--- ray/src/hd/rholo3.c 1997/11/03 18:33:13 3.2 +++ ray/src/hd/rholo3.c 2004/01/01 11:21:55 3.41 @@ -1,83 +1,202 @@ -/* Copyright (c) 1997 Silicon Graphics, Inc. */ - #ifndef lint -static char SCCSid[] = "$SunId$ SGI"; +static const char RCSid[] = "$Id: rholo3.c,v 3.41 2004/01/01 11:21:55 schorsch Exp $"; #endif - /* * Routines for tracking beam compuatations */ +#include +#include +#include + +#include "view.h" #include "rholo.h" +#ifndef NFRAG2CHUNK +#define NFRAG2CHUNK 4096 /* number of fragments to start chunking */ +#endif +#ifndef abs #define abs(x) ((x) > 0 ? (x) : -(x)) +#endif +#ifndef sgn #define sgn(x) ((x) > 0 ? 1 : (x) < 0 ? -1 : 0) +#endif +#define rchunk(n) (((n)+(RPACKSIZ/2))/RPACKSIZ) -static PACKHEAD *complist; /* list of beams to compute */ -static int complen; /* length of complist */ -static int listpos; /* current list position for next_packet */ -static int lastin = -1; /* last ordered position in list */ +int chunkycmp = 0; /* clump beams together on disk */ +static PACKHEAD *complist=NULL; /* list of beams to compute */ +static int complen=0; /* length of complist */ +static int listpos=0; /* current list position for next_packet */ +static int lastin= -1; /* last ordered position in list */ +static void sortcomplist(void); +static void mergeclists(PACKHEAD *cdest, PACKHEAD *cl1, int n1, PACKHEAD *cl2, int n2); +static void view_list(FILE *fp); +static void ambient_list(void); +static double beamvolume(HOLO *hp, int bi); +static void dispbeam(BEAM *b, HDBEAMI *hb); + + + +static int +beamcmp(b0, b1) /* comparison for compute order */ +register PACKHEAD *b0, *b1; +{ + BEAMI *bip0, *bip1; + register long c; + /* first check desired quantities */ + if (chunkycmp) + c = rchunk(b1->nr)*(rchunk(b0->nc)+1L) - + rchunk(b0->nr)*(rchunk(b1->nc)+1L); + else + c = b1->nr*(b0->nc+1L) - b0->nr*(b1->nc+1L); + if (c > 0) return(1); + if (c < 0) return(-1); + /* only one file, so skip the following: */ +#if 0 + /* next, check file descriptors */ + c = hdlist[b0->hd]->fd - hdlist[b1->hd]->fd; + if (c) return(c); +#endif + /* finally, check file positions */ + bip0 = &hdlist[b0->hd]->bi[b0->bi]; + bip1 = &hdlist[b1->hd]->bi[b1->bi]; + /* put diskless beams last */ + if (!bip0->nrd) + return(bip1->nrd > 0); + if (!bip1->nrd) + return(-1); + c = bip0->fo - bip1->fo; + return(c < 0 ? -1 : c > 0); +} + + int -beamcmp(b0, b1) /* comparison for descending compute order */ +beamidcmp(b0, b1) /* comparison for beam searching */ register PACKHEAD *b0, *b1; { - return( b1->nr*(bnrays(hdlist[b0->hd],b0->bi)+1) - - b0->nr*(bnrays(hdlist[b1->hd],b1->bi)+1) ); + register int c = b0->hd - b1->hd; + + if (c) return(c); + return(b0->bi - b1->bi); } -bundle_set(op, clist, nents) /* bundle set operation */ -int op; -PACKHEAD *clist; -int nents; +static void +dispbeam( /* display a holodeck beam */ + register BEAM *b, + register HDBEAMI *hb +) { - BEAM *b; - PACKHEAD *p; - register int i, n; + static int n = 0; + static PACKHEAD *p = NULL; + if (b == NULL) + return; + if (b->nrm > n) { /* (re)allocate packet holder */ + n = b->nrm; + if (p == NULL) p = (PACKHEAD *)malloc(packsiz(n)); + else p = (PACKHEAD *)realloc((void *)p, packsiz(n)); + CHECK(p==NULL, SYSTEM, "out of memory in dispbeam"); + } + /* assign packet fields */ + memcpy((void *)packra(p), (void *)hdbray(b), b->nrm*sizeof(RAYVAL)); + p->nr = p->nc = b->nrm; + for (p->hd = 0; hdlist[p->hd] != hb->h; p->hd++) + if (hdlist[p->hd] == NULL) + error(CONSISTENCY, "unregistered holodeck in dispbeam"); + p->bi = hb->b; + disp_packet(p); /* display it */ + if (n >= 1024) { /* free ridiculous packets */ + free((void *)p); + p = NULL; n = 0; + } +} + + +extern void +bundle_set( /* bundle set operation */ + int op, + PACKHEAD *clist, + int nents +) +{ + int oldnr, n; + HDBEAMI *hbarr; + register PACKHEAD *csm; + register int i; + /* search for common members */ + for (csm = clist+nents; csm-- > clist; ) + csm->nc = -1; + qsort((void *)clist, nents, sizeof(PACKHEAD), beamidcmp); + for (i = 0; i < complen; i++) { + csm = (PACKHEAD *)bsearch((void *)(complist+i), (void *)clist, + nents, sizeof(PACKHEAD), beamidcmp); + if (csm == NULL) + continue; + oldnr = complist[i].nr; + csm->nc = complist[i].nc; + switch (op) { + case BS_ADD: /* add to count */ + complist[i].nr += csm->nr; + csm->nr = 0; + break; + case BS_MAX: /* maximum of counts */ + if (csm->nr > complist[i].nr) + complist[i].nr = csm->nr; + csm->nr = 0; + break; + case BS_ADJ: /* reset count */ + complist[i].nr = csm->nr; + csm->nr = 0; + break; + case BS_DEL: /* delete count */ + if (csm->nr == 0 || csm->nr >= complist[i].nr) + complist[i].nr = 0; + else + complist[i].nr -= csm->nr; + break; + } + if (complist[i].nr != oldnr) + lastin = -1; /* flag sort */ + } + /* record computed rays for uncommon beams */ + for (csm = clist+nents; csm-- > clist; ) + if (csm->nc < 0) + csm->nc = bnrays(hdlist[csm->hd], csm->bi); + /* complete list operations */ switch (op) { case BS_NEW: /* new computation set */ - if (complen) - free((char *)complist); - if (nents <= 0) { - complist = NULL; - listpos = complen = 0; - lastin = -1; + listpos = 0; lastin = -1; + if (complen) /* free old list */ + free((void *)complist); + complist = NULL; + if (!(complen = nents)) return; - } complist = (PACKHEAD *)malloc(nents*sizeof(PACKHEAD)); if (complist == NULL) goto memerr; - bcopy((char *)clist, (char *)complist, nents*sizeof(PACKHEAD)); - complen = nents; - listpos = 0; - lastin = -1; /* flag for initial sort */ + memcpy((void *)complist, (void *)clist, nents*sizeof(PACKHEAD)); break; case BS_ADD: /* add to computation set */ + case BS_MAX: /* maximum of quantities */ + case BS_ADJ: /* adjust set quantities */ if (nents <= 0) return; - /* merge any common members */ - for (i = 0; i < complen; i++) - for (n = 0; n < nents; n++) - if (clist[n].bi == complist[i].bi && - clist[n].hd == complist[i].hd) { - complist[i].nr += clist[n].nr; - clist[n].nr = 0; - lastin = -1; /* flag full sort */ - break; - } - /* sort updated list */ - sortcomplist(); - /* sort new entries */ - qsort((char *)clist, nents, sizeof(PACKHEAD), beamcmp); + sortcomplist(); /* sort