Changes and check-in for 3.5 release Includes new source files and modifications not recorded for many years See ray/doc/notes/ReleaseNotes for notes between 3.1 and 3.5 release
added -r option for read-only holodeck with computation
added "-o slave" option for slave server operation
fixed too-small buffer size for geometry arguments in start_rtrace()
added new "portals" variable for multiple section geometry
added FNONBLK define for Solaris systems
added paranoid checks for negative message sizes
added more careful calls to disp_check()
added motion outside section when OBSTRUCTIONS=True
change driver suffix
took out unnecessary call to disp_check(1)
now we don't quit display process when our calculation ends
added comments
improved error recovery when display process dies
eliminated queue flushing in sortbeamlist() added DS_ADJSET request for adjusting set quantities
added check for delete after processing add in disp_check()
added noop function to recover from vain DR_ATTEN
removed pipesiz variable
changed from unbuffered to buffered output to display process added name to display program arguments
changed disp_packet to take PACKHEAD* r.t. PACKET*
minor bug fixes
