root/Development/ray/src/hd/rholo3.c
Revision 3.43 - (view) (download) (annotate) - [select for diffs]
Thu Sep 30 14:10:19 2010 UTC (15 years, 3 months ago) by greg
Changes since 3.42: +7 -2 lines
Diff to previous 3.42 , to selected 3.40
Increased maximum "ambient" holodeck size from 2 GBytes to 10 GBytes
Revision 3.42 - (view) (download) (annotate) - [select for diffs]
Tue Jun 8 19:48:30 2004 UTC (21 years, 7 months ago) by greg
Changes since 3.41: +1 -6 lines
Diff to previous 3.41 , to selected 3.40
Thu Jan 1 11:21:55 2004 UTC (22 years ago) by schorsch
Changes since 3.40: +53 -33 lines
Diff to previous 3.40
Ansification and prototypes.
Revision 3.40 - (view) (download) (annotate) - [selected]
Mon Jul 21 22:30:18 2003 UTC (22 years, 5 months ago) by schorsch
Changes since 3.39: +4 -4 lines
Diff to previous 3.39
Mon Jul 7 17:21:51 2003 UTC (22 years, 6 months ago) by greg
Changes since 3.38: +2 -2 lines
Diff to previous 3.38 , to selected 3.40
Mon Jun 30 14:59:12 2003 UTC (22 years, 6 months ago) by schorsch
Changes since 3.37: +6 -4 lines
Diff to previous 3.37 , to selected 3.40
Fri Jun 20 00:25:49 2003 UTC (22 years, 6 months ago) by greg
Diff to previous 3.36 , to selected 3.40
Tue May 13 17:58:33 2003 UTC (22 years, 8 months ago) by greg
Changes since 3.35: +8 -8 lines
Diff to previous 3.35 , to selected 3.40
Wed Apr 23 00:52:33 2003 UTC (22 years, 8 months ago) by greg
Diff to previous 3.34 , to selected 3.40
Sat Feb 22 02:07:25 2003 UTC (22 years, 10 months ago) by greg
Changes since 3.33: +9 -12 lines
Diff to previous 3.33 , to selected 3.40
Mon Mar 8 17:31:49 1999 UTC (26 years, 10 months ago) by gwlarson
Changes since 3.32: +1 -2 lines
Diff to previous 3.32 , to selected 3.40
Thu Mar 4 15:44:10 1999 UTC (26 years, 10 months ago) by gwlarson
Changes since 3.31: +10 -8 lines
Diff to previous 3.31 , to selected 3.40
put in mimimum ray count for ambient_list()
Thu Mar 4 10:29:23 1999 UTC (26 years, 10 months ago) by gwlarson
Changes since 3.30: +62 -22 lines
Diff to previous 3.30 , to selected 3.40
Tue Feb 2 16:13:24 1999 UTC (26 years, 11 months ago) by gwlarson
Changes since 3.29: +6 -10 lines
Diff to previous 3.29 , to selected 3.40
Sat Jan 9 19:48:28 1999 UTC (27 years ago) by gwlarson
Changes since 3.28: +4 -0 lines
Diff to previous 3.28 , to selected 3.40
added packet deallocation to dispbeam()
Sat Jan 9 09:17:10 1999 UTC (27 years ago) by gwlarson
Changes since 3.27: +17 -8 lines
Diff to previous 3.27 , to selected 3.40
added random number seed to init_global()
Thu Jan 7 22:04:49 1999 UTC (27 years ago) by gwlarson
Changes since 3.26: +57 -3 lines
Diff to previous 3.26 , to selected 3.40
Tue Dec 15 09:28:18 1998 UTC (27 years ago) by gwlarson
Changes since 3.25: +2 -3 lines
Diff to previous 3.25 , to selected 3.40
minor change after realloc() call in sortcomplist()
Thu Dec 10 10:47:50 1998 UTC (27 years, 1 month ago) by gwlarson
Changes since 3.24: +3 -1 lines
Diff to previous 3.24 , to selected 3.40
set viewpoint range to zero in init_global()
Fri Nov 13 15:57:13 1998 UTC (27 years, 1 month ago) by gwlarson
Changes since 3.23: +4 -4 lines
Diff to previous 3.23 , to selected 3.40
minor optimizations in bundle_set() and init_global()
Wed Aug 12 17:56:06 1998 UTC (27 years, 5 months ago) by gwlarson
Changes since 3.22: +68 -47 lines
Diff to previous 3.22 , to selected 3.40
changed parameters to function passed to hdloadbeams()
improved speed of common member match in bundle_set()
Wed Jul 8 17:59:58 1998 UTC (27 years, 6 months ago) by gwlarson
Changes since 3.21: +15 -18 lines
Diff to previous 3.21 , to selected 3.40
