| 1 |
#ifndef lint
| 2 |
static const char RCSid[] = "$Id: rholo3.c,v 3.38 2003/06/30 14:59:12 schorsch Exp $";
| 3 |
#endif
| 4 |
| 5 |
* Routines for tracking beam compuatations
| 6 |
| 7 |
| 8 |
#include <string.h>
| 9 |
| 10 |
#include "rholo.h"
| 11 |
#include "view.h"
| 12 |
| 13 |
#ifndef NFRAG2CHUNK
| 14 |
#define NFRAG2CHUNK 4096 /* number of fragments to start chunking */
| 15 |
#endif
| 16 |
| 17 |
#ifndef abs
| 18 |
#define abs(x) ((x) > 0 ? (x) : -(x))
| 19 |
#endif
| 20 |
#ifndef sgn
| 21 |
#define sgn(x) ((x) > 0 ? 1 : (x) < 0 ? -1 : 0)
| 22 |
#endif
| 23 |
| 24 |
#define rchunk(n) (((n)+(RPACKSIZ/2))/RPACKSIZ)
| 25 |
| 26 |
extern time_t time();
| 27 |
| 28 |
int chunkycmp = 0; /* clump beams together on disk */
| 29 |
| 30 |
static PACKHEAD *complist=NULL; /* list of beams to compute */
| 31 |
static int complen=0; /* length of complist */
| 32 |
static int listpos=0; /* current list position for next_packet */
| 33 |
static int lastin= -1; /* last ordered position in list */
| 34 |
| 35 |
| 36 |
int
| 37 |
beamcmp(b0, b1) /* comparison for compute order */
| 38 |
register PACKHEAD *b0, *b1;
| 39 |
| 40 |
BEAMI *bip0, *bip1;
| 41 |
register long c;
| 42 |
/* first check desired quantities */
| 43 |
if (chunkycmp)
| 44 |
c = rchunk(b1->nr)*(rchunk(b0->nc)+1L) -
| 45 |
rchunk(b0->nr)*(rchunk(b1->nc)+1L);
| 46 |
else
| 47 |
c = b1->nr*(b0->nc+1L) - b0->nr*(b1->nc+1L);
| 48 |
if (c > 0) return(1);
| 49 |
if (c < 0) return(-1);
| 50 |
/* only one file, so skip the following: */
| 51 |
#if 0
| 52 |
/* next, check file descriptors */
| 53 |
c = hdlist[b0->hd]->fd - hdlist[b1->hd]->fd;
| 54 |
if (c) return(c);
| 55 |
#endif
| 56 |
/* finally, check file positions */
| 57 |
bip0 = &hdlist[b0->hd]->bi[b0->bi];
| 58 |
bip1 = &hdlist[b1->hd]->bi[b1->bi];
| 59 |
/* put diskless beams last */
| 60 |
if (!bip0->nrd)
| 61 |
return(bip1->nrd > 0);
| 62 |
if (!bip1->nrd)
| 63 |
return(-1);
| 64 |
c = bip0->fo - bip1->fo;
| 65 |
return(c < 0 ? -1 : c > 0);
| 66 |
| 67 |
| 68 |
| 69 |
int
| 70 |
beamidcmp(b0, b1) /* comparison for beam searching */
| 71 |
| 72 |
| 73 |
register int c = b0->hd - b1->hd;
| 74 |
| 75 |
if (c) return(c);
| 76 |
return(b0->bi - b1->bi);
| 77 |
| 78 |
| 79 |
| 80 |
void
| 81 |
dispbeam(b, hb) /* display a holodeck beam */
| 82 |
register BEAM *b;
| 83 |
register HDBEAMI *hb;
| 84 |
| 85 |
static int n = 0;
| 86 |
static PACKHEAD *p = NULL;
| 87 |
| 88 |
if (b == NULL)
| 89 |
return;
| 90 |
if (b->nrm > n) { /* (re)allocate packet holder */
| 91 |
n = b->nrm;
| 92 |
if (p == NULL) p = (PACKHEAD *)malloc(packsiz(n));
| 93 |
else p = (PACKHEAD *)realloc((void *)p, packsiz(n));
| 94 |
CHECK(p==NULL, SYSTEM, "out of memory in dispbeam");
| 95 |
| 96 |
/* assign packet fields */
| 97 |
memcpy((void *)packra(p), (void *)hdbray(b), b->nrm*sizeof(RAYVAL));
| 98 |
p->nr = p->nc = b->nrm;
| 99 |
