program gracefully */
247 int code;
248 {
249 if (tempfile[0])
250 unlink(tempfile);
251 exit(code);
252 }
