--- ray/src/hd/rholo4.c 1997/10/31 10:23:29 3.1 +++ ray/src/hd/rholo4.c 1997/11/04 09:58:24 3.3 @@ -10,23 +10,175 @@ static char SCCSid[] = "$SunId$ SGI"; #include "rholo.h" #include "rhdisp.h" +#include +#ifndef HDSUF +#define HDSUF ".hdisp" +#endif -open_display(dname) /* open a display process */ +static int inp_flags; +static int dpd[3]; +static int pipesiz; + + +disp_open(dname) /* open the named display driver */ char *dname; { - error(INTERNAL, "display process unimplemented"); + char dpath[128], *com[2]; + int i; + +#ifdef DEVPATH + sprintf(dpath, "%s/%s%s", DEVPATH, dname, HDSUF); +#else + sprintf(dpath, "dev/%s%s", dname, HDSUF); +#endif + com[0] = dpath; com[1] = NULL; + pipesiz = open_process(dpd, com); + if (pipesiz <= 0) + error(USER, "cannot start display process"); + inp_flags = 0; + /* write out hologram grids */ + for (i = 0; hdlist[i] != NULL; i++) + disp_result(DS_ADDHOLO, sizeof(HDGRID), (char *)hdlist[i]); } +disp_packet(p) /* display a packet */ +register PACKET *p; +{ + disp_result(DS_BUNDLE, sizeof(PACKHEAD) + p->nr*sizeof(RAYVAL), + (char *)p); +} + + disp_check(block) /* check display process */ int block; { - return(1); + MSGHEAD msg; + int n; + char *buf = NULL; + + if (pipesiz <= 0) + return(-1); + /* check read blocking */ + if (block != (inp_flags == 0)) { + inp_flags = block ? 0 : FNONBLK; + if (fcntl(dpd[0], F_SETFL, inp_flags) < 0) + goto fcntlerr; + } + /* read message header */ + n = read(dpd[0], (char *)&msg, sizeof(MSGHEAD)); + if (n != sizeof(MSGHEAD)) { + if (n >= 0) + error(USER, "display process died"); + if (errno != EAGAIN & errno != EINTR) + goto readerr; + return(2); /* acceptable failure */ + } + if (msg.nbytes) { /* get the message body */ + buf = (char *)malloc(msg.nbytes); + if (buf == NULL) + error(SYSTEM, "out of memory in disp_check"); + if (fcntl(dpd[0], F_SETFL, inp_flags=0) < 0) + goto fcntlerr; + if (readbuf(dpd[0], buf, msg.nbytes) != msg.nbytes) + goto readerr; + } + switch (msg.type) { /* take appropriate action */ + case DR_BUNDLE: + if (msg.nbytes != sizeof(PACKHEAD)) + error(INTERNAL, "bad DR_BUNDLE from display process"); + bundle_set(BS_ADD, (PACKHEAD *)buf, 1); + break; + case DR_NEWSET: + if (msg.nbytes % sizeof(PACKHEAD)) + error(INTERNAL, "bad DR_NEWSET from display process"); + disp_result(DS_STARTIMM, 0, NULL); + bundle_set(BS_NEW, (PACKHEAD *)buf, msg.nbytes/sizeof(PACKHEAD)); + disp_result(DS_ENDIMM, 0, NULL); + break; + case DR_ADDSET: + if (msg.nbytes % sizeof(PACKHEAD)) + error(INTERNAL, "bad DR_ADDSET from display process"); + disp_result(DS_STARTIMM, 0, NULL); + bundle_set(BS_ADD, (PACKHEAD *)buf, msg.nbytes/sizeof(PACKHEAD)); + disp_result(DS_ENDIMM, 0, NULL); + break; + case DR_DELSET: + if (msg.nbytes % sizeof(PACKHEAD)) + error(INTERNAL, "bad DR_DELSET from display process"); + bundle_set(BS_DEL, (PACKHEAD *)buf, msg.nbytes/sizeof(PACKHEAD)); + break; + case DR_ATTEN: + if (msg.nbytes) + error(INTERNAL, "bad DR_ATTEN from display process"); + /* send acknowledgement */ + disp_result(DS_ACKNOW, 0, NULL); + return(disp_check(1)); /* block on following request */ + case DR_SHUTDOWN: + if (msg.nbytes) + error(INTERNAL, "bad DR_SHUTDOWN from display process"); + return(0); /* zero return signals shutdown */ + default: + error(INTERNAL, "unrecognized request from display process"); + } + if (msg.nbytes) /* clean up */ + free(buf); + return(1); /* normal return value */ +fcntlerr: + error(SYSTEM, "cannot change display blocking mode"); +readerr: + error(SYSTEM, "error reading from display process"); } -disp_packet(p) /* display a packet */ -register PACKET *p; +int +disp_close() /* close our display process */ { + int rval; + + if (pipesiz <= 0) + return(-1); + disp_result(DS_SHUTDOWN, 0, NULL); + pipesiz = 0; + return(close_process(dpd)); +} + + +disp_result(type, nbytes, p) /* send result message to display process */ +int type, nbytes; +char *p; +{ + struct iovec iov[2]; + MSGHEAD msg; + int n; + + if (pipesiz <= 0) + return; + msg.type = type; + msg.nbytes = nbytes; + if (nbytes == 0 || sizeof(MSGHEAD)+nbytes > pipesiz) { + do + n = write(dpd[1], (char *)&msg, sizeof(MSGHEAD)); + while (n < 0 && errno == EINTR); + if (n != sizeof(MSGHEAD)) + goto writerr; + if (nbytes > 0) { + n = writebuf(dpd[1], p, nbytes); + if (n != nbytes) + goto writerr; + } + return; + } + iov[0].iov_base = (char *)&msg; + iov[0].iov_len = sizeof(MSGHEAD); + iov[1].iov_base = p; + iov[1].iov_len = nbytes; + do + n = writev(dpd[1], iov, 2); + while (n < 0 && errno == EINTR); + if (n == sizeof(MSGHEAD)+nbytes) + return; +writerr: + error(SYSTEM, "write error in disp_result"); }