fixed bundle_set() with BS_ADJ to send satisfiable requests
Mon Feb 2 11:42:10 1998 UTC (27 years, 11 months ago) by gwlarson
Diff to previous 3.20 , to selected 3.40
perform sorting in init_global() rather than delaying for later
Thu Jan 22 11:25:51 1998 UTC (27 years, 11 months ago) by gregl
Changes since 3.19: +40 -55 lines
Diff to previous 3.19 , to selected 3.40
made it so ^L does not require flushing of queue
Tue Jan 6 15:08:51 1998 UTC (28 years ago) by gregl
Changes since 3.18: +3 -3 lines
Diff to previous 3.18 , to selected 3.40
Mon Jan 5 16:46:34 1998 UTC (28 years ago) by gregl
Changes since 3.17: +6 -3 lines
Diff to previous 3.17 , to selected 3.40
fixed dire bug in init_global() that caused it to recompute rays
Wed Dec 31 20:24:11 1997 UTC (28 years ago) by gregl
Changes since 3.16: +8 -3 lines
Diff to previous 3.16 , to selected 3.40
modify ray packet size based on computation time
Wed Dec 24 12:22:58 1997 UTC (28 years ago) by gregl
Changes since 3.15: +3 -3 lines
Diff to previous 3.15 , to selected 3.40
changed pointers to register pointers in mergeclists()
Fri Dec 19 09:55:36 1997 UTC (28 years ago) by gregl
Changes since 3.14: +2 -5 lines
Diff to previous 3.14 , to selected 3.40
simplified beam volume calculation slightly and fixed bug in init_global()
Thu Dec 18 14:46:00 1997 UTC (28 years ago) by gregl
Changes since 3.13: +40 -25 lines
Diff to previous 3.13 , to selected 3.40
Mon Dec 15 20:44:28 1997 UTC (28 years ago) by gregl
Changes since 3.12: +38 -65 lines
Diff to previous 3.12 , to selected 3.40
eliminated OCCUPANCY variable and improved beam volume calculation
Mon Dec 1 16:35:02 1997 UTC (28 years, 1 month ago) by gregl
Changes since 3.11: +17 -15 lines
Diff to previous 3.11 , to selected 3.40
minor bug fixes and enhancements
Wed Nov 26 21:34:28 1997 UTC (28 years, 1 month ago) by gregl
Changes since 3.10: +32 -27 lines
Diff to previous 3.10 , to selected 3.40
Mon Nov 24 15:18:30 1997 UTC (28 years, 1 month ago) by gregl
Changes since 3.9: +2 -10 lines
Diff to previous 3.9 , to selected 3.40
fixed bug in next_packet() which caused core dumps with empty list
Fri Nov 21 17:47:56 1997 UTC (28 years, 1 month ago) by gregl
Changes since 3.8: +1 -4 lines
Diff to previous 3.8 , to selected 3.40
fixed problem with allocating huge array for unreasonable request
Thu Nov 20 11:39:57 1997 UTC (28 years, 1 month ago) by gregl
Changes since 3.7: +2 -0 lines
Diff to previous 3.7 , to selected 3.40
added check for no display process
Wed Nov 19 17:05:16 1997 UTC (28 years, 1 month ago) by gregl
Changes since 3.6: +9 -1 lines
Diff to previous 3.6 , to selected 3.40
fixed bug in too small ray packet array
Mon Nov 10 18:06:18 1997 UTC (28 years, 2 months ago) by gregl
Diff to previous 3.5 , to selected 3.40
took out VIEW type and changed packray() macro to packra()
Thu Nov 6 16:11:49 1997 UTC (28 years, 2 months ago) by gregl
Changes since 3.4: +3 -3 lines
Diff to previous 3.4 , to selected 3.40
changed disp_packet to take PACKHEAD* r.t. PACKET*
Tue Nov 4 11:52:21 1997 UTC (28 years, 2 months ago) by gregl
Changes since 3.3: +10 -6 lines
Diff to previous 3.3 , to selected 3.40
added check for null list in sortcomplist()
Tue Nov 4 09:58:24 1997 UTC (28 years, 2 months ago) by gregl
Changes since 3.2: +10 -6 lines
Diff to previous 3.2 , to selected 3.40
minor bug fixes
Mon Nov 3 18:33:13 1997 UTC (28 years, 2 months ago) by gregl
Changes since 3.1: +140 -12 lines
Diff to previous 3.1 , to selected 3.40
Fri Oct 31 10:23:29 1997 UTC (28 years, 2 months ago) by gregl
Diff to selected 3.40
