| 1 |
#ifndef lint
| 2 |
static const char RCSid[] = "$Id$";
| 3 |
#endif
| 4 |
| 5 |
* Holodeck display process communication
| 6 |
| 7 |
| 8 |
#include "rholo.h"
| 9 |
#include "rhdisp.h"
| 10 |
#include <sys/uio.h>
| 11 |
| 12 |
#ifndef HDSUF
| 13 |
#define HDSUF ".hdi"
| 14 |
#endif
| 15 |
#ifndef SLAVENAME
| 16 |
#define SLAVENAME "slave"
| 17 |
#endif
| 18 |
| 19 |
#ifndef FNONBLK
| 20 |
#define FNONBLK O_NONBLOCK
| 21 |
#endif
| 22 |
| 23 |
static int inp_flags;
| 24 |
static int dpd[3];
| 25 |
static FILE *dpout;
| 26 |
| 27 |
| 28 |
disp_open(dname) /* open the named display driver */
| 29 |
char *dname;
| 30 |
| 31 |
char buf[sizeof(HDGRID)+512], fd0[8], fd1[8], *cmd[5], *sfn;
| 32 |
int i, n, len;
| 33 |
| 34 |
if (!strcmp(dname, SLAVENAME)) {
| 35 |
dpd[0] = 0; /* read from stdin */
| 36 |
dpout = stdout; /* write to stdout */
| 37 |
dpd[2] = -1; /* we're the slave process */
| 38 |
} else {
| 39 |
/* get full display program name */
| 40 |
#ifdef DEVPATH
| 41 |
sprintf(buf, "%s/%s%s", DEVPATH, dname, HDSUF);
| 42 |
#else
| 43 |
sprintf(buf, "dev/%s%s", dname, HDSUF);
| 44 |
#endif
| 45 |
/* dup stdin and stdout */
| 46 |
if (readinp)
| 47 |
sprintf(fd0, "%d", dup(0));
| 48 |
else
| 49 |
strcpy(fd0, "-1");
| 50 |
sprintf(fd1, "%d", dup(1));
| 51 |
/* start the display process */
| 52 |
cmd[0] = buf;
| 53 |
cmd[1] = froot; cmd[2] = fd1; cmd[3] = fd0;
| 54 |
cmd[4] = NULL;
| 55 |
i = open_process(dpd, cmd);
| 56 |
if (i <= 0)
| 57 |
error(USER, "cannot start display process");
| 58 |
if ((dpout = fdopen(dpd[1], "w")) == NULL)
| 59 |
error(SYSTEM, "problem opening display pipe");
| 60 |
/* close dup'ed stdin and stdout */
| 61 |
if (readinp)
| 62 |
close(atoi(fd0));
| 63 |
close(atoi(fd1));
| 64 |
| 65 |
dpd[1] = -1; /* causes ignored error in close_process() */
| 66 |
inp_flags = 0;
| 67 |
/* check if outside */
| 68 |
if (vdef(OBSTRUCTIONS) && vbool(OBSTRUCTIONS))
| 69 |
disp_result(DS_OUTSECT, 0, NULL);
| 70 |
/* send eye separation if specified */
| 71 |
if (vdef(EYESEP)) {
| 72 |
sprintf(buf, "%.9e", vflt(EYESEP));
| 73 |
disp_result(DS_EYESEP, strlen(buf)+1, buf);
| 74 |
| 75 |
/* write out hologram grids & octrees */
| 76 |
for (i = 0; hdlist[i] != NULL; i++) {
| 77 |
bcopy((char *)hdlist[i], buf, sizeof(HDGRID));
| 78 |
len = sizeof(HDGRID);
| 79 |
n = vdef(GEOMETRY);
| 80 |
sfn = i<n ? nvalue(GEOMETRY,i) :
| 81 |
n ? nvalue(GEOMETRY,n-1) : vval(OCTREE);
| 82 |
strcpy(buf+len, sfn);
| 83 |
len += strlen(sfn) + 1;
| 84 |
n = vdef(PORTS);
| 85 |
sfn = i<n ? nvalue(PORTS,i) : n ? nvalue(PORTS,n-1) : "";
| 86 |
| 87 |
| 88 |
disp_result(DS_ADDHOLO, len, buf);
| 89 |
| 90 |
disp_flush();
| 91 |
| 92 |
| 93 |
| 94 |
disp_packet(p) /* display a packet */
| 95 |
register PACKHEAD *p;
| 96 |
| 97 |
disp_result(DS_BUNDLE, packsiz(p->nr), (char *)p);
| 98 |
| 99 |
| 100 |
| 101 |
disp_check(block) /* check display process */
| 102 |
int block;
| 103 |
| 104 |
MSGHEAD msg;
| 105 |
