1 |
/* Copyright (c) 1998 Silicon Graphics, Inc. */ |
2 |
3 |
#ifndef lint |
4 |
static char SCCSid[] = "$SunId$ SGI"; |
5 |
#endif |
6 |
7 |
8 |
* Holodeck display process communication |
9 |
10 |
11 |
#include "rholo.h" |
12 |
#include "rhdisp.h" |
13 |
#include <sys/uio.h> |
14 |
15 |
#ifndef HDSUF |
16 |
#define HDSUF ".hdi" |
17 |
#endif |
18 |
19 |
#ifndef FNONBLK |
20 |
#define FNONBLK O_NONBLOCK |
21 |
#endif |
22 |
23 |
static int inp_flags; |
24 |
static int dpd[3]; |
25 |
static FILE *dpout; |
26 |
27 |
28 |
disp_open(dname) /* open the named display driver */ |
29 |
char *dname; |
30 |
31 |
char dpath[128], fd0[8], fd1[8], *cmd[5]; |
32 |
int i; |
33 |
/* get full display program name */ |
34 |
#ifdef DEVPATH |
35 |
sprintf(dpath, "%s/%s%s", DEVPATH, dname, HDSUF); |
36 |
#else |
37 |
sprintf(dpath, "dev/%s%s", dname, HDSUF); |
38 |
#endif |
39 |
/* dup stdin and stdout */ |
40 |
if (readinp) |
41 |
sprintf(fd0, "%d", dup(0)); |
42 |
else |
43 |
strcpy(fd0, "-1"); |
44 |
sprintf(fd1, "%d", dup(1)); |
45 |
/* start the display process */ |
46 |
cmd[0] = dpath; |
47 |
cmd[1] = froot; cmd[2] = fd1; cmd[3] = fd0; |
48 |
cmd[4] = NULL; |
49 |
i = open_process(dpd, cmd); |
50 |
if (i <= 0) |
51 |
error(USER, "cannot start display process"); |
52 |
if ((dpout = fdopen(dpd[1], "w")) == NULL) |
53 |
error(SYSTEM, "cannot associate FILE with display pipe"); |
54 |
dpd[1] = -1; /* causes ignored error in close_process() */ |
55 |
inp_flags = 0; |
56 |
/* close dup'ed stdin and stdout */ |
57 |
if (readinp) |
58 |
close(atoi(fd0)); |
59 |
close(atoi(fd1)); |
60 |
/* check if outside */ |
61 |
if (vdef(OBSTRUCTIONS) && vbool(OBSTRUCTIONS)) |
62 |
disp_result(DS_OUTSECT, 0, NULL); |
63 |
/* send eye separation if specified */ |
64 |
if (vdef(EYESEP)) { |
65 |
char fbuf[32]; |
66 |
sprintf(fbuf, "%.9e", vflt(EYESEP)); |
67 |
disp_result(DS_EYESEP, strlen(fbuf)+1, fbuf); |
68 |
69 |
/* write out hologram grids */ |
70 |
for (i = 0; hdlist[i] != NULL; i++) |
71 |
disp_result(DS_ADDHOLO, sizeof(HDGRID), (char *)hdlist[i]); |
72 |
disp_flush(); |
73 |
74 |
75 |
76 |
disp_packet(p) /* display a packet */ |
77 |
register PACKHEAD *p; |
78 |
79 |
disp_result(DS_BUNDLE, packsiz(p->nr), (char *)p); |
80 |
81 |
82 |
83 |
disp_check(block) /* check display process */ |
84 |
int block; |
85 |
86 |
MSGHEAD msg; |
87 |
int n; |
88 |
char *buf = NULL; |
89 |
90 |
if (dpout == NULL) |
91 |
return(-1); |
92 |
/* flush display output */ |
93 |
disp_flush(); |
94 |
/* check read blocking */ |
95 |
if (block != (inp_flags == 0)) { |
96 |
inp_flags = block ? 0 : FNONBLK; |
97 |
if (fcntl(dpd[0], F_SETFL, inp_flags) < 0) |
98 |
goto fcntlerr; |
99 |
100 |
/* read message header */ |
101 |
n = read(dpd[0], (char *)&msg, sizeof(MSGHEAD)); |
102 |
if (n != sizeof(MSGHEAD)) { |
103 |
if (n >= 0) { |
104 |
dpout = NULL; |
105 |
error(USER, "display process died"); |
106 |
107 |
if (errno != EAGAIN & errno != EINTR) |
108 |
goto readerr; |
109 |
return(2); /* acceptable failure */ |
110 |
111 |
if (msg.nbytes) { /* get the message body */ |
112 |
if (msg.nbytes < 0) |
113 |
error(INTERNAL, "anti-message from display process"); |
114 |
buf = (char *)malloc(msg.nbytes); |
115 |
if (buf == NULL) |
116 |
error(SYSTEM, "out of memory in disp_check"); |
117 |
if (inp_flags != 0 && fcntl(dpd[0], F_SETFL, inp_flags=0) < 0) |
118 |
goto fcntlerr; |
119 |
if (readbuf(dpd[0], buf, msg.nbytes) != msg.nbytes) |
120 |
goto readerr; |
121 |
122 |
switch (msg.type) { /* take appropriate action */ |
123 |
case DR_BUNDLE: /* new bundle to calculate */ |
124 |
if (msg.nbytes != sizeof(PACKHEAD)) |
125 |
error(INTERNAL, "bad DR_BUNDLE from display process"); |
126 |
bundle_set(BS_ADD, (PACKHEAD *)buf, 1); |
127 |
break; |
128 |
case DR_NEWSET: /* new calculation set */ |
129 |
if (msg.nbytes % sizeof(PACKHEAD)) |
130 |
error(INTERNAL, "bad DR_NEWSET from display process"); |
131 |
if (msg.nbytes) |
