root/radiance/ray/src/hd/rholo4.c
Revision: 3.27
Committed: Thu Aug 5 13:51:21 1999 UTC (26 years ago) by gwlarson
Changes since 3.26: +1 -1 lines
added -r option for read-only holodeck with computation
1 /* Copyright (c) 1999 Silicon Graphics, Inc. */
2
3 #ifndef lint
4 static char SCCSid[] = "$SunId$ SGI";
5 #endif
6
7 /*
8 * Holodeck display process communication
9 */
10
11 #include "rholo.h"
12 #include "rhdisp.h"
13 #include <sys/uio.h>
14
15 #ifndef HDSUF
16 #define HDSUF ".hdi"
17 #endif
18 #ifndef SLAVENAME
19 #define SLAVENAME "slave"
20 #endif
21
22 #ifndef FNONBLK
23 #define FNONBLK O_NONBLOCK
24 #endif
25
26 static int inp_flags;
27 static int dpd[3];
28 static FILE *dpout;
29
30
31 disp_open(dname) /* open the named display driver */
32 char *dname;
33 {
34 char buf[sizeof(HDGRID)+512], fd0[8], fd1[8], *cmd[5], *sfn;
35 int i, n, len;
36
37 if (!strcmp(dname, SLAVENAME)) {
38 dpd[0] = 0; /* read from stdin */
39 dpout = stdout; /* write to stdout */
40 dpd[2] = -1; /* we're the slave process */
41 } else {
42 /* get full display program name */
43 #ifdef DEVPATH
44 sprintf(buf, "%s/%s%s", DEVPATH, dname, HDSUF);
45 #else
46 sprintf(buf, "dev/%s%s", dname, HDSUF);
47 #endif
48 /* dup stdin and stdout */
49 if (readinp)
50 sprintf(fd0, "%d", dup(0));
51 else
52 strcpy(fd0, "-1");
53 sprintf(fd1, "%d", dup(1));
54 /* start the display process */
55 cmd[0] = buf;
56 cmd[1] = froot; cmd[2] = fd1; cmd[3] = fd0;
57 cmd[4] = NULL;
58 i = open_process(dpd, cmd);
59 if (i <= 0)
60 error(USER, "cannot start display process");
61 if ((dpout = fdopen(dpd[1], "w")) == NULL)
62 error(SYSTEM, "problem opening display pipe");
63 /* close dup'ed stdin and stdout */
64 if (readinp)
65 close(atoi(fd0));
66 close(atoi(fd1));
67 }
68 dpd[1] = -1; /* causes ignored error in close_process() */
69 inp_flags = 0;
70 /* check if outside */
71 if (vdef(OBSTRUCTIONS) && vbool(OBSTRUCTIONS))
72 disp_result(DS_OUTSECT, 0, NULL);
73 /* send eye separation if specified */
74 if (vdef(EYESEP)) {
75 sprintf(buf, "%.9e", vflt(EYESEP));
76 disp_result(DS_EYESEP, strlen(buf)+1, buf);
77 }
78 /* write out hologram grids & octrees */
79 for (i = 0; hdlist[i] != NULL; i++) {
80 bcopy((char *)hdlist[i], buf, sizeof(HDGRID));
81 len = sizeof(HDGRID);
82 n = vdef(GEOMETRY);
83 sfn = i<n ? nvalue(GEOMETRY,i) :
84 n ? nvalue(GEOMETRY,n-1) : vval(OCTREE);
85 strcpy(buf+len, sfn);
86 len += strlen(sfn) + 1;
87 n = vdef(PORTS);
88 sfn = i<n ? nvalue(PORTS,i) : n ? nvalue(PORTS,n-1) : "";
89 strcpy(buf+len, sfn);
90 len += strlen(sfn) + 1;
91 disp_result(DS_ADDHOLO, len, buf);
92 }
93 disp_flush();
94 }
95
96
97 disp_packet(p) /* display a packet */
98 register PACKHEAD *p;
99 {
100 disp_result(DS_BUNDLE, packsiz(p->nr), (char *)p);
101 }
102
103
104 disp_check(block) /* check display process */
105 int block;
106 {
107 MSGHEAD msg;
108 int n;
109 char *buf = NULL;
110
111 if (dpout == NULL)
112 return(-1);
113 /* flush display output */
114 disp_flush();
115 /* check read blocking */
116 if (block != (inp_flags == 0)) {
117 inp_flags = block ? 0 : FNONBLK;
118 if (fcntl(dpd[0], F_SETFL, inp_flags) < 0)
119 goto fcntlerr;
120 }
121 /* read message header */
122 n = read(dpd[0], (char *)&msg, sizeof(MSGHEAD));
123 if (n != sizeof(MSGHEAD)) {
124 if (n >= 0) {
125 dpout = NULL;
126 error(USER, "display process died");
127 }
128 if (errno != EAGAIN & errno != EINTR)
129 goto readerr;
130 return(2); /* acceptable failure */
131 }
132 if (msg.nbytes) { /* get the message body */
133 if (msg.nbytes < 0)
134 error(INTERNAL, "anti-message from display process");
135 buf = (char *)malloc(msg.nbytes);
136 if (buf == NULL)
137 error(SYSTEM, "out of memory in disp_check");
138 if (inp_flags != 0 && fcntl(dpd[0], F_SETFL, inp_flags=0) < 0)
139 goto fcntlerr;
140 if (readbuf(dpd[0], buf, msg.nbytes) != msg.nbytes)
141 goto readerr;
142 }
143 switch (msg.type) { /* take appropriate action */
144 case DR_BUNDLE: /* new bundle to calculate */
145 if (msg.nbytes != sizeof(PACKHEAD))
146 error(INTERNAL, "bad DR_BUNDLE from display process");
147 bundle_set(BS_ADD, (PACKHEAD *)buf, 1);
148 break;
149 case DR_NEWSET: /* new calculation set */
