--- ray/src/hd/rholo4.c 1997/12/11 17:40:04 3.12 +++ ray/src/hd/rholo4.c 2003/06/26 00:58:10 3.30 @@ -1,61 +1,94 @@ -/* Copyright (c) 1997 Silicon Graphics, Inc. */ - #ifndef lint -static char SCCSid[] = "$SunId$ SGI"; +static const char RCSid[] = "$Id: rholo4.c,v 3.30 2003/06/26 00:58:10 schorsch Exp $"; #endif - /* * Holodeck display process communication */ +#include + #include "rholo.h" #include "rhdisp.h" -#include +#include "rtprocess.h" #ifndef HDSUF -#define HDSUF ".hdisp" +#define HDSUF ".hdi" #endif +#ifndef SLAVENAME +#define SLAVENAME "slave" +#endif +#ifndef FNONBLK +#define FNONBLK O_NONBLOCK +#endif + static int inp_flags; -static int dpd[3]; +static SUBPROC dpd; static FILE *dpout; disp_open(dname) /* open the named display driver */ char *dname; { - char dpath[128], fd0[8], fd1[8], *cmd[5]; - int i; - /* get full display program name */ + char buf[sizeof(HDGRID)+512], fd0[8], fd1[8], *cmd[5], *sfn; + int i, n, len; + + if (!strcmp(dname, SLAVENAME)) { + dpd.r = 0; /* read from stdin */ + dpout = stdout; /* write to stdout */ + dpd.running = 0; /* we're the slave procees */ + } else { + /* get full display program name */ #ifdef DEVPATH - sprintf(dpath, "%s/%s%s", DEVPATH, dname, HDSUF); + sprintf(buf, "%s/%s%s", DEVPATH, dname, HDSUF); #else - sprintf(dpath, "dev/%s%s", dname, HDSUF); + sprintf(buf, "dev/%s%s", dname, HDSUF); #endif - /* dup stdin and stdout */ - if (readinp) - sprintf(fd0, "%d", dup(0)); - else - strcpy(fd0, "-1"); - sprintf(fd1, "%d", dup(1)); - /* start the display process */ - cmd[0] = dpath; - cmd[1] = froot; cmd[2] = fd1; cmd[3] = fd0; - cmd[4] = NULL; - i = open_process(dpd, cmd); - if (i <= 0) - error(USER, "cannot start display process"); - if ((dpout = fdopen(dpd[1], "w")) == NULL) - error(SYSTEM, "cannot associate FILE with display pipe"); - dpd[1] = -1; /* causes ignored error in close_process() */ + /* dup stdin and stdout */ + if (readinp) + sprintf(fd0, "%d", dup(0)); + else + strcpy(fd0, "-1"); + sprintf(fd1, "%d", dup(1)); + /* start the display process */ + cmd[0] = buf; + cmd[1] = froot; cmd[2] = fd1; cmd[3] = fd0; + cmd[4] = NULL; + i = open_process(&dpd, cmd); + if (i <= 0) + error(USER, "cannot start display process"); + if ((dpout = fdopen(dpd.w, "w")) == NULL) + error(SYSTEM, "problem opening display pipe"); + /* close dup'ed stdin and stdout */ + if (readinp) + close(atoi(fd0)); + close(atoi(fd1)); + } + dpd.w = -1; /* causes ignored error in close_process() */ inp_flags = 0; - /* close dup'ed stdin and stdout */ - if (readinp) - close(atoi(fd0)); - close(atoi(fd1)); - /* write out hologram grids */ - for (i = 0; hdlist[i] != NULL; i++) - disp_result(DS_ADDHOLO, sizeof(HDGRID), (char *)hdlist[i]); + /* check if outside */ + if (vdef(OBSTRUCTIONS) && vbool(OBSTRUCTIONS)) + disp_result(DS_OUTSECT, 0, NULL); + /* send eye separation if specified */ + if (vdef(EYESEP)) { + sprintf(buf, "%.9e", vflt(EYESEP)); + disp_result(DS_EYESEP, strlen(buf)+1, buf); + } + /* write out hologram grids & octrees */ + for (i = 0; hdlist[i] != NULL; i++) { + bcopy((void *)hdlist[i], buf, sizeof(HDGRID)); + len = sizeof(HDGRID); + n = vdef(GEOMETRY); + sfn = i= 0) { dpout = NULL; @@ -96,12 +129,14 @@ int block; return(2); /* acceptable failure */ } if (msg.nbytes) { /* get the message body */ + if (msg.nbytes < 0) + error(INTERNAL, "anti-message from display process"); buf = (char *)malloc(msg.nbytes); if (buf == NULL) error(SYSTEM, "out of memory in disp_check"); - if (fcntl(dpd[0], F_SETFL, inp_flags=0) < 