--- ray/src/hd/rholo4.c 1997/10/31 10:23:29 3.1 +++ ray/src/hd/rholo4.c 2020/02/28 05:18:49 3.39 @@ -1,32 +1,296 @@ -/* Copyright (c) 1997 Silicon Graphics, Inc. */ - #ifndef lint -static char SCCSid[] = "$SunId$ SGI"; +static const char RCSid[] = "$Id: rholo4.c,v 3.39 2020/02/28 05:18:49 greg Exp $"; #endif - /* * Holodeck display process communication */ #include "rholo.h" #include "rhdisp.h" +#include "rtprocess.h" +#include +#include +#ifndef HDSUF +#define HDSUF ".hdi" +#endif +#ifndef SLAVENAME +#define SLAVENAME "slave" +#endif -open_display(dname) /* open a display process */ -char *dname; +#ifndef FNONBLK +#define FNONBLK O_NONBLOCK +#endif + +static int inp_flags; +static SUBPROC dpd = SP_INACTIVE; +static FILE *dpout; + +static void disp_flush(void); +static void disp_result(int type, int nbytes, char *p); + + +void +disp_open( /* open the named display driver */ + char *dname +) { - error(INTERNAL, "display process unimplemented"); + char buf[sizeof(HDGRID)+512], fd0[8], fd1[8], *cmd[5], *sfn; + int i, n, len; + + if (!strcmp(dname, SLAVENAME)) { + dpd.r = 0; /* read from stdin */ + dpout = stdout; /* write to stdout */ + dpd.flags = 0; /* we're the slave procees */ + } else { + /* get full display program name */ +#ifdef DEVPATH + sprintf(buf, "%s/%s%s", DEVPATH, dname, HDSUF); +#else + sprintf(buf, "dev/%s%s", dname, HDSUF); +#endif + /* dup stdin and stdout */ + if (readinp) + sprintf(fd0, "%d", dup(0)); + else + strcpy(fd0, "-1"); + sprintf(fd1, "%d", dup(1)); + /* start the display process */ + cmd[0] = buf; + cmd[1] = froot; cmd[2] = fd1; cmd[3] = fd0; + cmd[4] = NULL; + i = open_process(&dpd, cmd); + if (i <= 0) + error(USER, "cannot start display process"); + if ((dpout = fdopen(dpd.w, "w")) == NULL) + error(SYSTEM, "problem opening display pipe"); + /* close dup'ed stdin and stdout */ + if (readinp) + close(atoi(fd0)); + close(atoi(fd1)); + } + dpd.w = -1; /* causes ignored error in close_process() */ + inp_flags = 0; + /* check if outside */ + if (vdef(OBSTRUCTIONS) && vbool(OBSTRUCTIONS)) + disp_result(DS_OUTSECT, 0, NULL); + /* send eye separation if specified */ + if (vdef(EYESEP)) { + sprintf(buf, "%.9e", vflt(EYESEP)); + disp_result(DS_EYESEP, strlen(buf)+1, buf); + } + /* write out hologram grids & octrees */ + for (i = 0; hdlist[i] != NULL; i++) { + memcpy(buf, (void *)hdlist[i], sizeof(HDGRID)); + len = sizeof(HDGRID); + n = vdef(GEOMETRY); + sfn = inr), (char *)p); } -disp_packet(p) /* display a packet */ -register PACKET *p; +int +disp_check( /* check display process */ + int block +) { + MSGHEAD msg; + int n; + char *buf = NULL; + + if (dpout == NULL) + return(-1); + /* flush display output */ + disp_flush(); + /* check read blocking */ + if (block != (inp_flags == 0)) { + inp_flags = block ? 0 : FNONBLK; + if (fcntl(dpd.r, F_SETFL, inp_flags) < 0) + goto fcntlerr; + } + /* read message header */ + n = read(dpd.r, (char *)&msg, sizeof(MSGHEAD)); + if (n != sizeof(MSGHEAD)) { + if (n >= 0) { + dpout = NULL; + error(USER, "display process died"); + } + if ((errno != EAGAIN) & (errno != EINTR)) + goto readerr; + return(2); /* acceptable failure */ + } + if (msg.nbytes) { /* get the message body */ + if (msg.nbytes < 0) + error(INTERNAL, "anti-message from display process"); + buf = (char *)malloc(msg.nbytes); + if (buf == NULL) + error(SYSTEM, "out of memory in disp_check"); + if (inp_flags != 0 && fcntl(dpd.r, F_SETFL, inp_flags=0) < 0) + goto fcntlerr; + if (readbuf(dpd.r, buf, msg.nbytes) != msg.nbytes) + goto readerr; + } + switch (msg.type) { /* take appropriate action */ + case DR_BUNDLE: /* new bundle to calculate */ + if (msg.nbytes != sizeof(PACKHEAD)) + error(INTERNAL, "bad DR_BUNDLE from display process"); + bundle_set(BS_ADD, (PACKHEAD *)buf, 1); + break; + case DR_NEWSET: /* new calculation set */ + if (msg.nbytes % sizeof(PACKHEAD)) + error(INTERNAL, "bad