--- ray/src/hd/rholo3.c 1997/12/01 16:35:02 3.12 +++ ray/src/hd/rholo3.c 1997/12/15 20:44:28 3.13 @@ -158,74 +158,49 @@ memerr: } -int -weightf(hp, x0, x1, x2) /* voxel weighting function */ -register HOLO *hp; -register int x0, x1, x2; -{ - switch (vlet(OCCUPANCY)) { - case 'U': /* uniform weighting */ - return(1); - case 'C': /* center weighting (crude) */ - x0 += x0 - hp->grid[0] + 1; - x0 = abs(x0)*hp->grid[1]*hp->grid[2]; - x1 += x1 - hp->grid[1] + 1; - x1 = abs(x1)*hp->grid[0]*hp->grid[2]; - x2 += x2 - hp->grid[2] + 1; - x2 = abs(x2)*hp->grid[0]*hp->grid[1]; - return(hp->grid[0]*hp->grid[1]*hp->grid[2] - - (x0+x1+x2)/3); - default: - badvalue(OCCUPANCY); - } -} - - -/* The following is by Daniel Cohen, taken from Graphics Gems IV, p. 368 */ -long -lineweight(hp, x, y, z, dx, dy, dz) /* compute weights along a line */ +double +beamvolume(hp, bi) /* compute approximate volume of a beam */ HOLO *hp; -int x, y, z, dx, dy, dz; +int bi; { - long wres = 0; - int n, sx, sy, sz, exy, exz, ezy, ax, ay, az, bx, by, bz; - - sx = sgn(dx); sy = sgn(dy); sz = sgn(dz); - ax = abs(dx); ay = abs(dy); az = abs(dz); - bx = 2*ax; by = 2*ay; bz = 2*az; - exy = ay-ax; exz = az-ax; ezy = ay-az; - n = ax+ay+az + 1; /* added increment to visit last */ - while (n--) { - wres += weightf(hp, x, y, z); - if (exy < 0) { - if (exz < 0) { - x += sx; - exy += by; exz += bz; - } else { - z += sz; - exz -= bx; ezy += by; - } - } else { - if (ezy < 0) { - z += sz; - exz -= bx; ezy += by; - } else { - y += sy; - exy -= bx; ezy -= bz; - } - } + GCOORD gc[2]; + FVECT cp[4], edgeA, edgeB, cent[2]; + FVECT v, crossp[2], diffv; + double vol[2]; + register int i; + /* get grid coordinates */ + if (!hdbcoord(gc, hp, bi)) + error(CONSISTENCY, "bad beam index in beamvolume"); + for (i = 0; i < 2; i++) { /* compute cell area vectors */ + hdcell(cp, hp, gc+i); + VSUM(edgeA, cp[1], cp[0], -1.0); + VSUM(edgeB, cp[3], cp[1], -1.0); + fcross(crossp[i], edgeA, edgeB); + VSUM(edgeA, cp[2], cp[3], -1.0); + VSUM(edgeB, cp[0], cp[2], -1.0); + fcross(v, edgeA, edgeB); + VSUM(crossp[i], crossp[i], v, 1.0); + /* compute center */ + cent[i][0] = 0.5*(cp[0][0] + cp[2][0]); + cent[i][1] = 0.5*(cp[0][1] + cp[2][1]); + cent[i][2] = 0.5*(cp[0][2] + cp[2][2]); } - return(wres); + /* compute difference vector */ + VSUM(diffv, cent[1], cent[0], -1.0); + for (i = 0; i < 2; i++) { /* compute volume contributions */ + vol[i] = 0.25*DOT(crossp[i], diffv); + if (vol[i] < 0.) vol[i] = -vol[i]; + } + return(vol[0] + vol[1]); /* return total volume */ } init_global() /* initialize global ray computation */ { long wtotal = 0; - int i, j; - int lseg[2][3]; double frac; - register int k; + int i; + register int j, k; /* free old list */ if (complen > 0) free((char *)complist); @@ -238,18 +213,16 @@ init_global() /* initialize global ray computation * error(SYSTEM, "out of memory in init_global"); /* compute beam weights */ k = 0; - for (j = 0; hdlist[j] != NULL; j++) + for (j = 0; hdlist[j] != NULL; j++) { + frac = 512. * hdlist[j]->wg[0] * + hdlist[j]->wg[1] * hdlist[j]->wg[2]; for (i = nbeams(hdlist[j]); i > 0; i--) { - hdlseg(lseg, hdlist[j], i); complist[k].hd = j; complist[k].bi = i; - complist[k].nr = lineweight( hdlist[j], - lseg[0][0], lseg[0][1], lseg[0][2], - lseg[1][0] - lseg[0][0], - lseg[1][1] - lseg[0][1], - lseg[1][2] - lseg[0][2] ); + complist[k].nr = frac*beamvolume(hdlist[j], i) + 0.5; wtotal += complist[k++].nr; } + } /* adjust weights */ if (vdef(DISKSPACE)) frac = 1024.*1024.*vflt(DISKSPACE) / (wtotal*sizeof(RAYVAL));
