root/radiance/ray/src/hd/rholo4.c
Revision: 3.23
Committed: Fri Dec 18 11:56:11 1998 UTC (26 years, 4 months ago) by gwlarson
Changes since 3.22: +17 -11 lines
1 /* Copyright (c) 1998 Silicon Graphics, Inc. */
2
3 #ifndef lint
4 static char SCCSid[] = "$SunId$ SGI";
5 #endif
6
7 /*
8 * Holodeck display process communication
9 */
10
11 #include "rholo.h"
12 #include "rhdisp.h"
13 #include <sys/uio.h>
14
15 #ifndef HDSUF
16 #define HDSUF ".hdi"
17 #endif
18
19 #ifndef FNONBLK
20 #define FNONBLK O_NONBLOCK
21 #endif
22
23 static int inp_flags;
24 static int dpd[3];
25 static FILE *dpout;
26
27
28 disp_open(dname) /* open the named display driver */
29 char *dname;
30 {
31 char buf[128], fd0[8], fd1[8], *cmd[5], *ofn;
32 int i, n;
33 /* get full display program name */
34 #ifdef DEVPATH
35 sprintf(buf, "%s/%s%s", DEVPATH, dname, HDSUF);
36 #else
37 sprintf(buf, "dev/%s%s", dname, HDSUF);
38 #endif
39 /* dup stdin and stdout */
40 if (readinp)
41 sprintf(fd0, "%d", dup(0));
42 else
43 strcpy(fd0, "-1");
44 sprintf(fd1, "%d", dup(1));
45 /* start the display process */
46 cmd[0] = buf;
47 cmd[1] = froot; cmd[2] = fd1; cmd[3] = fd0;
48 cmd[4] = NULL;
49 i = open_process(dpd, cmd);
50 if (i <= 0)
51 error(USER, "cannot start display process");
52 if ((dpout = fdopen(dpd[1], "w")) == NULL)
53 error(SYSTEM, "cannot associate FILE with display pipe");
54 dpd[1] = -1; /* causes ignored error in close_process() */
55 inp_flags = 0;
56 /* close dup'ed stdin and stdout */
57 if (readinp)
58 close(atoi(fd0));
59 close(atoi(fd1));
60 /* check if outside */
61 if (vdef(OBSTRUCTIONS) && vbool(OBSTRUCTIONS))
62 disp_result(DS_OUTSECT, 0, NULL);
63 /* send eye separation if specified */
64 if (vdef(EYESEP)) {
65 sprintf(buf, "%.9e", vflt(EYESEP));
66 disp_result(DS_EYESEP, strlen(buf)+1, buf);
67 }
68 /* write out hologram grids & octrees */
69 for (i = 0; hdlist[i] != NULL; i++) {
70 bcopy((char *)hdlist[i], buf, sizeof(HDGRID));
71 n = vdef(OSECTION);
72 ofn = i<n ? nvalue(OSECTION,i) :
73 n ? nvalue(OSECTION,n-1) : vval(OCTREE);
74 strcpy(buf+sizeof(HDGRID), ofn);
75 disp_result(DS_ADDHOLO, sizeof(HDGRID)+1+strlen(ofn), buf);
76 }
77 disp_flush();
78 }
79
80
81 disp_packet(p) /* display a packet */
82 register PACKHEAD *p;
83 {
84 disp_result(DS_BUNDLE, packsiz(p->nr), (char *)p);
85 }
86
87
88 disp_check(block) /* check display process */
89 int block;
90 {
91 MSGHEAD msg;
92 int n;
93 char *buf = NULL;
94
95 if (dpout == NULL)
96 return(-1);
97 /* flush display output */
98 disp_flush();
99 /* check read blocking */
100 if (block != (inp_flags == 0)) {
101 inp_flags = block ? 0 : FNONBLK;
102 if (fcntl(dpd[0], F_SETFL, inp_flags) < 0)
103 goto fcntlerr;
104 }
105 /* read message header */
106 n = read(dpd[0], (char *)&msg, sizeof(MSGHEAD));
107 if (n != sizeof(MSGHEAD)) {
108 if (n >= 0) {
109 dpout = NULL;
110 error(USER, "display process died");
111 }
112 if (errno != EAGAIN & errno != EINTR)
113 goto readerr;
114 return(2); /* acceptable failure */
115 }
116 if (msg.nbytes) { /* get the message body */
117 if (msg.nbytes < 0)
118 error(INTERNAL, "anti-message from display process");
119 buf = (char *)malloc(msg.nbytes);
120 if (buf == NULL)
121 error(SYSTEM, "out of memory in disp_check");
122 if (inp_flags != 0 && fcntl(dpd[0], F_SETFL, inp_flags=0) < 0)
123 goto fcntlerr;
124 if (readbuf(dpd[0], buf, msg.nbytes) != msg.nbytes)
125 goto readerr;
126 }
127 switch (msg.type) { /* take appropriate action */
128 case DR_BUNDLE: /* new bundle to calculate */
129 if (msg.nbytes != sizeof(PACKHEAD))
130 error(INTERNAL, "bad DR_BUNDLE from display process");
131 bundle_set(BS_ADD, (PACKHEAD *)buf, 1);
132 break;
133 case DR_NEWSET: /* new calculation set */
134 if (msg.nbytes % sizeof(PACKHEAD))
135 error(INTERNAL, "bad DR_NEWSET from display process");
136 if (msg.nbytes)
137 disp_result(DS_STARTIMM, 0, NULL);
138 bundle_set(BS_NEW, (PACKHEAD *)buf, msg.nbytes/sizeof(PACKHEAD));
