| 1 |
/* Copyright (c) 1997 Silicon Graphics, Inc. */
| 2 |
| 3 |
#ifndef lint
| 4 |
static char SCCSid[] = "$SunId$ SGI";
| 5 |
#endif
| 6 |
| 7 |
| 8 |
* Routines for tracking beam compuatations
| 9 |
| 10 |
| 11 |
#include "rholo.h"
| 12 |
| 13 |
#define abs(x) ((x) > 0 ? (x) : -(x))
| 14 |
#define sgn(x) ((x) > 0 ? 1 : (x) < 0 ? -1 : 0)
| 15 |
| 16 |
static PACKHEAD *complist=NULL; /* list of beams to compute */
| 17 |
static int complen=0; /* length of complist */
| 18 |
static int listpos=0; /* current list position for next_packet */
| 19 |
static int lastin= -1; /* last ordered position in list */
| 20 |
| 21 |
| 22 |
int
| 23 |
beamcmp(b0, b1) /* comparison for descending compute order */
| 24 |
register PACKHEAD *b0, *b1;
| 25 |
| 26 |
return( b1->nr*(b0->nc+1) - b0->nr*(b1->nc+1) );
| 27 |
| 28 |
| 29 |
| 30 |
bundle_set(op, clist, nents) /* bundle set operation */
| 31 |
int op;
| 32 |
PACKHEAD *clist;
| 33 |
int nents;
| 34 |
| 35 |
BEAM *b;
| 36 |
PACKHEAD *p;
| 37 |
register int i, n;
| 38 |
| 39 |
switch (op) {
| 40 |
case BS_NEW: /* new computation set */
| 41 |
if (complen)
| 42 |
free((char *)complist);
| 43 |
if (nents <= 0) {
| 44 |
complist = NULL;
| 45 |
listpos = complen = 0;
| 46 |
lastin = -1;
| 47 |
return;
| 48 |
| 49 |
complist = (PACKHEAD *)malloc(nents*sizeof(PACKHEAD));
| 50 |
if (complist == NULL)
| 51 |
goto memerr;
| 52 |
bcopy((char *)clist, (char *)complist, nents*sizeof(PACKHEAD));
| 53 |
complen = nents; /* finish initialization below */
| 54 |
break;
| 55 |
case BS_ADD: /* add to computation set */
| 56 |
case BS_ADJ: /* adjust set quantities */
| 57 |
if (nents <= 0)
| 58 |
return;
| 59 |
/* merge any common members */
| 60 |
for (n = 0; n < nents; n++) {
| 61 |
for (i = 0; i < complen; i++)
| 62 |
if (clist[n].bi == complist[i].bi &&
| 63 |
clist[n].hd == complist[i].hd) {
| 64 |
int oldnr = complist[i].nr;
| 65 |
if (op == BS_ADD)
| 66 |
complist[i].nr += clist[n].nr;
| 67 |
else /* op == BS_ADJ */
| 68 |
complist[i].nr = clist[n].nr;
| 69 |
clist[n].nr = 0;
| 70 |
clist[n].nc = complist[i].nc;
| 71 |
if (complist[i].nr != oldnr)
| 72 |
lastin = -1; /* flag sort */
| 73 |
break;
| 74 |
| 75 |
if (i >= complen)
| 76 |
clist[n].nc = bnrays(hdlist[clist[n].hd],
| 77 |
clist[n].bi);
| 78 |
| 79 |
/* sort updated list */
| 80 |
sortcomplist();
| 81 |
/* sort new entries */
| 82 |
qsort((char *)clist, nents, sizeof(PACKHEAD), beamcmp);
| 83 |
/* what can't we satisfy? */
| 84 |
for (n = 0; n < nents && clist[n].nr > clist[n].nc; n++)
| 85 |
| 86 |
if (op == BS_ADJ)
| 87 |
nents = n;
| 88 |
if (n) { /* allocate space for merged list */
| 89 |
PACKHEAD *newlist;
| 90 |
newlist = (PACKHEAD *)malloc(
