root/radiance/ray/src/hd/rholo4.c
Revision: 3.36
Committed: Thu Jan 1 11:21:55 2004 UTC (20 years, 4 months ago) by schorsch
CVS Tags: rad4R2P2, rad5R0, rad3R7P2, rad3R7P1, rad4R2, rad4R1, rad4R0, rad3R6, rad3R6P1, rad3R8, rad3R9, rad4R2P1
Changes since 3.35: +27 -15 lines
Ansification and prototypes.
2 static const char RCSid[] = "$Id: rholo4.c,v 3.35 2003/07/27 22:12:02 schorsch Exp $";
5 * Holodeck display process communication
6 */
7
8 #include "rholo.h"
9 #include "rhdisp.h"
10 #include "rtprocess.h"
11 #include <sys/uio.h>
12 #include <string.h>
13
14 #ifndef HDSUF
15 #define HDSUF ".hdi"
16 #endif
17 #ifndef SLAVENAME
18 #define SLAVENAME "slave"
19 #endif
20
21 #ifndef FNONBLK
22 #define FNONBLK O_NONBLOCK
23 #endif
24
25 static int inp_flags;
26 static SUBPROC dpd;
27 static FILE *dpout;
28
29 static void disp_flush(void);
30 static void disp_result(int type, int nbytes, char *p);
31
32
33 extern void
34 disp_open( /* open the named display driver */
35 char *dname
36 )
37 {
38 char buf[sizeof(HDGRID)+512], fd0[8], fd1[8], *cmd[5], *sfn;
39 int i, n, len;
40
41 if (!strcmp(dname, SLAVENAME)) {
42 dpd.r = 0; /* read from stdin */
43 dpout = stdout; /* write to stdout */
44 dpd.running = 0; /* we're the slave procees */
45 } else {
46 /* get full display program name */
47 #ifdef DEVPATH
48 sprintf(buf, "%s/%s%s", DEVPATH, dname, HDSUF);
49 #else
50 sprintf(buf, "dev/%s%s", dname, HDSUF);
51 #endif
52 /* dup stdin and stdout */
53 if (readinp)
54 sprintf(fd0, "%d", dup(0));
55 else
56 strcpy(fd0, "-1");
57 sprintf(fd1, "%d", dup(1));
58 /* start the display process */
59 cmd[0] = buf;
60 cmd[1] = froot; cmd[2] = fd1; cmd[3] = fd0;
61 cmd[4] = NULL;
62 i = open_process(&dpd, cmd);
63 if (i <= 0)
64 error(USER, "cannot start display process");
65 if ((dpout = fdopen(dpd.w, "w")) == NULL)
66 error(SYSTEM, "problem opening display pipe");
67 /* close dup'ed stdin and stdout */
68 if (readinp)
69 close(atoi(fd0));
70 close(atoi(fd1));
71 }
72 dpd.w = -1; /* causes ignored error in close_process() */
73 inp_flags = 0;
74 /* check if outside */
75 if (vdef(OBSTRUCTIONS) && vbool(OBSTRUCTIONS))
76 disp_result(DS_OUTSECT, 0, NULL);
77 /* send eye separation if specified */
78 if (vdef(EYESEP)) {
79 sprintf(buf, "%.9e", vflt(EYESEP));
80 disp_result(DS_EYESEP, strlen(buf)+1, buf);
81 }
82 /* write out hologram grids & octrees */
83 for (i = 0; hdlist[i] != NULL; i++) {
84 memcpy(buf, (void *)hdlist[i], sizeof(HDGRID));
85 len = sizeof(HDGRID);
86 n = vdef(GEOMETRY);
87 sfn = i<n ? nvalue(GEOMETRY,i) :
88 n ? nvalue(GEOMETRY,n-1) : vval(OCTREE);
89 strcpy(buf+len, sfn);
90 len += strlen(sfn) + 1;
91 n = vdef(PORTS);
92 sfn = i<n ? nvalue(PORTS,i) : n ? nvalue(PORTS,n-1) : "";
93 strcpy(buf+len, sfn);
94 len += strlen(sfn) + 1;
95 disp_result(DS_ADDHOLO, len, buf);
96 }
97 disp_flush();
98 }
99
100
101 extern void
