1 |
#ifndef lint |
2 |
static const char RCSid[] = "$Id: rholo4.c,v 3.36 2004/01/01 11:21:55 schorsch Exp $"; |
3 |
#endif |
4 |
5 |
* Holodeck display process communication |
6 |
7 |
8 |
#include "rholo.h" |
9 |
#include "rhdisp.h" |
10 |
#include "rtprocess.h" |
11 |
#include <sys/uio.h> |
12 |
#include <string.h> |
13 |
14 |
#ifndef HDSUF |
15 |
#define HDSUF ".hdi" |
16 |
#endif |
17 |
#ifndef SLAVENAME |
18 |
#define SLAVENAME "slave" |
19 |
#endif |
20 |
21 |
#ifndef FNONBLK |
22 |
#define FNONBLK O_NONBLOCK |
23 |
#endif |
24 |
25 |
static int inp_flags; |
26 |
static SUBPROC dpd; |
27 |
static FILE *dpout; |
28 |
29 |
static void disp_flush(void); |
30 |
static void disp_result(int type, int nbytes, char *p); |
31 |
32 |
33 |
extern void |
34 |
disp_open( /* open the named display driver */ |
35 |
char *dname |
36 |
37 |
38 |
char buf[sizeof(HDGRID)+512], fd0[8], fd1[8], *cmd[5], *sfn; |
39 |
int i, n, len; |
40 |
41 |
if (!strcmp(dname, SLAVENAME)) { |
42 |
dpd.r = 0; /* read from stdin */ |
43 |
dpout = stdout; /* write to stdout */ |
44 |
dpd.running = 0; /* we're the slave procees */ |
45 |
} else { |
46 |
/* get full display program name */ |
47 |
#ifdef DEVPATH |
48 |
sprintf(buf, "%s/%s%s", DEVPATH, dname, HDSUF); |
49 |
#else |
50 |
sprintf(buf, "dev/%s%s", dname, HDSUF); |
51 |
#endif |
52 |
/* dup stdin and stdout */ |
53 |
if (readinp) |
54 |
sprintf(fd0, "%d", dup(0)); |
55 |
else |
56 |
strcpy(fd0, "-1"); |
57 |
sprintf(fd1, "%d", dup(1)); |
58 |
/* start the display process */ |
59 |
cmd[0] = buf; |
60 |
cmd[1] = froot; cmd[2] = fd1; cmd[3] = fd0; |
61 |
cmd[4] = NULL; |
62 |
i = open_process(&dpd, cmd); |
63 |
if (i <= 0) |
64 |
error(USER, "cannot start display process"); |
65 |
if ((dpout = fdopen(dpd.w, "w")) == NULL) |
66 |
error(SYSTEM, "problem opening display pipe"); |
67 |
/* close dup'ed stdin and stdout */ |
68 |
if (readinp) |
69 |
close(atoi(fd0)); |
70 |
close(atoi(fd1)); |
71 |
72 |
dpd.w = -1; /* causes ignored error in close_process() */ |
73 |
inp_flags = 0; |
74 |
/* check if outside */ |
75 |
if (vdef(OBSTRUCTIONS) && vbool(OBSTRUCTIONS)) |
76 |
disp_result(DS_OUTSECT, 0, NULL); |
77 |
/* send eye separation if specified */ |
78 |
if (vdef(EYESEP)) { |
79 |
sprintf(buf, "%.9e", vflt(EYESEP)); |
80 |
disp_result(DS_EYESEP, strlen(buf)+1, buf); |
81 |
82 |
/* write out hologram grids & octrees */ |
83 |
for (i = 0; hdlist[i] != NULL; i++) { |
84 |
memcpy(buf, (void *)hdlist[i], sizeof(HDGRID)); |
85 |
len = sizeof(HDGRID); |
86 |
n = vdef(GEOMETRY); |
87 |
sfn = i<n ? nvalue(GEOMETRY,i) : |
88 |
n ? nvalue(GEOMETRY,n-1) : vval(OCTREE); |
89 |
strcpy(buf+len, sfn); |
90 |
len += strlen(sfn) + 1; |
91 |
n = vdef(PORTS); |
92 |
sfn = i<n ? nvalue(PORTS,i) : n ? nvalue(PORTS,n-1) : ""; |
93 |
94 |
95 |
disp_result(DS_ADDHOLO, len, buf); |
96 |
97 |
disp_flush(); |
98 |
99 |
100 |
101 |
extern void |
102 |
disp_packet( /* display a packet */ |
103 |
register PACKHEAD *p |
104 |
105 |
106 |
disp_result(DS_BUNDLE, packsiz(p->nr), (char *)p); |
