root/radiance/ray/src/hd/rholo4.c
Changes since 3.35: +27 -15 lines
Diff to previous 3.35 , to selected 3.32
Ansification and prototypes.
Sun Jul 27 22:12:02 2003 UTC (20 years, 9 months ago) by schorsch
Changes since 3.34: +3 -3 lines
Diff to previous 3.34 , to selected 3.32
Mon Jul 21 22:30:18 2003 UTC (20 years, 9 months ago) by schorsch
Changes since 3.33: +2 -2 lines
Diff to previous 3.33 , to selected 3.32
Tue Jul 1 21:21:40 2003 UTC (20 years, 10 months ago) by greg
Changes since 3.32: +3 -4 lines
Diff to previous 3.32
Compile fixes for gcc 3.3
Revision 3.32 - (view) (download) (annotate) - [selected]
Changes since 3.31: +5 -4 lines
Diff to previous 3.31
Changes since 3.30: +3 -3 lines
Diff to previous 3.30 , to selected 3.32
Changes since 3.29: +16 -13 lines
Diff to previous 3.29 , to selected 3.32
Tue May 13 17:58:33 2003 UTC (20 years, 11 months ago) by greg
Changes since 3.28: +1 -1 lines
Diff to previous 3.28 , to selected 3.32
Sat Feb 22 02:07:25 2003 UTC (21 years, 2 months ago) by greg
Changes since 3.27: +1 -4 lines
Diff to previous 3.27 , to selected 3.32
Thu Aug 5 13:51:21 1999 UTC (24 years, 8 months ago) by gwlarson
Changes since 3.26: +1 -1 lines
Diff to previous 3.26 , to selected 3.32
added -r option for read-only holodeck with computation
Fri Feb 12 11:32:22 1999 UTC (25 years, 2 months ago) by gwlarson
Changes since 3.25: +34 -24 lines
Diff to previous 3.25 , to selected 3.32
added "-o slave" option for slave server operation
Mon Jan 4 17:48:30 1999 UTC (25 years, 3 months ago) by gwlarson
Diff to previous 3.24 , to selected 3.32
fixed too-small buffer size for geometry arguments in start_rtrace()
Sun Dec 20 20:39:31 1998 UTC (25 years, 4 months ago) by gwlarson
Changes since 3.23: +13 -7 lines
Diff to previous 3.23 , to selected 3.32
added new "portals" variable for multiple section geometry
Fri Dec 18 11:56:11 1998 UTC (25 years, 4 months ago) by gwlarson
Changes since 3.22: +17 -11 lines
Diff to previous 3.22 , to selected 3.32
Tue Nov 24 17:05:36 1998 UTC (25 years, 5 months ago) by gwlarson
Changes since 3.21: +5 -0 lines
Diff to previous 3.21 , to selected 3.32
Thu Oct 22 08:47:40 1998 UTC (25 years, 6 months ago) by gwlarson
Changes since 3.20: +4 -0 lines
Diff to previous 3.20 , to selected 3.32
added FNONBLK define for Solaris systems
Tue Oct 6 18:09:49 1998 UTC (25 years, 6 months ago) by gwlarson
Changes since 3.19: +7 -1 lines
Diff to previous 3.19 , to selected 3.32
added paranoid checks for negative message sizes
Wed Aug 12 17:55:11 1998 UTC (25 years, 8 months ago) by gwlarson
Changes since 3.18: +14 -5 lines
Diff to previous 3.18 , to selected 3.32
added more careful calls to disp_check()
Fri May 22 08:30:41 1998 UTC (25 years, 11 months ago) by gwlarson
Changes since 3.17: +6 -0 lines
Diff to previous 3.17 , to selected 3.32
Sun Jan 4 18:37:11 1998 UTC (26 years, 3 months ago) by gregl
Changes since 3.16: +3 -0 lines
Diff to previous 3.16 , to selected 3.32
added motion outside section when OBSTRUCTIONS=True
Mon Dec 22 17:42:03 1997 UTC (26 years, 4 months ago) by gregl
Changes since 3.15: +1 -1 lines
Diff to previous 3.15 , to selected 3.32
change driver suffix
Tue Dec 16 12:26:04 1997 UTC (26 years, 4 months ago) by gregl
Changes since 3.14: +1 -1 lines
Diff to previous 3.14 , to selected 3.32
took out unnecessary call to disp_check(1)
Fri Dec 12 18:12:40 1997 UTC (26 years, 4 months ago) by gregl
Changes since 3.13: +6 -10 lines
Diff to previous 3.13 , to selected 3.32
now we don't quit display process when our calculation ends
Fri Dec 12 11:13:17 1997 UTC (26 years, 4 months ago) by gregl
Changes since 3.12: +32 -0 lines
Diff to previous 3.12 , to selected 3.32
Thu Dec 11 17:40:04 1997 UTC (26 years, 4 months ago) by gregl
Changes since 3.11: +8 -8 lines
Diff to previous 3.11 , to selected 3.32
added comments
Mon Dec 8 18:51:15 1997 UTC (26 years, 4 months ago) by gregl
Changes since 3.10: +19 -5 lines
Diff to previous 3.10 , to selected 3.32
Mon Dec 1 16:35:35 1997 UTC (26 years, 5 months ago) by gregl
Changes since 3.9: +3 -1 lines
Diff to previous 3.9 , to selected 3.32
improved error recovery when display process dies
Wed Nov 26 21:34:28 1997 UTC (26 years, 5 months ago) by gregl
Changes since 3.8: +8 -0 lines
Diff to previous 3.8 , to selected 3.32
Wed Nov 26 20:14:43 1997 UTC (26 years, 5 months ago) by gregl
Changes since 3.7: +1 -1 lines
Diff to previous 3.7 , to selected 3.32
added check for delete after processing add in disp_check()
Thu Nov 20 18:07:00 1997 UTC (26 years, 5 months ago) by gregl
Changes since 3.6: +2 -0 lines
Diff to previous 3.6 , to selected 3.32
added noop function to recover from vain DR_ATTEN
Thu Nov 20 11:40:11 1997 UTC (26 years, 5 months ago) by gregl
Changes since 3.5: +6 -6 lines
Diff to previous 3.5 , to selected 3.32
removed pipesiz variable
Mon Nov 10 18:07:15 1997 UTC (26 years, 5 months ago) by gregl
Changes since 3.4: +23 -28 lines
Diff to previous 3.4 , to selected 3.32
changed from unbuffered to buffered output to display process
added name to display program arguments
Thu Nov 6 16:12:41 1997 UTC (26 years, 5 months ago) by gregl
Changes since 3.3: +4 -8 lines
Diff to previous 3.3 , to selected 3.32
changed disp_packet to take PACKHEAD* r.t. PACKET*
Tue Nov 4 09:58:24 1997 UTC (26 years, 5 months ago) by gregl
Changes since 3.2: +13 -10 lines
Diff to previous 3.2 , to selected 3.32
minor bug fixes
Mon Nov 3 18:33:14 1997 UTC (26 years, 5 months ago) by gregl
Changes since 3.1: +154 -5 lines
Diff to previous 3.1 , to selected 3.32
Fri Oct 31 10:23:29 1997 UTC (26 years, 6 months ago) by gregl
Diff to selected 3.32
