--- ray/src/hd/rholo4.c 1997/11/03 18:33:14 3.2 +++ ray/src/hd/rholo4.c 2003/06/27 06:53:22 3.31 @@ -1,55 +1,102 @@ -/* Copyright (c) 1997 Silicon Graphics, Inc. */ - #ifndef lint -static char SCCSid[] = "$SunId$ SGI"; +static const char RCSid[] = "$Id: rholo4.c,v 3.31 2003/06/27 06:53:22 greg Exp $"; #endif - /* * Holodeck display process communication */ #include "rholo.h" #include "rhdisp.h" +#include "rtprocess.h" + #include #ifndef HDSUF -#define HDSUF ".hdisp" +#define HDSUF ".hdi" #endif +#ifndef SLAVENAME +#define SLAVENAME "slave" +#endif +#ifndef FNONBLK +#define FNONBLK O_NONBLOCK +#endif + static int inp_flags; -static int dpd[3]; -static int pipesiz; +static SUBPROC dpd; +static FILE *dpout; disp_open(dname) /* open the named display driver */ char *dname; { - char dpath[128], *com[2]; - int i; + char buf[sizeof(HDGRID)+512], fd0[8], fd1[8], *cmd[5], *sfn; + int i, n, len; + if (!strcmp(dname, SLAVENAME)) { + dpd.r = 0; /* read from stdin */ + dpout = stdout; /* write to stdout */ + dpd.running = 0; /* we're the slave procees */ + } else { + /* get full display program name */ #ifdef DEVPATH - sprintf(dpath, "%s/%s%s", DEVPATH, dname, HDSUF); + sprintf(buf, "%s/%s%s", DEVPATH, dname, HDSUF); #else - sprintf(dpath, "dev/%s%s", dname, HDSUF); + sprintf(buf, "dev/%s%s", dname, HDSUF); #endif - com[0] = dpath; com[1] = NULL; - pipesiz = open_process(dpd, com); - if (pipesiz <= 0) - error(USER, "cannot start display process"); + /* dup stdin and stdout */ + if (readinp) + sprintf(fd0, "%d", dup(0)); + else + strcpy(fd0, "-1"); + sprintf(fd1, "%d", dup(1)); + /* start the display process */ + cmd[0] = buf; + cmd[1] = froot; cmd[2] = fd1; cmd[3] = fd0; + cmd[4] = NULL; + i = open_process(&dpd, cmd); + if (i <= 0) + error(USER, "cannot start display process"); + if ((dpout = fdopen(dpd.w, "w")) == NULL) + error(SYSTEM, "problem opening display pipe"); + /* close dup'ed stdin and stdout */ + if (readinp) + close(atoi(fd0)); + close(atoi(fd1)); + } + dpd.w = -1; /* causes ignored error in close_process() */ inp_flags = 0; - /* write out hologram grids */ - for (i = 0; hdlist[i] != NULL; i++) - disp_result(DS_ADDHOLO, sizeof(HDGRID), (char *)hdlist[i]); + /* check if outside */ + if (vdef(OBSTRUCTIONS) && vbool(OBSTRUCTIONS)) + disp_result(DS_OUTSECT, 0, NULL); + /* send eye separation if specified */ + if (vdef(EYESEP)) { + sprintf(buf, "%.9e", vflt(EYESEP)); + disp_result(DS_EYESEP, strlen(buf)+1, buf); + } + /* write out hologram grids & octrees */ + for (i = 0; hdlist[i] != NULL; i++) { + bcopy((void *)hdlist[i], buf, sizeof(HDGRID)); + len = sizeof(HDGRID); + n = vdef(GEOMETRY); + sfn = inr*sizeof(RAYVAL), - (char *)p); + disp_result(DS_BUNDLE, packsiz(p->nr), (char *)p); } @@ -60,72 +107,131 @@ int block; int n; char *buf = NULL; - if (pipesiz <= 0) + if (dpout == NULL) return(-1); -restart: /* check read blocking */ + /* flush display output */ + disp_flush(); + /* check read blocking */ if (block != (inp_flags == 0)) { inp_flags = block ? 