107 |
108 |
109 |
110 |
extern int |
111 |
disp_check( /* check display process */ |
112 |
int block |
113 |
114 |
115 |
MSGHEAD msg; |
116 |
int n; |
117 |
char *buf = NULL; |
118 |
119 |
if (dpout == NULL) |
120 |
return(-1); |
121 |
/* flush display output */ |
122 |
disp_flush(); |
123 |
/* check read blocking */ |
124 |
if (block != (inp_flags == 0)) { |
125 |
inp_flags = block ? 0 : FNONBLK; |
126 |
if (fcntl(dpd.r, F_SETFL, inp_flags) < 0) |
127 |
goto fcntlerr; |
128 |
129 |
/* read message header */ |
130 |
n = read(dpd.r, (char *)&msg, sizeof(MSGHEAD)); |
131 |
if (n != sizeof(MSGHEAD)) { |
132 |
if (n >= 0) { |
133 |
dpout = NULL; |
134 |
error(USER, "display process died"); |
135 |
136 |
if ((errno != EAGAIN) & (errno != EINTR)) |
137 |
goto readerr; |
138 |
return(2); /* acceptable failure */ |
139 |
140 |
if (msg.nbytes) { /* get the message body */ |
141 |
if (msg.nbytes < 0) |
142 |
error(INTERNAL, "anti-message from display process"); |
143 |
buf = (char *)malloc(msg.nbytes); |
144 |
if (buf == NULL) |
145 |
error(SYSTEM, "out of memory in disp_check"); |
146 |
if (inp_flags != 0 && fcntl(dpd.r, F_SETFL, inp_flags=0) < 0) |
147 |
goto fcntlerr; |
148 |
if (readbuf(dpd.r, buf, msg.nbytes) != msg.nbytes) |
149 |
goto readerr; |
150 |
151 |
switch (msg.type) { /* take appropriate action */ |
152 |
case DR_BUNDLE: /* new bundle to calculate */ |
153 |
if (msg.nbytes != sizeof(PACKHEAD)) |
154 |
error(INTERNAL, "bad DR_BUNDLE from display process"); |
155 |
bundle_set(BS_ADD, (PACKHEAD *)buf, 1); |
156 |
break; |
157 |
case DR_NEWSET: /* new calculation set */ |
158 |
if (msg.nbytes % sizeof(PACKHEAD)) |
159 |
error(INTERNAL, "bad DR_NEWSET from display process"); |
160 |
if (msg.nbytes) |
161 |
disp_result(DS_STARTIMM, 0, NULL); |
162 |
bundle_set(BS_NEW, (PACKHEAD *)buf, msg.nbytes/sizeof(PACKHEAD)); |
163 |
if (msg.nbytes) { |
164 |
disp_result(DS_ENDIMM, 0, NULL); |
165 |
disp_flush(); |
166 |
167 |
break; |
168 |
case DR_ADDSET: /* add to calculation set */ |
169 |
if (!msg.nbytes) |
170 |
break; |
171 |
172 |
error(INTERNAL, "bad DR_ADDSET from display process"); |
173 |
174 |
bundle_set(BS_ADD, (PACKHEAD *)buf, msg.nbytes/sizeof(PACKHEAD)); |
175 |
176 |
disp_flush(); |
177 |
break; |
178 |
case DR_ADJSET: /* adjust calculation set members */ |
179 |
if (!msg.nbytes) |
180 |
break; |
181 |
182 |
error(INTERNAL, "bad DR_ADJSET from display process"); |
183 |
184 |
bundle_set(BS_ADJ, (PACKHEAD *)buf, msg.nbytes/sizeof(PACKHEAD)); |
185 |
186 |
disp_flush(); |
187 |
break; |
188 |
case DR_DELSET: /* delete from calculation set */ |
189 |
if (!msg.nbytes) |
190 |
break; |
191 |
192 |
error(INTERNAL, "bad DR_DELSET from display process"); |
193 |
bundle_set(BS_DEL, (PACKHEAD *)buf, msg.nbytes/sizeof(PACKHEAD)); |
194 |
break; |
195 |
case DR_VIEWPOINT: /* set target eye position */ |
196 |
if (msg.nbytes != sizeof(VIEWPOINT)) |
197 |
error(INTERNAL, "bad DR_VIEWPOINT from display process"); |
198 |
myeye = *((VIEWPOINT *)buf); |
