--- ray/src/hd/rholo3.c 1997/12/01 16:35:02 3.12 +++ ray/src/hd/rholo3.c 1998/12/10 10:47:50 3.25 @@ -1,4 +1,4 @@ -/* Copyright (c) 1997 Silicon Graphics, Inc. */ +/* Copyright (c) 1998 Silicon Graphics, Inc. */ #ifndef lint static char SCCSid[] = "$SunId$ SGI"; @@ -20,71 +20,124 @@ static int lastin= -1; /* last ordered position in lis int -beamcmp(b0, b1) /* comparison for descending compute order */ +beamcmp(b0, b1) /* comparison for compute order */ register PACKHEAD *b0, *b1; { return( b1->nr*(b0->nc+1) - b0->nr*(b1->nc+1) ); } +int +beamidcmp(b0, b1) /* comparison for beam searching */ +register PACKHEAD *b0, *b1; +{ + register int c = b0->hd - b1->hd; + + if (c) return(c); + return(b0->bi - b1->bi); +} + + +int +dispbeam(b, hb) /* display a holodeck beam */ +register BEAM *b; +register HDBEAMI *hb; +{ + static int n = 0; + static PACKHEAD *p = NULL; + + if (b == NULL) + return; + if (b->nrm > n) { /* (re)allocate packet holder */ + n = b->nrm; + if (p == NULL) p = (PACKHEAD *)malloc(packsiz(n)); + else p = (PACKHEAD *)realloc((char *)p, packsiz(n)); + if (p == NULL) + error(SYSTEM, "out of memory in dispbeam"); + } + /* assign packet fields */ + bcopy((char *)hdbray(b), (char *)packra(p), b->nrm*sizeof(RAYVAL)); + p->nr = p->nc = b->nrm; + for (p->hd = 0; hdlist[p->hd] != hb->h; p->hd++) + if (hdlist[p->hd] == NULL) + error(CONSISTENCY, "unregistered holodeck in dispbeam"); + p->bi = hb->b; + disp_packet(p); /* display it */ +} + + bundle_set(op, clist, nents) /* bundle set operation */ int op; PACKHEAD *clist; int nents; { - BEAM *b; - PACKHEAD *p; - register int i, n; - + int oldnr, n; + HDBEAMI *hbarr; + register PACKHEAD *csm; + register int i; + /* search for common members */ + for (csm = clist+nents; csm-- > clist; ) + csm->nc = -1; + qsort((char *)clist, nents, sizeof(PACKHEAD), beamidcmp); + for (i = 0; i < complen; i++) { + csm = (PACKHEAD *)bsearch((char *)(complist+i), (char *)clist, + nents, sizeof(PACKHEAD), beamidcmp); + if (csm == NULL) + continue; + oldnr = complist[i].nr; + csm->nc = complist[i].nc; + switch (op) { + case BS_ADD: /* add to count */ + complist[i].nr += csm->nr; + csm->nr = 0; + break; + case BS_ADJ: /* reset count */ + complist[i].nr = csm->nr; + csm->nr = 0; + break; + case BS_DEL: /* delete count */ + if (csm->nr == 0 || csm->nr >= complist[i].nr) + complist[i].nr = 0; + else + complist[i].nr -= csm->nr; + break; + } + if (complist[i].nr != oldnr) + lastin = -1; /* flag sort */ + } + /* record computed rays for uncommon beams */ + for (csm = clist+nents; csm-- > clist; ) + if (csm->nc < 0) + csm->nc = bnrays(hdlist[csm->hd], csm->bi); + /* complete list operations */ switch (op) { case BS_NEW: /* new computation set */ - if (complen) + listpos = 0; lastin = -1; + if (complen) /* free old list */ free((char *)complist); - if (nents <= 0) { - complist = NULL; - listpos = complen = 0; - lastin = -1; + complist = NULL; + if (!(complen = nents)) return; - } complist = (PACKHEAD *)malloc(nents*sizeof(PACKHEAD)); if (complist == NULL) goto memerr; bcopy((char *)clist, (char *)complist, nents*sizeof(PACKHEAD)); - complen = nents; /* finish initialization below */ break; case BS_ADD: /* add to computation set */ case BS_ADJ: /* adjust set quantities */ if (nents <= 0) return; - /* merge any common members */ - for (n = 0; n < nents; n++) { - for (i = 0; i < complen; i++) - if (clist[n].bi == complist[i].bi && - clist[n].hd == complist[i].hd) { - int oldnr = complist[i].nr; - if (op == BS_ADD) - complist[i].nr += clist[n].nr; - else /* op == BS_ADJ */ - complist[i].nr = clist[n].nr; - clist[n].nr = 0; - clist[n].nc = complist[i].nc; - if (complist[i].nr != oldnr) - lastin = -1; /* flag sort */ - break; - } - if (i >= complen) - clist[n].nc = bnrays(hdlist[clist[n].hd], - clist[n].bi); - } - /* sort updated list */ - sortcomplist(); - /* sort new entries */ + sortcomplist(); /* sort updated list & new entries */ qsort((char *)clist, nents, sizeof(PACKHEAD), beamcmp); /* what can't we satisfy? */ - for (n = 0; n < nents && clist[n].nr > clist[n].nc; n++) + for (i = nents, csm = clist; i-- && csm->nr > csm->nc; csm++) ; - if (op == BS_ADJ) - nents = n; + n = csm - clist; + if (op == BS_ADJ) { /* don't regenerate adjusted beams */ + for (++i; i-- && csm->nr > 0; csm++) + ; + nents = csm - clist; + } if (n) { /* allocate space for merged list */ PACKHEAD *newlist; newlist = (PACKHEAD *)malloc( @@ -102,133 +155,70 @@ int nents; lastin = complen-1; /* list is now sorted */ break; case BS_DEL: /* delete from computation set */ - if (nents <= 0) - return; - /* find each member */ - for (i = 0; i < complen; i++) - for (n = 0; n < nents; n++) - if (clist[n].bi == complist[i].bi && - clist[n].hd == complist[i].hd) { - if (clist[n].nr == 0 || - clist[n].nr >= complist[i].nr) - complist[i].nr = 0; - else - complist[i].nr -= clist[n].nr; - lastin = -1; /* flag full sort */ - break; - } - return; /* no display */ + return; /* already done */ default: error(CONSISTENCY, "bundle_set called with unknown operation"); } - if (outdev == NULL) + if (outdev == NULL) /* nothing to display? */ return; - n = 32*RPACKSIZ; /* allocate packet holder */ - p = (PACKHEAD *)malloc(packsiz(n)); - if (p == NULL) - goto memerr; - /* display what we have */ - for (i = 0; i < nents; i++) - if ((b = hdgetbeam(hdlist[clist[i].hd], clist[i].bi)) != NULL) { - if (b->nrm > n) { - n = b->nrm; - p = (PACKHEAD *)realloc((char *)p, packsiz(n)); - if (p == NULL) - goto memerr; - } - bcopy((char *)hdbray(b), (char *)packra(p), - b->nrm*sizeof(RAYVAL)); - p->hd = clist[i].hd; - p->bi = clist[i].bi; - p->nr = p->nc = b->nrm; - disp_packet(p); - } - free((char *)p); /* clean up */ - if (op == BS_NEW) { - done_packets(flush_queue()); /* empty queue, so we can... */ - for (i = 0; i < complen; i++) /* ...get number computed */ - complist[i].nc = bnrays(hdlist[complist[i].hd], - complist[i].bi); - listpos = 0; - lastin = -1; /* flag for initial sort */ + /* load and display beams we have */ + hbarr = (HDBEAMI *)malloc(nents*sizeof(HDBEAMI)); + for (i = nents; i--; ) { + hbarr[i].h = hdlist[clist[i].hd]; + hbarr[i].b = clist[i].bi; } + hdloadbeams(hbarr, nents, dispbeam); + free((char *)hbarr); return; memerr: error(SYSTEM, "out of memory in bundle_set"); } -int -weightf(hp, x0, x1, x2) /* voxel weighting function */ -register HOLO *hp; -register int x0, x1, x2; -{ - switch (vlet(OCCUPANCY)) { - case 'U': /* uniform weighting */ - return(1); - case 'C': /* center weighting (crude) */ - x0 += x0 - hp->grid[0] + 1; - x0 = abs(x0)*hp->grid[1]*hp->grid[2]; - x1 += x1 - hp->grid[1] + 1; - x1 = abs(x1)*hp->grid[0]*hp->grid[2]; - x2 += x2 - hp->grid[2] + 1; - x2 = abs(x2)*hp->grid[0]*hp->grid[1]; - return(hp->grid[0]*hp->grid[1]*hp->grid[2] - - (x0+x1+x2)/3); - default: - badvalue(OCCUPANCY); - } -} - - -/* The following is by Daniel Cohen, taken from Graphics Gems IV, p. 368 */ -long -lineweight(hp, x, y, z, dx, dy, dz) /* compute weights along a line */ +double +beamvolume(hp, bi) /* compute approximate volume of a beam */ HOLO *hp; -int x, y, z, dx, dy, dz; +int bi; { - long wres = 0; - int n, sx, sy, sz, exy, exz, ezy, ax, ay, az, bx, by, bz; - - sx = sgn(dx); sy = sgn(dy); sz = sgn(dz); - ax = abs(dx); ay = abs(dy); az = abs(dz); - bx = 2*ax; by = 2*ay; bz = 2*az; - exy = ay-ax; exz = az-ax; ezy = ay-az; - n = ax+ay+az + 1; /* added increment to visit last */ - while (n--) { - wres += weightf(hp, x, y, z); - if (exy < 0) { - if (exz < 0) { - x += sx; - exy += by; exz += bz; - } else { - z += sz; - exz -= bx; ezy += by; - } - } else { - if (ezy < 0) { - z += sz; - exz -= bx; ezy += by; - } else { - y += sy; - exy -= bx; ezy -= bz; - } - } + GCOORD gc[2]; + FVECT cp[4], edgeA, edgeB, cent[2]; + FVECT v, crossp[2], diffv; + double vol[2]; + register int i; + /* get grid coordinates */ + if (!hdbcoord(gc, hp, bi)) + error(CONSISTENCY, "bad beam index in beamvolume"); + for (i = 0; i < 2; i++) { /* compute cell area vectors */ + hdcell(cp, hp, gc+i); + VSUM(edgeA, cp[1], cp[0], -1.0); + VSUM(edgeB, cp[3], cp[1], -1.0); + fcross(crossp[i], edgeA, edgeB); + /* compute center */ + cent[i][0] = 0.5*(cp[0][0] + cp[2][0]); + cent[i][1] = 0.5*(cp[0][1] + cp[2][1]); + cent[i][2] = 0.5*(cp[0][2] + cp[2][2]); } - return(wres); + /* compute difference vector */ + VSUM(diffv, cent[1], cent[0], -1.0); + for (i = 0; i < 2; i++) { /* compute volume contributions */ + vol[i] = 0.5*DOT(crossp[i], diffv); + if (vol[i] < 0.) vol[i] = -vol[i]; + } + return(vol[0] + vol[1]); /* return total volume */ } init_global() /* initialize global ray computation */ { long wtotal = 0; - int i, j; - int lseg[2][3]; double frac; - register int k; - /* free old list */ - if (complen > 0) + int i; + register int j, k; + /* free old list and empty queue */ + if (complen > 0) { free((char *)complist); + done_packets(flush_queue()); + } /* allocate beam list */ complen = 0; for (j = 0; hdlist[j] != NULL; j++) @@ -238,35 +228,38 @@ init_global() /* initialize global ray computation * error(SYSTEM, "out of memory in init_global"); /* compute beam weights */ k = 0; - for (j = 0; hdlist[j] != NULL; j++) + for (j = 0; hdlist[j] != NULL; j++) { + frac = 512. * VLEN(hdlist[j]->wg[0]) * + VLEN(hdlist[j]->wg[1]) * + VLEN(hdlist[j]->wg[2]); for (i = nbeams(hdlist[j]); i > 0; i--) { - hdlseg(lseg, hdlist[j], i); complist[k].hd = j; complist[k].bi = i; - complist[k].nr = lineweight( hdlist[j], - lseg[0][0], lseg[0][1], lseg[0][2], - lseg[1][0] - lseg[0][0], - lseg[1][1] - lseg[0][1], - lseg[1][2] - lseg[0][2] ); + complist[k].nr = frac*beamvolume(hdlist[j], i) + 0.5; + complist[k].nc = bnrays(hdlist[j], i); wtotal += complist[k++].nr; } + } /* adjust weights */ if (vdef(DISKSPACE)) frac = 1024.*1024.*vflt(DISKSPACE) / (wtotal*sizeof(RAYVAL)); else frac = 1024.*1024.*16384. / (wtotal*sizeof(RAYVAL)); while (k--) - complist[k].nr = frac * complist[k].nr; - listpos = 0; lastin = -1; /* flag initial sort */ + complist[k].nr = frac*complist[k].nr + 0.5; + listpos = 0; lastin = -1; /* perform initial sort */ + sortcomplist(); + /* no view vicinity */ + myeye.rng = 0; } mergeclists(cdest, cl1, n1, cl2, n2) /* merge two sorted lists */ -PACKHEAD *cdest; -PACKHEAD *cl1, *cl2; +register PACKHEAD *cdest; +register PACKHEAD *cl1, *cl2; int n1, n2; { - int cmp; + register int cmp; while (n1 | n2) { if (!n1) cmp = 1; @@ -331,8 +324,9 @@ sortcomplist() /* fix our list order */ * list and start again from the beginning. Since * a merge sort is used, the sorting costs are minimal. */ -next_packet(p) /* prepare packet for computation */ +next_packet(p, n) /* prepare packet for computation */ register PACKET *p; +int n; { register int i; @@ -346,8 +340,12 @@ register PACKET *p; p->nr = complist[listpos].nr - p->nc; if (p->nr <= 0) return(0); - if (p->nr > RPACKSIZ) - p->nr = RPACKSIZ; +#ifdef DEBUG + if (n < 1 | n > RPACKSIZ) + error(CONSISTENCY, "next_packet called with bad n value"); +#endif + if (p->nr > n) + p->nr = n; complist[listpos].nc += p->nr; /* find where this one would go */ while (lastin > listpos && beamcmp(complist+lastin, complist+listpos) > 0)
