1 |
/* Copyright (c) 1997 Silicon Graphics, Inc. */ |
2 |
3 |
#ifndef lint |
4 |
static char SCCSid[] = "$SunId$ SGI"; |
5 |
#endif |
6 |
7 |
8 |
* Holodeck display process communication |
9 |
10 |
11 |
#include "rholo.h" |
12 |
#include "rhdisp.h" |
13 |
#include <sys/uio.h> |
14 |
15 |
#ifndef HDSUF |
16 |
#define HDSUF ".hdisp" |
17 |
#endif |
18 |
19 |
static int inp_flags; |
20 |
static int dpd[3]; |
21 |
static int pipesiz; |
22 |
23 |
24 |
disp_open(dname) /* open the named display driver */ |
25 |
char *dname; |
26 |
27 |
char dpath[128], *com[2]; |
28 |
int i; |
29 |
30 |
#ifdef DEVPATH |
31 |
sprintf(dpath, "%s/%s%s", DEVPATH, dname, HDSUF); |
32 |
#else |
33 |
sprintf(dpath, "dev/%s%s", dname, HDSUF); |
34 |
#endif |
35 |
com[0] = dpath; com[1] = NULL; |
36 |
pipesiz = open_process(dpd, com); |
37 |
if (pipesiz <= 0) |
38 |
error(USER, "cannot start display process"); |
39 |
inp_flags = 0; |
40 |
/* write out hologram grids */ |
41 |
for (i = 0; hdlist[i] != NULL; i++) |
42 |
disp_result(DS_ADDHOLO, sizeof(HDGRID), (char *)hdlist[i]); |
43 |
44 |
45 |
46 |
disp_packet(p) /* display a packet */ |
47 |
register PACKET *p; |
48 |
49 |
if (pipesiz <= 0) |
50 |
return; |
51 |
disp_result(DS_BUNDLE, sizeof(PACKHEAD) + p->nr*sizeof(RAYVAL), |
52 |
(char *)p); |
53 |
54 |
55 |
56 |
disp_check(block) /* check display process */ |
57 |
int block; |
58 |
59 |
MSGHEAD msg; |
60 |
int n; |
61 |
char *buf = NULL; |
62 |
63 |
if (pipesiz <= 0) |
64 |
return(-1); |
65 |
restart: /* check read blocking */ |
66 |
if (block != (inp_flags == 0)) { |
67 |
inp_flags = block ? 0 : FNONBLK; |
68 |
if (fcntl(dpd[0], F_SETFL, inp_flags) < 0) |
69 |
goto fcntlerr; |
70 |
71 |
/* read message header */ |
72 |
n = read(dpd[0], (char *)&msg, sizeof(MSGHEAD)); |
73 |
if (n != sizeof(MSGHEAD)) { |
74 |
if (n >= 0) |
75 |
error(USER, "display process died"); |
76 |
if (errno != EAGAIN & errno != EINTR) |
77 |
goto readerr; |
78 |
return(2); /* else acceptable failure */ |
79 |
80 |
if (msg.nbytes) { /* get the message body */ |
81 |
buf = (char *)malloc(msg.nbytes); |
82 |
if (buf == NULL) |
83 |
error(SYSTEM, "out of memory in disp_check"); |
84 |
if (fcntl(dpd[0], F_SETFL, inp_flags=0) < 0) |
85 |
goto fcntlerr; |
86 |
if (readbuf(dpd[0], buf, msg.nbytes) != msg.nbytes) |
87 |
goto readerr; |
88 |
89 |
switch (msg.type) { /* take appropriate action */ |
90 |
case DR_BUNDLE: |
91 |
if (msg.nbytes != sizeof(PACKHEAD)) |
92 |
error(INTERNAL, "bad DR_BUNDLE from display process"); |
93 |
bundle_set(BS_ADD, (PACKHEAD *)buf, 1); |
94 |
break; |
95 |
case DR_NEWSET: |
96 |
if (msg.nbytes % sizeof(PACKHEAD)) |
97 |
error(INTERNAL, "bad DR_NEWSET from display process"); |
98 |
disp_result(DS_STARTIMM, 0, NULL); |
99 |
bundle_set(BS_NEW, (PACKHEAD *)buf, msg.nbytes/sizeof(PACKHEAD)); |
100 |
disp_result(DS_ENDIMM, 0, NULL); |
101 |
break; |
102 |
case DR_ADDSET: |
103 |
104 |
error(INTERNAL, "bad DR_ADDSET from display process"); |
105 |
106 |
bundle_set(BS_ADD, (PACKHEAD *)buf, msg.nbytes/sizeof(PACKHEAD)); |
107 |
108 |
break; |
109 |
case DR_DELSET: |
110 |
111 |
error(INTERNAL, "bad DR_DELSET from display process"); |
112 |
bundle_set(BS_DEL, (PACKHEAD *)buf, msg.nbytes/sizeof(PACKHEAD)); |
113 |
break; |
114 |
case DR_ATTEN: |
115 |
if (msg.nbytes) |
116 |
error(INTERNAL, "bad DR_ATTEN from display process"); |
117 |
/* send acknowledgement */ |
118 |
disp_result(DS_ACKNOW, 0, NULL); |
119 |
block = 1; /* block on following request */ |
120 |
goto restart; |
121 |
case DR_SHUTDOWN: |
122 |
if (msg.nbytes) |
123 |
error(INTERNAL, "bad DR_SHUTDOWN from display process"); |
124 |
return(0); /* zero return signals shutdown */ |
125 |
default: |
126 |
error(INTERNAL, "unrecognized request from display process"); |
127 |
128 |
if (msg.nbytes) |
129 |
free(buf); |
130 |
return(1); /* normal return value */ |
131 |
fcntlerr: |
132 |
error(SYSTEM, "cannot change display blocking mode"); |
133 |
readerr: |
134 |
error(SYSTEM, "error reading from display process"); |
135 |
136 |
137 |
138 |
int |
139 |
disp_close() /* close our display process */ |
140 |
141 |
int rval; |
142 |
143 |
if (pipesiz <= 0) |
144 |
return(-1); |
145 |
disp_result(DS_SHUTDOWN, 0, NULL); |
146 |
pipesiz = 0; |
147 |
return(close_process(dpd)); |
148 |
149 |
150 |
151 |
disp_result(type, nbytes, p) /* send result message to display process */ |
152 |
int type, nbytes; |
153 |
char *p; |
154 |
155 |
struct iovec iov[2]; |
156 |
MSGHEAD msg; |
157 |
int n; |
158 |
159 |
msg.type = type; |
160 |
msg.nbytes = nbytes; |
161 |
if (nbytes == 0 || sizeof(MSGHEAD)+nbytes > pipesiz) { |
162 |
n = write(dpd[1], (char *)&msg, sizeof(MSGHEAD)); |
163 |
if (n != sizeof(MSGHEAD)) |
164 |
goto writerr; |
165 |
if (nbytes > 0) { |
166 |
n = writebuf(dpd[1], p, nbytes); |
167 |
if (n != nbytes) |
168 |
goto writerr; |
169 |
170 |
return; |
171 |
172 |
iov[0].iov_base = (char *)&msg; |
173 |
iov[0].iov_len = sizeof(MSGHEAD); |
174 |
iov[1].iov_base = p; |
175 |
iov[1].iov_len = nbytes; |
176 |
n = writev(dpd[1], iov, 2); |
177 |
if (n == nbytes+sizeof(MSGHEAD)) |
178 |
return; |
179 |
writerr: |
180 |
error(SYSTEM, "write error in disp_result"); |
181 |