139 if (msg.nbytes) {
140 disp_result(DS_ENDIMM, 0, NULL);
141 disp_flush();
142 }
143 break;
144 case DR_ADDSET: /* add to calculation set */
145 if (!msg.nbytes)
146 break;
147 if (msg.nbytes % sizeof(PACKHEAD))
148 error(INTERNAL, "bad DR_ADDSET from display process");
149 disp_result(DS_STARTIMM, 0, NULL);
150 bundle_set(BS_ADD, (PACKHEAD *)buf, msg.nbytes/sizeof(PACKHEAD));
151 disp_result(DS_ENDIMM, 0, NULL);
152 disp_flush();
153 break;
154 case DR_ADJSET: /* adjust calculation set members */
155 if (!msg.nbytes)
156 break;
157 if (msg.nbytes % sizeof(PACKHEAD))
158 error(INTERNAL, "bad DR_ADJSET from display process");
159 disp_result(DS_STARTIMM, 0, NULL);
160 bundle_set(BS_ADJ, (PACKHEAD *)buf, msg.nbytes/sizeof(PACKHEAD));
161 disp_result(DS_ENDIMM, 0, NULL);
162 disp_flush();
163 break;
164 case DR_DELSET: /* delete from calculation set */
165 if (!msg.nbytes)
166 break;
167 if (msg.nbytes % sizeof(PACKHEAD))
168 error(INTERNAL, "bad DR_DELSET from display process");
169 bundle_set(BS_DEL, (PACKHEAD *)buf, msg.nbytes/sizeof(PACKHEAD));
170 break;
171 case DR_VIEWPOINT: /* set target eye position */
172 if (msg.nbytes != sizeof(VIEWPOINT))
173 error(INTERNAL, "bad DR_VIEWPOINT from display process");
174 copystruct(&myeye, (VIEWPOINT *)buf);
175 break;
176 case DR_ATTEN: /* block for priority request */
177 if (msg.nbytes)
178 error(INTERNAL, "bad DR_ATTEN from display process");
179 /* send acknowledgement */
180 disp_result(DS_ACKNOW, 0, NULL);
181 return(disp_check(1)); /* block on following request */
182 case DR_KILL: /* kill computation process(es) */
183 if (msg.nbytes)
184 error(INTERNAL, "bad DR_KILL from display process");
185 if (nprocs > 0)
186 done_rtrace();
187 else
188 error(WARNING, "no rtrace process to kill");
189 break;
190 case DR_RESTART: /* restart computation process(es) */
191 if (msg.nbytes)
192 error(INTERNAL, "bad DR_RESTART from display process");
193 if (ncprocs > nprocs)
194 new_rtrace();
195 else if (nprocs > 0)
196 error(WARNING, "rtrace already runnning");
197 else
198 error(WARNING, "holodeck not open for writing");
199 break;
200 case DR_CLOBBER: /* clobber holodeck */
201 if (msg.nbytes)
202 error(INTERNAL, "bad DR_CLOBBER from display process");
203 if (!force || !ncprocs)
204 error(WARNING, "request to clobber holodeck denied");
205 else {
206 error(WARNING, "clobbering holodeck contents");
207 hdclobber(NULL);
208 }
209 break;
210 case DR_SHUTDOWN: /* shut down program */
211 if (msg.nbytes)
212 error(INTERNAL, "bad DR_SHUTDOWN from display process");
213 return(0); /* zero return signals shutdown */
214 case DR_NOOP: /* do nothing */
215 break;
216 default:
217 error(INTERNAL, "unrecognized request from display process");
218 }
219 if (msg.nbytes) /* clean up */
220 free(buf);
221 return(1); /* normal return value */
222 fcntlerr:
223 error(SYSTEM, "cannot change display blocking mode");
224 readerr:
225 error(SYSTEM, "error reading from display process");
226 }
227
228
229 int
230 disp_close() /* close our display process */
231 {
232 int rval;
233
234 if (dpout == NULL)
235 return(-1);
236 myeye.rng = 0;
237 disp_result(DS_SHUTDOWN, 0, NULL);
238 fclose(dpout);
239 dpout = NULL;
240 return(close_process(dpd));
241 }
242
243
244 disp_result(type, nbytes, p) /* queue result message to display process */
245 int type, nbytes;
246 char *p;
247 {
248 MSGHEAD msg;
249 /* consistency checks */
250 #ifdef DEBUG
251 if (nbytes < 0 || nbytes > 0 & p == NULL)
252 error(CONSISTENCY, "bad buffer handed to disp_result");
253 #endif
254 if (dpout == NULL)
255 return;
256 msg.type = type;
257 msg.nbytes = nbytes;
258 fwrite((char *)&msg, sizeof(MSGHEAD), 1, dpout);
259 if (nbytes > 0)
260 fwrite(p, 1, nbytes, dpout);
261 }
262
263
264 disp_flush() /* flush output to display */
265 {
266 if (fflush(dpout) < 0)
267 error(SYSTEM, "error writing to the display process");
268 }