150 if (msg.nbytes % sizeof(PACKHEAD))
151 error(INTERNAL, "bad DR_NEWSET from display process");
152 if (msg.nbytes)
153 disp_result(DS_STARTIMM, 0, NULL);
154 bundle_set(BS_NEW, (PACKHEAD *)buf, msg.nbytes/sizeof(PACKHEAD));
155 if (msg.nbytes) {
156 disp_result(DS_ENDIMM, 0, NULL);
157 disp_flush();
158 }
159 break;
160 case DR_ADDSET: /* add to calculation set */
161 if (!msg.nbytes)
162 break;
163 if (msg.nbytes % sizeof(PACKHEAD))
164 error(INTERNAL, "bad DR_ADDSET from display process");
165 disp_result(DS_STARTIMM, 0, NULL);
166 bundle_set(BS_ADD, (PACKHEAD *)buf, msg.nbytes/sizeof(PACKHEAD));
167 disp_result(DS_ENDIMM, 0, NULL);
168 disp_flush();
169 break;
170 case DR_ADJSET: /* adjust calculation set members */
171 if (!msg.nbytes)
172 break;
173 if (msg.nbytes % sizeof(PACKHEAD))
174 error(INTERNAL, "bad DR_ADJSET from display process");
175 disp_result(DS_STARTIMM, 0, NULL);
176 bundle_set(BS_ADJ, (PACKHEAD *)buf, msg.nbytes/sizeof(PACKHEAD));
177 disp_result(DS_ENDIMM, 0, NULL);
178 disp_flush();
179 break;
180 case DR_DELSET: /* delete from calculation set */
181 if (!msg.nbytes)
182 break;
183 if (msg.nbytes % sizeof(PACKHEAD))
184 error(INTERNAL, "bad DR_DELSET from display process");
185 bundle_set(BS_DEL, (PACKHEAD *)buf, msg.nbytes/sizeof(PACKHEAD));
186 break;
187 case DR_VIEWPOINT: /* set target eye position */
188 if (msg.nbytes != sizeof(VIEWPOINT))
189 error(INTERNAL, "bad DR_VIEWPOINT from display process");
190 copystruct(&myeye, (VIEWPOINT *)buf);
191 break;
192 case DR_ATTEN: /* block for priority request */
193 if (msg.nbytes)
194 error(INTERNAL, "bad DR_ATTEN from display process");
195 /* send acknowledgement */
196 disp_result(DS_ACKNOW, 0, NULL);
197 return(disp_check(1)); /* block on following request */
198 case DR_KILL: /* kill computation process(es) */
199 if (msg.nbytes)
200 error(INTERNAL, "bad DR_KILL from display process");
201 if (nprocs > 0)
202 done_rtrace();
203 else
204 error(WARNING, "no rtrace process to kill");
205 break;
206 case DR_RESTART: /* restart computation process(es) */
207 if (msg.nbytes)
208 error(INTERNAL, "bad DR_RESTART from display process");
209 if (ncprocs > nprocs)
210 new_rtrace();
211 else if (nprocs > 0)
212 error(WARNING, "rtrace already runnning");
213 else
214 error(WARNING, "holodeck not open for writing");
215 break;
216 case DR_CLOBBER: /* clobber holodeck */
217 if (msg.nbytes)
218 error(INTERNAL, "bad DR_CLOBBER from display process");
219 if (force <= 0 | ncprocs <= 0)
220 error(WARNING, "request to clobber holodeck denied");
221 else {
222 error(WARNING, "clobbering holodeck contents");
223 hdclobber(NULL);
224 }
225 break;
226 case DR_SHUTDOWN: /* shut down program */
227 if (msg.nbytes)
228 error(INTERNAL, "bad DR_SHUTDOWN from display process");
229 return(0); /* zero return signals shutdown */
230 case DR_NOOP: /* do nothing */
231 break;
232 default:
233 error(INTERNAL, "unrecognized request from display process");
234 }
235 if (msg.nbytes) /* clean up */
236 free(buf);
237 return(1); /* normal return value */
238 fcntlerr:
239 error(SYSTEM, "cannot change display blocking mode");
240 readerr:
241 error(SYSTEM, "error reading from display process");
242 }
243
244
245 int
246 disp_close() /* close our display process */
247 {
248 int rval;
249
250 if (dpout == NULL)
251 return(-1);
252 myeye.rng = 0;
253 disp_result(DS_SHUTDOWN, 0, NULL);
254 fclose(dpout);
255 dpout = NULL;
256 return(dpd[2]<0 ? 0 : close_process(dpd));
257 }
258
259
260 disp_result(type, nbytes, p) /* queue result message to display process */
261 int type, nbytes;
262 char *p;
263 {
264 MSGHEAD msg;
265 /* consistency checks */
266 #ifdef DEBUG
267 if (nbytes < 0 || nbytes > 0 & p == NULL)
268 error(CONSISTENCY, "bad buffer handed to disp_result");
269 #endif
270 if (dpout == NULL)
271 return;
272 msg.type = type;
273 msg.nbytes = nbytes;
274 fwrite((char *)&msg, sizeof(MSGHEAD), 1, dpout);
275 if (nbytes > 0)
276 fwrite(p, 1, nbytes, dpout);
277 }
278
279
280 disp_flush() /* flush output to display */
281 {
282 if (fflush(dpout) < 0)
283 error(SYSTEM, "error writing to the display process");
284 }
