--- ray/src/hd/rholo3.c 1997/11/21 17:47:56 3.9 +++ ray/src/hd/rholo3.c 1997/12/01 16:35:02 3.12 @@ -10,11 +10,9 @@ static char SCCSid[] = "$SunId$ SGI"; #include "rholo.h" - #define abs(x) ((x) > 0 ? (x) : -(x)) #define sgn(x) ((x) > 0 ? 1 : (x) < 0 ? -1 : 0) - static PACKHEAD *complist=NULL; /* list of beams to compute */ static int complen=0; /* length of complist */ static int listpos=0; /* current list position for next_packet */ @@ -25,8 +23,7 @@ int beamcmp(b0, b1) /* comparison for descending compute order */ register PACKHEAD *b0, *b1; { - return( b1->nr*(bnrays(hdlist[b0->hd],b0->bi)+1) - - b0->nr*(bnrays(hdlist[b1->hd],b1->bi)+1) ); + return( b1->nr*(b0->nc+1) - b0->nr*(b1->nc+1) ); } @@ -53,31 +50,41 @@ int nents; if (complist == NULL) goto memerr; bcopy((char *)clist, (char *)complist, nents*sizeof(PACKHEAD)); - complen = nents; - listpos = 0; - lastin = -1; /* flag for initial sort */ + complen = nents; /* finish initialization below */ break; case BS_ADD: /* add to computation set */ + case BS_ADJ: /* adjust set quantities */ if (nents <= 0) return; /* merge any common members */ - for (i = 0; i < complen; i++) - for (n = 0; n < nents; n++) + for (n = 0; n < nents; n++) { + for (i = 0; i < complen; i++) if (clist[n].bi == complist[i].bi && clist[n].hd == complist[i].hd) { - complist[i].nr += clist[n].nr; + int oldnr = complist[i].nr; + if (op == BS_ADD) + complist[i].nr += clist[n].nr; + else /* op == BS_ADJ */ + complist[i].nr = clist[n].nr; clist[n].nr = 0; - lastin = -1; /* flag full sort */ + clist[n].nc = complist[i].nc; + if (complist[i].nr != oldnr) + lastin = -1; /* flag sort */ break; } + if (i >= complen) + clist[n].nc = bnrays(hdlist[clist[n].hd], + clist[n].bi); + } /* sort updated list */ sortcomplist(); /* sort new entries */ qsort((char *)clist, nents, sizeof(PACKHEAD), beamcmp); /* what can't we satisfy? */ - for (n = 0; n < nents && clist[n].nr > - bnrays(hdlist[clist[n].hd],clist[n].bi); n++) + for (n = 0; n < nents && clist[n].nr > clist[n].nc; n++) ; + if (op == BS_ADJ) + nents = n; if (n) { /* allocate space for merged list */ PACKHEAD *newlist; newlist = (PACKHEAD *)malloc( @@ -110,15 +117,13 @@ int nents; lastin = -1; /* flag full sort */ break; } - if (lastin < 0) /* sort updated list */ - sortcomplist(); return; /* no display */ default: error(CONSISTENCY, "bundle_set called with unknown operation"); } if (outdev == NULL) return; - n = 8*RPACKSIZ; /* allocate packet holder */ + n = 32*RPACKSIZ; /* allocate packet holder */ p = (PACKHEAD *)malloc(packsiz(n)); if (p == NULL) goto memerr; @@ -132,12 +137,21 @@ int nents; goto memerr; } bcopy((char *)hdbray(b), (char *)packra(p), - (p->nr=b->nrm)*sizeof(RAYVAL)); + b->nrm*sizeof(RAYVAL)); p->hd = clist[i].hd; p->bi = clist[i].bi; + p->nr = p->nc = b->nrm; disp_packet(p); } free((char *)p); /* clean up */ + if (op == BS_NEW) { + done_packets(flush_queue()); /* empty queue, so we can... */ + for (i = 0; i < complen; i++) /* ...get number computed */ + complist[i].nc = bnrays(hdlist[complist[i].hd], + complist[i].bi); + listpos = 0; + lastin = -1; /* flag for initial sort */ + } return; memerr: error(SYSTEM, "out of memory in bundle_set"); @@ -237,12 +251,12 @@ init_global() /* initialize global ray computation * wtotal += complist[k++].nr; } /* adjust weights */ - if (vdef(DISKSPACE)) { + if (vdef(DISKSPACE)) frac = 1024.*1024.*vflt(DISKSPACE) / (wtotal*sizeof(RAYVAL)); - if (frac < 0.95 | frac > 1.05) - while (k--) - complist[k].nr = frac * complist[k].nr; - } + else + frac = 1024.*1024.*16384. / (wtotal*sizeof(RAYVAL)); + while (k--) + complist[k].nr = frac * complist[k].nr; listpos = 0; lastin = -1; /* flag initial sort */ } @@ -275,8 +289,6 @@ sortcomplist() /* fix our list order */ PACKHEAD *list2; register int i; - /* empty queue */ - done_packets(flush_queue()); if (complen <= 0) /* check to see if there is even a list */ return; if (lastin < 0 || listpos*4 >= complen*3) @@ -291,15 +303,8 @@ sortcomplist() /* fix our list order */ complist+listpos, complen-listpos); free((char *)list2); } - /* check for all finished */ - if (complist[0].nr <= bnrays(hdlist[complist[0].hd],complist[0].bi)) { - free((char *)complist); - complist = NULL; - complen = 0; - } /* drop satisfied requests */ - for (i = complen; i-- && complist[i].nr <= - bnrays(hdlist[complist[i].hd],complist[i].bi); ) + for (i = complen; i-- && complist[i].nr <= complist[i].nc; ) ; if (i < 0) { free((char *)complist); @@ -323,35 +328,29 @@ sortcomplist() /* fix our list order */ * a given bundle to move way down in the computation order. We keep * track of where the computed bundle with the highest priority would end * up, and if we get further in our compute list than this, we resort the - * list and start again from the beginning. We have to flush the queue - * each time we sort, to ensure that we are not disturbing the order. - * If our major assumption is violated, and we have a very steep - * descent in our weights, then we will end up resorting much more often - * than necessary, resulting in frequent flushing of the queue. Since - * a merge sort is used, the sorting costs will be minimal. + * list and start again from the beginning. Since + * a merge sort is used, the sorting costs are minimal. */ next_packet(p) /* prepare packet for computation */ register PACKET *p; { - int ncomp; register int i; - if (complen <= 0) - return(0); if (listpos > lastin) /* time to sort the list */ sortcomplist(); + if (complen <= 0) + return(0); p->hd = complist[listpos].hd; p->bi = complist[listpos].bi; - ncomp = bnrays(hdlist[p->hd],p->bi); - p->nr = complist[listpos].nr - ncomp; + p->nc = complist[listpos].nc; + p->nr = complist[listpos].nr - p->nc; if (p->nr <= 0) return(0); if (p->nr > RPACKSIZ) p->nr = RPACKSIZ; - ncomp += p->nr; /* find where this one would go */ - while (lastin > listpos && complist[listpos].nr * - (bnrays(hdlist[complist[lastin].hd],complist[lastin].bi)+1) - > complist[lastin].nr * (ncomp+1)) + complist[listpos].nc += p->nr; /* find where this one would go */ + while (lastin > listpos && + beamcmp(complist+lastin, complist+listpos) > 0) lastin--; listpos++; return(1);
