--- ray/src/hd/rholo4.c 2003/06/27 06:53:22 3.31 +++ ray/src/hd/rholo4.c 2018/10/05 19:19:16 3.38 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: rholo4.c,v 3.31 2003/06/27 06:53:22 greg Exp $"; +static const char RCSid[] = "$Id: rholo4.c,v 3.38 2018/10/05 19:19:16 greg Exp $"; #endif /* * Holodeck display process communication @@ -8,8 +8,8 @@ static const char RCSid[] = "$Id: rholo4.c,v 3.31 2003 #include "rholo.h" #include "rhdisp.h" #include "rtprocess.h" - #include +#include #ifndef HDSUF #define HDSUF ".hdi" @@ -26,9 +26,14 @@ static int inp_flags; static SUBPROC dpd; static FILE *dpout; +static void disp_flush(void); +static void disp_result(int type, int nbytes, char *p); -disp_open(dname) /* open the named display driver */ -char *dname; + +void +disp_open( /* open the named display driver */ + char *dname +) { char buf[sizeof(HDGRID)+512], fd0[8], fd1[8], *cmd[5], *sfn; int i, n, len; @@ -76,7 +81,7 @@ char *dname; } /* write out hologram grids & octrees */ for (i = 0; hdlist[i] != NULL; i++) { - bcopy((void *)hdlist[i], buf, sizeof(HDGRID)); + memcpy(buf, (void *)hdlist[i], sizeof(HDGRID)); len = sizeof(HDGRID); n = vdef(GEOMETRY); sfn = inr), (char *)p); } -disp_check(block) /* check display process */ -int block; +int +disp_check( /* check display process */ + int block +) { MSGHEAD msg; int n; @@ -124,7 +133,7 @@ int block; dpout = NULL; error(USER, "display process died"); } - if (errno != EAGAIN & errno != EINTR) + if ((errno != EAGAIN) & (errno != EINTR)) goto readerr; return(2); /* acceptable failure */ } @@ -186,7 +195,7 @@ int block; case DR_VIEWPOINT: /* set target eye position */ if (msg.nbytes != sizeof(VIEWPOINT)) error(INTERNAL, "bad DR_VIEWPOINT from display process"); - copystruct(&myeye, (VIEWPOINT *)buf); + myeye = *((VIEWPOINT *)buf); break; case DR_ATTEN: /* block for priority request */ if (msg.nbytes) @@ -215,7 +224,7 @@ int block; case DR_CLOBBER: /* clobber holodeck */ if (msg.nbytes) error(INTERNAL, "bad DR_CLOBBER from display process"); - if (force <= 0 | ncprocs <= 0) + if ((force <= 0) | (ncprocs <= 0)) error(WARNING, "request to clobber holodeck denied"); else { error(WARNING, "clobbering holodeck contents"); @@ -238,14 +247,13 @@ fcntlerr: error(SYSTEM, "cannot change display blocking mode"); readerr: error(SYSTEM, "error reading from display process"); + return -1; /* pro forma return */ } int -disp_close() /* close our display process */ +disp_close(void) /* close our display process */ { - int rval; - if (dpout == NULL) return(-1); myeye.rng = 0; @@ -257,9 +265,12 @@ disp_close() /* close our display process */ } -disp_result(type, nbytes, p) /* queue result message to display process */ -int type, nbytes; -char *p; +static void +disp_result( /* queue result message to display process */ + int type, + int nbytes, + char *p +) { MSGHEAD msg; /* consistency checks */ @@ -271,13 +282,14 @@ char *p; return; msg.type = type; msg.nbytes = nbytes; - fwrite((char *)&msg, sizeof(MSGHEAD), 1, dpout); + putbinary(&msg, sizeof(MSGHEAD), 1, dpout); if (nbytes > 0) - fwrite(p, 1, nbytes, dpout); + putbinary(p, 1, nbytes, dpout); } -disp_flush() /* flush output to display */ +static void +disp_flush(void) /* flush output to display */ { if (fflush(dpout) < 0) error(SYSTEM, "error writing to the display process");
