root/radiance/ray/src/hd/rhoptimize.c
Revision: 3.13
Committed: Mon Jul 14 20:02:29 2003 UTC (21 years, 10 months ago) by schorsch
Changes since 3.12: +2 -4 lines
2 static const char RCSid[] = "$Id: rhoptimize.c,v 3.12 2003/06/30 14:59:12 schorsch Exp $";
5 * Optimize holodeck for quick access.
6 *
7 * 11/4/98 Greg Ward Larson
8 */
9
10 #include <signal.h>
11 #include <string.h>
12
13 #include "rtprocess.h" /* getpid() */
14 #include "holo.h"
15
16 #ifndef BKBSIZE
17 #define BKBSIZE 256 /* beam clump size (kilobytes) */
18 #endif
19
20 char *progname;
21 char tempfile[128];
22 int dupchecking = 0;
23
24 extern long rhinitcopy();
25
26
27 main(argc, argv)
28 int argc;
29 char *argv[];
30 {
31 char *inpname, *outname;
32 int hdfd[2];
33 long nextipos, lastopos, thisopos;
34
35 progname = argv[0];
36 argv++; argc--; /* duplicate checking flag? */
37 if (argc > 1 && !strcmp(argv[0], "-u")) {
38 dupchecking++;
39 argv++; argc--;
40 }
41 if (argc < 1 | argc > 2) {
42 fprintf(stderr, "Usage: %s [-u] input.hdk [output.hdk]\n",
43 progname);
44 exit(1);
45 }
46 inpname = argv[0]; /* get input file */
47 argv++; argc--;
48 if (argc == 1) /* use given output file */
49 outname = argv[0];
50 else { /* else use temporary file */
51 if (access(inpname, R_OK|W_OK) < 0) { /* check permissions */
52 sprintf(errmsg, "cannot access \"%s\"", inpname);
53 error(SYSTEM, errmsg);
54 }
55 strcpy(tempfile, inpname);
56 if ((outname = strrchr(tempfile, '/')) != NULL)
57 outname++;
58 else
59 outname = tempfile;
60 sprintf(outname, "rho%d.hdk", getpid());
61 outname = tempfile;
62 }
63 /* copy holodeck file header */
64 nextipos = rhinitcopy(hdfd, inpname, outname);
65 lastopos = 0L; /* copy sections one by one */
66 while (nextipos != 0L) {
67 /* set input position; get next */
68 lseek(hdfd[0], (off_t)nextipos, 0);
69 read(hdfd[0], (char *)&nextipos, sizeof(nextipos));
70 /* get output position; set last */
71 thisopos = lseek(hdfd[1], (off_t)0, 2);
72 if (lastopos > 0L) {
73 lseek(hdfd[1], (off_t)lastopos, 0);
74 write(hdfd[1], (char *)&thisopos, sizeof(thisopos));
75 lseek(hdfd[1], (off_t)0, 2);
76 }
77 lastopos = thisopos;
78 thisopos = 0L; /* write place holder */
79 write(hdfd[1], (char *)&thisopos, sizeof(thisopos));
80 /* copy holodeck section */
81 copysect(hdfd[0], hdfd[1]);
82 }
83 /* clean up */
84 close(hdfd[0]);
85 close(hdfd[1]);
86 if (outname == tempfile && rename(outname, inpname) < 0) {
87 sprintf(errmsg, "cannot rename \"%s\" to \"%s\"",
88 outname, inpname);
89 error(SYSTEM, errmsg);
90 }
91 exit(0);
92 }
93
94
95 long
96 rhinitcopy(hfd, infn, outfn) /* open files and copy header */
97 int hfd[2]; /* returned file descriptors */
98 char *infn, *outfn;
99 {
100 FILE *infp, *outfp;
101 long ifpos;
102 /* open files for i/o */
103 if ((infp = fopen(infn, "r")) == NULL) {
104 sprintf(errmsg, "cannot open \"%s\" for reading", infn);
105 error(SYSTEM, errmsg);
106 }
107 if (access(outfn, F_OK) == 0) {
108 sprintf(errmsg, "output file \"%s\" already exists!", outfn);
109 error(USER, errmsg);
110 }
111 if ((outfp = fopen(outfn, "w+")) == NULL) {
112 sprintf(errmsg, "cannot open \"%s\" for writing", outfn);
113 error(SYSTEM, errmsg);
114 }
115 /* set up signal handling */
116 if (signal(SIGINT, quit) == SIG_IGN) signal(SIGINT, SIG_IGN);
117 if (signal(SIGHUP, quit) == SIG_IGN) signal(SIGHUP, SIG_IGN);
118 if (signal(SIGTERM, quit) == SIG_IGN) signal(SIGTERM, SIG_IGN);