DR_NEWSET from display process"); + if (msg.nbytes) + disp_result(DS_STARTIMM, 0, NULL); + bundle_set(BS_NEW, (PACKHEAD *)buf, msg.nbytes/sizeof(PACKHEAD)); + if (msg.nbytes) { + disp_result(DS_ENDIMM, 0, NULL); + disp_flush(); + } + break; + case DR_ADDSET: /* add to calculation set */ + if (!msg.nbytes) + break; + if (msg.nbytes % sizeof(PACKHEAD)) + error(INTERNAL, "bad DR_ADDSET from display process"); + disp_result(DS_STARTIMM, 0, NULL); + bundle_set(BS_ADD, (PACKHEAD *)buf, msg.nbytes/sizeof(PACKHEAD)); + disp_result(DS_ENDIMM, 0, NULL); + disp_flush(); + break; + case DR_ADJSET: /* adjust calculation set members */ + if (!msg.nbytes) + break; + if (msg.nbytes % sizeof(PACKHEAD)) + error(INTERNAL, "bad DR_ADJSET from display process"); + disp_result(DS_STARTIMM, 0, NULL); + bundle_set(BS_ADJ, (PACKHEAD *)buf, msg.nbytes/sizeof(PACKHEAD)); + disp_result(DS_ENDIMM, 0, NULL); + disp_flush(); + break; + case DR_DELSET: /* delete from calculation set */ + if (!msg.nbytes) + break; + if (msg.nbytes % sizeof(PACKHEAD)) + error(INTERNAL, "bad DR_DELSET from display process"); + bundle_set(BS_DEL, (PACKHEAD *)buf, msg.nbytes/sizeof(PACKHEAD)); + break; + case DR_VIEWPOINT: /* set target eye position */ + if (msg.nbytes != sizeof(VIEWPOINT)) + error(INTERNAL, "bad DR_VIEWPOINT from display process"); + myeye = *((VIEWPOINT *)buf); + break; + case DR_ATTEN: /* block for priority request */ + if (msg.nbytes) + error(INTERNAL, "bad DR_ATTEN from display process"); + /* send acknowledgement */ + disp_result(DS_ACKNOW, 0, NULL); + return(disp_check(1)); /* block on following request */ + case DR_KILL: /* kill computation process(es) */ + if (msg.nbytes) + error(INTERNAL, "bad DR_KILL from display process"); + if (nprocs > 0) + done_rtrace(); + else + error(WARNING, "no rtrace process to kill"); + break; + case DR_RESTART: /* restart computation process(es) */ + if (msg.nbytes) + error(INTERNAL, "bad DR_RESTART from display process"); + if (ncprocs > nprocs) + new_rtrace(); + else if (nprocs > 0) + error(WARNING, "rtrace already runnning"); + else + error(WARNING, "holodeck not open for writing"); + break; + case DR_CLOBBER: /* clobber holodeck */ + if (msg.nbytes) + error(INTERNAL, "bad DR_CLOBBER from display process"); + if ((force <= 0) | (ncprocs <= 0)) + error(WARNING, "request to clobber holodeck denied"); + else { + error(WARNING, "clobbering holodeck contents"); + hdclobber(NULL); + } + break; + case DR_SHUTDOWN: /* shut down program */ + if (msg.nbytes) + error(INTERNAL, "bad DR_SHUTDOWN from display process"); + return(0); /* zero return signals shutdown */ + case DR_NOOP: /* do nothing */ + break; + default: + error(INTERNAL, "unrecognized request from display process"); + } + if (msg.nbytes) /* clean up */ + free(buf); + return(1); /* normal return value */ +fcntlerr: + error(SYSTEM, "cannot change display blocking mode"); +readerr: + error(SYSTEM, "error reading from display process"); + return -1; /* pro forma return */ +} + + +int +disp_close(void) /* close our display process */ +{ + if (dpout == NULL) + return(-1); + myeye.rng = 0; + disp_result(DS_SHUTDOWN, 0, NULL); + fclose(dpout); + dpout = NULL; + return(dpd.flags&PF_RUNNING ? close_process(&dpd) : 0); + +} + + +static void +disp_result( /* queue result message to display process */ + int type, + int nbytes, + char *p +) +{ + MSGHEAD msg; + /* consistency checks */ +#ifdef DEBUG + if (nbytes < 0 || nbytes > 0 & p == NULL) + error(CONSISTENCY, "bad buffer handed to disp_result"); +#endif + if (dpout == NULL) + return; + msg.type = type; + msg.nbytes = nbytes; + putbinary(&msg, sizeof(MSGHEAD), 1, dpout); + if (nbytes > 0) + putbinary(p, 1, nbytes, dpout); +} + + +static void +disp_flush(void) /* flush output to display */ +{ + if (fflush(dpout) < 0) + error(SYSTEM, "error writing to the display process"); }