102 disp_packet( /* display a packet */
103 register PACKHEAD *p
104 )
105 {
106 disp_result(DS_BUNDLE, packsiz(p->nr), (char *)p);
107 }
108
109
110 extern int
111 disp_check( /* check display process */
112 int block
113 )
114 {
115 MSGHEAD msg;
116 int n;
117 char *buf = NULL;
118
119 if (dpout == NULL)
120 return(-1);
121 /* flush display output */
122 disp_flush();
123 /* check read blocking */
124 if (block != (inp_flags == 0)) {
125 inp_flags = block ? 0 : FNONBLK;
126 if (fcntl(dpd.r, F_SETFL, inp_flags) < 0)
127 goto fcntlerr;
128 }
129 /* read message header */
130 n = read(dpd.r, (char *)&msg, sizeof(MSGHEAD));
131 if (n != sizeof(MSGHEAD)) {
132 if (n >= 0) {
133 dpout = NULL;
134 error(USER, "display process died");
135 }
136 if ((errno != EAGAIN) & (errno != EINTR))
137 goto readerr;
138 return(2); /* acceptable failure */
139 }
140 if (msg.nbytes) { /* get the message body */
141 if (msg.nbytes < 0)
142 error(INTERNAL, "anti-message from display process");
143 buf = (char *)malloc(msg.nbytes);
144 if (buf == NULL)
145 error(SYSTEM, "out of memory in disp_check");
146 if (inp_flags != 0 && fcntl(dpd.r, F_SETFL, inp_flags=0) < 0)
147 goto fcntlerr;
148 if (readbuf(dpd.r, buf, msg.nbytes) != msg.nbytes)
149 goto readerr;
150 }
151 switch (msg.type) { /* take appropriate action */
152 case DR_BUNDLE: /* new bundle to calculate */
153 if (msg.nbytes != sizeof(PACKHEAD))
154 error(INTERNAL, "bad DR_BUNDLE from display process");
155 bundle_set(BS_ADD, (PACKHEAD *)buf, 1);
156 break;
157 case DR_NEWSET: /* new calculation set */
158 if (msg.nbytes % sizeof(PACKHEAD))
159 error(INTERNAL, "bad DR_NEWSET from display process");
160 if (msg.nbytes)
161 disp_result(DS_STARTIMM, 0, NULL);
162 bundle_set(BS_NEW, (PACKHEAD *)buf, msg.nbytes/sizeof(PACKHEAD));
163 if (msg.nbytes) {
164 disp_result(DS_ENDIMM, 0, NULL);
165 disp_flush();
166 }
167 break;
168 case DR_ADDSET: /* add to calculation set */
169 if (!msg.nbytes)
170 break;
171 if (msg.nbytes % sizeof(PACKHEAD))
172 error(INTERNAL, "bad DR_ADDSET from display process");
173 disp_result(DS_STARTIMM, 0, NULL);
174 bundle_set(BS_ADD, (PACKHEAD *)buf, msg.nbytes/sizeof(PACKHEAD));
175 disp_result(DS_ENDIMM, 0, NULL);
176 disp_flush();
177 break;
178 case DR_ADJSET: /* adjust calculation set members */
179 if (!msg.nbytes)
180 break;
181 if (msg.nbytes % sizeof(PACKHEAD))
182 error(INTERNAL, "bad DR_ADJSET from display process");
183 disp_result(DS_STARTIMM, 0, NULL);
184 bundle_set(BS_ADJ, (PACKHEAD *)buf, msg.nbytes/sizeof(PACKHEAD));
185 disp_result(DS_ENDIMM, 0, NULL);
186 disp_flush();
187 break;
188 case DR_DELSET: /* delete from calculation set */
189 if (!msg.nbytes)
190 break;
191 if (msg.nbytes % sizeof(PACKHEAD))
192 error(INTERNAL, "bad DR_DELSET from display process");
193 bundle_set(BS_DEL, (PACKHEAD *)buf, msg.nbytes/sizeof(PACKHEAD));
194 break;