119 #ifdef SIGXCPU
120 if (signal(SIGXCPU, quit) == SIG_IGN) signal(SIGXCPU, SIG_IGN);
121 if (signal(SIGXFSZ, quit) == SIG_IGN) signal(SIGXFSZ, SIG_IGN);
122 #endif
123 /* copy and verify header */
124 if (checkheader(infp, HOLOFMT, outfp) < 0 || getw(infp) != HOLOMAGIC)
125 error(USER, "input not in holodeck format");
126 fputformat(HOLOFMT, outfp);
127 fputc('\n', outfp);
128 putw(HOLOMAGIC, outfp);
129 /* get descriptors and free stdio */
130 if ((hfd[0] = dup(fileno(infp))) < 0 ||
131 (hfd[1] = dup(fileno(outfp))) < 0)
132 error(SYSTEM, "dup call failed in rhinitcopy");
133 ifpos = ftell(infp);
134 fclose(infp);
135 if (fclose(outfp) == EOF)
136 error(SYSTEM, "file flushing error in rhinitcopy");
137 /* check cache size */
138 if (BKBSIZE*1024*1.5 > hdcachesize)
139 hdcachesize = BKBSIZE*1024*1.5;
140 /* return input position */
141 return(ifpos);
142 }
143
144
145 int
146 nuniq(rva, n) /* sort unique rays to front of beam list */
147 register RAYVAL *rva;
148 int n;
149 {
150 register int i, j;
151 RAYVAL rtmp;
152
153 for (j = 0; j < n; j++)
154 for (i = j+1; i < n; i++)
155 if ( rva[i].d == rva[j].d &&
156 rva[i].r[0][0]==rva[j].r[0][0] &&
157 rva[i].r[0][1]==rva[j].r[0][1] &&
158 rva[i].r[1][0]==rva[j].r[1][0] &&
159 rva[i].r[1][1]==rva[j].r[1][1] ) {
160 n--; /* swap duplicate with end */
161 copystruct(&rtmp, rva+n);
162 copystruct(rva+n, rva+i);
163 copystruct(rva+i, &rtmp);
164 i--; /* recheck one we swapped */
165 }
166 return(n);
167 }
168
169
170 static BEAMI *beamdir;
171
172 static int
173 bpcmp(b1p, b2p) /* compare beam positions on disk */
174 int *b1p, *b2p;
175 {
176 register off_t pdif = beamdir[*b1p].fo - beamdir[*b2p].fo;
177
178 if (pdif < 0L) return(-1);
179 return(pdif > 0L);
180 }
181
182 static HOLO *hout;
183
184 static int
185 xferclump(hp, bq, nb) /* transfer the given clump to hout and free */
186 HOLO *hp;
187 int *bq, nb;
188 {
189 register int i;
190 register BEAM *bp;
191 int n;
192
193 beamdir = hp->bi; /* sort based on file position */
194 qsort((void *)bq, nb, sizeof(*bq), bpcmp);
195 /* transfer and free each beam */
196 for (i = 0; i < nb; i++) {
197 bp = hdgetbeam(hp, bq[i]);
198 DCHECK(bp==NULL, CONSISTENCY, "empty beam in xferclump");
199 n = dupchecking ? nuniq(hdbray(bp),bp->nrm) : bp->nrm;
200 memcpy((void *)hdnewrays(hout,bq[i],n),(void *)hdbray(bp),
201 n*sizeof(RAYVAL));
202 hdfreebeam(hp, bq[i]);
203 }
204 hdfreebeam(hout, 0); /* write & free clump */
205 return(0);
206 }
207
208 copysect(ifd, ofd) /* copy holodeck section from ifd to ofd */
209 int ifd, ofd;
210 {
211 HOLO *hinp;
212 /* load input section directory */
213 hinp = hdinit(ifd, NULL);
214 /* create output section directory */
215 hout = hdinit(ofd, (HDGRID *)hinp);
216 /* clump the beams */
217 clumpbeams(hinp, 0, BKBSIZE*1024, xferclump);
218 /* clean up */
219 hddone(hinp);
220 hddone(hout);
221 }
222
223
224 void
225 eputs(s) /* put error message to stderr */
226 register char *s;
227 {
228 static int midline = 0;
229
230 if (!*s)
231 return;
232 if (!midline++) { /* prepend line with program name */
233 fputs(progname, stderr);
234 fputs(": ", stderr);
235 }
236 fputs(s, stderr);
237 if (s[strlen(s)-1] == '\n') {
238 fflush(stderr);
239 midline = 0;
240 }
241 }
242
243
244 void
245 quit(code) /* exit the program gracefully */
246 int code;
247 {
248 if (tempfile[0])
249 unlink(tempfile);
250 exit(code);
251 }
