--- ray/src/hd/rholo4.c 1997/11/26 20:14:43 3.8 +++ ray/src/hd/rholo4.c 1997/12/08 18:51:15 3.11 @@ -24,21 +24,35 @@ static FILE *dpout; disp_open(dname) /* open the named display driver */ char *dname; { - char dpath[128], *com[3]; + char dpath[128], fd0[8], fd1[8], *cmd[5]; int i; - + /* get full display program name */ #ifdef DEVPATH sprintf(dpath, "%s/%s%s", DEVPATH, dname, HDSUF); #else sprintf(dpath, "dev/%s%s", dname, HDSUF); #endif - com[0] = dpath; com[1] = froot; com[2] = NULL; - i = open_process(dpd, com); + /* dup stdin and stdout */ + if (readinp) + sprintf(fd0, "%d", dup(0)); + else + strcpy(fd0, "-1"); + sprintf(fd1, "%d", dup(1)); + /* start the display process */ + cmd[0] = dpath; + cmd[1] = froot; cmd[2] = fd1; cmd[3] = fd0; + cmd[4] = NULL; + i = open_process(dpd, cmd); if (i <= 0) error(USER, "cannot start display process"); - if ((dpout = fdopen(dup(dpd[1]), "w")) == NULL) + if ((dpout = fdopen(dpd[1], "w")) == NULL) error(SYSTEM, "cannot associate FILE with display pipe"); + dpd[1] = -1; /* causes ignored error in close_process() */ inp_flags = 0; + /* close dup'ed stdin and stdout */ + if (readinp) + close(atoi(fd0)); + close(atoi(fd1)); /* write out hologram grids */ for (i = 0; hdlist[i] != NULL; i++) disp_result(DS_ADDHOLO, sizeof(HDGRID), (char *)hdlist[i]); @@ -73,8 +87,10 @@ int block; /* read message header */ n = read(dpd[0], (char *)&msg, sizeof(MSGHEAD)); if (n != sizeof(MSGHEAD)) { - if (n >= 0) + if (n >= 0) { + dpout = NULL; error(USER, "display process died"); + } if (errno != EAGAIN & errno != EINTR) goto readerr; return(2); /* acceptable failure */ @@ -109,6 +125,14 @@ int block; bundle_set(BS_ADD, (PACKHEAD *)buf, msg.nbytes/sizeof(PACKHEAD)); disp_result(DS_ENDIMM, 0, NULL); disp_check(0); /* hack -- delete usu. follows add */ + break; + case DR_ADJSET: + if (msg.nbytes % sizeof(PACKHEAD)) + error(INTERNAL, "bad DR_ADJSET from display process"); + disp_result(DS_STARTIMM, 0, NULL); + bundle_set(BS_ADJ, (PACKHEAD *)buf, msg.nbytes/sizeof(PACKHEAD)); + disp_result(DS_ENDIMM, 0, NULL); + disp_flush(); break; case DR_DELSET: if (msg.nbytes % sizeof(PACKHEAD))
