--- ray/src/hd/rholo4.c 1999/01/04 17:48:30 3.25 +++ ray/src/hd/rholo4.c 2003/06/26 00:58:10 3.30 @@ -1,27 +1,29 @@ -/* Copyright (c) 1999 Silicon Graphics, Inc. */ - #ifndef lint -static char SCCSid[] = "$SunId$ SGI"; +static const char RCSid[] = "$Id: rholo4.c,v 3.30 2003/06/26 00:58:10 schorsch Exp $"; #endif - /* * Holodeck display process communication */ +#include + #include "rholo.h" #include "rhdisp.h" -#include +#include "rtprocess.h" #ifndef HDSUF -#define HDSUF ".hdi" +#define HDSUF ".hdi" #endif +#ifndef SLAVENAME +#define SLAVENAME "slave" +#endif #ifndef FNONBLK #define FNONBLK O_NONBLOCK #endif static int inp_flags; -static int dpd[3]; +static SUBPROC dpd; static FILE *dpout; @@ -30,33 +32,40 @@ char *dname; { char buf[sizeof(HDGRID)+512], fd0[8], fd1[8], *cmd[5], *sfn; int i, n, len; - /* get full display program name */ + + if (!strcmp(dname, SLAVENAME)) { + dpd.r = 0; /* read from stdin */ + dpout = stdout; /* write to stdout */ + dpd.running = 0; /* we're the slave procees */ + } else { + /* get full display program name */ #ifdef DEVPATH - sprintf(buf, "%s/%s%s", DEVPATH, dname, HDSUF); + sprintf(buf, "%s/%s%s", DEVPATH, dname, HDSUF); #else - sprintf(buf, "dev/%s%s", dname, HDSUF); + sprintf(buf, "dev/%s%s", dname, HDSUF); #endif - /* dup stdin and stdout */ - if (readinp) - sprintf(fd0, "%d", dup(0)); - else - strcpy(fd0, "-1"); - sprintf(fd1, "%d", dup(1)); - /* start the display process */ - cmd[0] = buf; - cmd[1] = froot; cmd[2] = fd1; cmd[3] = fd0; - cmd[4] = NULL; - i = open_process(dpd, cmd); - if (i <= 0) - error(USER, "cannot start display process"); - if ((dpout = fdopen(dpd[1], "w")) == NULL) - error(SYSTEM, "cannot associate FILE with display pipe"); - dpd[1] = -1; /* causes ignored error in close_process() */ + /* dup stdin and stdout */ + if (readinp) + sprintf(fd0, "%d", dup(0)); + else + strcpy(fd0, "-1"); + sprintf(fd1, "%d", dup(1)); + /* start the display process */ + cmd[0] = buf; + cmd[1] = froot; cmd[2] = fd1; cmd[3] = fd0; + cmd[4] = NULL; + i = open_process(&dpd, cmd); + if (i <= 0) + error(USER, "cannot start display process"); + if ((dpout = fdopen(dpd.w, "w")) == NULL) + error(SYSTEM, "problem opening display pipe"); + /* close dup'ed stdin and stdout */ + if (readinp) + close(atoi(fd0)); + close(atoi(fd1)); + } + dpd.w = -1; /* causes ignored error in close_process() */ inp_flags = 0; - /* close dup'ed stdin and stdout */ - if (readinp) - close(atoi(fd0)); - close(atoi(fd1)); /* check if outside */ if (vdef(OBSTRUCTIONS) && vbool(OBSTRUCTIONS)) disp_result(DS_OUTSECT, 0, NULL); @@ -67,7 +76,7 @@ char *dname; } /* write out hologram grids & octrees */ for (i = 0; hdlist[i] != NULL; i++) { - bcopy((char *)hdlist[i], buf, sizeof(HDGRID)); + bcopy((void *)hdlist[i], buf, sizeof(HDGRID)); len = sizeof(HDGRID); n = vdef(GEOMETRY); sfn = i= 0) { dpout = NULL; @@ -125,9 +134,9 @@ int block; buf = (char *)malloc(msg.nbytes); if (buf == NULL) error(SYSTEM, "out of memory in disp_check"); - if (inp_flags != 0 && fcntl(dpd[0], F_SETFL, inp_flags=0) < 0) + if (inp_flags != 0 && fcntl(dpd.r, F_SETFL, inp_flags=0) < 0) goto fcntlerr; - if (readbuf(dpd[0], buf, msg.nbytes) != msg.nbytes) + if (readbuf(dpd.r, buf, msg.nbytes) != msg.nbytes) goto readerr; } switch (msg.type) { /* take appropriate action */ @@ -206,7 +215,7 @@ int block; case DR_CLOBBER: /* clobber holodeck */ if (msg.nbytes) error(INTERNAL, "bad DR_CLOBBER from display process"); - if (!force || !ncprocs) + if (force <= 0 | ncprocs <= 0) error(WARNING, "request to clobber holodeck denied"); else { error(WARNING, "clobbering holodeck contents"); @@ -243,7 +252,8 @@ disp_close() /* close our display process */ disp_result(DS_SHUTDOWN, 0, NULL); fclose(dpout); dpout = NULL; - return(close_process(dpd)); + return(dpd.running ? close_process(&dpd) : 0); + }
