root/radiance/ray/src/hd/rholo4.c
Revision: 3.17
Committed: Sun Jan 4 18:37:11 1998 UTC (27 years, 4 months ago) by gregl
Changes since 3.16: +3 -0 lines
added motion outside section when OBSTRUCTIONS=True
1 /* Copyright (c) 1997 Silicon Graphics, Inc. */
2
3 #ifndef lint
4 static char SCCSid[] = "$SunId$ SGI";
5 #endif
6
7 /*
8 * Holodeck display process communication
9 */
10
11 #include "rholo.h"
12 #include "rhdisp.h"
13 #include <sys/uio.h>
14
15 #ifndef HDSUF
16 #define HDSUF ".hdi"
17 #endif
18
19 static int inp_flags;
20 static int dpd[3];
21 static FILE *dpout;
22
23
24 disp_open(dname) /* open the named display driver */
25 char *dname;
26 {
27 char dpath[128], fd0[8], fd1[8], *cmd[5];
28 int i;
29 /* get full display program name */
30 #ifdef DEVPATH
31 sprintf(dpath, "%s/%s%s", DEVPATH, dname, HDSUF);
32 #else
33 sprintf(dpath, "dev/%s%s", dname, HDSUF);
34 #endif
35 /* dup stdin and stdout */
36 if (readinp)
37 sprintf(fd0, "%d", dup(0));
38 else
39 strcpy(fd0, "-1");
40 sprintf(fd1, "%d", dup(1));
41 /* start the display process */
42 cmd[0] = dpath;
43 cmd[1] = froot; cmd[2] = fd1; cmd[3] = fd0;
44 cmd[4] = NULL;
45 i = open_process(dpd, cmd);
46 if (i <= 0)
47 error(USER, "cannot start display process");
48 if ((dpout = fdopen(dpd[1], "w")) == NULL)
49 error(SYSTEM, "cannot associate FILE with display pipe");
50 dpd[1] = -1; /* causes ignored error in close_process() */
51 inp_flags = 0;
52 /* close dup'ed stdin and stdout */
53 if (readinp)
54 close(atoi(fd0));
55 close(atoi(fd1));
56 /* check if outside */
57 if (vdef(OBSTRUCTIONS) && vbool(OBSTRUCTIONS))
58 disp_result(DS_OUTSECT, 0, NULL);
59 /* write out hologram grids */
60 for (i = 0; hdlist[i] != NULL; i++)
61 disp_result(DS_ADDHOLO, sizeof(HDGRID), (char *)hdlist[i]);
62 disp_flush();
63 }
64
65
66 disp_packet(p) /* display a packet */
67 register PACKHEAD *p;
68 {
69 disp_result(DS_BUNDLE, packsiz(p->nr), (char *)p);
70 }
71
72
73 disp_check(block) /* check display process */
74 int block;
75 {
76 MSGHEAD msg;
77 int n;
78 char *buf = NULL;
79
80 if (dpout == NULL)
81 return(-1);
82 /* flush display output */
83 disp_flush();
84 /* check read blocking */
85 if (block != (inp_flags == 0)) {
86 inp_flags = block ? 0 : FNONBLK;
87 if (fcntl(dpd[0], F_SETFL, inp_flags) < 0)
88 goto fcntlerr;
89 }
90 /* read message header */
91 n = read(dpd[0], (char *)&msg, sizeof(MSGHEAD));
92 if (n != sizeof(MSGHEAD)) {
93 if (n >= 0) {
94 dpout = NULL;
95 error(USER, "display process died");
96 }
97 if (errno != EAGAIN & errno != EINTR)
98 goto readerr;
99 return(2); /* acceptable failure */
100 }
101 if (msg.nbytes) { /* get the message body */
102 buf = (char *)malloc(msg.nbytes);
103 if (buf == NULL)
104 error(SYSTEM, "out of memory in disp_check");
105 if (fcntl(dpd[0], F_SETFL, inp_flags=0) < 0)
106 goto fcntlerr;
107 if (readbuf(dpd[0], buf, msg.nbytes) != msg.nbytes)
108 goto readerr;
109 }
110 switch (msg.type) { /* take appropriate action */
111 case DR_BUNDLE: /* new bundle to calculate */
112 if (msg.nbytes != sizeof(PACKHEAD))
113 error(INTERNAL, "bad DR_BUNDLE from display process");
114 bundle_set(BS_ADD, (PACKHEAD *)buf, 1);
115 break;
116 case DR_NEWSET: /* new calculation set */
117 if (msg.nbytes % sizeof(PACKHEAD))
118 error(INTERNAL, "bad DR_NEWSET from display process");
119 disp_result(DS_STARTIMM, 0, NULL);
120 bundle_set(BS_NEW, (PACKHEAD *)buf, msg.nbytes/sizeof(PACKHEAD));