for (p->hd = 0; hdlist[p->hd] != hb->h; p->hd++)
| 100 |
if (hdlist[p->hd] == NULL)
| 101 |
error(CONSISTENCY, "unregistered holodeck in dispbeam");
| 102 |
p->bi = hb->b;
| 103 |
disp_packet(p); /* display it */
| 104 |
if (n >= 1024) { /* free ridiculous packets */
| 105 |
free((void *)p);
| 106 |
p = NULL; n = 0;
| 107 |
| 108 |
| 109 |
| 110 |
| 111 |
bundle_set(op, clist, nents) /* bundle set operation */
| 112 |
int op;
| 113 |
PACKHEAD *clist;
| 114 |
int nents;
| 115 |
| 116 |
int oldnr, n;
| 117 |
HDBEAMI *hbarr;
| 118 |
register PACKHEAD *csm;
| 119 |
register int i;
| 120 |
/* search for common members */
| 121 |
for (csm = clist+nents; csm-- > clist; )
| 122 |
csm->nc = -1;
| 123 |
qsort((void *)clist, nents, sizeof(PACKHEAD), beamidcmp);
| 124 |
for (i = 0; i < complen; i++) {
| 125 |
csm = (PACKHEAD *)bsearch((void *)(complist+i), (void *)clist,
| 126 |
| 127 |
if (csm == NULL)
| 128 |
continue;
| 129 |
oldnr = complist[i].nr;
| 130 |
csm->nc = complist[i].nc;
| 131 |
switch (op) {
| 132 |
case BS_ADD: /* add to count */
| 133 |
complist[i].nr += csm->nr;
| 134 |
csm->nr = 0;
| 135 |
break;
| 136 |
case BS_MAX: /* maximum of counts */
| 137 |
if (csm->nr > complist[i].nr)
| 138 |
complist[i].nr = csm->nr;
| 139 |
csm->nr = 0;
| 140 |
break;
| 141 |
case BS_ADJ: /* reset count */
| 142 |
| 143 |
csm->nr = 0;
| 144 |
break;
| 145 |
case BS_DEL: /* delete count */
| 146 |
if (csm->nr == 0 || csm->nr >= complist[i].nr)
| 147 |
complist[i].nr = 0;
| 148 |
else
| 149 |
complist[i].nr -= csm->nr;
| 150 |
break;
| 151 |
| 152 |
if (complist[i].nr != oldnr)
| 153 |
lastin = -1; /* flag sort */
| 154 |
| 155 |
/* record computed rays for uncommon beams */
| 156 |
| 157 |
if (csm->nc < 0)
| 158 |
csm->nc = bnrays(hdlist[csm->hd], csm->bi);
| 159 |
/* complete list operations */
| 160 |
switch (op) {
| 161 |
case BS_NEW: /* new computation set */
| 162 |
listpos = 0; lastin = -1;
| 163 |
if (complen) /* free old list */
| 164 |
free((void *)complist);
| 165 |
complist = NULL;
| 166 |
if (!(complen = nents))
| 167 |
return;
| 168 |
complist = (PACKHEAD *)malloc(nents*sizeof(PACKHEAD));
| 169 |
if (complist == NULL)
| 170 |
goto memerr;
| 171 |
memcpy((void *)complist, (void *)clist, nents*sizeof(PACKHEAD));
| 172 |
break;
| 173 |
case BS_ADD: /* add to computation set */
| 174 |
case BS_MAX: /* maximum of quantities */
| 175 |
case BS_ADJ: /* adjust set quantities */
| 176 |
if (nents <= 0)
| 177 |
return;
| 178 |
sortcomplist(); /* sort updated list & new entries */
| 179 |
qsort((void *)clist, nents, sizeof(PACKHEAD), beamcmp);
| 180 |
/* what can't we satisfy? */
| 181 |
for (i = nents, csm = clist; i-- && csm->nr > csm->nc; csm++)
| 182 |
| 183 |
n = csm - clist;
| 184 |
if (op != BS_ADD) { /* don't regenerate adjusted beams */
| 185 |
for (++i; i-- && csm->nr > 0; csm++)
| 186 |
| 187 |
nents = csm - clist;
