--- ray/src/hd/rholo3.c 1998/01/05 16:46:34 3.18 +++ ray/src/hd/rholo3.c 1998/08/12 17:56:06 3.23 @@ -20,7 +20,7 @@ static int lastin= -1; /* last ordered position in lis int -beamcmp(b0, b1) /* comparison for descending compute order */ +beamcmp(b0, b1) /* comparison for compute order */ register PACKHEAD *b0, *b1; { return( b1->nr*(b0->nc+1) - b0->nr*(b1->nc+1) ); @@ -28,10 +28,20 @@ register PACKHEAD *b0, *b1; int -dispbeam(b, hp, bi) /* display a holodeck beam */ +beamidcmp(b0, b1) /* comparison for beam searching */ +register PACKHEAD *b0, *b1; +{ + register int c = b0->hd - b1->hd; + + if (c) return(c); + return(b0->bi - b1->bi); +} + + +int +dispbeam(b, hb) /* display a holodeck beam */ register BEAM *b; -HOLO *hp; -int bi; +register HDBEAMI *hb; { static int n = 0; static PACKHEAD *p = NULL; @@ -48,70 +58,86 @@ int bi; /* assign packet fields */ bcopy((char *)hdbray(b), (char *)packra(p), b->nrm*sizeof(RAYVAL)); p->nr = p->nc = b->nrm; - for (p->hd = 0; hdlist[p->hd] != hp; p->hd++) + for (p->hd = 0; hdlist[p->hd] != hb->h; p->hd++) if (hdlist[p->hd] == NULL) error(CONSISTENCY, "unregistered holodeck in dispbeam"); - p->bi = bi; + p->bi = hb->b; disp_packet(p); /* display it */ } bundle_set(op, clist, nents) /* bundle set operation */ int op; -register PACKHEAD *clist; +PACKHEAD *clist; int nents; { - register int i, n; - + int oldnr, n; + HDBEAMI *hbarr; + register PACKHEAD *csm; + register int i; + /* search for common members */ + qsort((char *)clist, nents, sizeof(PACKHEAD), beamidcmp); + for (csm = clist+nents; csm-- > clist; ) + csm->nc = -1; + for (i = 0; i < complen; i++) { + csm = (PACKHEAD *)bsearch((char *)(complist+i), (char *)clist, + nents, sizeof(PACKHEAD), beamidcmp); + if (csm == NULL) + continue; + oldnr = complist[i].nr; + csm->nc = complist[i].nc; + switch (op) { + case BS_ADD: /* add to count */ + complist[i].nr += csm->nr; + csm->nr = 0; + break; + case BS_ADJ: /* reset count */ + complist[i].nr = csm->nr; + csm->nr = 0; + break; + case BS_DEL: /* delete count */ + if (csm->nr == 0 || csm->nr >= complist[i].nr) + complist[i].nr = 0; + else + complist[i].nr -= csm->nr; + break; + } + if (complist[i].nr != oldnr) + lastin = -1; /* flag sort */ + } + /* computed rays for each uncommon beams */ + for (csm = clist+nents; csm-- > clist; ) + if (csm->nc < 0) + csm->nc = bnrays(hdlist[csm->hd], csm->bi); + /* complete list operations */ switch (op) { case BS_NEW: /* new computation set */ - if (complen) + listpos = 0; lastin = -1; + if (complen) /* free old list */ free((char *)complist); - if (nents <= 0) { - complist = NULL; - listpos = complen = 0; - lastin = -1; + complist = NULL; + if (!(complen = nents)) return; - } complist = (PACKHEAD *)malloc(nents*sizeof(PACKHEAD)); if (complist == NULL) goto memerr; bcopy((char *)clist, (char *)complist, nents*sizeof(PACKHEAD)); - complen = nents; /* finish initialization below */ break; case BS_ADD: /* add to computation set */ case BS_ADJ: /* adjust set quantities */ if (nents <= 0) return; - /* merge any common members */ - for (n = 0; n < nents; n++) { - for (i = 0; i < complen; i++) - if (clist[n].bi == complist[i].bi && - clist[n].hd == complist[i].hd) { - int oldnr = complist[i].nr; - if (op == BS_ADD) - complist[i].nr += clist[n].nr; - else /* op == BS_ADJ */ - complist[i].nr = clist[n].nr; - clist[n].nr = 0; - clist[n].nc = complist[i].nc; - if (complist[i].nr != oldnr) - lastin = -1; /* flag sort */ - break; - } - if (i >= complen) - clist[n].nc = bnrays(hdlist[clist[n].hd], - clist[n].bi); - } - /* sort updated list */ - sortcomplist(); - /* sort new entries */ + sortcomplist(); /* sort updated list & new entries */ qsort((char *)clist, nents, sizeof(PACKHEAD), beamcmp); /* what can't we satisfy? */ - for (n = 0; n < nents && clist[n].nr > clist[n].nc; n++) + for (i = nents, csm = clist; i-- && csm->nr > csm->nc; csm++) ; - if (op == BS_ADJ) - nents = n; + n = csm - clist; + if (op == BS_ADJ) { /* don't regenerate adjusted beams */ + for (i = n; i < nents && clist[i].nr > 0; i++) + ; + nents = i; + } if (n) { /* allocate space for merged list */ PACKHEAD *newlist; newlist = (PACKHEAD *)malloc( @@ -129,44 +155,20 @@ int nents; lastin = complen-1; /* list is now sorted */ break; case BS_DEL: /* delete from computation set */ - if (nents <= 0) - return; - /* find each member */ - for (i = 0; i < complen; i++) - for (n = 0; n < nents; n++) - if (clist[n].bi == complist[i].bi && - clist[n].hd == complist[i].hd) { - if (clist[n].nr == 0 || - clist[n].nr >= complist[i].nr) - complist[i].nr = 0; - else - complist[i].nr -= clist[n].nr; - lastin = -1; /* flag full sort */ - break; - } - return; /* no display */ + return; /* already done */ default: error(CONSISTENCY, "bundle_set called with unknown operation"); } - if (outdev != NULL) { /* load and display beams we have */ - register HDBEAMI *hb; - - hb = (HDBEAMI *)malloc(nents*sizeof(HDBEAMI)); - for (i = 0; i < nents; i++) { - hb[i].h = hdlist[clist[i].hd]; - hb[i].b = clist[i].bi; - } - hdloadbeams(hb, nents, dispbeam); - free((char *)hb); + if (outdev == NULL) /* nothing to display? */ + return; + /* load and display beams we have */ + hbarr = (HDBEAMI *)malloc(nents*sizeof(HDBEAMI)); + for (i = nents; i--; ) { + hbarr[i].h = hdlist[clist[i].hd]; + hbarr[i].b = clist[i].bi; } - if (op == BS_NEW) { - done_packets(flush_queue()); /* empty queue, so we can... */ - for (i = 0; i < complen; i++) /* ...get number computed */ - complist[i].nc = bnrays(hdlist[complist[i].hd], - complist[i].bi); - listpos = 0; - lastin = -1; /* flag for initial sort */ - } + hdloadbeams(hbarr, nents, dispbeam); + free((char *)hbarr); return; memerr: error(SYSTEM, "out of memory in bundle_set"); @@ -227,9 +229,9 @@ init_global() /* initialize global ray computation * /* compute beam weights */ k = 0; for (j = 0; hdlist[j] != NULL; j++) { - frac = 512. * hdlist[j]->wg[0] * - hdlist[j]->wg[1] * hdlist[j]->wg[2]; - if (frac < 0.) frac = -frac; + frac = 512. * VLEN(hdlist[j]->wg[0]) * + VLEN(hdlist[j]->wg[1]) * + VLEN(hdlist[j]->wg[2]); for (i = nbeams(hdlist[j]); i > 0; i--) { complist[k].hd = j; complist[k].bi = i; @@ -245,7 +247,8 @@ init_global() /* initialize global ray computation * frac = 1024.*1024.*16384. / (wtotal*sizeof(RAYVAL)); while (k--) complist[k].nr = frac * complist[k].nr; - listpos = 0; lastin = -1; /* flag initial sort */ + listpos = 0; lastin = -1; /* perform initial sort */ + sortcomplist(); }