121 disp_result(DS_ENDIMM, 0, NULL);
122 disp_flush();
123 break;
124 case DR_ADDSET: /* add to calculation set */
125 if (msg.nbytes % sizeof(PACKHEAD))
126 error(INTERNAL, "bad DR_ADDSET from display process");
127 disp_result(DS_STARTIMM, 0, NULL);
128 bundle_set(BS_ADD, (PACKHEAD *)buf, msg.nbytes/sizeof(PACKHEAD));
129 disp_result(DS_ENDIMM, 0, NULL);
130 disp_flush();
131 break;
132 case DR_ADJSET: /* adjust calculation set members */
133 if (msg.nbytes % sizeof(PACKHEAD))
134 error(INTERNAL, "bad DR_ADJSET from display process");
135 disp_result(DS_STARTIMM, 0, NULL);
136 bundle_set(BS_ADJ, (PACKHEAD *)buf, msg.nbytes/sizeof(PACKHEAD));
137 disp_result(DS_ENDIMM, 0, NULL);
138 disp_flush();
139 break;
140 case DR_DELSET: /* delete from calculation set */
141 if (msg.nbytes % sizeof(PACKHEAD))
142 error(INTERNAL, "bad DR_DELSET from display process");
143 bundle_set(BS_DEL, (PACKHEAD *)buf, msg.nbytes/sizeof(PACKHEAD));
144 break;
145 case DR_ATTEN: /* block for priority request */
146 if (msg.nbytes)
147 error(INTERNAL, "bad DR_ATTEN from display process");
148 /* send acknowledgement */
149 disp_result(DS_ACKNOW, 0, NULL);
150 return(disp_check(1)); /* block on following request */
151 case DR_KILL: /* kill computation process(es) */
152 if (msg.nbytes)
153 error(INTERNAL, "bad DR_KILL from display process");
154 if (nprocs > 0)
155 done_rtrace();
156 else
157 error(WARNING, "no rtrace process to kill");
158 break;
159 case DR_RESTART: /* restart computation process(es) */
160 if (msg.nbytes)
161 error(INTERNAL, "bad DR_RESTART from display process");
162 if (ncprocs > nprocs)
163 new_rtrace();
164 else if (nprocs > 0)
165 error(WARNING, "rtrace already runnning");
166 else
167 error(WARNING, "holodeck not open for writing");
168 break;
169 case DR_CLOBBER: /* clobber holodeck */
170 if (msg.nbytes)
171 error(INTERNAL, "bad DR_CLOBBER from display process");
172 if (!force || !ncprocs)
173 error(WARNING, "request to clobber holodeck denied");
174 else {
175 error(WARNING, "clobbering holodeck contents");
176 hdclobber(NULL);
177 }
178 break;
179 case DR_SHUTDOWN: /* shut down program */
180 if (msg.nbytes)
181 error(INTERNAL, "bad DR_SHUTDOWN from display process");
182 return(0); /* zero return signals shutdown */
183 case DR_NOOP: /* do nothing */
184 break;
185 default:
186 error(INTERNAL, "unrecognized request from display process");
187 }
188 if (msg.nbytes) /* clean up */
189 free(buf);
190 return(1); /* normal return value */
191 fcntlerr:
192 error(SYSTEM, "cannot change display blocking mode");
193 readerr:
194 error(SYSTEM, "error reading from display process");
195 }
196
197
198 int
199 disp_close() /* close our display process */
200 {
201 int rval;
202
203 if (dpout == NULL)
204 return(-1);
205 disp_result(DS_SHUTDOWN, 0, NULL);
206 fclose(dpout);
207 dpout = NULL;
208 return(close_process(dpd));
209 }
210
211
212 disp_result(type, nbytes, p) /* queue result message to display process */
213 int type, nbytes;
214 char *p;
215 {
216 MSGHEAD msg;
217
218 if (dpout == NULL)
219 return;
220 msg.type = type;
221 msg.nbytes = nbytes;
222 fwrite((char *)&msg, sizeof(MSGHEAD), 1, dpout);
223 if (nbytes > 0)
224 fwrite(p, 1, nbytes, dpout);
225 }
226
227
228 disp_flush() /* flush output to display */
229 {
230 if (fflush(dpout) < 0)
231 error(SYSTEM, "error writing to the display process");
232 }
