--- ray/src/hd/rholo4.c 1997/12/22 17:42:03 3.16 +++ ray/src/hd/rholo4.c 2016/08/18 00:52:48 3.37 @@ -1,74 +1,116 @@ -/* Copyright (c) 1997 Silicon Graphics, Inc. */ - #ifndef lint -static char SCCSid[] = "$SunId$ SGI"; +static const char RCSid[] = "$Id: rholo4.c,v 3.37 2016/08/18 00:52:48 greg Exp $"; #endif - /* * Holodeck display process communication */ #include "rholo.h" #include "rhdisp.h" +#include "rtprocess.h" #include +#include #ifndef HDSUF -#define HDSUF ".hdi" +#define HDSUF ".hdi" #endif +#ifndef SLAVENAME +#define SLAVENAME "slave" +#endif +#ifndef FNONBLK +#define FNONBLK O_NONBLOCK +#endif + static int inp_flags; -static int dpd[3]; +static SUBPROC dpd; static FILE *dpout; +static void disp_flush(void); +static void disp_result(int type, int nbytes, char *p); -disp_open(dname) /* open the named display driver */ -char *dname; + +extern void +disp_open( /* open the named display driver */ + char *dname +) { - char dpath[128], fd0[8], fd1[8], *cmd[5]; - int i; - /* get full display program name */ + char buf[sizeof(HDGRID)+512], fd0[8], fd1[8], *cmd[5], *sfn; + int i, n, len; + + if (!strcmp(dname, SLAVENAME)) { + dpd.r = 0; /* read from stdin */ + dpout = stdout; /* write to stdout */ + dpd.running = 0; /* we're the slave procees */ + } else { + /* get full display program name */ #ifdef DEVPATH - sprintf(dpath, "%s/%s%s", DEVPATH, dname, HDSUF); + sprintf(buf, "%s/%s%s", DEVPATH, dname, HDSUF); #else - sprintf(dpath, "dev/%s%s", dname, HDSUF); + sprintf(buf, "dev/%s%s", dname, HDSUF); #endif - /* dup stdin and stdout */ - if (readinp) - sprintf(fd0, "%d", dup(0)); - else - strcpy(fd0, "-1"); - sprintf(fd1, "%d", dup(1)); - /* start the display process */ - cmd[0] = dpath; - cmd[1] = froot; cmd[2] = fd1; cmd[3] = fd0; - cmd[4] = NULL; - i = open_process(dpd, cmd); - if (i <= 0) - error(USER, "cannot start display process"); - if ((dpout = fdopen(dpd[1], "w")) == NULL) - error(SYSTEM, "cannot associate FILE with display pipe"); - dpd[1] = -1; /* causes ignored error in close_process() */ + /* dup stdin and stdout */ + if (readinp) + sprintf(fd0, "%d", dup(0)); + else + strcpy(fd0, "-1"); + sprintf(fd1, "%d", dup(1)); + /* start the display process */ + cmd[0] = buf; + cmd[1] = froot; cmd[2] = fd1; cmd[3] = fd0; + cmd[4] = NULL; + i = open_process(&dpd, cmd); + if (i <= 0) + error(USER, "cannot start display process"); + if ((dpout = fdopen(dpd.w, "w")) == NULL) + error(SYSTEM, "problem opening display pipe"); + /* close dup'ed stdin and stdout */ + if (readinp) + close(atoi(fd0)); + close(atoi(fd1)); + } + dpd.w = -1; /* causes ignored error in close_process() */ inp_flags = 0; - /* close dup'ed stdin and stdout */ - if (readinp) - close(atoi(fd0)); - close(atoi(fd1)); - /* write out hologram grids */ - for (i = 0; hdlist[i] != NULL; i++) - disp_result(DS_ADDHOLO, sizeof(HDGRID), (char *)hdlist[i]); + /* check if outside */ + if (vdef(OBSTRUCTIONS) && vbool(OBSTRUCTIONS)) + disp_result(DS_OUTSECT, 0, NULL); + /* send eye separation if specified */ + if (vdef(EYESEP)) { + sprintf(buf, "%.9e", vflt(EYESEP)); + disp_result(DS_EYESEP, strlen(buf)+1, buf); + } + /* write out hologram grids & octrees */ + for (i = 0; hdlist[i] != NULL; i++) { + memcpy(buf, (void *)hdlist[i], sizeof(HDGRID)); + len = sizeof(HDGRID); + n = vdef(GEOMETRY); + sfn = inr), (char *)p); } -disp_check(block) /* check display process */ -int block; +extern int +disp_check( /* check display process */ + int block +) { MSGHEAD msg; int n; @@ -81,27 +123,29 @@ int block; /* check read blocking */ if (block != (inp_flags == 0)) { inp_flags = block ? 