--- ray/src/hd/rholo4.c 1997/11/04 09:58:24 3.3 +++ ray/src/hd/rholo4.c 1997/12/08 18:51:15 3.11 @@ -18,36 +18,52 @@ static char SCCSid[] = "$SunId$ SGI"; static int inp_flags; static int dpd[3]; -static int pipesiz; +static FILE *dpout; disp_open(dname) /* open the named display driver */ char *dname; { - char dpath[128], *com[2]; + char dpath[128], fd0[8], fd1[8], *cmd[5]; int i; - + /* get full display program name */ #ifdef DEVPATH sprintf(dpath, "%s/%s%s", DEVPATH, dname, HDSUF); #else sprintf(dpath, "dev/%s%s", dname, HDSUF); #endif - com[0] = dpath; com[1] = NULL; - pipesiz = open_process(dpd, com); - if (pipesiz <= 0) + /* dup stdin and stdout */ + if (readinp) + sprintf(fd0, "%d", dup(0)); + else + strcpy(fd0, "-1"); + sprintf(fd1, "%d", dup(1)); + /* start the display process */ + cmd[0] = dpath; + cmd[1] = froot; cmd[2] = fd1; cmd[3] = fd0; + cmd[4] = NULL; + i = open_process(dpd, cmd); + if (i <= 0) error(USER, "cannot start display process"); + if ((dpout = fdopen(dpd[1], "w")) == NULL) + error(SYSTEM, "cannot associate FILE with display pipe"); + dpd[1] = -1; /* causes ignored error in close_process() */ inp_flags = 0; + /* close dup'ed stdin and stdout */ + if (readinp) + close(atoi(fd0)); + close(atoi(fd1)); /* write out hologram grids */ for (i = 0; hdlist[i] != NULL; i++) disp_result(DS_ADDHOLO, sizeof(HDGRID), (char *)hdlist[i]); + disp_flush(); } disp_packet(p) /* display a packet */ -register PACKET *p; +register PACKHEAD *p; { - disp_result(DS_BUNDLE, sizeof(PACKHEAD) + p->nr*sizeof(RAYVAL), - (char *)p); + disp_result(DS_BUNDLE, packsiz(p->nr), (char *)p); } @@ -58,8 +74,10 @@ int block; int n; char *buf = NULL; - if (pipesiz <= 0) + if (dpout == NULL) return(-1); + /* flush display output */ + disp_flush(); /* check read blocking */ if (block != (inp_flags == 0)) { inp_flags = block ? 0 : FNONBLK; @@ -69,8 +87,10 @@ int block; /* read message header */ n = read(dpd[0], (char *)&msg, sizeof(MSGHEAD)); if (n != sizeof(MSGHEAD)) { - if (n >= 0) + if (n >= 0) { + dpout = NULL; error(USER, "display process died"); + } if (errno != EAGAIN & errno != EINTR) goto readerr; return(2); /* acceptable failure */ @@ -96,6 +116,7 @@ int block; disp_result(DS_STARTIMM, 0, NULL); bundle_set(BS_NEW, (PACKHEAD *)buf, msg.nbytes/sizeof(PACKHEAD)); disp_result(DS_ENDIMM, 0, NULL); + disp_flush(); break; case DR_ADDSET: if (msg.nbytes % sizeof(PACKHEAD)) @@ -103,7 +124,16 @@ int block; disp_result(DS_STARTIMM, 0, NULL); bundle_set(BS_ADD, (PACKHEAD *)buf, msg.nbytes/sizeof(PACKHEAD)); disp_result(DS_ENDIMM, 0, NULL); + disp_check(0); /* hack -- delete usu. follows add */ break; + case DR_ADJSET: + if (msg.nbytes % sizeof(PACKHEAD)) + error(INTERNAL, "bad DR_ADJSET from display process"); + disp_result(DS_STARTIMM, 0, NULL); + bundle_set(BS_ADJ, (PACKHEAD *)buf, msg.nbytes/sizeof(PACKHEAD)); + disp_result(DS_ENDIMM, 0, NULL); + disp_flush(); + break; case DR_DELSET: if (msg.nbytes % sizeof(PACKHEAD)) error(INTERNAL, "bad DR_DELSET from display process"); @@ -119,6 +149,8 @@ int block; if (msg.nbytes) error(INTERNAL, "bad DR_SHUTDOWN from display process"); return(0); /* zero return signals shutdown */ + case DR_NOOP: + break; default: error(INTERNAL, "unrecognized request from display process"); } @@ -137,48 +169,33 @@ disp_close() /* close our display process */ { int rval; - if (pipesiz <= 0) + if (dpout == NULL) return(-1); disp_result(DS_SHUTDOWN, 0, NULL); - pipesiz = 0; + fclose(dpout); + dpout = NULL; return(close_process(dpd)); } -disp_result(type, nbytes, p) /* send result message to display process */ +disp_result(type, nbytes, p) /* queue result message to display process */ int type, nbytes; char *p; { - struct iovec iov[2]; MSGHEAD msg; - int n; - if (pipesiz <= 0) + if (dpout == NULL) return; msg.type = type; msg.nbytes = nbytes; - if (nbytes == 0 || sizeof(MSGHEAD)+nbytes > pipesiz) { - do - n = write(dpd[1], (char *)&msg, sizeof(MSGHEAD)); - while (n < 0 && errno == EINTR); - if (n != sizeof(MSGHEAD)) - goto writerr; - if (nbytes > 0) { - n = writebuf(dpd[1], p, nbytes); - if (n != nbytes) - goto writerr; - } - return; - } - iov[0].iov_base = (char *)&msg; - iov[0].iov_len = sizeof(MSGHEAD); - iov[1].iov_base = p; - iov[1].iov_len = nbytes; - do - n = writev(dpd[1], iov, 2); - while (n < 0 && errno == EINTR); - if (n == sizeof(MSGHEAD)+nbytes) - return; -writerr: - error(SYSTEM, "write error in disp_result"); + fwrite((char *)&msg, sizeof(MSGHEAD), 1, dpout); + if (nbytes > 0) + fwrite(p, 1, nbytes, dpout); +} + + +disp_flush() /* flush output to display */ +{ + if (fflush(dpout) < 0) + error(SYSTEM, "error writing to the display process"); }