| 188 |
| 189 |
if (n) { /* allocate space for merged list */
| 190 |
PACKHEAD *newlist;
| 191 |
newlist = (PACKHEAD *)malloc(
| 192 |
(complen+n)*sizeof(PACKHEAD) );
| 193 |
if (newlist == NULL)
| 194 |
goto memerr;
| 195 |
/* merge lists */
| 196 |
mergeclists(newlist, clist, n, complist, complen);
| 197 |
if (complen)
| 198 |
| 199 |
complist = newlist;
| 200 |
complen += n;
| 201 |
| 202 |
listpos = 0;
| 203 |
lastin = complen-1; /* list is now sorted */
| 204 |
break;
| 205 |
case BS_DEL: /* delete from computation set */
| 206 |
return; /* already done */
| 207 |
default:
| 208 |
error(CONSISTENCY, "bundle_set called with unknown operation");
| 209 |
| 210 |
if (outdev == NULL || !nents) /* nothing to display? */
| 211 |
return;
| 212 |
/* load and display beams we have */
| 213 |
hbarr = (HDBEAMI *)malloc(nents*sizeof(HDBEAMI));
| 214 |
for (i = nents; i--; ) {
| 215 |
hbarr[i].h = hdlist[clist[i].hd];
| 216 |
hbarr[i].b = clist[i].bi;
| 217 |
| 218 |
hdloadbeams(hbarr, nents, dispbeam);
| 219 |
free((void *)hbarr);
| 220 |
if (hdfragflags&FF_READ) {
| 221 |
listpos = 0;
| 222 |
lastin = -1; /* need to re-sort list */
| 223 |
| 224 |
return;
| 225 |
memerr:
| 226 |
error(SYSTEM, "out of memory in bundle_set");
| 227 |
| 228 |
| 229 |
| 230 |
double
| 231 |
beamvolume(hp, bi) /* compute approximate volume of a beam */
| 232 |
HOLO *hp;
| 233 |
int bi;
| 234 |
| 235 |
GCOORD gc[2];
| 236 |
FVECT cp[4], edgeA, edgeB, cent[2];
| 237 |
FVECT v, crossp[2], diffv;
| 238 |
double vol[2];
| 239 |
register int i;
| 240 |
/* get grid coordinates */
| 241 |
if (!hdbcoord(gc, hp, bi))
| 242 |
error(CONSISTENCY, "bad beam index in beamvolume");
| 243 |
for (i = 0; i < 2; i++) { /* compute cell area vectors */
| 244 |
hdcell(cp, hp, gc+i);
| 245 |
VSUM(edgeA, cp[1], cp[0], -1.0);
| 246 |
VSUM(edgeB, cp[3], cp[1], -1.0);
| 247 |
fcross(crossp[i], edgeA, edgeB);
| 248 |
/* compute center */
| 249 |
cent[i][0] = 0.5*(cp[0][0] + cp[2][0]);
| 250 |
cent[i][1] = 0.5*(cp[0][1] + cp[2][1]);
| 251 |
cent[i][2] = 0.5*(cp[0][2] + cp[2][2]);
| 252 |
| 253 |
/* compute difference vector */
| 254 |
VSUM(diffv, cent[1], cent[0], -1.0);
| 255 |
for (i = 0; i < 2; i++) { /* compute volume contributions */
| 256 |
vol[i] = 0.5*DOT(crossp[i], diffv);
| 257 |
if (vol[i] < 0.) vol[i] = -vol[i];
| 258 |
| 259 |
return(vol[0] + vol[1]); /* return total volume */
| 260 |
| 261 |
| 262 |
| 263 |
ambient_list() /* compute ambient beam list */
| 264 |
| 265 |
int32 wtotal, minrt;
| 266 |
double frac;
| 267 |
int i;
| 268 |
register int j, k;
| 269 |
| 270 |
complen = 0;
| 271 |
for (j = 0; hdlist[j] != NULL; j++)
| 272 |
complen += nbeams(hdlist[j]);
| 273 |
complist = (PACKHEAD *)malloc(complen*sizeof(PACKHEAD));
| 274 |
CHECK(complist==NULL, SYSTEM, "out of memory in ambient_list");
| 275 |
/* compute beam weights */
| 276 |
k = 0; wtotal = 0;