updated list & new entries */ + qsort((void *)clist, nents, sizeof(PACKHEAD), beamcmp); /* what can't we satisfy? */ - for (n = 0; n < nents && clist[n].nr > - bnrays(hdlist[clist[n].hd],clist[n].bi); n++) + for (i = nents, csm = clist; i-- && csm->nr > csm->nc; csm++) ; + n = csm - clist; + if (op != BS_ADD) { /* don't regenerate adjusted beams */ + for (++i; i-- && csm->nr > 0; csm++) + ; + nents = csm - clist; + } if (n) { /* allocate space for merged list */ PACKHEAD *newlist; newlist = (PACKHEAD *)malloc( @@ -87,7 +206,7 @@ int nents; /* merge lists */ mergeclists(newlist, clist, n, complist, complen); if (complen) - free((char *)complist); + free((void *)complist); complist = newlist; complen += n; } @@ -95,163 +214,172 @@ int nents; lastin = complen-1; /* list is now sorted */ break; case BS_DEL: /* delete from computation set */ - if (nents <= 0) - return; - /* find each member */ - for (i = 0; i < complen; i++) - for (n = 0; n < nents; n++) - if (clist[n].bi == complist[i].bi && - clist[n].hd == complist[i].hd) { - if (clist[n].nr == 0 || - clist[n].nr >= complist[i].nr) - complist[i].nr = 0; - else - complist[i].nr -= clist[n].nr; - lastin = -1; /* flag full sort */ - break; - } - /* sort updated list */ - sortcomplist(); - return; /* no display */ + return; /* already done */ default: error(CONSISTENCY, "bundle_set called with unknown operation"); } - n = 0; /* allocate packet holder */ - for (i = 0; i < nents; i++) - if (clist[i].nr > n) - n = clist[i].nr; - p = (PACKHEAD *)malloc(sizeof(PACKHEAD) + n*sizeof(RAYVAL)); - /* now, display what we can */ - for (i = 0; i < nents; i++) - if (clist[i].nr > 0 && - (b = hdgetbeam(hdlist[clist[i].hd], clist[i].bi)) != NULL) { - bcopy((char *)hdbray(b), (char *)(p+1), - (p->nr=b->nrm)*sizeof(RAYVAL)); - disp_packet((PACKET *)p); - } - free((char *)p); /* clean up */ + if (outdev == NULL || !nents) /* nothing to display? */ + return; + /* load and display beams we have */ + hbarr = (HDBEAMI *)malloc(nents*sizeof(HDBEAMI)); + for (i = nents; i--; ) { + hbarr[i].h = hdlist[clist[i].hd]; + hbarr[i].b = clist[i].bi; + } + hdloadbeams(hbarr, nents, dispbeam); + free((void *)hbarr); + if (hdfragflags&FF_READ) { + listpos = 0; + lastin = -1; /* need to re-sort list */ + } return; memerr: error(SYSTEM, "out of memory in bundle_set"); } -int -weightf(hp, x0, x1, x2) /* voxel weighting function */ -register HOLO *hp; -register int x0, x1, x2; +static double +beamvolume( /* compute approximate volume of a beam */ + HOLO *hp, + int bi +) { - switch (vlet(OCCUPANCY)) { - case 'U': /* uniform weighting */ - return(1); - case 'C': /* center weighting (crude) */ - x0 += x0 - hp->grid[0] + 1; - x0 = abs(x0)*hp->grid[1]*hp->grid[2]; - x1 += x1 - hp->grid[1] + 1; - x1 = abs(x1)*hp->grid[0]*hp->grid[2]; - x2 += x2 - hp->grid[2] + 1; - x2 = abs(x2)*hp->grid[0]*hp->grid[1]; - return(hp->grid[0]*hp->grid[1]*hp->grid[2] - - (x0+x1+x2)/3); - default: - badvalue(OCCUPANCY); + GCOORD gc[2]; + FVECT cp[4], edgeA, edgeB, cent[2]; + FVECT crossp[2], diffv; + double vol[2]; + register int