root/radiance/ray/src/hd/rholo4.c
Revision: 3.19
Committed: Wed Aug 12 17:55:11 1998 UTC (27 years ago) by gwlarson
Changes since 3.18: +14 -5 lines
added more careful calls to disp_check()
1 /* Copyright (c) 1998 Silicon Graphics, Inc. */
2
3 #ifndef lint
4 static char SCCSid[] = "$SunId$ SGI";
5 #endif
6
7 /*
8 * Holodeck display process communication
9 */
10
11 #include "rholo.h"
12 #include "rhdisp.h"
13 #include <sys/uio.h>
14
15 #ifndef HDSUF
16 #define HDSUF ".hdi"
17 #endif
18
19 static int inp_flags;
20 static int dpd[3];
21 static FILE *dpout;
22
23
24 disp_open(dname) /* open the named display driver */
25 char *dname;
26 {
27 char dpath[128], fd0[8], fd1[8], *cmd[5];
28 int i;
29 /* get full display program name */
30 #ifdef DEVPATH
31 sprintf(dpath, "%s/%s%s", DEVPATH, dname, HDSUF);
32 #else
33 sprintf(dpath, "dev/%s%s", dname, HDSUF);
34 #endif
35 /* dup stdin and stdout */
36 if (readinp)
37 sprintf(fd0, "%d", dup(0));
38 else
39 strcpy(fd0, "-1");
40 sprintf(fd1, "%d", dup(1));
41 /* start the display process */
42 cmd[0] = dpath;
43 cmd[1] = froot; cmd[2] = fd1; cmd[3] = fd0;
44 cmd[4] = NULL;
45 i = open_process(dpd, cmd);
46 if (i <= 0)
47 error(USER, "cannot start display process");
48 if ((dpout = fdopen(dpd[1], "w")) == NULL)
49 error(SYSTEM, "cannot associate FILE with display pipe");
50 dpd[1] = -1; /* causes ignored error in close_process() */
51 inp_flags = 0;
52 /* close dup'ed stdin and stdout */
53 if (readinp)
54 close(atoi(fd0));
55 close(atoi(fd1));
56 /* check if outside */
57 if (vdef(OBSTRUCTIONS) && vbool(OBSTRUCTIONS))
58 disp_result(DS_OUTSECT, 0, NULL);
59 /* send eye separation if specified */
60 if (vdef(EYESEP)) {
61 char fbuf[32];
62 sprintf(fbuf, "%.9e", vflt(EYESEP));
63 disp_result(DS_EYESEP, strlen(fbuf)+1, fbuf);
64 }
65 /* write out hologram grids */
66 for (i = 0; hdlist[i] != NULL; i++)
67 disp_result(DS_ADDHOLO, sizeof(HDGRID), (char *)hdlist[i]);
68 disp_flush();
69 }
70
71
72 disp_packet(p) /* display a packet */
73 register PACKHEAD *p;
74 {
75 disp_result(DS_BUNDLE, packsiz(p->nr), (char *)p);
76 }
77
78
79 disp_check(block) /* check display process */
80 int block;
81 {
82 MSGHEAD msg;
83 int n;
84 char *buf = NULL;
85
86 if (dpout == NULL)
87 return(-1);
88 /* flush display output */
89 disp_flush();
90 /* check read blocking */
91 if (block != (inp_flags == 0)) {
92 inp_flags = block ? 0 : FNONBLK;
93 if (fcntl(dpd[0], F_SETFL, inp_flags) < 0)
94 goto fcntlerr;
95 }
96 /* read message header */
97 n = read(dpd[0], (char *)&msg, sizeof(MSGHEAD));
98 if (n != sizeof(MSGHEAD)) {
99 if (n >= 0) {
100 dpout = NULL;
101 error(USER, "display process died");
102 }
103 if (errno != EAGAIN & errno != EINTR)
104 goto readerr;
105 return(2); /* acceptable failure */
106 }
107 if (msg.nbytes) { /* get the message body */
108 buf = (char *)malloc(msg.nbytes);
109 if (buf == NULL)
110 error(SYSTEM, "out of memory in disp_check");
111 if (inp_flags != 0 && fcntl(dpd[0], F_SETFL, inp_flags=0) < 0)
112 goto fcntlerr;
113 if (readbuf(dpd[0], buf, msg.nbytes) != msg.nbytes)
114 goto readerr;
115 }
116 switch (msg.type) { /* take appropriate action */
117 case DR_BUNDLE: /* new bundle to calculate */
118 if (msg.nbytes != sizeof(PACKHEAD))
119 error(INTERNAL, "bad DR_BUNDLE from display process");
120 bundle_set(BS_ADD, (PACKHEAD *)buf, 1);
121 break;
122 case DR_NEWSET: /* new calculation set */
123 if (msg.nbytes % sizeof(PACKHEAD))
124 error(INTERNAL, "bad DR_NEWSET from display process");
125 if (msg.nbytes)
126 disp_result(DS_STARTIMM, 0, NULL);
