root/radiance/ray/src/hd/rholo4.c
Revision: 3.38
Committed: Fri Oct 5 19:19:16 2018 UTC (5 years, 8 months ago) by greg
Changes since 3.37: +6 -6 lines
# User Rev Content
1 gregl 3.1 #ifndef lint
2 greg 3.38 static const char RCSid[] = "$Id: rholo4.c,v 3.37 2016/08/18 00:52:48 greg Exp $";
3 gregl 3.1 #endif
4     /*
5     * Holodeck display process communication
6     */
7
8     #include "rholo.h"
9     #include "rhdisp.h"
10 schorsch 3.30 #include "rtprocess.h"
11 greg 3.33 #include <sys/uio.h>
12     #include <string.h>
13 greg 3.31
14 gregl 3.2 #ifndef HDSUF
15 gwlarson 3.26 #define HDSUF ".hdi"
16 gregl 3.2 #endif
17 gwlarson 3.26 #ifndef SLAVENAME
18     #define SLAVENAME "slave"
19     #endif
20 gregl 3.1
21 gwlarson 3.21 #ifndef FNONBLK
22     #define FNONBLK O_NONBLOCK
23     #endif
24
25 gregl 3.2 static int inp_flags;
26 schorsch 3.30 static SUBPROC dpd;
27 gregl 3.5 static FILE *dpout;
28 gregl 3.2
29 schorsch 3.36 static void disp_flush(void);
30     static void disp_result(int type, int nbytes, char *p);
31 gregl 3.2
32 schorsch 3.36
33 greg 3.38 void
34 schorsch 3.36 disp_open( /* open the named display driver */
35     char *dname
36     )
37 gregl 3.1 {
38 gwlarson 3.25 char buf[sizeof(HDGRID)+512], fd0[8], fd1[8], *cmd[5], *sfn;
39 gwlarson 3.24 int i, n, len;
40 gwlarson 3.26
41     if (!strcmp(dname, SLAVENAME)) {
42 schorsch 3.30 dpd.r = 0; /* read from stdin */
43 gwlarson 3.26 dpout = stdout; /* write to stdout */
44 schorsch 3.30 dpd.running = 0; /* we're the slave procees */
45 gwlarson 3.26 } else {
46     /* get full display program name */
47 gregl 3.2 #ifdef DEVPATH
48 gwlarson 3.26 sprintf(buf, "%s/%s%s", DEVPATH, dname, HDSUF);
49 gregl 3.2 #else
50 gwlarson 3.26 sprintf(buf, "dev/%s%s", dname, HDSUF);
51 gregl 3.2 #endif
52 gwlarson 3.26 /* dup stdin and stdout */
53     if (readinp)
54     sprintf(fd0, "%d", dup(0));
55     else
56     strcpy(fd0, "-1");
57     sprintf(fd1, "%d", dup(1));
58     /* start the display process */
59     cmd[0] = buf;
60     cmd[1] = froot; cmd[2] = fd1; cmd[3] = fd0;
61     cmd[4] = NULL;
62 schorsch 3.30 i = open_process(&dpd, cmd);
63 gwlarson 3.26 if (i <= 0)
64     error(USER, "cannot start display process");
65 schorsch 3.30 if ((dpout = fdopen(dpd.w, "w")) == NULL)
66 gwlarson 3.26 error(SYSTEM, "problem opening display pipe");
67     /* close dup'ed stdin and stdout */
68     if (readinp)
69     close(atoi(fd0));
70     close(atoi(fd1));
71     }
72 schorsch 3.30 dpd.w = -1; /* causes ignored error in close_process() */
73 gregl 3.2 inp_flags = 0;
74 gregl 3.17 /* check if outside */
75     if (vdef(OBSTRUCTIONS) && vbool(OBSTRUCTIONS))
76     disp_result(DS_OUTSECT, 0, NULL);
77 gwlarson 3.18 /* send eye separation if specified */
78     if (vdef(EYESEP)) {
79 gwlarson 3.23 sprintf(buf, "%.9e", vflt(EYESEP));
80     disp_result(DS_EYESEP, strlen(buf)+1, buf);
81 gwlarson 3.18 }
82 gwlarson 3.23 /* write out hologram grids & octrees */
83     for (i = 0; hdlist[i] != NULL; i++) {
84 schorsch 3.32 memcpy(buf, (void *)hdlist[i], sizeof(HDGRID));
85 gwlarson 3.24 len = sizeof(HDGRID);
86     n = vdef(GEOMETRY);
87     sfn = i<n ? nvalue(GEOMETRY,i) :
88     n ? nvalue(GEOMETRY,n-1) : vval(OCTREE);
89     strcpy(buf+len, sfn);
90     len += strlen(sfn) + 1;
91     n = vdef(PORTS);
92     sfn = i<n ? nvalue(PORTS,i) : n ? nvalue(PORTS,n-1) : "";
93     strcpy(buf+len, sfn);
94     len += strlen(sfn) + 1;
95     disp_result(DS_ADDHOLO, len, buf);
96 gwlarson 3.23 }
97 gregl 3.5 disp_flush();
98 gregl 3.1 }
99
100
101 greg 3.38 void