199 |
break; |
200 |
case DR_ATTEN: /* block for priority request */ |
201 |
if (msg.nbytes) |
202 |
error(INTERNAL, "bad DR_ATTEN from display process"); |
203 |
/* send acknowledgement */ |
204 |
disp_result(DS_ACKNOW, 0, NULL); |
205 |
return(disp_check(1)); /* block on following request */ |
206 |
case DR_KILL: /* kill computation process(es) */ |
207 |
if (msg.nbytes) |
208 |
error(INTERNAL, "bad DR_KILL from display process"); |
209 |
if (nprocs > 0) |
210 |
done_rtrace(); |
211 |
else |
212 |
error(WARNING, "no rtrace process to kill"); |
213 |
break; |
214 |
case DR_RESTART: /* restart computation process(es) */ |
215 |
if (msg.nbytes) |
216 |
error(INTERNAL, "bad DR_RESTART from display process"); |
217 |
if (ncprocs > nprocs) |
218 |
new_rtrace(); |
219 |
else if (nprocs > 0) |
220 |
error(WARNING, "rtrace already runnning"); |
221 |
else |
222 |
error(WARNING, "holodeck not open for writing"); |
223 |
break; |
224 |
case DR_CLOBBER: /* clobber holodeck */ |
225 |
if (msg.nbytes) |
226 |
error(INTERNAL, "bad DR_CLOBBER from display process"); |
227 |
if ((force <= 0) | (ncprocs <= 0)) |
228 |
error(WARNING, "request to clobber holodeck denied"); |
229 |
else { |
230 |
error(WARNING, "clobbering holodeck contents"); |
231 |
hdclobber(NULL); |
232 |
233 |
break; |
234 |
case DR_SHUTDOWN: /* shut down program */ |
235 |
if (msg.nbytes) |
236 |
error(INTERNAL, "bad DR_SHUTDOWN from display process"); |
237 |
return(0); /* zero return signals shutdown */ |
238 |
case DR_NOOP: /* do nothing */ |
239 |
break; |
240 |
default: |
241 |
error(INTERNAL, "unrecognized request from display process"); |
242 |
243 |
if (msg.nbytes) /* clean up */ |
244 |
free(buf); |
245 |
return(1); /* normal return value */ |
246 |
fcntlerr: |
247 |
error(SYSTEM, "cannot change display blocking mode"); |
248 |
readerr: |
249 |
error(SYSTEM, "error reading from display process"); |
250 |
return -1; /* pro forma return */ |
251 |
252 |
253 |
254 |
extern int |
255 |
disp_close(void) /* close our display process */ |
256 |
257 |
258 |
return(-1); |
259 |
myeye.rng = 0; |
260 |
disp_result(DS_SHUTDOWN, 0, NULL); |
261 |
fclose(dpout); |
262 |
dpout = NULL; |
263 |
return(dpd.running ? close_process(&dpd) : 0); |
264 |
265 |
266 |
267 |
268 |
static void |
269 |
disp_result( /* queue result message to display process */ |
270 |
int type, |
271 |
int nbytes, |
272 |
char *p |
273 |
274 |
275 |
MSGHEAD msg; |
276 |
/* consistency checks */ |
277 |
#ifdef DEBUG |
278 |
if (nbytes < 0 || nbytes > 0 & p == NULL) |
279 |
error(CONSISTENCY, "bad buffer handed to disp_result"); |
280 |
#endif |
281 |
282 |
return; |
283 |
msg.type = type; |
284 |
msg.nbytes = nbytes; |
285 |
putbinary(&msg, sizeof(MSGHEAD), 1, dpout); |
286 |
if (nbytes > 0) |
287 |
putbinary(p, 1, nbytes, dpout); |
288 |
289 |
290 |
291 |
static void |
292 |
disp_flush(void) /* flush output to display */ |
293 |
294 |
if (fflush(dpout) < 0) |
295 |
error(SYSTEM, "error writing to the display process"); |
296 |