0) + if (inp_flags != 0 && fcntl(dpd.r, F_SETFL, inp_flags=0) < 0) goto fcntlerr; - if (readbuf(dpd[0], buf, msg.nbytes) != msg.nbytes) + if (readbuf(dpd.r, buf, msg.nbytes) != msg.nbytes) goto readerr; } switch (msg.type) { /* take appropriate action */ @@ -113,20 +148,27 @@ int block; case DR_NEWSET: /* new calculation set */ if (msg.nbytes % sizeof(PACKHEAD)) error(INTERNAL, "bad DR_NEWSET from display process"); - disp_result(DS_STARTIMM, 0, NULL); + if (msg.nbytes) + disp_result(DS_STARTIMM, 0, NULL); bundle_set(BS_NEW, (PACKHEAD *)buf, msg.nbytes/sizeof(PACKHEAD)); - disp_result(DS_ENDIMM, 0, NULL); - disp_flush(); + if (msg.nbytes) { + disp_result(DS_ENDIMM, 0, NULL); + disp_flush(); + } break; case DR_ADDSET: /* add to calculation set */ + if (!msg.nbytes) + break; if (msg.nbytes % sizeof(PACKHEAD)) error(INTERNAL, "bad DR_ADDSET from display process"); disp_result(DS_STARTIMM, 0, NULL); bundle_set(BS_ADD, (PACKHEAD *)buf, msg.nbytes/sizeof(PACKHEAD)); disp_result(DS_ENDIMM, 0, NULL); - disp_check(0); /* hack -- delete usu. follows add */ + disp_flush(); break; case DR_ADJSET: /* adjust calculation set members */ + if (!msg.nbytes) + break; if (msg.nbytes % sizeof(PACKHEAD)) error(INTERNAL, "bad DR_ADJSET from display process"); disp_result(DS_STARTIMM, 0, NULL); @@ -135,16 +177,51 @@ int block; disp_flush(); break; case DR_DELSET: /* delete from calculation set */ + if (!msg.nbytes) + break; if (msg.nbytes % sizeof(PACKHEAD)) error(INTERNAL, "bad DR_DELSET from display process"); bundle_set(BS_DEL, (PACKHEAD *)buf, msg.nbytes/sizeof(PACKHEAD)); break; + case DR_VIEWPOINT: /* set target eye position */ + if (msg.nbytes != sizeof(VIEWPOINT)) + error(INTERNAL, "bad DR_VIEWPOINT from display process"); + copystruct(&myeye, (VIEWPOINT *)buf); + break; case DR_ATTEN: /* block for priority request */ if (msg.nbytes) error(INTERNAL, "bad DR_ATTEN from display process"); /* send acknowledgement */ disp_result(DS_ACKNOW, 0, NULL); return(disp_check(1)); /* block on following request */ + case DR_KILL: /* kill computation process(es) */ + if (msg.nbytes) + error(INTERNAL, "bad DR_KILL from display process"); + if (nprocs > 0) + done_rtrace(); + else + error(WARNING, "no rtrace process to kill"); + break; + case DR_RESTART: /* restart computation process(es) */ + if (msg.nbytes) + error(INTERNAL, "bad DR_RESTART from display process"); + if (ncprocs > nprocs) + new_rtrace(); + else if (nprocs > 0) + error(WARNING, "rtrace already runnning"); + else + error(WARNING, "holodeck not open for writing"); + break; + case DR_CLOBBER: /* clobber holodeck */ + if (msg.nbytes) + error(INTERNAL, "bad DR_CLOBBER from display process"); + if (force <= 0 | ncprocs <= 0) + error(WARNING, "request to clobber holodeck denied"); + else { + error(WARNING, "clobbering holodeck contents"); + hdclobber(NULL); + } + break; case DR_SHUTDOWN: /* shut down program */ if (msg.nbytes) error(INTERNAL, "bad DR_SHUTDOWN from display process"); @@ -171,10 +248,12 @@ disp_close() /* close our display process */ if (dpout == NULL) return(-1); + myeye.rng = 0; disp_result(DS_SHUTDOWN, 0, NULL); fclose(dpout); dpout = NULL; - return(close_process(dpd)); + return(dpd.running ? close_process(&dpd) : 0); + } @@ -183,7 +262,11 @@ int type, nbytes; char *p; { MSGHEAD msg; - + /* consistency checks */ +#ifdef DEBUG + if (nbytes < 0 || nbytes > 0 & p == NULL) + error(CONSISTENCY, "bad buffer handed to disp_result"); +#endif if (dpout == NULL) return; msg.type = type;