| 91 |
(complen+n)*sizeof(PACKHEAD) );
| 92 |
if (newlist == NULL)
| 93 |
goto memerr;
| 94 |
/* merge lists */
| 95 |
mergeclists(newlist, clist, n, complist, complen);
| 96 |
if (complen)
| 97 |
| 98 |
complist = newlist;
| 99 |
complen += n;
| 100 |
| 101 |
listpos = 0;
| 102 |
lastin = complen-1; /* list is now sorted */
| 103 |
break;
| 104 |
case BS_DEL: /* delete from computation set */
| 105 |
if (nents <= 0)
| 106 |
return;
| 107 |
/* find each member */
| 108 |
| 109 |
| 110 |
| 111 |
| 112 |
if (clist[n].nr == 0 ||
| 113 |
clist[n].nr >= complist[i].nr)
| 114 |
complist[i].nr = 0;
| 115 |
else
| 116 |
complist[i].nr -= clist[n].nr;
| 117 |
lastin = -1; /* flag full sort */
| 118 |
break;
| 119 |
| 120 |
return; /* no display */
| 121 |
default:
| 122 |
error(CONSISTENCY, "bundle_set called with unknown operation");
| 123 |
| 124 |
if (outdev == NULL)
| 125 |
return;
| 126 |
n = 32*RPACKSIZ; /* allocate packet holder */
| 127 |
p = (PACKHEAD *)malloc(packsiz(n));
| 128 |
if (p == NULL)
| 129 |
goto memerr;
| 130 |
/* display what we have */
| 131 |
for (i = 0; i < nents; i++)
| 132 |
if ((b = hdgetbeam(hdlist[clist[i].hd], clist[i].bi)) != NULL) {
| 133 |
if (b->nrm > n) {
| 134 |
n = b->nrm;
| 135 |
p = (PACKHEAD *)realloc((char *)p, packsiz(n));
| 136 |
if (p == NULL)
| 137 |
goto memerr;
| 138 |
| 139 |
bcopy((char *)hdbray(b), (char *)packra(p),
| 140 |
b->nrm*sizeof(RAYVAL));
| 141 |
p->hd = clist[i].hd;
| 142 |
p->bi = clist[i].bi;
| 143 |
p->nr = p->nc = b->nrm;
| 144 |
disp_packet(p);
| 145 |
| 146 |
free((char *)p); /* clean up */
| 147 |
if (op == BS_NEW) {
| 148 |
done_packets(flush_queue()); /* empty queue, so we can... */
| 149 |
for (i = 0; i < complen; i++) /* ...get number computed */
| 150 |
complist[i].nc = bnrays(hdlist[complist[i].hd],
| 151 |
complist[i].bi);
| 152 |
listpos = 0;
| 153 |
lastin = -1; /* flag for initial sort */
| 154 |
| 155 |
return;
| 156 |
memerr:
| 157 |
error(SYSTEM, "out of memory in bundle_set");
| 158 |
| 159 |
| 160 |
| 161 |
int
| 162 |
weightf(hp, x0, x1, x2) /* voxel weighting function */
| 163 |
register HOLO *hp;
| 164 |
register int x0, x1, x2;
| 165 |
| 166 |
switch (vlet(OCCUPANCY)) {
| 167 |
case 'U': /* uniform weighting */
| 168 |
return(1);
| 169 |
case 'C': /* center weighting (crude) */
| 170 |
x0 += x0 - hp->grid[0] + 1;
| 171 |
x0 = abs(x0)*hp->grid[1]*hp->grid[2];
| 172 |
x1 += x1 - hp->grid[1] + 1;
| 173 |
x1 = abs(x1)*hp->grid[0]*hp->grid[2];
| 174 |
x2 += x2 - hp->grid[2] + 1;
| 175 |
x2 = abs(x2)*hp->grid[0]*hp->grid[1];
| 176 |
return(hp->grid[0]*hp->grid[1]*hp->grid[2] -
| 177 |
(x0+x1+x2)/3);
| 178 |
default:
| 179 |
badvalue(OCCUPANCY);
| 180 |
| 181 |