int n;
| 106 |
char *buf = NULL;
| 107 |
| 108 |
if (dpout == NULL)
| 109 |
return(-1);
| 110 |
/* flush display output */
| 111 |
disp_flush();
| 112 |
/* check read blocking */
| 113 |
if (block != (inp_flags == 0)) {
| 114 |
inp_flags = block ? 0 : FNONBLK;
| 115 |
if (fcntl(dpd[0], F_SETFL, inp_flags) < 0)
| 116 |
goto fcntlerr;
| 117 |
| 118 |
/* read message header */
| 119 |
n = read(dpd[0], (char *)&msg, sizeof(MSGHEAD));
| 120 |
if (n != sizeof(MSGHEAD)) {
| 121 |
if (n >= 0) {
| 122 |
dpout = NULL;
| 123 |
error(USER, "display process died");
| 124 |
| 125 |
if (errno != EAGAIN & errno != EINTR)
| 126 |
goto readerr;
| 127 |
return(2); /* acceptable failure */
| 128 |
| 129 |
if (msg.nbytes) { /* get the message body */
| 130 |
if (msg.nbytes < 0)
| 131 |
error(INTERNAL, "anti-message from display process");
| 132 |
buf = (char *)malloc(msg.nbytes);
| 133 |
if (buf == NULL)
| 134 |
error(SYSTEM, "out of memory in disp_check");
| 135 |
if (inp_flags != 0 && fcntl(dpd[0], F_SETFL, inp_flags=0) < 0)
| 136 |
goto fcntlerr;
| 137 |
if (readbuf(dpd[0], buf, msg.nbytes) != msg.nbytes)
| 138 |
goto readerr;
| 139 |
| 140 |
switch (msg.type) { /* take appropriate action */
| 141 |
case DR_BUNDLE: /* new bundle to calculate */
| 142 |
if (msg.nbytes != sizeof(PACKHEAD))
| 143 |
error(INTERNAL, "bad DR_BUNDLE from display process");
| 144 |
bundle_set(BS_ADD, (PACKHEAD *)buf, 1);
| 145 |
break;
| 146 |
case DR_NEWSET: /* new calculation set */
| 147 |
if (msg.nbytes % sizeof(PACKHEAD))
| 148 |
error(INTERNAL, "bad DR_NEWSET from display process");
| 149 |
if (msg.nbytes)
| 150 |
disp_result(DS_STARTIMM, 0, NULL);
| 151 |
bundle_set(BS_NEW, (PACKHEAD *)buf, msg.nbytes/sizeof(PACKHEAD));
| 152 |
if (msg.nbytes) {
| 153 |
disp_result(DS_ENDIMM, 0, NULL);
| 154 |
disp_flush();
| 155 |
| 156 |
break;
| 157 |
case DR_ADDSET: /* add to calculation set */
| 158 |
if (!msg.nbytes)
| 159 |
break;
| 160 |
| 161 |
error(INTERNAL, "bad DR_ADDSET from display process");
| 162 |
| 163 |
bundle_set(BS_ADD, (PACKHEAD *)buf, msg.nbytes/sizeof(PACKHEAD));
| 164 |
| 165 |
disp_flush();
| 166 |
break;
| 167 |
case DR_ADJSET: /* adjust calculation set members */
| 168 |
if (!msg.nbytes)
| 169 |
break;
| 170 |
| 171 |
error(INTERNAL, "bad DR_ADJSET from display process");
| 172 |
| 173 |
bundle_set(BS_ADJ, (PACKHEAD *)buf, msg.nbytes/sizeof(PACKHEAD));
| 174 |
| 175 |
disp_flush();
| 176 |
break;
| 177 |
case DR_DELSET: /* delete from calculation set */
| 178 |
if (!msg.nbytes)
| 179 |
break;
| 180 |
| 181 |
error(INTERNAL, "bad DR_DELSET from display process");
| 182 |
bundle_set(BS_DEL, (PACKHEAD *)buf, msg.nbytes/sizeof(PACKHEAD));
| 183 |
break;
| 184 |
case DR_VIEWPOINT: /* set target eye position */
| 185 |
if (msg.nbytes != sizeof(VIEWPOINT))
| 186 |
error(INTERNAL, "bad DR_VIEWPOINT from display process");
| 187 |
copystruct(&myeye, (VIEWPOINT *)buf);
| 188 |
break;
| 189 |
case DR_ATTEN: /* block for priority request */