102 schorsch 3.36 disp_packet( /* display a packet */
103 greg 3.38 PACKHEAD *p
104 schorsch 3.36 )
105 gregl 3.2 {
106 gregl 3.4 disp_result(DS_BUNDLE, packsiz(p->nr), (char *)p);
107 gregl 3.2 }
108
109
110 greg 3.38 int
111 schorsch 3.36 disp_check( /* check display process */
112     int block
113     )
114 gregl 3.1 {
115 gregl 3.2 MSGHEAD msg;
116     int n;
117     char *buf = NULL;
118
119 gregl 3.6 if (dpout == NULL)
120 gregl 3.2 return(-1);
121 gregl 3.5 /* flush display output */
122     disp_flush();
123 gregl 3.3 /* check read blocking */
124 gregl 3.2 if (block != (inp_flags == 0)) {
125     inp_flags = block ? 0 : FNONBLK;
126 schorsch 3.30 if (fcntl(dpd.r, F_SETFL, inp_flags) < 0)
127 gregl 3.2 goto fcntlerr;
128     }
129     /* read message header */
130 schorsch 3.30 n = read(dpd.r, (char *)&msg, sizeof(MSGHEAD));
131 gregl 3.2 if (n != sizeof(MSGHEAD)) {
132 gregl 3.10 if (n >= 0) {
133     dpout = NULL;
134 gregl 3.2 error(USER, "display process died");
135 gregl 3.10 }
136 schorsch 3.35 if ((errno != EAGAIN) & (errno != EINTR))
137 gregl 3.2 goto readerr;
138 gregl 3.3 return(2); /* acceptable failure */
139 gregl 3.2 }
140     if (msg.nbytes) { /* get the message body */
141 gwlarson 3.20 if (msg.nbytes < 0)
142     error(INTERNAL, "anti-message from display process");
143 gregl 3.2 buf = (char *)malloc(msg.nbytes);
144     if (buf == NULL)
145     error(SYSTEM, "out of memory in disp_check");
146 schorsch 3.30 if (inp_flags != 0 && fcntl(dpd.r, F_SETFL, inp_flags=0) < 0)
147 gregl 3.2 goto fcntlerr;
148 schorsch 3.30 if (readbuf(dpd.r, buf, msg.nbytes) != msg.nbytes)
149 gregl 3.2 goto readerr;
150     }
151     switch (msg.type) { /* take appropriate action */
152 gregl 3.12 case DR_BUNDLE: /* new bundle to calculate */
153 gregl 3.2 if (msg.nbytes != sizeof(PACKHEAD))
154     error(INTERNAL, "bad DR_BUNDLE from display process");
155     bundle_set(BS_ADD, (PACKHEAD *)buf, 1);
156     break;
157 gregl 3.12 case DR_NEWSET: /* new calculation set */
158 gregl 3.2 if (msg.nbytes % sizeof(PACKHEAD))
159     error(INTERNAL, "bad DR_NEWSET from display process");
160 gwlarson 3.19 if (msg.nbytes)
161     disp_result(DS_STARTIMM, 0, NULL);
162 gregl 3.2 bundle_set(BS_NEW, (PACKHEAD *)buf, msg.nbytes/sizeof(PACKHEAD));
163 gwlarson 3.19 if (msg.nbytes) {
164     disp_result(DS_ENDIMM, 0, NULL);
165     disp_flush();
166     }
167 gregl 3.2 break;
168 gregl 3.12 case DR_ADDSET: /* add to calculation set */
169 gwlarson 3.19 if (!msg.nbytes)
170     break;
171 gregl 3.2 if (msg.nbytes % sizeof(PACKHEAD))
172     error(INTERNAL, "bad DR_ADDSET from display process");
173     disp_result(DS_STARTIMM, 0, NULL);
174     bundle_set(BS_ADD, (PACKHEAD *)buf, msg.nbytes/sizeof(PACKHEAD));
175     disp_result(DS_ENDIMM, 0, NULL);
176 gregl 3.15 disp_flush();
177 gregl 3.2 break;
178 gregl 3.12 case DR_ADJSET: /* adjust calculation set members */
179 gwlarson 3.19 if (!msg.nbytes)
180     break;
181 gregl 3.9 if (msg.nbytes % sizeof(PACKHEAD))
182     error(INTERNAL, "bad DR_ADJSET from display process");
183     disp_result(DS_STARTIMM, 0, NULL);
184     bundle_set(BS_ADJ, (PACKHEAD *)buf, msg.nbytes/sizeof(PACKHEAD));
185     disp_result(DS_ENDIMM, 0, NULL);
186     disp_flush();
187     break;
188 gregl 3.12 case DR_DELSET: /* delete from calculation set */
189 gwlarson 3.19 if (!msg.nbytes)
190     break;
191 gregl 3.2 if (msg.nbytes % sizeof(PACKHEAD))
192     error(INTERNAL, "bad DR_DELSET from display process");
193     bundle_set(BS_DEL, (PACKHEAD *)buf, msg.nbytes/sizeof(PACKHEAD));
194     break;
