root/radiance/ray/src/hd/rholo4.c
Revision: 3.9
Committed: Wed Nov 26 21:34:28 1997 UTC (26 years, 5 months ago) by gregl
Changes since 3.8: +8 -0 lines
1 /* Copyright (c) 1997 Silicon Graphics, Inc. */
2
3 #ifndef lint
4 static char SCCSid[] = "$SunId$ SGI";
5 #endif
6
7 /*
8 * Holodeck display process communication
9 */
10
11 #include "rholo.h"
12 #include "rhdisp.h"
13 #include <sys/uio.h>
14
15 #ifndef HDSUF
16 #define HDSUF ".hdisp"
17 #endif
18
19 static int inp_flags;
20 static int dpd[3];
21 static FILE *dpout;
22
23
24 disp_open(dname) /* open the named display driver */
25 char *dname;
26 {
27 char dpath[128], *com[3];
28 int i;
29
30 #ifdef DEVPATH
31 sprintf(dpath, "%s/%s%s", DEVPATH, dname, HDSUF);
32 #else
33 sprintf(dpath, "dev/%s%s", dname, HDSUF);
34 #endif
35 com[0] = dpath; com[1] = froot; com[2] = NULL;
36 i = open_process(dpd, com);
37 if (i <= 0)
38 error(USER, "cannot start display process");
39 if ((dpout = fdopen(dup(dpd[1]), "w")) == NULL)
40 error(SYSTEM, "cannot associate FILE with display pipe");
41 inp_flags = 0;
42 /* write out hologram grids */
43 for (i = 0; hdlist[i] != NULL; i++)
44 disp_result(DS_ADDHOLO, sizeof(HDGRID), (char *)hdlist[i]);
45 disp_flush();
46 }
47
48
49 disp_packet(p) /* display a packet */
50 register PACKHEAD *p;
51 {
52 disp_result(DS_BUNDLE, packsiz(p->nr), (char *)p);
53 }
54
55
56 disp_check(block) /* check display process */
57 int block;
58 {
59 MSGHEAD msg;
60 int n;
61 char *buf = NULL;
62
63 if (dpout == NULL)
64 return(-1);
65 /* flush display output */
66 disp_flush();
67 /* check read blocking */
68 if (block != (inp_flags == 0)) {
69 inp_flags = block ? 0 : FNONBLK;
70 if (fcntl(dpd[0], F_SETFL, inp_flags) < 0)
71 goto fcntlerr;
72 }
73 /* read message header */
74 n = read(dpd[0], (char *)&msg, sizeof(MSGHEAD));
75 if (n != sizeof(MSGHEAD)) {
76 if (n >= 0)
77 error(USER, "display process died");
78 if (errno != EAGAIN & errno != EINTR)
79 goto readerr;
80 return(2); /* acceptable failure */
81 }
82 if (msg.nbytes) { /* get the message body */
83 buf = (char *)malloc(msg.nbytes);
84 if (buf == NULL)
85 error(SYSTEM, "out of memory in disp_check");
86 if (fcntl(dpd[0], F_SETFL, inp_flags=0) < 0)
87 goto fcntlerr;
88 if (readbuf(dpd[0], buf, msg.nbytes) != msg.nbytes)
89 goto readerr;
90 }
91 switch (msg.type) { /* take appropriate action */
92 case DR_BUNDLE:
93 if (msg.nbytes != sizeof(PACKHEAD))
94 error(INTERNAL, "bad DR_BUNDLE from display process");
95 bundle_set(BS_ADD, (PACKHEAD *)buf, 1);
96 break;
97 case DR_NEWSET:
98 if (msg.nbytes % sizeof(PACKHEAD))
99 error(INTERNAL, "bad DR_NEWSET from display process");
100 disp_result(DS_STARTIMM, 0, NULL);
101 bundle_set(BS_NEW, (PACKHEAD *)buf, msg.nbytes/sizeof(PACKHEAD));
102 disp_result(DS_ENDIMM, 0, NULL);
103 disp_flush();
104 break;
105 case DR_ADDSET:
106 if (msg.nbytes % sizeof(PACKHEAD))
107 error(INTERNAL, "bad DR_ADDSET from display process");
108 disp_result(DS_STARTIMM, 0, NULL);
109 bundle_set(BS_ADD, (PACKHEAD *)buf, msg.nbytes/sizeof(PACKHEAD));
110 disp_result(DS_ENDIMM, 0, NULL);
111 disp_check(0); /* hack -- delete usu. follows add */
112 break;
113 case DR_ADJSET:
114 if (msg.nbytes % sizeof(PACKHEAD))
115 error(INTERNAL, "bad DR_ADJSET from display process");
116 disp_result(DS_STARTIMM, 0, NULL);
117 bundle_set(BS_ADJ, (PACKHEAD *)buf, msg.nbytes/sizeof(PACKHEAD));
118 disp_result(DS_ENDIMM, 0, NULL);
119 disp_flush();
120 break;
121 case DR_DELSET:
122 if (msg.nbytes % sizeof(PACKHEAD))
123 error(INTERNAL, "bad DR_DELSET from display process");
124 bundle_set(BS_DEL, (PACKHEAD *)buf, msg.nbytes/sizeof(PACKHEAD));
125 break;
126 case DR_ATTEN:
127 if (msg.nbytes)
128 error(INTERNAL, "bad DR_ATTEN from display process");
129 /* send acknowledgement */
130 disp_result(DS_ACKNOW, 0, NULL);
131 return(disp_check(1)); /* block on following request */
132 case DR_SHUTDOWN:
133 if (msg.nbytes)
134 error(INTERNAL, "bad DR_SHUTDOWN from display process");
135 return(0); /* zero return signals shutdown */
136 case DR_NOOP:
137 break;
138 default:
139 error(INTERNAL, "unrecognized request from display process");
140 }
141 if (msg.nbytes) /* clean up */
142 free(buf);
143 return(1); /* normal return value */
144 fcntlerr:
145 error(SYSTEM, "cannot change display blocking mode");
146 readerr:
147 error(SYSTEM, "error reading from display process");
148 }
149
150
151 int
152 disp_close() /* close our display process */
153 {
154 int rval;
155
156 if (dpout == NULL)
157 return(-1);
158 disp_result(DS_SHUTDOWN, 0, NULL);
159 fclose(dpout);
160 dpout = NULL;
161 return(close_process(dpd));
162 }
163
164
165 disp_result(type, nbytes, p) /* queue result message to display process */
166 int type, nbytes;
167 char *p;
168 {
169 MSGHEAD msg;
170
171 if (dpout == NULL)
172 return;
173 msg.type = type;
174 msg.nbytes = nbytes;
175 fwrite((char *)&msg, sizeof(MSGHEAD), 1, dpout);
176 if (nbytes > 0)
177 fwrite(p, 1, nbytes, dpout);
178 }
179
180
181 disp_flush() /* flush output to display */
182 {
183 if (fflush(dpout) < 0)
184 error(SYSTEM, "error writing to the display process");
185 }