| 190 |
if (msg.nbytes)
| 191 |
error(INTERNAL, "bad DR_ATTEN from display process");
| 192 |
/* send acknowledgement */
| 193 |
disp_result(DS_ACKNOW, 0, NULL);
| 194 |
return(disp_check(1)); /* block on following request */
| 195 |
case DR_KILL: /* kill computation process(es) */
| 196 |
if (msg.nbytes)
| 197 |
error(INTERNAL, "bad DR_KILL from display process");
| 198 |
if (nprocs > 0)
| 199 |
done_rtrace();
| 200 |
else
| 201 |
error(WARNING, "no rtrace process to kill");
| 202 |
break;
| 203 |
case DR_RESTART: /* restart computation process(es) */
| 204 |
if (msg.nbytes)
| 205 |
error(INTERNAL, "bad DR_RESTART from display process");
| 206 |
if (ncprocs > nprocs)
| 207 |
new_rtrace();
| 208 |
else if (nprocs > 0)
| 209 |
error(WARNING, "rtrace already runnning");
| 210 |
else
| 211 |
error(WARNING, "holodeck not open for writing");
| 212 |
break;
| 213 |
case DR_CLOBBER: /* clobber holodeck */
| 214 |
if (msg.nbytes)
| 215 |
error(INTERNAL, "bad DR_CLOBBER from display process");
| 216 |
if (force <= 0 | ncprocs <= 0)
| 217 |
error(WARNING, "request to clobber holodeck denied");
| 218 |
else {
| 219 |
error(WARNING, "clobbering holodeck contents");
| 220 |
hdclobber(NULL);
| 221 |
| 222 |
break;
| 223 |
case DR_SHUTDOWN: /* shut down program */
| 224 |
if (msg.nbytes)
| 225 |
error(INTERNAL, "bad DR_SHUTDOWN from display process");
| 226 |
return(0); /* zero return signals shutdown */
| 227 |
case DR_NOOP: /* do nothing */
| 228 |
break;
| 229 |
default:
| 230 |
error(INTERNAL, "unrecognized request from display process");
| 231 |
| 232 |
if (msg.nbytes) /* clean up */
| 233 |
free(buf);
| 234 |
return(1); /* normal return value */
| 235 |
fcntlerr:
| 236 |
error(SYSTEM, "cannot change display blocking mode");
| 237 |
readerr:
| 238 |
error(SYSTEM, "error reading from display process");
| 239 |
| 240 |
| 241 |
| 242 |
int
| 243 |
disp_close() /* close our display process */
| 244 |
| 245 |
int rval;
| 246 |
| 247 |
if (dpout == NULL)
| 248 |
return(-1);
| 249 |
myeye.rng = 0;
| 250 |
disp_result(DS_SHUTDOWN, 0, NULL);
| 251 |
fclose(dpout);
| 252 |
dpout = NULL;
| 253 |
return(dpd[2]<0 ? 0 : close_process(dpd));
| 254 |
| 255 |
| 256 |
| 257 |
disp_result(type, nbytes, p) /* queue result message to display process */
| 258 |
int type, nbytes;
| 259 |
char *p;
| 260 |
| 261 |
MSGHEAD msg;
| 262 |
/* consistency checks */
| 263 |
#ifdef DEBUG
| 264 |
if (nbytes < 0 || nbytes > 0 & p == NULL)
| 265 |
error(CONSISTENCY, "bad buffer handed to disp_result");
| 266 |
#endif
| 267 |
if (dpout == NULL)
| 268 |
return;
| 269 |
msg.type = type;
| 270 |
msg.nbytes = nbytes;
| 271 |
fwrite((char *)&msg, sizeof(MSGHEAD), 1, dpout);
| 272 |
if (nbytes > 0)
| 273 |
fwrite(p, 1, nbytes, dpout);
| 274 |
| 275 |
| 276 |
| 277 |
disp_flush() /* flush output to display */
| 278 |
| 279 |
if (fflush(dpout) < 0)
| 280 |
error(SYSTEM, "error writing to the display process");
| 281 |