132 |
disp_result(DS_STARTIMM, 0, NULL); |
133 |
bundle_set(BS_NEW, (PACKHEAD *)buf, msg.nbytes/sizeof(PACKHEAD)); |
134 |
if (msg.nbytes) { |
135 |
disp_result(DS_ENDIMM, 0, NULL); |
136 |
disp_flush(); |
137 |
138 |
break; |
139 |
case DR_ADDSET: /* add to calculation set */ |
140 |
if (!msg.nbytes) |
141 |
break; |
142 |
143 |
error(INTERNAL, "bad DR_ADDSET from display process"); |
144 |
145 |
bundle_set(BS_ADD, (PACKHEAD *)buf, msg.nbytes/sizeof(PACKHEAD)); |
146 |
147 |
disp_flush(); |
148 |
break; |
149 |
case DR_ADJSET: /* adjust calculation set members */ |
150 |
if (!msg.nbytes) |
151 |
break; |
152 |
153 |
error(INTERNAL, "bad DR_ADJSET from display process"); |
154 |
155 |
bundle_set(BS_ADJ, (PACKHEAD *)buf, msg.nbytes/sizeof(PACKHEAD)); |
156 |
157 |
disp_flush(); |
158 |
break; |
159 |
case DR_DELSET: /* delete from calculation set */ |
160 |
if (!msg.nbytes) |
161 |
break; |
162 |
163 |
error(INTERNAL, "bad DR_DELSET from display process"); |
164 |
bundle_set(BS_DEL, (PACKHEAD *)buf, msg.nbytes/sizeof(PACKHEAD)); |
165 |
break; |
166 |
case DR_ATTEN: /* block for priority request */ |
167 |
if (msg.nbytes) |
168 |
error(INTERNAL, "bad DR_ATTEN from display process"); |
169 |
/* send acknowledgement */ |
170 |
disp_result(DS_ACKNOW, 0, NULL); |
171 |
return(disp_check(1)); /* block on following request */ |
172 |
case DR_KILL: /* kill computation process(es) */ |
173 |
if (msg.nbytes) |
174 |
error(INTERNAL, "bad DR_KILL from display process"); |
175 |
if (nprocs > 0) |
176 |
done_rtrace(); |
177 |
else |
178 |
error(WARNING, "no rtrace process to kill"); |
179 |
break; |
180 |
case DR_RESTART: /* restart computation process(es) */ |
181 |
if (msg.nbytes) |
182 |
error(INTERNAL, "bad DR_RESTART from display process"); |
183 |
if (ncprocs > nprocs) |
184 |
new_rtrace(); |
185 |
else if (nprocs > 0) |
186 |
error(WARNING, "rtrace already runnning"); |
187 |
else |
188 |
error(WARNING, "holodeck not open for writing"); |
189 |
break; |
190 |
case DR_CLOBBER: /* clobber holodeck */ |
191 |
if (msg.nbytes) |
192 |
error(INTERNAL, "bad DR_CLOBBER from display process"); |
193 |
if (!force || !ncprocs) |
194 |
error(WARNING, "request to clobber holodeck denied"); |
195 |
else { |
196 |
error(WARNING, "clobbering holodeck contents"); |
197 |
hdclobber(NULL); |
198 |
199 |
break; |
200 |
case DR_SHUTDOWN: /* shut down program */ |
201 |
if (msg.nbytes) |
202 |
error(INTERNAL, "bad DR_SHUTDOWN from display process"); |
203 |
return(0); /* zero return signals shutdown */ |
204 |
case DR_NOOP: /* do nothing */ |
205 |
break; |
206 |
default: |
207 |
error(INTERNAL, "unrecognized request from display process"); |
208 |
209 |
if (msg.nbytes) /* clean up */ |
210 |
free(buf); |
211 |
return(1); /* normal return value */ |
212 |
fcntlerr: |
213 |
error(SYSTEM, "cannot change display blocking mode"); |
214 |
readerr: |
215 |
error(SYSTEM, "error reading from display process"); |
216 |
217 |
218 |
219 |
int |
220 |
disp_close() /* close our display process */ |
221 |
222 |
int rval; |
223 |
224 |
225 |
return(-1); |
226 |
disp_result(DS_SHUTDOWN, 0, NULL); |
227 |
fclose(dpout); |
228 |
dpout = NULL; |
229 |
return(close_process(dpd)); |
230 |
231 |
232 |
233 |
disp_result(type, nbytes, p) /* queue result message to display process */ |
234 |
int type, nbytes; |
235 |
char *p; |
236 |
237 |
MSGHEAD msg; |
238 |
/* consistency checks */ |
239 |
#ifdef DEBUG |
240 |
if (nbytes < 0 || nbytes > 0 & p == NULL) |
241 |
error(CONSISTENCY, "bad buffer handed to disp_result"); |
242 |
#endif |
243 |
244 |
return; |
245 |
msg.type = type; |
246 |
msg.nbytes = nbytes; |
247 |
fwrite((char *)&msg, sizeof(MSGHEAD), 1, dpout); |
248 |
if (nbytes > 0) |
249 |
fwrite(p, 1, nbytes, dpout); |
250 |
251 |
252 |
253 |
disp_flush() /* flush output to display */ |
254 |
255 |
if (fflush(dpout) < 0) |
256 |
error(SYSTEM, "error writing to the display process"); |
257 |