0 : FNONBLK; - if (fcntl(dpd[0], F_SETFL, inp_flags) < 0) + if (fcntl(dpd.r, F_SETFL, inp_flags) < 0) goto fcntlerr; } /* read message header */ - n = read(dpd[0], (char *)&msg, sizeof(MSGHEAD)); + n = read(dpd.r, (char *)&msg, sizeof(MSGHEAD)); if (n != sizeof(MSGHEAD)) { - if (n >= 0) + if (n >= 0) { + dpout = NULL; error(USER, "display process died"); + } if (errno != EAGAIN & errno != EINTR) goto readerr; - return(2); /* else acceptable failure */ + return(2); /* acceptable failure */ } if (msg.nbytes) { /* get the message body */ + if (msg.nbytes < 0) + error(INTERNAL, "anti-message from display process"); buf = (char *)malloc(msg.nbytes); if (buf == NULL) error(SYSTEM, "out of memory in disp_check"); - if (fcntl(dpd[0], F_SETFL, inp_flags=0) < 0) + if (inp_flags != 0 && fcntl(dpd.r, F_SETFL, inp_flags=0) < 0) goto fcntlerr; - if (readbuf(dpd[0], buf, msg.nbytes) != msg.nbytes) + if (readbuf(dpd.r, buf, msg.nbytes) != msg.nbytes) goto readerr; } switch (msg.type) { /* take appropriate action */ - case DR_BUNDLE: + case DR_BUNDLE: /* new bundle to calculate */ if (msg.nbytes != sizeof(PACKHEAD)) error(INTERNAL, "bad DR_BUNDLE from display process"); bundle_set(BS_ADD, (PACKHEAD *)buf, 1); break; - case DR_NEWSET: + case DR_NEWSET: /* new calculation set */ if (msg.nbytes % sizeof(PACKHEAD)) error(INTERNAL, "bad DR_NEWSET from display process"); - disp_result(DS_STARTIMM, 0, NULL); + if (msg.nbytes) + disp_result(DS_STARTIMM, 0, NULL); bundle_set(BS_NEW, (PACKHEAD *)buf, msg.nbytes/sizeof(PACKHEAD)); - disp_result(DS_ENDIMM, 0, NULL); + if (msg.nbytes) { + disp_result(DS_ENDIMM, 0, NULL); + disp_flush(); + } break; - case DR_ADDSET: + case DR_ADDSET: /* add to calculation set */ + if (!msg.nbytes) + break; if (msg.nbytes % sizeof(PACKHEAD)) error(INTERNAL, "bad DR_ADDSET from display process"); disp_result(DS_STARTIMM, 0, NULL); bundle_set(BS_ADD, (PACKHEAD *)buf, msg.nbytes/sizeof(PACKHEAD)); disp_result(DS_ENDIMM, 0, NULL); + disp_flush(); break; - case DR_DELSET: + case DR_ADJSET: /* adjust calculation set members */ + if (!msg.nbytes) + break; if (msg.nbytes % sizeof(PACKHEAD)) + error(INTERNAL, "bad DR_ADJSET from display process"); + disp_result(DS_STARTIMM, 0, NULL); + bundle_set(BS_ADJ, (PACKHEAD *)buf, msg.nbytes/sizeof(PACKHEAD)); + disp_result(DS_ENDIMM, 0, NULL); + disp_flush(); + break; + case DR_DELSET: /* delete from calculation set */ + if (!msg.nbytes) + break; + if (msg.nbytes % sizeof(PACKHEAD)) error(INTERNAL, "bad DR_DELSET from display process"); bundle_set(BS_DEL, (PACKHEAD *)buf, msg.nbytes/sizeof(PACKHEAD)); break; - case DR_ATTEN: + case DR_VIEWPOINT: /* set target eye position */ + if (msg.nbytes != sizeof(VIEWPOINT)) + error(INTERNAL, "bad DR_VIEWPOINT from display process"); + copystruct(&myeye, (VIEWPOINT *)buf); + break; + case DR_ATTEN: /* block for priority request */ if (msg.nbytes) error(INTERNAL, "bad DR_ATTEN