195 gwlarson 3.22 case DR_VIEWPOINT: /* set target eye position */
196     if (msg.nbytes != sizeof(VIEWPOINT))
197     error(INTERNAL, "bad DR_VIEWPOINT from display process");
198 schorsch 3.34 myeye = *((VIEWPOINT *)buf);
199 gwlarson 3.22 break;
200 gregl 3.12 case DR_ATTEN: /* block for priority request */
201 gregl 3.2 if (msg.nbytes)
202     error(INTERNAL, "bad DR_ATTEN from display process");
203     /* send acknowledgement */
204     disp_result(DS_ACKNOW, 0, NULL);
205 gregl 3.3 return(disp_check(1)); /* block on following request */
206 gregl 3.13 case DR_KILL: /* kill computation process(es) */
207     if (msg.nbytes)
208     error(INTERNAL, "bad DR_KILL from display process");
209 gregl 3.14 if (nprocs > 0)
210     done_rtrace();
211     else
212 gregl 3.13 error(WARNING, "no rtrace process to kill");
213     break;
214     case DR_RESTART: /* restart computation process(es) */
215     if (msg.nbytes)
216     error(INTERNAL, "bad DR_RESTART from display process");
217 gregl 3.14 if (ncprocs > nprocs)
218     new_rtrace();
219     else if (nprocs > 0)
220 gregl 3.13 error(WARNING, "rtrace already runnning");
221     else
222     error(WARNING, "holodeck not open for writing");
223     break;
224     case DR_CLOBBER: /* clobber holodeck */
225     if (msg.nbytes)
226     error(INTERNAL, "bad DR_CLOBBER from display process");
227 schorsch 3.35 if ((force <= 0) | (ncprocs <= 0))
228 gregl 3.13 error(WARNING, "request to clobber holodeck denied");
229     else {
230     error(WARNING, "clobbering holodeck contents");
231     hdclobber(NULL);
232     }
233     break;
234 gregl 3.12 case DR_SHUTDOWN: /* shut down program */
235 gregl 3.2 if (msg.nbytes)
236     error(INTERNAL, "bad DR_SHUTDOWN from display process");
237     return(0); /* zero return signals shutdown */
238 gregl 3.12 case DR_NOOP: /* do nothing */
239 gregl 3.7 break;
240 gregl 3.2 default:
241     error(INTERNAL, "unrecognized request from display process");
242     }
243 gregl 3.3 if (msg.nbytes) /* clean up */
244 gregl 3.2 free(buf);
245     return(1); /* normal return value */
246     fcntlerr:
247     error(SYSTEM, "cannot change display blocking mode");
248     readerr:
249     error(SYSTEM, "error reading from display process");
250 schorsch 3.36 return -1; /* pro forma return */
251 gregl 3.1 }
252
253
254 greg 3.38 int
255 schorsch 3.36 disp_close(void) /* close our display process */
256 gregl 3.1 {
257 gregl 3.6 if (dpout == NULL)
258 gregl 3.2 return(-1);
259 gwlarson 3.23 myeye.rng = 0;
260 gregl 3.2 disp_result(DS_SHUTDOWN, 0, NULL);
261 gregl 3.5 fclose(dpout);
262     dpout = NULL;
263 schorsch 3.30 return(dpd.running ? close_process(&dpd) : 0);
264
265 gregl 3.2 }
266
267
268 schorsch 3.36 static void
269     disp_result( /* queue result message to display process */
270     int type,
271     int nbytes,
272     char *p
273     )
274 gregl 3.2 {
275     MSGHEAD msg;
276 gwlarson 3.20 /* consistency checks */
277     #ifdef DEBUG
278     if (nbytes < 0 || nbytes > 0 & p == NULL)
279     error(CONSISTENCY, "bad buffer handed to disp_result");
280     #endif
281 gregl 3.6 if (dpout == NULL)
282     return;
283 gregl 3.2 msg.type = type;
284     msg.nbytes = nbytes;
285 greg 3.37 putbinary(&msg, sizeof(MSGHEAD), 1, dpout);
286 gregl 3.5 if (nbytes > 0)
287 greg 3.37 putbinary(p, 1, nbytes, dpout);
288 gregl 3.5 }
289
290
291 schorsch 3.36 static void
292     disp_flush(void) /* flush output to display */
293 gregl 3.5 {
294     if (fflush(dpout) < 0)
295     error(SYSTEM, "error writing to the display process");
296 gregl 3.1 }