195 case DR_VIEWPOINT: /* set target eye position */
196 if (msg.nbytes != sizeof(VIEWPOINT))
197 error(INTERNAL, "bad DR_VIEWPOINT from display process");
198 myeye = *((VIEWPOINT *)buf);
199 break;
200 case DR_ATTEN: /* block for priority request */
201 if (msg.nbytes)
202 error(INTERNAL, "bad DR_ATTEN from display process");
203 /* send acknowledgement */
204 disp_result(DS_ACKNOW, 0, NULL);
205 return(disp_check(1)); /* block on following request */
206 case DR_KILL: /* kill computation process(es) */
207 if (msg.nbytes)
208 error(INTERNAL, "bad DR_KILL from display process");
209 if (nprocs > 0)
210 done_rtrace();
211 else
212 error(WARNING, "no rtrace process to kill");
213 break;
214 case DR_RESTART: /* restart computation process(es) */
215 if (msg.nbytes)
216 error(INTERNAL, "bad DR_RESTART from display process");
217 if (ncprocs > nprocs)
218 new_rtrace();
219 else if (nprocs > 0)
220 error(WARNING, "rtrace already runnning");
221 else
222 error(WARNING, "holodeck not open for writing");
223 break;
224 case DR_CLOBBER: /* clobber holodeck */
225 if (msg.nbytes)
226 error(INTERNAL, "bad DR_CLOBBER from display process");
227 if ((force <= 0) | (ncprocs <= 0))
228 error(WARNING, "request to clobber holodeck denied");
229 else {
230 error(WARNING, "clobbering holodeck contents");
231 hdclobber(NULL);
232 }
233 break;
234 case DR_SHUTDOWN: /* shut down program */
235 if (msg.nbytes)
236 error(INTERNAL, "bad DR_SHUTDOWN from display process");
237 return(0); /* zero return signals shutdown */
238 case DR_NOOP: /* do nothing */
239 break;
240 default:
241 error(INTERNAL, "unrecognized request from display process");
242 }
243 if (msg.nbytes) /* clean up */
244 free(buf);
245 return(1); /* normal return value */
246 fcntlerr:
247 error(SYSTEM, "cannot change display blocking mode");
248 readerr:
249 error(SYSTEM, "error reading from display process");
250 return -1; /* pro forma return */
251 }
252
253
254 extern int
255 disp_close(void) /* close our display process */
256 {
257 if (dpout == NULL)
258 return(-1);
259 myeye.rng = 0;
260 disp_result(DS_SHUTDOWN, 0, NULL);
261 fclose(dpout);
262 dpout = NULL;
263 return(dpd.running ? close_process(&dpd) : 0);
264
265 }
266
267
268 static void
269 disp_result( /* queue result message to display process */
270 int type,
271 int nbytes,
272 char *p
273 )
274 {
275 MSGHEAD msg;
276 /* consistency checks */
277 #ifdef DEBUG
278 if (nbytes < 0 || nbytes > 0 & p == NULL)
279 error(CONSISTENCY, "bad buffer handed to disp_result");
280 #endif
281 if (dpout == NULL)
282 return;
283 msg.type = type;
284 msg.nbytes = nbytes;
285 fwrite((char *)&msg, sizeof(MSGHEAD), 1, dpout);
286 if (nbytes > 0)
287 fwrite(p, 1, nbytes, dpout);
288 }
289
290
291 static void
292 disp_flush(void) /* flush output to display */
293 {
294 if (fflush(dpout) < 0)
295 error(SYSTEM, "error writing to the display process");
296 }