| 182 |
| 183 |
| 184 |
/* The following is by Daniel Cohen, taken from Graphics Gems IV, p. 368 */
| 185 |
long
| 186 |
lineweight(hp, x, y, z, dx, dy, dz) /* compute weights along a line */
| 187 |
HOLO *hp;
| 188 |
int x, y, z, dx, dy, dz;
| 189 |
| 190 |
long wres = 0;
| 191 |
int n, sx, sy, sz, exy, exz, ezy, ax, ay, az, bx, by, bz;
| 192 |
| 193 |
sx = sgn(dx); sy = sgn(dy); sz = sgn(dz);
| 194 |
ax = abs(dx); ay = abs(dy); az = abs(dz);
| 195 |
bx = 2*ax; by = 2*ay; bz = 2*az;
| 196 |
exy = ay-ax; exz = az-ax; ezy = ay-az;
| 197 |
n = ax+ay+az + 1; /* added increment to visit last */
| 198 |
while (n--) {
| 199 |
wres += weightf(hp, x, y, z);
| 200 |
if (exy < 0) {
| 201 |
if (exz < 0) {
| 202 |
x += sx;
| 203 |
exy += by; exz += bz;
| 204 |
} else {
| 205 |
z += sz;
| 206 |
exz -= bx; ezy += by;
| 207 |
| 208 |
} else {
| 209 |
if (ezy < 0) {
| 210 |
z += sz;
| 211 |
| 212 |
} else {
| 213 |
y += sy;
| 214 |
exy -= bx; ezy -= bz;
| 215 |
| 216 |
| 217 |
| 218 |
return(wres);
| 219 |
| 220 |
| 221 |
| 222 |
init_global() /* initialize global ray computation */
| 223 |
| 224 |
long wtotal = 0;
| 225 |
int i, j;
| 226 |
int lseg[2][3];
| 227 |
double frac;
| 228 |
register int k;
| 229 |
/* free old list */
| 230 |
if (complen > 0)
| 231 |
| 232 |
/* allocate beam list */
| 233 |
complen = 0;
| 234 |
for (j = 0; hdlist[j] != NULL; j++)
| 235 |
complen += nbeams(hdlist[j]);
| 236 |
complist = (PACKHEAD *)malloc(complen*sizeof(PACKHEAD));
| 237 |
| 238 |
error(SYSTEM, "out of memory in init_global");
| 239 |
/* compute beam weights */
| 240 |
k = 0;
| 241 |
| 242 |
for (i = nbeams(hdlist[j]); i > 0; i--) {
| 243 |
hdlseg(lseg, hdlist[j], i);
| 244 |
complist[k].hd = j;
| 245 |
complist[k].bi = i;
| 246 |
complist[k].nr = lineweight( hdlist[j],
| 247 |
lseg[0][0], lseg[0][1], lseg[0][2],
| 248 |
lseg[1][0] - lseg[0][0],
| 249 |
lseg[1][1] - lseg[0][1],
| 250 |
lseg[1][2] - lseg[0][2] );
| 251 |
wtotal += complist[k++].nr;
| 252 |
| 253 |
/* adjust weights */
| 254 |
if (vdef(DISKSPACE))
| 255 |
frac = 1024.*1024.*vflt(DISKSPACE) / (wtotal*sizeof(RAYVAL));
| 256 |
else
| 257 |
frac = 1024.*1024.*16384. / (wtotal*sizeof(RAYVAL));
| 258 |
while (k--)
| 259 |
complist[k].nr = frac * complist[k].nr;
| 260 |
listpos = 0; lastin = -1; /* flag initial sort */
| 261 |
| 262 |
| 263 |
| 264 |
mergeclists(cdest, cl1, n1, cl2, n2) /* merge two sorted lists */
| 265 |
PACKHEAD *cdest;
| 266 |
PACKHEAD *cl1, *cl2;
| 267 |
int n1, n2;
| 268 |
| 269 |
int cmp;
| 270 |
| 271 |
while (n1 | n2) {
| 272 |
if (!n1) cmp = 1;
| 273 |
else if (!n2) cmp = -1;
| 274 |
else cmp = beamcmp(cl1, cl2);
| 275 |
if (cmp > 0) {
| 276 |
copystruct(cdest, cl2);