from display process"); /* send acknowledgement */ disp_result(DS_ACKNOW, 0, NULL); - block = 1; /* block on following request */ - goto restart; - case DR_SHUTDOWN: + return(disp_check(1)); /* block on following request */ + case DR_KILL: /* kill computation process(es) */ if (msg.nbytes) + error(INTERNAL, "bad DR_KILL from display process"); + if (nprocs > 0) + done_rtrace(); + else + error(WARNING, "no rtrace process to kill"); + break; + case DR_RESTART: /* restart computation process(es) */ + if (msg.nbytes) + error(INTERNAL, "bad DR_RESTART from display process"); + if (ncprocs > nprocs) + new_rtrace(); + else if (nprocs > 0) + error(WARNING, "rtrace already runnning"); + else + error(WARNING, "holodeck not open for writing"); + break; + case DR_CLOBBER: /* clobber holodeck */ + if (msg.nbytes) + error(INTERNAL, "bad DR_CLOBBER from display process"); + if (force <= 0 | ncprocs <= 0) + error(WARNING, "request to clobber holodeck denied"); + else { + error(WARNING, "clobbering holodeck contents"); + hdclobber(NULL); + } + break; + case DR_SHUTDOWN: /* shut down program */ + if (msg.nbytes) error(INTERNAL, "bad DR_SHUTDOWN from display process"); return(0); /* zero return signals shutdown */ + case DR_NOOP: /* do nothing */ + break; default: error(INTERNAL, "unrecognized request from display process"); } - if (msg.nbytes) + if (msg.nbytes) /* clean up */ free(buf); return(1); /* normal return value */ fcntlerr: @@ -140,42 +246,39 @@ disp_close() /* close our display process */ { int rval; - if (pipesiz <= 0) + if (dpout == NULL) return(-1); + myeye.rng = 0; disp_result(DS_SHUTDOWN, 0, NULL); - pipesiz = 0; - return(close_process(dpd)); + fclose(dpout); + dpout = NULL; + return(dpd.running ? close_process(&dpd) : 0); + } -disp_result(type, nbytes, p) /* send result message to display process */ +disp_result(type, nbytes, p) /* queue result message to display process */ int type, nbytes; char *p; { - struct iovec iov[2]; MSGHEAD msg; - int n; - + /* consistency checks */ +#ifdef DEBUG + if (nbytes < 0 || nbytes > 0 & p == NULL) + error(CONSISTENCY, "bad buffer handed to disp_result"); +#endif + if (dpout == NULL) + return; msg.type = type; msg.nbytes = nbytes; - if (nbytes == 0 || sizeof(MSGHEAD)+nbytes > pipesiz) { - n = write(dpd[1], (char *)&msg, sizeof(MSGHEAD)); - if (n != sizeof(MSGHEAD)) - goto writerr; - if (nbytes > 0) { - n = writebuf(dpd[1], p, nbytes); - if (n != nbytes) - goto writerr; - } - return; - } - iov[0].iov_base = (char *)&msg; - iov[0].iov_len = sizeof(MSGHEAD); - iov[1].iov_base = p; - iov[1].iov_len = nbytes; - n = writev(dpd[1], iov, 2); - if (n == nbytes+sizeof(MSGHEAD)) - return; -writerr: - error(SYSTEM, "write error in disp_result"); + fwrite((char *)&msg, sizeof(MSGHEAD), 1, dpout); + if (nbytes > 0) + fwrite(p, 1, nbytes, dpout); +} + + +disp_flush() /* flush output to display */ +{ + if (fflush(dpout) < 0) + error(SYSTEM, "error writing to the display process"); }
