Ansification and prototypes.
Eliminated copystruct() macro, which is unnecessary in ANSI. Reduced ambiguity warnings for nested if/if/else clauses.
Compile fixes for gcc 3.3
Abstracted process and path handling for Windows. Renamed FLOAT to RREAL because of conflict on Windows. Added conditional compiles for some signal handlers.
Changes and check-in for 3.5 release Includes new source files and modifications not recorded for many years See ray/doc/notes/ReleaseNotes for notes between 3.1 and 3.5 release
added -r option for read-only holodeck with computation
added "-o slave" option for slave server operation
fixed too-small buffer size for geometry arguments in start_rtrace()
added new "portals" variable for multiple section geometry
added FNONBLK define for Solaris systems
added paranoid checks for negative message sizes
added more careful calls to disp_check()
added motion outside section when OBSTRUCTIONS=True
change driver suffix
took out unnecessary call to disp_check(1)
now we don't quit display process when our calculation ends
added comments
improved error recovery when display process dies
eliminated queue flushing in sortbeamlist() added DS_ADJSET request for adjusting set quantities
added check for delete after processing add in disp_check()
added noop function to recover from vain DR_ATTEN
removed pipesiz variable
changed from unbuffered to buffered output to display process added name to display program arguments
changed disp_packet to take PACKHEAD* r.t. PACKET*
minor bug fixes