i; + /* get grid coordinates */ + if (!hdbcoord(gc, hp, bi)) + error(CONSISTENCY, "bad beam index in beamvolume"); + for (i = 0; i < 2; i++) { /* compute cell area vectors */ + hdcell(cp, hp, gc+i); + VSUM(edgeA, cp[1], cp[0], -1.0); + VSUM(edgeB, cp[3], cp[1], -1.0); + fcross(crossp[i], edgeA, edgeB); + /* compute center */ + cent[i][0] = 0.5*(cp[0][0] + cp[2][0]); + cent[i][1] = 0.5*(cp[0][1] + cp[2][1]); + cent[i][2] = 0.5*(cp[0][2] + cp[2][2]); } -} - - -/* The following is by Daniel Cohen, taken from Graphics Gems IV, p. 368 */ -long -lineweight(hp, x, y, z, dx, dy, dz) /* compute weights along a line */ -HOLO *hp; -int x, y, z, dx, dy, dz; -{ - long wres = 0; - int n, sx, sy, sz, exy, exz, ezy, ax, ay, az, bx, by, bz; - - sx = sgn(dx); sy = sgn(dy); sz = sgn(dz); - ax = abs(dx); ay = abs(dy); az = abs(dz); - bx = 2*ax; by = 2*ay; bz = 2*az; - exy = ay-ax; exz = az-ax; ezy = ay-az; - n = ax+ay+az + 1; /* added increment to visit last */ - while (n--) { - wres += weightf(hp, x, y, z); - if (exy < 0) { - if (exz < 0) { - x += sx; - exy += by; exz += bz; - } else { - z += sz; - exz -= bx; ezy += by; - } - } else { - if (ezy < 0) { - z += sz; - exz -= bx; ezy += by; - } else { - y += sy; - exy -= bx; ezy -= bz; - } - } + /* compute difference vector */ + VSUM(diffv, cent[1], cent[0], -1.0); + for (i = 0; i < 2; i++) { /* compute volume contributions */ + vol[i] = 0.5*DOT(crossp[i], diffv); + if (vol[i] < 0.) vol[i] = -vol[i]; } - return(wres); + return(vol[0] + vol[1]); /* return total volume */ } -init_global() /* initialize global ray computation */ +static void +ambient_list(void) /* compute ambient beam list */ { - long wtotal = 0; - int i, j; - int lseg[2][3]; + int32 wtotal, minrt; double frac; - register int k; - /* allocate beam list */ + int i; + register int j, k; + complen = 0; for (j = 0; hdlist[j] != NULL; j++) complen += nbeams(hdlist[j]); complist = (PACKHEAD *)malloc(complen*sizeof(PACKHEAD)); - if (complist == NULL) - error(SYSTEM, "out of memory in init_global"); + CHECK(complist==NULL, SYSTEM, "out of memory in ambient_list"); /* compute beam weights */ - k = 0; - for (j = 0; hdlist[j] != NULL; j++) + k = 0; wtotal = 0; + for (j = 0; hdlist[j] != NULL; j++) { + frac = 512. * VLEN(hdlist[j]->wg[0]) * + VLEN(hdlist[j]->wg[1]) * + VLEN(hdlist[j]->wg[2]); for (i = nbeams(hdlist[j]); i > 0; i--) { - hdlseg(lseg, hdlist[j], i); complist[k].hd = j; complist[k].bi = i; - complist[k].nr = lineweight( hdlist[j], - lseg[0][0], lseg[0][1], lseg[0][2], - lseg[1][0] - lseg[0][0], - lseg[1][1] - lseg[0][1], - lseg[1][2] - lseg[0][2] ); + complist[k].nr = frac*beamvolume(hdlist[j], i) + 0.5; + complist[k].nc = bnrays(hdlist[j], i); wtotal += complist[k++].nr; } - /* adjust weights */ - if (vdef(DISKSPACE)) { + } + /* adjust sample weights */ + if (vdef(DISKSPACE)) frac = 1024.*1024.*vflt(DISKSPACE) / (wtotal*sizeof(RAYVAL)); - if (frac < 0.95 | frac > 1.05) - while (k--) - complist[k].nr = frac * complist[k].nr; + else + frac = 1024.*1024.