127 bundle_set(BS_NEW, (PACKHEAD *)buf, msg.nbytes/sizeof(PACKHEAD));
128 if (msg.nbytes) {
129 disp_result(DS_ENDIMM, 0, NULL);
130 disp_flush();
131 }
132 break;
133 case DR_ADDSET: /* add to calculation set */
134 if (!msg.nbytes)
135 break;
136 if (msg.nbytes % sizeof(PACKHEAD))
137 error(INTERNAL, "bad DR_ADDSET from display process");
138 disp_result(DS_STARTIMM, 0, NULL);
139 bundle_set(BS_ADD, (PACKHEAD *)buf, msg.nbytes/sizeof(PACKHEAD));
140 disp_result(DS_ENDIMM, 0, NULL);
141 disp_flush();
142 break;
143 case DR_ADJSET: /* adjust calculation set members */
144 if (!msg.nbytes)
145 break;
146 if (msg.nbytes % sizeof(PACKHEAD))
147 error(INTERNAL, "bad DR_ADJSET from display process");
148 disp_result(DS_STARTIMM, 0, NULL);
149 bundle_set(BS_ADJ, (PACKHEAD *)buf, msg.nbytes/sizeof(PACKHEAD));
150 disp_result(DS_ENDIMM, 0, NULL);
151 disp_flush();
152 break;
153 case DR_DELSET: /* delete from calculation set */
154 if (!msg.nbytes)
155 break;
156 if (msg.nbytes % sizeof(PACKHEAD))
157 error(INTERNAL, "bad DR_DELSET from display process");
158 bundle_set(BS_DEL, (PACKHEAD *)buf, msg.nbytes/sizeof(PACKHEAD));
159 break;
160 case DR_ATTEN: /* block for priority request */
161 if (msg.nbytes)
162 error(INTERNAL, "bad DR_ATTEN from display process");
163 /* send acknowledgement */
164 disp_result(DS_ACKNOW, 0, NULL);
165 return(disp_check(1)); /* block on following request */
166 case DR_KILL: /* kill computation process(es) */
167 if (msg.nbytes)
168 error(INTERNAL, "bad DR_KILL from display process");
169 if (nprocs > 0)
170 done_rtrace();
171 else
172 error(WARNING, "no rtrace process to kill");
173 break;
174 case DR_RESTART: /* restart computation process(es) */
175 if (msg.nbytes)
176 error(INTERNAL, "bad DR_RESTART from display process");
177 if (ncprocs > nprocs)
178 new_rtrace();
179 else if (nprocs > 0)
180 error(WARNING, "rtrace already runnning");
181 else
182 error(WARNING, "holodeck not open for writing");
183 break;
184 case DR_CLOBBER: /* clobber holodeck */
185 if (msg.nbytes)
186 error(INTERNAL, "bad DR_CLOBBER from display process");
187 if (!force || !ncprocs)
188 error(WARNING, "request to clobber holodeck denied");
189 else {
190 error(WARNING, "clobbering holodeck contents");
191 hdclobber(NULL);
192 }
193 break;
194 case DR_SHUTDOWN: /* shut down program */
195 if (msg.nbytes)
196 error(INTERNAL, "bad DR_SHUTDOWN from display process");
197 return(0); /* zero return signals shutdown */
198 case DR_NOOP: /* do nothing */
199 break;
200 default:
201 error(INTERNAL, "unrecognized request from display process");
202 }
203 if (msg.nbytes) /* clean up */
204 free(buf);
205 return(1); /* normal return value */
206 fcntlerr:
207 error(SYSTEM, "cannot change display blocking mode");
208 readerr:
209 error(SYSTEM, "error reading from display process");
210 }
211
212
213 int
214 disp_close() /* close our display process */
215 {
216 int rval;
217
218 if (dpout == NULL)
219 return(-1);
220 disp_result(DS_SHUTDOWN, 0, NULL);
221 fclose(dpout);
222 dpout = NULL;
223 return(close_process(dpd));
224 }
225
226
227 disp_result(type, nbytes, p) /* queue result message to display process */
228 int type, nbytes;
229 char *p;
230 {
231 MSGHEAD msg;
232
233 if (dpout == NULL)
234 return;
235 msg.type = type;
236 msg.nbytes = nbytes;
237 fwrite((char *)&msg, sizeof(MSGHEAD), 1, dpout);
238 if (nbytes > 0)
239 fwrite(p, 1, nbytes, dpout);
240 }
241
242
243 disp_flush() /* flush output to display */
244 {
245 if (fflush(dpout) < 0)
246 error(SYSTEM, "error writing to the display process");
247 }