| 277 |
cl2++; n2--;
| 278 |
} else {
| 279 |
copystruct(cdest, cl1);
| 280 |
cl1++; n1--;
| 281 |
| 282 |
cdest++;
| 283 |
| 284 |
| 285 |
| 286 |
| 287 |
sortcomplist() /* fix our list order */
| 288 |
| 289 |
PACKHEAD *list2;
| 290 |
register int i;
| 291 |
| 292 |
if (complen <= 0) /* check to see if there is even a list */
| 293 |
return;
| 294 |
if (lastin < 0 || listpos*4 >= complen*3)
| 295 |
qsort((char *)complist, complen, sizeof(PACKHEAD), beamcmp);
| 296 |
else if (listpos) { /* else sort and merge sublist */
| 297 |
list2 = (PACKHEAD *)malloc(listpos*sizeof(PACKHEAD));
| 298 |
if (list2 == NULL)
| 299 |
error(SYSTEM, "out of memory in sortcomplist");
| 300 |
bcopy((char *)complist,(char *)list2,listpos*sizeof(PACKHEAD));
| 301 |
qsort((char *)list2, listpos, sizeof(PACKHEAD), beamcmp);
| 302 |
mergeclists(complist, list2, listpos,
| 303 |
complist+listpos, complen-listpos);
| 304 |
free((char *)list2);
| 305 |
| 306 |
/* drop satisfied requests */
| 307 |
for (i = complen; i-- && complist[i].nr <= complist[i].nc; )
| 308 |
| 309 |
if (i < 0) {
| 310 |
| 311 |
complist = NULL;
| 312 |
complen = 0;
| 313 |
} else if (i < complen-1) {
| 314 |
list2 = (PACKHEAD *)realloc((char *)complist,
| 315 |
(i+1)*sizeof(PACKHEAD));
| 316 |
if (list2 != NULL) {
| 317 |
complist = list2;
| 318 |
complen = i+1;
| 319 |
| 320 |
| 321 |
listpos = 0; lastin = i;
| 322 |
| 323 |
| 324 |
| 325 |
| 326 |
* The following routine works on the assumption that the bundle weights are
| 327 |
* more or less evenly distributed, such that computing a packet causes
| 328 |
* a given bundle to move way down in the computation order. We keep
| 329 |
* track of where the computed bundle with the highest priority would end
| 330 |
* up, and if we get further in our compute list than this, we resort the
| 331 |
* list and start again from the beginning. Since
| 332 |
* a merge sort is used, the sorting costs are minimal.
| 333 |
| 334 |
next_packet(p) /* prepare packet for computation */
| 335 |
register PACKET *p;
| 336 |
| 337 |
register int i;
| 338 |
| 339 |
if (listpos > lastin) /* time to sort the list */
| 340 |
sortcomplist();
| 341 |
if (complen <= 0)
| 342 |
return(0);
| 343 |
p->hd = complist[listpos].hd;
| 344 |
p->bi = complist[listpos].bi;
| 345 |
p->nc = complist[listpos].nc;
| 346 |
p->nr = complist[listpos].nr - p->nc;
| 347 |
if (p->nr <= 0)
| 348 |
return(0);
| 349 |
if (p->nr > RPACKSIZ)
| 350 |
p->nr = RPACKSIZ;
| 351 |
complist[listpos].nc += p->nr; /* find where this one would go */
| 352 |
while (lastin > listpos &&
| 353 |
beamcmp(complist+lastin, complist+listpos) > 0)
| 354 |
lastin--;
| 355 |
listpos++;
| 356 |
return(1);
| 357 |