| 277 |
for (j = 0; hdlist[j] != NULL; j++) {
| 278 |
frac = 512. * VLEN(hdlist[j]->wg[0]) *
| 279 |
VLEN(hdlist[j]->wg[1]) *
| 280 |
VLEN(hdlist[j]->wg[2]);
| 281 |
for (i = nbeams(hdlist[j]); i > 0; i--) {
| 282 |
complist[k].hd = j;
| 283 |
complist[k].bi = i;
| 284 |
complist[k].nr = frac*beamvolume(hdlist[j], i) + 0.5;
| 285 |
complist[k].nc = bnrays(hdlist[j], i);
| 286 |
wtotal += complist[k++].nr;
| 287 |
| 288 |
| 289 |
/* adjust sample weights */
| 290 |
if (vdef(DISKSPACE))
| 291 |
frac = 1024.*1024.*vflt(DISKSPACE) / (wtotal*sizeof(RAYVAL));
| 292 |
else
| 293 |
frac = 1024.*1024.*2048. / (wtotal*sizeof(RAYVAL));
| 294 |
minrt = .02*frac*wtotal/complen + .5; /* heuristic mimimum */
| 295 |
if (minrt > RPACKSIZ)
| 296 |
minrt = RPACKSIZ;
| 297 |
for (k = complen; k--; )
| 298 |
if ((complist[k].nr = frac*complist[k].nr + 0.5) < minrt)
| 299 |
complist[k].nr = minrt;
| 300 |
listpos = 0; lastin = -1; /* flag initial sort */
| 301 |
| 302 |
| 303 |
| 304 |
view_list(fp) /* assign beam priority from view list */
| 305 |
FILE *fp;
| 306 |
| 307 |
double pa = 1.;
| 308 |
VIEW curview;
| 309 |
int xr, yr;
| 310 |
char *err;
| 311 |
BEAMLIST blist;
| 312 |
| 313 |
copystruct(&curview, &stdview);
| 314 |
while (nextview(&curview, fp) != EOF) {
| 315 |
if ((err = setview(&curview)) != NULL) {
| 316 |
error(WARNING, err);
| 317 |
continue;
| 318 |
| 319 |
xr = yr = 1024;
| 320 |
normaspect(viewaspect(&curview), &pa, &xr, &yr);
| 321 |
viewbeams(&curview, xr, yr, &blist);
| 322 |
bundle_set(BS_MAX, blist.bl, blist.nb);
| 323 |
free((void *)blist.bl);
| 324 |
| 325 |
| 326 |
| 327 |
| 328 |
init_global() /* initialize global ray computation */
| 329 |
| 330 |
register int k;
| 331 |
/* free old list and empty queue */
| 332 |
if (complen > 0) {
| 333 |
| 334 |
done_packets(flush_queue());
| 335 |
| 336 |
/* reseed random number generator */
| 337 |
srandom(time(NULL));
| 338 |
/* allocate beam list */
| 339 |
if (readinp)
| 340 |
view_list(stdin);
| 341 |
else
| 342 |
ambient_list();
| 343 |
/* no view vicinity */
| 344 |
myeye.rng = 0;
| 345 |
| 346 |
| 347 |
| 348 |
mergeclists(cdest, cl1, n1, cl2, n2) /* merge two sorted lists */
| 349 |
register PACKHEAD *cdest;
| 350 |
register PACKHEAD *cl1, *cl2;
| 351 |
int n1, n2;
| 352 |
| 353 |
register int cmp;
| 354 |
| 355 |
while (n1 | n2) {
| 356 |
if (!n1) cmp = 1;
| 357 |
else if (!n2) cmp = -1;
| 358 |
else cmp = beamcmp(cl1, cl2);
| 359 |
if (cmp > 0) {
| 360 |
copystruct(cdest, cl2);
| 361 |
cl2++; n2--;
| 362 |
} else {
| 363 |
copystruct(cdest, cl1);
| 364 |
cl1++; n1--;
| 365 |
| 366 |
cdest++;
| 367 |
| 368 |
| 369 |
| 370 |
| 371 |
sortcomplist() /* fix our list order */
| 372 |
| 373 |
PACKHEAD *list2;
| 374 |
int listlen;
| 375 |
register int i;
| 376 |
| 377 |
if (complen <= 0) /* check to see if there is even a list */
| 378 |
return;
| 379 |