*2048. / (wtotal*sizeof(RAYVAL)); + minrt = .02*frac*wtotal/complen + .5; /* heuristic mimimum */ + if (minrt > RPACKSIZ) + minrt = RPACKSIZ; + for (k = complen; k--; ) + if ((complist[k].nr = frac*complist[k].nr + 0.5) < minrt) + complist[k].nr = minrt; + listpos = 0; lastin = -1; /* flag initial sort */ +} + + +static void +view_list( /* assign beam priority from view list */ + FILE *fp +) +{ + double pa = 1.; + VIEW curview; + int xr, yr; + char *err; + BEAMLIST blist; + + curview = stdview; + while (nextview(&curview, fp) != EOF) { + if ((err = setview(&curview)) != NULL) { + error(WARNING, err); + continue; + } + xr = yr = 1024; + normaspect(viewaspect(&curview), &pa, &xr, &yr); + viewbeams(&curview, xr, yr, &blist); + bundle_set(BS_MAX, blist.bl, blist.nb); + free((void *)blist.bl); } - listpos = 0; lastin = -1; } -mergeclists(cdest, cl1, n1, cl2, n2) /* merge two sorted lists */ -PACKHEAD *cdest; -PACKHEAD *cl1, *cl2; -int n1, n2; +extern void +init_global(void) /* initialize global ray computation */ { - int cmp; + /* free old list and empty queue */ + if (complen > 0) { + free((void *)complist); + done_packets(flush_queue()); + } + /* reseed random number generator */ + srandom(time(NULL)); + /* allocate beam list */ + if (readinp) + view_list(stdin); + else + ambient_list(); + /* no view vicinity */ + myeye.rng = 0; +} + +static void +mergeclists( /* merge two sorted lists */ + register PACKHEAD *cdest, + register PACKHEAD *cl1, + int n1, + register PACKHEAD *cl2, + int n2 +) +{ + register int cmp; + while (n1 | n2) { if (!n1) cmp = 1; else if (!n2) cmp = -1; else cmp = beamcmp(cl1, cl2); if (cmp > 0) { - copystruct(cdest, cl2); + *cdest = *cl2; cl2++; n2--; } else { - copystruct(cdest, cl1); + *cdest = *cl1; cl1++; n1--; } cdest++; @@ -259,44 +387,51 @@ int n1, n2; } -sortcomplist() /* fix our list order */ +static void +sortcomplist(void) /* fix our list order */ { PACKHEAD *list2; + int listlen; register int i; - /* empty queue */ - done_packets(flush_queue()); - if (complen <= 0) /* check to see if there even is a list */ + if (complen <= 0) /* check to see if there is even a list */ return; - if (lastin < 0) /* flag to sort entire list */ - qsort((char *)complist, complen, sizeof(PACKHEAD), beamcmp); + if (!chunkycmp) /* check to see if fragment list is full */ + if (!hdfragOK(hdlist[0]->fd, &listlen, NULL) +#if NFRAG2CHUNK + || listlen >= NFRAG2CHUNK +#endif + ) { + chunkycmp++; /* use "chunky" comparison */ + lastin = -1; /* need to re-sort list */ +#ifdef DEBUG + error(WARNING, "using chunky comparison mode"); +#endif + } + if (lastin < 0 || listpos*4 >= complen*3) + qsort((void *)complist, complen, sizeof(PACKHEAD), beamcmp); else if (listpos) { /* else sort and merge sublist */ list2 = (PACKHEAD *)malloc(listpos*sizeof(PACKHEAD)); - if (list2 == NULL) - error(SYSTEM, "out of memory in sortcomplist"); - bcopy((char *)complist,(char *)list2,listpos*sizeof(PACKHEAD)); - qsort((char *)list2, listpos, sizeof(PACKHEAD), beamcmp); + CHECK(list2==NULL, SYSTEM, "out of memory in sortcomplist"); + memcpy((void *)list2,(void *)complist,listpos*sizeof(PACKHEAD)); + qsort((void *)list2, listpos, sizeof(PACKHEAD), beamcmp); mergeclists(complist, list2, listpos, complist+listpos, complen-listpos); - free((char *)list2); + free((void *)list2); } - /* check for all finished */ - if (complist[0].nr <= bnrays(hdlist[complist[0].hd],complist[0].bi)) { - free((char *)complist); - complist = NULL; - complen = 0; - } /* drop satisfied requests */ - for (i = complen; i-- && complist[i].nr <= - bnrays(hdlist[complist[i].hd],complist[i].bi); ) + for (i = complen; i-- && complist[i].nr <= complist[i].nc; ) ; - if (i < complen-1) { - list2 = (PACKHEAD *)realloc((char *)complist, + if (i < 0) { + free((void *)complist); + complist = NULL; + complen = 0; + } else if (i < complen-1) { + list2 = (PACKHEAD *)realloc((void *)complist, (i+1)*sizeof(PACKHEAD)); - if (list2 != NULL) { + if (list2 != NULL) complist = list2; - complen = i+1; - } + complen = i+1; } listpos = 0; lastin = i; } @@ -307,36 +442,35 @@ sortcomplist() /* fix our list order */ * more or less evenly distributed, such that computing a packet causes * a given bundle to move way down in the computation order. We keep * track of where the computed bundle with the highest priority would end - * up, and if we get further in our compute list than this, we resort the - * list and start again from the beginning. We have to flush the queue - * each time we sort, to ensure that we are not disturbing the order. - * If our major assumption is violated, and we have a very steep - * descent in our weights, then we will end up resorting much more often - * than necessary, resulting in frequent flushing of the queue. Since - * a merge sort is used, the sorting costs will be minimal. + * up, and if we get further in our compute list than this, we re-sort the + * list and start again from the beginning. Since + * a merge sort is used, the sorting costs are minimal. */ -next_packet(p) /* prepare packet for computation */ -register PACKET *p; +extern int +next_packet( /* prepare packet for computation */ + register PACKET *p, + int n +) { - int ncomp; - register int i; - - if (complen <= 0) - return(0); if (listpos > lastin) /* time to sort the list */ sortcomplist(); + if (complen <= 0) + return(0); p->hd = complist[listpos].hd; p->bi = complist[listpos].bi; - ncomp = bnrays(hdlist[p->hd],p->bi); - p->nr = complist[listpos].nr - ncomp; + p->nc = complist[listpos].nc; + p->nr = complist[listpos].nr - p->nc; if (p->nr <= 0) return(0); - if (p->nr > RPACKSIZ) - p->nr = RPACKSIZ; - ncomp += p->nr; /* find where this one would go */ - while (lastin > listpos && complist[listpos].nr * - (bnrays(hdlist[complist[lastin].hd],complist[lastin].bi)+1) - > complist[lastin].nr * (ncomp+1)) + DCHECK(n < 1 | n > RPACKSIZ, + CONSISTENCY, "next_packet called with bad n value"); + if (p->nr > n) + p->nr = n; + complist[listpos].nc += p->nr; /* find where this one would go */ + if (hdgetbeam(hdlist[p->hd], p->bi) != NULL) + hdfreefrag(hdlist[p->hd], p->bi); + while (lastin > listpos && + beamcmp(complist+lastin, complist+listpos) > 0) lastin--; listpos++; return(1);