0 : FNONBLK; - if (fcntl(dpd[0], F_SETFL, inp_flags) < 0) + if (fcntl(dpd.r, F_SETFL, inp_flags) < 0) goto fcntlerr; } /* read message header */ - n = read(dpd[0], (char *)&msg, sizeof(MSGHEAD)); + n = read(dpd.r, (char *)&msg, sizeof(MSGHEAD)); if (n != sizeof(MSGHEAD)) { if (n >= 0) { dpout = NULL; error(USER, "display process died"); } - if (errno != EAGAIN & errno != EINTR) + if ((errno != EAGAIN) & (errno != EINTR)) goto readerr; return(2); /* acceptable failure */ } if (msg.nbytes) { /* get the message body */ + if (msg.nbytes < 0) + error(INTERNAL, "anti-message from display process"); buf = (char *)malloc(msg.nbytes); if (buf == NULL) error(SYSTEM, "out of memory in disp_check"); - if (fcntl(dpd[0], F_SETFL, inp_flags=0) < 0) + if (inp_flags != 0 && fcntl(dpd.r, F_SETFL, inp_flags=0) < 0) goto fcntlerr; - if (readbuf(dpd[0], buf, msg.nbytes) != msg.nbytes) + if (readbuf(dpd.r, buf, msg.nbytes) != msg.nbytes) goto readerr; } switch (msg.type) { /* take appropriate action */ @@ -113,12 +157,17 @@ int block; case DR_NEWSET: /* new calculation set */ if (msg.nbytes % sizeof(PACKHEAD)) error(INTERNAL, "bad DR_NEWSET from display process"); - disp_result(DS_STARTIMM, 0, NULL); + if (msg.nbytes) + disp_result(DS_STARTIMM, 0, NULL); bundle_set(BS_NEW, (PACKHEAD *)buf, msg.nbytes/sizeof(PACKHEAD)); - disp_result(DS_ENDIMM, 0, NULL); - disp_flush(); + if (msg.nbytes) { + disp_result(DS_ENDIMM, 0, NULL); + disp_flush(); + } break; case DR_ADDSET: /* add to calculation set */ + if (!msg.nbytes) + break; if (msg.nbytes % sizeof(PACKHEAD)) error(INTERNAL, "bad DR_ADDSET from display process"); disp_result(DS_STARTIMM, 0, NULL); @@ -127,6 +176,8 @@ int block; disp_flush(); break; case DR_ADJSET: /* adjust calculation set members */ + if (!msg.nbytes) + break; if (msg.nbytes % sizeof(PACKHEAD)) error(INTERNAL, "bad DR_ADJSET from display process"); disp_result(DS_STARTIMM, 0, NULL); @@ -135,10 +186,17 @@ int block; disp_flush(); break; case DR_DELSET: /* delete from calculation set */ + if (!msg.nbytes) + break; if (msg.nbytes % sizeof(PACKHEAD)) error(INTERNAL, "bad DR_DELSET from display process"); bundle_set(BS_DEL, (PACKHEAD *)buf, msg.nbytes/sizeof(PACKHEAD)); break; + case DR_VIEWPOINT: /* set target eye position */ + if (msg.nbytes != sizeof(VIEWPOINT)) + error(INTERNAL, "bad DR_VIEWPOINT from display process"); + myeye = *((VIEWPOINT *)buf); + break; case DR_ATTEN: /* block for priority request */ if (msg.nbytes) error(INTERNAL, "bad DR_ATTEN from display process"); @@ -166,7 +224,7 @@ int block; case DR_CLOBBER: /* clobber holodeck */ if (msg.nbytes) error(INTERNAL, "bad DR_CLOBBER from display process"); - if (!force || !ncprocs) + if ((force <= 0) | (ncprocs <= 0)) error(WARNING, "request to clobber holodeck denied"); else { error(WARNING, "clobbering holodeck contents"); @@ -189,40 +247,49 @@ fcntlerr: error(SYSTEM, "cannot change display blocking mode"); readerr: error(SYSTEM, "error reading from display process"); + return -1; /* pro forma return */ } -int -disp_close() /* close our display process */ +extern int +disp_close(void) /* close our display process */ { - int rval; - if (dpout == NULL) return(-1); + myeye.rng = 0; disp_result(DS_SHUTDOWN, 0, NULL); fclose(dpout); dpout = NULL; - return(close_process(dpd)); + return(dpd.running ? close_process(&dpd) : 0); + } -disp_result(type, nbytes, p) /* queue result message to display process */ -int type, nbytes; -char *p; +static void +disp_result( /* queue result message to display process */ + int type, + int nbytes, + char *p +) { MSGHEAD msg; - + /* consistency checks */ +#ifdef DEBUG + if (nbytes < 0 || nbytes > 0 & p == NULL) + error(CONSISTENCY, "bad buffer handed to disp_result"); +#endif if (dpout == NULL) return; msg.type = type; msg.nbytes = nbytes; - fwrite((char *)&msg, sizeof(MSGHEAD), 1, dpout); + putbinary(&msg, sizeof(MSGHEAD), 1, dpout); if (nbytes > 0) - fwrite(p, 1, nbytes, dpout); + putbinary(p, 1, nbytes, dpout); } -disp_flush() /* flush output to display */ +static void +disp_flush(void) /* flush output to display */ { if (fflush(dpout) < 0) error(SYSTEM, "error writing to the display process");