if (!chunkycmp) /* check to see if fragment list is full */
| 380 |
if (!hdfragOK(hdlist[0]->fd, &listlen, NULL)
| 381 |
#if NFRAG2CHUNK
| 382 |
|| listlen >= NFRAG2CHUNK
| 383 |
#endif
| 384 |
| 385 |
chunkycmp++; /* use "chunky" comparison */
| 386 |
| 387 |
#ifdef DEBUG
| 388 |
error(WARNING, "using chunky comparison mode");
| 389 |
#endif
| 390 |
| 391 |
if (lastin < 0 || listpos*4 >= complen*3)
| 392 |
qsort((void *)complist, complen, sizeof(PACKHEAD), beamcmp);
| 393 |
else if (listpos) { /* else sort and merge sublist */
| 394 |
list2 = (PACKHEAD *)malloc(listpos*sizeof(PACKHEAD));
| 395 |
CHECK(list2==NULL, SYSTEM, "out of memory in sortcomplist");
| 396 |
memcpy((void *)list2,(void *)complist,listpos*sizeof(PACKHEAD));
| 397 |
qsort((void *)list2, listpos, sizeof(PACKHEAD), beamcmp);
| 398 |
mergeclists(complist, list2, listpos,
| 399 |
complist+listpos, complen-listpos);
| 400 |
free((void *)list2);
| 401 |
| 402 |
/* drop satisfied requests */
| 403 |
for (i = complen; i-- && complist[i].nr <= complist[i].nc; )
| 404 |
| 405 |
if (i < 0) {
| 406 |
| 407 |
complist = NULL;
| 408 |
complen = 0;
| 409 |
} else if (i < complen-1) {
| 410 |
list2 = (PACKHEAD *)realloc((void *)complist,
| 411 |
(i+1)*sizeof(PACKHEAD));
| 412 |
if (list2 != NULL)
| 413 |
complist = list2;
| 414 |
complen = i+1;
| 415 |
| 416 |
listpos = 0; lastin = i;
| 417 |
| 418 |
| 419 |
| 420 |
| 421 |
* The following routine works on the assumption that the bundle weights are
| 422 |
* more or less evenly distributed, such that computing a packet causes
| 423 |
* a given bundle to move way down in the computation order. We keep
| 424 |
* track of where the computed bundle with the highest priority would end
| 425 |
* up, and if we get further in our compute list than this, we re-sort the
| 426 |
* list and start again from the beginning. Since
| 427 |
* a merge sort is used, the sorting costs are minimal.
| 428 |
| 429 |
next_packet(p, n) /* prepare packet for computation */
| 430 |
register PACKET *p;
| 431 |
int n;
| 432 |
| 433 |
register int i;
| 434 |
| 435 |
if (listpos > lastin) /* time to sort the list */
| 436 |
sortcomplist();
| 437 |
if (complen <= 0)
| 438 |
return(0);
| 439 |
p->hd = complist[listpos].hd;
| 440 |
p->bi = complist[listpos].bi;
| 441 |
p->nc = complist[listpos].nc;
| 442 |
p->nr = complist[listpos].nr - p->nc;
| 443 |
if (p->nr <= 0)
| 444 |
return(0);
| 445 |
DCHECK(n < 1 | n > RPACKSIZ,
| 446 |
CONSISTENCY, "next_packet called with bad n value");
| 447 |
if (p->nr > n)
| 448 |
p->nr = n;
| 449 |
complist[listpos].nc += p->nr; /* find where this one would go */
| 450 |
if (hdgetbeam(hdlist[p->hd], p->bi) != NULL)
| 451 |
hdfreefrag(hdlist[p->hd], p->bi);
| 452 |
while (lastin > listpos &&
| 453 |
beamcmp(complist+lastin, complist+listpos) > 0)
| 454 |
lastin--;
| 455 |
listpos++;
| 456 |
return(1);
| 457 |
